    4. [Adapter] Sonoff- Tasmota
    • kmxak
      kmxak Most Active last edited by Jey Cee
      Installiert und bekomme aktuell folgenden Fehler (Port geändert da den standart ja der MQTT Adapter benutzt):
      host.ioBroker	2017-10-02 20:16:53.256	error	instance system.adapter.sonoff.0 terminated with code 0 (OK)
      Caught	2017-10-02 20:16:53.256	error	by controller[0]: port: 1884 }
      Caught	2017-10-02 20:16:53.256	error	by controller[0]: address: '0.0.0.0',
      Caught	2017-10-02 20:16:53.256	error	by controller[0]: syscall: 'listen',
      Caught	2017-10-02 20:16:53.256	error	by controller[0]: errno: 'EADDRINUSE',
      Caught	2017-10-02 20:16:53.256	error	by controller[0]: code: 'EADDRINUSE',
      Caught	2017-10-02 20:16:53.256	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
      Caught	2017-10-02 20:16:53.256	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:83:11)
      Caught	2017-10-02 20:16:53.256	error	by controller[0]: at net.js:1404:9
      Caught	2017-10-02 20:16:53.256	error	by controller[0]: at listen (net.js:1294:10)
      Caught	2017-10-02 20:16:53.255	error	by controller[0]: at Server._listen2 (net.js:1258:14)
      Caught	2017-10-02 20:16:53.255	error	by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
      Caught	2017-10-02 20:16:53.255	error	by controller[0]: at Object.exports._errnoException (util.js:1020:11)
      Caught	2017-10-02 20:16:53.255	error	by controller[0]: { Error: listen EADDRINUSE 0.0.0.0:1884
      Der Port scheine auch Belegt zu sein:
      Habe nun 1337 genommen und habe eine Verbindung:
      19:19:21 MQT: Connected
      19:19:21 MQT: tele/SonoffPOW/LWT = Online (retained)
      19:19:21 MQT: cmnd/SonoffPOW/POWER =
      19:19:21 MQT: tele/SonoffPOW/INFO1 = {"Module":"Sonoff Pow", "Version":"5.8.0", "FallbackTopic":"SonoffPOW", "GroupTopic":"sonoffs"}
      19:19:21 MQT: tele/SonoffPOW/INFO2 = {"WebServerMode":"Admin", "Hostname":"Sonoffpow", "IPAddress":"192.168.2.182"}
      19:19:21 MQT: tele/SonoffPOW/INFO3 = {"RestartReason":"Software/System restart"}
      19:19:21 UPP: Multicast (re)joined
      19:19:22 MQT: stat/SonoffPOW/RESULT = {"POWER":"ON"}
      19:19:22 MQT: stat/SonoffPOW/POWER = ON
      19:19:29 MQT: tele/SonoffPOW/STATE = {"Time":"2017-10-02T19:19:29", "Uptime":0, "Vcc":3.243, "POWER":"ON", "Wifi":{"AP":1, "SSId":"IOT", "RSSI":86, "APMac":"CC:CE:1E:2B:8D:4B"}}
      19:19:29 MQT: tele/SonoffPOW/ENERGY = {"Time":"2017-10-02T19:19:29", "Total":1.753, "Yesterday":0.308, "Today":0.205, "Period":0, "Power":3, "Factor":0.16, "Voltage":221, "Current":0.073}
      Bekomme nun:
      sonoff.0	2017-10-02 20:20:44.719	info	Client [SonoffPOW] closed
      sonoff.0	2017-10-02 20:20:44.719	warn	Client error [SonoffPOW]: Error: Invalid messageId
      sonoff.0	2017-10-02 20:20:44.718	info	Client [SonoffPOW] closed
      Nen Debug schicke ich dir per PN
      Unter den Objekten habe ich einen Sonoff Power 3 stehen ka wie der dahin kommt siehe Screenshot in der PN.
