    3. Einsteigerfragen
    4. Installation
    5. Docker Installation lädt admin Adapter nicht
      ferrog last edited by ferrog
      Logs —watch von latest-v8:
      2023-05-13 18:49:56.226  - info: host.buanet-iobroker3 iobroker.js-controller version 4.0.24 js-controller starting
      2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 hostname: buanet-iobroker3, node: v18.16.0
      2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 ip addresses: 192.168.178.3 fd9b:f2b9:802:4f06:9209:d0ff:fe32:33f3 2003:cd:f47:c000:9209:d0ff:fe32:33f3 fe80::9209:d0ff:fe32:33f3 172.17.0.1 fe80::42:caff:fe53:7492 fe80::5ca4:c5ff:fec1:c9b fe80::6054:cbff:fe48:42d2 fe80::8c55:c1ff:fee3:f31b fe80::f4c1:fbff:fe20:3a8f fe80::c866:afff:fe37:903a
      2023-05-13 18:49:56.474  - info: host.buanet-iobroker3 connected to Objects and States
      2023-05-13 18:49:56.481  - info: host.buanet-iobroker3 Node.js version has changed from unknown to 18.16.0
      2023-05-13 18:49:56.501  - info: host.buanet-iobroker3 added notifications configuration of host
      2023-05-13 18:49:56.658  - info: host.buanet-iobroker3 3 instances found
      2023-05-13 18:49:56.661  - info: host.buanet-iobroker3 starting 3 instances
      2023-05-13 18:49:56.680  - info: host.buanet-iobroker3 instance system.adapter.admin.0 started with pid 1761
      2023-05-13 18:49:57.314  - info: host.buanet-iobroker3 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2023-05-13 18:49:58.050  - info: admin.0 (1761) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
      2023-05-13 18:49:58.067  - info: admin.0 (1761) requesting all states
      2023-05-13 18:49:58.068  - info: admin.0 (1761) requesting all objects
      2023-05-13 18:49:58.127  - info: admin.0 (1761) received all objects
      2023-05-13 18:49:58.151  - info: admin.0 (1761) Request actual repository...
      2023-05-13 18:49:58.160  - info: host.buanet-iobroker3 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-05-13 18:49:58.300  - warn: admin.0 (1761) Repository cannot be read: Active repo - stable
      2023-05-13 18:49:58.301  - warn: admin.0 (1761) Active repository "stable" cannot be read
      2023-05-13 18:49:58.763  - error: admin.0 (1761) port 8081 already in use
      2023-05-13 18:49:58.764  - info: admin.0 (1761) Terminated (ADAPTER_REQUESTED_TERMINATION): port 8081 already in use
      2023-05-13 18:49:59.277  - info: admin.0 (1761) terminating http server on port 8081
      2023-05-13 18:49:59.289  - error: host.buanet-iobroker3 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2023-05-13 18:49:59.290  - info: host.buanet-iobroker3 Do not restart adapter system.adapter.admin.0 because desired by instance
      2023-05-13 18:50:00.676  - info: host.buanet-iobroker3 instance system.adapter.discovery.0 started with pid 1785
      2023-05-13 18:50:01.342  - info: discovery.0 (1785) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
      2023-05-13 18:50:04.690  - info: host.buanet-iobroker3 instance system.adapter.backitup.0 started with pid 1804
      2023-05-13 18:50:05.314  - info: backitup.0 (1804) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
      2023-05-13 18:50:05.446  - info: backitup.0 (1804) [iobroker] backup will be activated at 02:40 every 1 day(s)
      Glasfaser 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @ferrog last edited by Glasfaser
        @ferrog sagte in Docker Installation lädt admin Adapter nicht:
        Logs
        2023-05-13 17:47:52.996
        Bitte aktuell zeigen !!
          Ahh, sorry falsche Datei, ist korrigiert. Da gibts auch errors…
          • Glasfaser
            Da läuft was doppelt , deshalb startet jetzt in diesem Log der ioBroker nicht
            • Glasfaser
              Glasfaser @Glasfaser last edited by
              @ferrog
              @glasfaser sagte in Docker Installation lädt admin Adapter nicht:
              Liegt das vielleicht an der Bereitstellung des Ports durch DSM „Webstation“?
              Welcher Port hat er denn ,
              dann würdest du aber nicht ioBroker mit 8081 erreichen !
              Kann du nicht meine Fragen beantworten !?
                Homoran Global Moderator Administrators @Glasfaser last edited by
                @ferrog
                bitte lesen und befolgen!
                  Ich habe das nicht als Frage verstanden.
                  Natürlich reicht die Webstation den Port 8081 an den Docker Container weiter.
                  • Glasfaser
                    Lösche alle diese Einträge !
                    Hier wird nur der Port vorgegeben :
                    siehe Beispiel Containereinstellung
                    und das ausschalten / haken bei dir raus
                      WOW, vielen Dank! Daran hats gelegen.
                      Und großen Respekt an die Schnelligkeit eurer Unterstützung!
                      Zum Hintergrund: Belegt Webstation dann in dem Container den besagten Port?
                      • Glasfaser
                        ... aber mühselig erfragt 😉
                        Jipp , deshalb meine Frage :
                        @ferrog
                        • Glasfaser
                          Dann setze den Thread auf [gelöst]
                          1285
