    3. Einsteigerfragen
    4. Installation
    5. Docker Installation lädt admin Adapter nicht
    • Glasfaser
      Glasfaser @ferrog last edited by Glasfaser
      @ferrog sagte in Docker Installation lädt admin Adapter nicht:
      Liegt das vielleicht an der Bereitstellung des Ports durch DSM „Webstation“?
      Welcher Port hat er denn ,
      dann würdest du aber nicht ioBroker mit 8081 erreichen !
      Der Loop ist ein anderer ( Fehler ) . kann Ihn aber nicht erkennen .
      Zeige mal die Ausgabe von
      iob logs --watch
      wenn du im Loop bist
        ferrog last edited by ferrog
        Logs —watch von latest-v8:
        2023-05-13 18:49:56.226  - info: host.buanet-iobroker3 iobroker.js-controller version 4.0.24 js-controller starting
        2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 hostname: buanet-iobroker3, node: v18.16.0
        2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 ip addresses: 192.168.178.3 fd9b:f2b9:802:4f06:9209:d0ff:fe32:33f3 2003:cd:f47:c000:9209:d0ff:fe32:33f3 fe80::9209:d0ff:fe32:33f3 172.17.0.1 fe80::42:caff:fe53:7492 fe80::5ca4:c5ff:fec1:c9b fe80::6054:cbff:fe48:42d2 fe80::8c55:c1ff:fee3:f31b fe80::f4c1:fbff:fe20:3a8f fe80::c866:afff:fe37:903a
        2023-05-13 18:49:56.474  - info: host.buanet-iobroker3 connected to Objects and States
        2023-05-13 18:49:56.481  - info: host.buanet-iobroker3 Node.js version has changed from unknown to 18.16.0
        2023-05-13 18:49:56.501  - info: host.buanet-iobroker3 added notifications configuration of host
        2023-05-13 18:49:56.658  - info: host.buanet-iobroker3 3 instances found
        2023-05-13 18:49:56.661  - info: host.buanet-iobroker3 starting 3 instances
        2023-05-13 18:49:56.680  - info: host.buanet-iobroker3 instance system.adapter.admin.0 started with pid 1761
        2023-05-13 18:49:57.314  - info: host.buanet-iobroker3 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
        2023-05-13 18:49:58.050  - info: admin.0 (1761) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
        2023-05-13 18:49:58.067  - info: admin.0 (1761) requesting all states
        2023-05-13 18:49:58.068  - info: admin.0 (1761) requesting all objects
        2023-05-13 18:49:58.127  - info: admin.0 (1761) received all objects
        2023-05-13 18:49:58.151  - info: admin.0 (1761) Request actual repository...
        2023-05-13 18:49:58.160  - info: host.buanet-iobroker3 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2023-05-13 18:49:58.300  - warn: admin.0 (1761) Repository cannot be read: Active repo - stable
        2023-05-13 18:49:58.301  - warn: admin.0 (1761) Active repository "stable" cannot be read
        2023-05-13 18:49:58.763  - error: admin.0 (1761) port 8081 already in use
        2023-05-13 18:49:58.764  - info: admin.0 (1761) Terminated (ADAPTER_REQUESTED_TERMINATION): port 8081 already in use
        2023-05-13 18:49:59.277  - info: admin.0 (1761) terminating http server on port 8081
        2023-05-13 18:49:59.289  - error: host.buanet-iobroker3 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2023-05-13 18:49:59.290  - info: host.buanet-iobroker3 Do not restart adapter system.adapter.admin.0 because desired by instance
        2023-05-13 18:50:00.676  - info: host.buanet-iobroker3 instance system.adapter.discovery.0 started with pid 1785
        2023-05-13 18:50:01.342  - info: discovery.0 (1785) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
        2023-05-13 18:50:04.690  - info: host.buanet-iobroker3 instance system.adapter.backitup.0 started with pid 1804
        2023-05-13 18:50:05.314  - info: backitup.0 (1804) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
        2023-05-13 18:50:05.446  - info: backitup.0 (1804) [iobroker] backup will be activated at 02:40 every 1 day(s)
        Glasfaser 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Logs
          2023-05-13 17:47:52.996
          Bitte aktuell zeigen !!
            Ahh, sorry falsche Datei, ist korrigiert. Da gibts auch errors…
            • Glasfaser
              Da läuft was doppelt , deshalb startet jetzt in diesem Log der ioBroker nicht
              • Glasfaser
                Glasfaser @Glasfaser last edited by
                @ferrog
                @glasfaser sagte in Docker Installation lädt admin Adapter nicht:
                Kann du nicht meine Fragen beantworten !?
                  Homoran Global Moderator Administrators @Glasfaser last edited by
                  @ferrog
                  bitte lesen und befolgen!
                    Ich habe das nicht als Frage verstanden.
                    Natürlich reicht die Webstation den Port 8081 an den Docker Container weiter.
                    • Glasfaser
                      Lösche alle diese Einträge !
                      Hier wird nur der Port vorgegeben :
                      siehe Beispiel Containereinstellung
                      und das ausschalten / haken bei dir raus
                        WOW, vielen Dank! Daran hats gelegen.
                        Und großen Respekt an die Schnelligkeit eurer Unterstützung!
                        Zum Hintergrund: Belegt Webstation dann in dem Container den besagten Port?
                        • Glasfaser
                          ... aber mühselig erfragt 😉
                          Jipp , deshalb meine Frage :
                          @ferrog
                          • Glasfaser
                            Dann setze den Thread auf [gelöst]
                            1285