      • lobomau
        lobomau last edited by
        Läuft soweit gut und unauffällig. Wenn er zuverlässig läuft, kann ich wieder von den hue Emulationen weg 🙂
        • chucky666
          chucky666 last edited by
          Teste ich morgen
            @Bluefox:
            Der Adapter kommuniziert über MQTT, d.h. in den Tasmota Geräten muss man ioBroker IP Adresse als MQTT Broker eingeben. `
            Heisst das, dass in dem Adapter ein MQTT Broker enthalten und aktiviert ist?
            Was passiert wenn man bereits einen aktiven mqtt Adapter als Broker laufen hat, oder andersrum, kann man den Adapter auch als MQTT Broker missbrauchen?
            Rainer
            • kmxak
              ESP mit BM280 Sensor gibt folgendes aus aber kein Objekt wird angelegt:
              sonoff.0	2017-10-02 21:37:44.403	debug	[ESPClient5] Received: /ESP_BOX/BM280/Pressure = 1010.09
              sonoff.0	2017-10-02 21:37:44.399	debug	[ESPClient5] Received: /ESP_BOX/BM280/Humidity = 42.39
              sonoff.0	2017-10-02 21:37:44.395	debug	[ESPClient5] Received: /ESP_BOX/BM280/Temperature = 25.86
              sonoff.0	2017-10-02 21:37:43.228	debug	stateChange sonoff.0.ESPClient5.alive: {"val":true,"ack":true,"ts":1506973063223,"q":0,"from":"system.adapter.sonoff.0","lc":1506973063223}
              sonoff.0	2017-10-02 21:37:43.225	debug	inMem message sonoff.0.* sonoff.0.ESPClient5.alive
              sonoff.0	2017-10-02 21:37:43.216	debug	stateChange sonoff.0.info.connection: {"val":"SonoffPOW,Sonoff4ch,ESPClient5","ack":true,"ts":1506973063212,"q":0,"from":"system.adapter.sonoff.0","lc":1506973063212}
              sonoff.0	2017-10-02 21:37:43.216	debug	inMem message sonoff.0.* sonoff.0.info.connection
              sonoff.0	2017-10-02 21:37:43.212	info	Client [ESPClient5] connected
              Möglich sollte es sein 😄
              sonoff.0 2017-10-02 21:40:53.911 info Starting MQTT authenticated server on port
                ccc.ggg73 last edited by
                @kmxak:
                Bekomme nun:
                Unter den Objekten habe ich einen Sonoff Power 3 stehen ka wie der dahin kommt siehe Screenshot in der PN. `  Hallo kmxak, ich hatte auch der gleiche Fehlermeldung. Nach ausschalten von mqtt Adapter hat alles funktioniert.
                Gesendet von meinem SM-G950F mit Tapatalk
                  knopers1 last edited by
                  Hi, will ich mal testen. Habe den ganzen Arschvoll von den Dingern mit Tasmota hier im Haus.
                  Beim installieren bekomme ich ein paar Fehler:
                  root@orangepiplus2e:~# cd /opt/iobroker
                  root@orangepiplus2e:/opt/iobroker# npm i https://github.com/ioBroker/ioBroker.sonoff/tarball/master --production
                  iobroker@1.0.0 /opt/iobroker
                  └─┬ iobroker.sonoff@1.3.2
                    └─┬ mqtt@2.13.0
                      ├─┬ readable-stream@2.3.3
                      │ ├── safe-buffer@5.1.1
                      │ └── string_decoder@1.0.3
                      └─┬ websocket-stream@5.0.1
                        └─┬ ws@3.2.0
                          └── async-limiter@1.0.0
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/greenlock/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/jszip/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/mdns/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/stk500/package.json'
                  root@orangepiplus2e:/opt/iobroker# iobroker a sonoff
                  host.orangepiplus2e install adapter sonoff
                  got /opt/iobroker/node_modules/iobroker.sonoff/admin
                  upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                  upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                  host.orangepiplus2e object system.adapter.sonoff created
                  host.orangepiplus2e create instance sonoff
                  host.orangepiplus2e object sonoff.0.info created
                  host.orangepiplus2e object system.adapter.sonoff.0.outputCount created
                  host.orangepiplus2e object system.adapter.sonoff.0.inputCount created
                  host.orangepiplus2e object system.adapter.sonoff.0.uptime created
                  host.orangepiplus2e object system.adapter.sonoff.0.memRss created
                  host.orangepiplus2e object system.adapter.sonoff.0.memHeapTotal created
                  host.orangepiplus2e object system.adapter.sonoff.0.memHeapUsed created
                  host.orangepiplus2e object system.adapter.sonoff.0.connected created
                  host.orangepiplus2e object system.adapter.sonoff.0.alive created
                  host.orangepiplus2e object system.adapter.sonoff.0 created
                  • kmxak
                    der adapter scheint aber dennoch installiert worden zu sein oder?
