    4. Z-Wave
    Z-Wave
    • AlCalzone
      Auf dem Pi3 musst du noch die serielle Schnittstelle umbiegen, um die Razberry-Platine zu benutzen:
      http://forum.iobroker.net/viewtopic.php?p=68701#p68701
      Am Pi2 müsste es aber gehen, also Log bitte 🙂
        helste64 last edited by
        Z-wave Adapter (habe einen USB Z-Wave-Stick in Verwendung) ist rot - hier das log-file - no idea, was da falsch läuft….DANKE für eure Hilfe
        zwave.0 2017-09-20 01:32:23.336 info terminating
        zwave.0 2017-09-20 01:32:23.294 error at Module.load (module.js:545:32)
        zwave.0 2017-09-20 01:32:23.294 error at Object.Module._extensions..js (module.js:635:10)
        zwave.0 2017-09-20 01:32:23.294 error at Module._compile (module.js:624:30)
        zwave.0 2017-09-20 01:32:23.294 error at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
        zwave.0 2017-09-20 01:32:23.294 error at require (internal/module.js:11:18)
        zwave.0 2017-09-20 01:32:23.294 error at Module.require (module.js:568:17)
        zwave.0 2017-09-20 01:32:23.294 error at Function.Module._load (module.js:500:3)
        zwave.0 2017-09-20 01:32:23.294 error at tryModuleLoad (module.js:508:12)
        zwave.0 2017-09-20 01:32:23.294 error at Object.Module._extensions..node (module.js:653:18)
        zwave.0 2017-09-20 01:32:23.294 error Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2017-09-20 01:32:23.293 error uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2017-09-20 01:32:23.209 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.5.0
        zwave.0 2017-09-20 01:32:21.073 info terminating
        zwave.0 2017-09-20 01:32:21.008 error at Module.load (module.js:545:32)
        zwave.0 2017-09-20 01:32:21.008 error at Object.Module._extensions..js (module.js:635:10)
        zwave.0 2017-09-20 01:32:21.008 error at Module._compile (module.js:624:30)
        zwave.0 2017-09-20 01:32:21.008 error at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
        zwave.0 2017-09-20 01:32:21.008 error at require (internal/module.js:11:18)
        zwave.0 2017-09-20 01:32:21.008 error at Module.require (module.js:568:17)
        zwave.0 2017-09-20 01:32:21.008 error at Function.Module._load (module.js:500:3)
        zwave.0 2017-09-20 01:32:21.008 error at tryModuleLoad (module.js:508:12)
        zwave.0 2017-09-20 01:32:21.008 error at Object.Module._extensions..node (module.js:653:18)
        zwave.0 2017-09-20 01:32:21.008 error Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2017-09-20 01:32:21.007 error uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2017-09-20 01:32:20.928 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.5.0
        zwave.0 2017-09-20 01:31:49.738 info terminating
        zwave.0 2017-09-20 01:31:49.694 error at Module.load (module.js:545:32)
        zwave.0 2017-09-20 01:31:49.694 error at Object.Module._extensions..js (module.js:635:10)
        zwave.0 2017-09-20 01:31:49.694 error at Module._compile (module.js:624:30)
        zwave.0 2017-09-20 01:31:49.694 error at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
        zwave.0 2017-09-20 01:31:49.694 error at require (internal/module.js:11:18)
        zwave.0 2017-09-20 01:31:49.694 error at Module.require (module.js:568:17)
        zwave.0 2017-09-20 01:31:49.694 error at Function.Module._load (module.js:500:3)
        zwave.0 2017-09-20 01:31:49.694 error at tryModuleLoad (module.js:508:12)
        zwave.0 2017-09-20 01:31:49.694 error at Object.Module._extensions..node (module.js:653:18)
        zwave.0 2017-09-20 01:31:49.694 error Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2017-09-20 01:31:49.693 error uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2017-09-20 01:31:49.610 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.5.0
        zwave.0 2017-09-20 01:31:35.685 info terminating
        zwave.0 2017-09-20 01:31:35.619 error at Module.load (module.js:545:32)
        zwave.0 2017-09-20 01:31:35.619 error at Object.Module._extensions..js (module.js:635:10)
        zwave.0 2017-09-20 01:31:35.619 error at Module._compile (module.js:624:30)