                      ja, es ist was neues da!
                      die Frage ist, wie binde ich den Sonoff jetzt ein?
                        @knopers1:
                        Beim installieren bekomme ich ein paar Fehler: `
                        Ich sehe keine Fehler!
                        dort sind höchstens ein paar WARNungen
                        also alles im grünen Bereich.
                        Rainer
                        • kmxak
                          Deine IP und Port sowie User und PW eintragen und auf geht es. Client ID ist der Name vom Sonoff. So wird er im ioBroker angezeigt.
                          Änder aber bitte den Port da der Port vom MQTT Adapter schon genutzt wird.
                          Alles speichern fertig.
                            stephan61 last edited by
                            Hallo Knoppers die warnmeldungen hatte ich beim update vom Host auch
                            habe mit
                            sudo npm install greenlock –production
                            sudo npm install jszip --production
                            und so weiter
                            die fehlenden Dateien installiert keine Ahnung was da passiert war
                            Gruß Stephan
                              ok,
                              es geht jetzt! Schalten geht auch. Super!
                              Jetzt möchte ich einen zweiten Tasmota einbinden. Kann ich den gleichen Port sowie Benutzername und Passwort nehmen?
                              Muß ich eine neue Instanz des Adapters installieren?
                              • kmxak
                                Auf jedem Sonoff die gleichen Daten eingeben. Ein Adapter. Aber immer eine andere Client ID vergeben.
                                • chucky666
                                  Hallo
                                  Der sonoff Th10 wird noch nicht unterstützt?
                                  • kmxak
                                    Ich denke Bluefox hat die Geräte nicht alle selber daher bat er uns Debugs zu schicken.
                                    Aktivier mal bitte Debug bei dem Adapter und schau mal ob der Sonoff Daten sendet. Schick das ganze mal Bluefox oder füg es hier an dann kann er das im Adapter aufnehmen.
                                    • chucky666
                                      Weiß nicht ob das richtig ist
                                      mqtt.0	2017-10-03 14:49:50.648	info	publishOnSubscribe send all known states
                                      mqtt.0	2017-10-03 14:49:50.648	info	Client [DVES_0736F2] subscribes on "cmnd.DVES_0736F2.#" with regex /^mqtt\.0\.cmnd\.DVES_0736F2\..*/
                                      mqtt.0	2017-10-03 14:49:50.647	info	Client [DVES_0736F2] subscribes on "cmnd.DVES_0736F2.#" with regex /^cmnd\.DVES_0736F2\..*/
                                      mqtt.0	2017-10-03 14:49:50.407	info	publishOnSubscribe send all known states
                                      mqtt.0	2017-10-03 14:49:50.407	info	Client [DVES_0736F2] subscribes on "cmnd.sonoffs.#" with regex /^mqtt\.0\.cmnd\.sonoffs\..*/
                                      mqtt.0	2017-10-03 14:49:50.406	info	Client [DVES_0736F2] subscribes on "cmnd.sonoffs.#" with regex /^cmnd\.sonoffs\..*/
                                      mqtt.0	2017-10-03 14:49:50.274	info	publishOnSubscribe send all known states
                                      mqtt.0	2017-10-03 14:49:50.274	info	Client [DVES_0736F2] subscribes on "cmnd.sonoff5.#" with regex /^mqtt\.0\.cmnd\.sonoff5\..*/
                                      mqtt.0	2017-10-03 14:49:50.273	info	Client [DVES_0736F2] subscribes on "cmnd.sonoff5.#" with regex /^cmnd\.sonoff5\..*/
                                      Gesendet von iPad mit Tapatalk Pro
                                      geändert: Code in Code-Tags; Homoran (Mod)
                                      • kmxak
                                        du hast den mqtt adapter geloggt xD
                                        Hast du unter Instanzen den Adapter auf Debug gesetzt? (Expertenansicht aktivieren)
                                        Nimm lieber den Sonoff und benutze die```
                                        <code>[code]hier den code einfügen[/code]</code>
                                        • chucky666
                                          sonoff.0 2017-10-03 15:03:08.830 debug Client [DVES_0736F2] pingreq
                                          sonoff.0 2017-10-03 15:03:08.340 debug Client [DVES_42009A] pingreq
                                          sonoff.0 2017-10-03 15:03:05.018 debug Client [DVES_41ECEC] pingreq
                                          sonoff.0 2017-10-03 15:02:53.830 debug Client [DVES_0736F2] pingreq
                                          sonoff.0 2017-10-03 15:02:53.340 debug Client [DVES_42009A] pingreq
                                          sonoff.0 2017-10-03 15:02:50.017 debug Client [DVES_41ECEC] pingreq
                                          sonoff.0 2017-10-03 15:02:38.829 debug Client [DVES_0736F2] pingreq
                                          sonoff.0 2017-10-03 15:02:38.340 debug Client [DVES_42009A] pingreq
                                          sonoff.0 2017-10-03 15:02:34.968 debug [DVES_41ECEC] Received: cmnd/sonoff2/POWER =
                                          sonoff.0 2017-10-03 15:02:34.940 debug stateChange sonoff.0.DVES_41ECEC.alive: {"val":true,"ack":true,"ts":1507035754933,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754933}
                                          sonoff.0 2017-10-03 15:02:34.938 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_41ECEC.alive {"val":true,"ack":true,"ts":1507035754933,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754933}
                                          sonoff.0 2017-10-03 15:02:34.929 debug stateChange sonoff.0.info.connection: {"val":"DVES_42009A,DVES_0736F2,DVES_41ECEC","ack":true,"ts":1507035754925,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754925}
                                          sonoff.0 2017-10-03 15:02:34.928 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_42009A,DVES_0736F2,DVES_41ECEC","ack":true,"ts":1507035754925,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754925}
                                          sonoff.0 2017-10-03 15:02:34.924 info Client [DVES_41ECEC] connected
                                          sonoff.0 2017-10-03 15:02:25.972 debug [DVES_0736F2] Received: tele/sonoff5/SENSOR = {"Time":"2017-10-03T14:02:25", "AM2301-14":{"Temperature":21.6, "Humidity":54.7}, "TempUnit":"C"}
                                          sonoff.0 2017-10-03 15:02:25.910 debug stateChange sonoff.0.DVES_0736F2.POWER: {"val":false,"ack":true,"ts":1507035745898,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745898}
                                          sonoff.0 2017-10-03 15:02:25.907 debug stateChange sonoff.0.DVES_0736F2.RSSI: {"val":84,"ack":true,"ts":1507035745897,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745897}
                                          sonoff.0 2017-10-03 15:02:25.906 debug stateChange sonoff.0.DVES_0736F2.Vcc: {"val":3.177,"ack":true,"ts":1507035745896,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745896}
                                          sonoff.0 2017-10-03 15:02:25.906 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.POWER {"val":false,"ack":true,"ts":1507035745898,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745898}
                                          sonoff.0 2017-10-03 15:02:25.905 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.RSSI {"val":84,"ack":true,"ts":1507035745897,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745897}
                                          sonoff.0 2017-10-03 15:02:25.904 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.Vcc {"val":3.177,"ack":true,"ts":1507035745896,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745896}
                                          sonoff.0 2017-10-03 15:02:25.886 debug [DVES_0736F2] Received: tele/sonoff5/STATE = {"Time":"2017-10-03T14:02:25", "Uptime":16, "Vcc":3.177, "POWER":"OFF", "Wifi":{"AP":1, "SSId":"Chucky", "RSSI":84, "APMac":"CC:CE:1E:A3:6C:D3"}}
                                          sonoff.0 2017-10-03 15:02:23.693 debug [DVES_0736F2] Received: cmnd/sonoff5/POWER =
                                          sonoff.0 2017-10-03 15:02:23.666 debug stateChange sonoff.0.DVES_0736F2.alive: {"val":true,"ack":true,"ts":1507035743661,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743661}
                                          sonoff.0 2017-10-03 15:02:23.663 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.alive {"val":true,"ack":true,"ts":1507035743661,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743661}