        zwave.0 2017-09-20 01:31:35.619 error at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
        zwave.0 2017-09-20 01:31:35.619 error at require (internal/module.js:11:18)
        zwave.0 2017-09-20 01:31:35.619 error at Module.require (module.js:568:17)
        zwave.0 2017-09-20 01:31:35.619 error at Function.Module._load (module.js:500:3)
        zwave.0 2017-09-20 01:31:35.619 error at tryModuleLoad (module.js:508:12)
        zwave.0 2017-09-20 01:31:35.619 error at Object.Module._extensions..node (module.js:653:18)
        zwave.0 2017-09-20 01:31:35.619 error Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2017-09-20 01:31:35.618 error uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
        zwave.0 2017-09-20 01:31:35.527 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.5.0
        zwave.0 2017-09-20 01:31:31.875 info terminating
        zwave.0 2017-09-20 01:31:22.495 info List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyAMA0"}]
        zwave.0 2017-09-20 01:31:20.812 warn No USB selected
        zwave.0 2017-09-20 01:31:20.745 info starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.5.0
        MOD-Edit by eric2905; 20.09.2017 / 0630; Cade- & Spoiler-Tags gesetzt
          apollon77 last edited by
          Die Infos von der Adapter github Seite hast du gesehen und versucht?
          • AlCalzone
            @apollon77:
            Die Infos von der Adapter github Seite hast du gesehen und versucht? `
            Anscheinend nicht:
            @helste64:
            Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory `
            Abhilfe schafft:
            sudo ldconfig
            oder wenn das nicht reicht:
            sudo ldconfig /usr/local/lib64
              mal zur info ich habe den gleichen Stick am laufen am Pi2 und Pi3 .. ohne Probleme
                Hallo arteck!
                Welche ioBroker Version und welche Raspbian Version (Jessie oder Stretch - lite oder full?) hast du installiert? Oder du ein fertiges ioBroker Image installiert, wenn ja, welches?
                Danke für deine Unterstützung.
                • AlCalzone
                  Hast du meinen Beitrag und/oder die Doku auf Github gelesen und die Lösungsvorschläge ausprobiert? Dein Fehler ist bekannt und einfach zu beheben.
                    Lieber AlCalzone!
                    Recht herzlichen Dank für deinen Beistand. Ich habe alle deine Anweisungen (github,….) für meinen Pi3B befolgt - leider ohne Erfolg. Nun habe ich auf meinem Pi2B ioBroker stretch (Version 2017-08-30) installiert. Das Razberry-Modul "aufgesetzt" und siehe da alles funktioniert 😄 Mit dem Pi3B habe ich leider kein glückliches Händchen....weder mit dem Z-Wave USB-Stick noch mit dem Razberry-Modul.
                    Nun ja, aufgeben tue ich nicht so schnell - wichtig ist mir mal, dass ein "System - Pi2B" läuft 😄
                    Werde mich weiter mit dem Pi3B beschäftigen....
                    Nochmals DANKE
                    Grüße aus Wien
                    • AlCalzone
                      @helste64:
                      Mit dem Pi3B habe ich leider kein glückliches Händchen `
                      Na wenn der Pi2 jetzt läuft, ist das doch schon mal was. Was bekommst du beim Pi3 für einen Fehler im Log nach dem Abarbeiten aller Lösungsvorschläge?
                      Aktivier in den Adapter-Optionen mal Logging. Sofern der Treiber startet, solltest du eine Datei OZW_Log.txt finden, entweder hier
                      /opt/iobroker/node_modules/openzwave-shared
                      oder
                      Die dann bitte auch mal posten.
                        Die Logs habe ich leider nicht mehr, Sorry 😉
                        Ich habe (keine Ahnung warum jetzt, habe die gleichen Schritte wie in der Vergangenheit durchgeführt) den Pi3 mit dem ZME_UZB1 zum "Laufen" gebracht :?
                        Teste gerade, wie stabil diese Installation ist und werde berichten, wenn etwas nicht mehr funktioniert.
                        Recht herzlichen DANK an die Community für eure exzellente Unterstützung!!
                        Liebe Grüße aus dem schönen Wien
                        1778