                                          sonoff.0 2017-10-03 15:02:23.659 debug stateChange sonoff.0.info.connection: {"val":"DVES_42009A,DVES_0736F2","ack":true,"ts":1507035743648,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743648}
                                          sonoff.0 2017-10-03 15:02:23.655 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_42009A,DVES_0736F2","ack":true,"ts":1507035743648,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743648}
                                          sonoff.0 2017-10-03 15:02:23.645 info Client [DVES_0736F2] connected
                                          sonoff.0 2017-10-03 15:02:23.348 debug stateChange sonoff.0.DVES_42009A.alive: {"val":true,"ack":true,"ts":1507035743342,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743342}
                                          sonoff.0 2017-10-03 15:02:23.347 debug stateChange sonoff.0.DVES_42009A.alive: {"val":true,"ack":true,"ts":1507035743341,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743341}
                                          sonoff.0 2017-10-03 15:02:23.347 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_42009A.alive {"val":true,"ack":true,"ts":1507035743342,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743342}
                                          sonoff.0 2017-10-03 15:02:23.346 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_42009A.alive {"val":true,"ack":true,"ts":1507035743341,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743341}
                                          sonoff.0 2017-10-03 15:02:23.328 debug [DVES_42009A] Received: cmnd/sonoff3/POWER =
                                          sonoff.0 2017-10-03 15:02:23.258 debug stateChange sonoff.0.info.connection: {"val":"DVES_42009A","ack":true,"ts":1507035743241,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743241}
                                          sonoff.0 2017-10-03 15:02:23.254 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_42009A","ack":true,"ts":1507035743241,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743241}
                                          sonoff.0 2017-10-03 15:02:23.239 debug stateChange sonoff.0.DVES_41ECEC.alive: {"val":false,"ack":true,"ts":1507035743194,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409102}
                                          sonoff.0 2017-10-03 15:02:23.239 debug stateChange sonoff.0.DVES_42009A.alive: {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409099}
                                          sonoff.0 2017-10-03 15:02:23.238 debug stateChange sonoff.0.DVES_0736F2.alive: {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409098}
                                          sonoff.0 2017-10-03 15:02:23.237 debug stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1507035743192,"q":0,"from":"system.adapter.sonoff.0","lc":1506975964976}
                                          sonoff.0 2017-10-03 15:02:23.222 info Client [DVES_42009A] connected
                                          sonoff.0 2017-10-03 15:02:23.206 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_41ECEC.alive {"val":false,"ack":true,"ts":1507035743194,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409102}
                                          sonoff.0 2017-10-03 15:02:23.204 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_42009A.alive {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409099}
                                          sonoff.0 2017-10-03 15:02:23.203 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.alive {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409098}
                                          sonoff.0 2017-10-03 15:02:23.197 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"","ack":true,"ts":1507035743192,"q":0,"from":"system.adapter.sonoff.0","lc":1506975964976}
                                          sonoff.0 2017-10-03 15:02:23.121 info Starting MQTT authenticated server on port 1883
                                          ****geändert: Code in Code-Tags und spoiler; Homoran (Mod)****
                                            habe vorerst 4 Stück an den Sonoff Adapter gekoppelt. Bis jetzt nichts negatives zu berichten.
                                            Die hue Instanzen wurden gelöscht, dadurch um die 100MB RAM frei geworden. Geil, darauf habe ich gewartet.
                                            720
                                            202533
