    4. [Adapter] Sonoff- Tasmota
      ccc.ggg73 last edited by
      @kmxak:
      Installiert und bekomme aktuell folgenden Fehler (Port geändert da den standart ja der MQTT Adapter benutzt):
      host.ioBroker 2017-10-02 20:16:53.256 error instance system.adapter.sonoff.0 terminated with code 0 (OK)
      Caught 2017-10-02 20:16:53.256 error by controller[0]: port: 1884 }
      Caught 2017-10-02 20:16:53.256 error by controller[0]: address: '0.0.0.0',
      Caught 2017-10-02 20:16:53.256 error by controller[0]: syscall: 'listen',
      Caught 2017-10-02 20:16:53.256 error by controller[0]: errno: 'EADDRINUSE',
      Caught 2017-10-02 20:16:53.256 error by controller[0]: code: 'EADDRINUSE',
      Caught 2017-10-02 20:16:53.256 error by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
      Caught 2017-10-02 20:16:53.256 error by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:83:11)
      Caught 2017-10-02 20:16:53.256 error by controller[0]: at net.js:1404:9
      Caught 2017-10-02 20:16:53.256 error by controller[0]: at listen (net.js:1294:10)
      Caught 2017-10-02 20:16:53.255 error by controller[0]: at Server._listen2 (net.js:1258:14)
      Caught 2017-10-02 20:16:53.255 error by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
      Caught 2017-10-02 20:16:53.255 error by controller[0]: at Object.exports._errnoException (util.js:1020:11)
      Caught 2017-10-02 20:16:53.255 error by controller[0]: { Error: listen EADDRINUSE 0.0.0.0:1884
      Der Port scheine auch Belegt zu sein:
      Habe nun 1337 genommen und habe eine Verbindung:
      19:19:21 MQT: Connected
      19:19:21 MQT: tele/SonoffPOW/LWT = Online (retained)
      19:19:21 MQT: cmnd/SonoffPOW/POWER =
      19:19:21 MQT: tele/SonoffPOW/INFO1 = {"Module":"Sonoff Pow", "Version":"5.8.0", "FallbackTopic":"SonoffPOW", "GroupTopic":"sonoffs"}
      19:19:21 MQT: tele/SonoffPOW/INFO2 = {"WebServerMode":"Admin", "Hostname":"Sonoffpow", "IPAddress":"192.168.2.182"}
      19:19:21 MQT: tele/SonoffPOW/INFO3 = {"RestartReason":"Software/System restart"}
      19:19:21 UPP: Multicast (re)joined
      19:19:22 MQT: stat/SonoffPOW/RESULT = {"POWER":"ON"}
      19:19:22 MQT: stat/SonoffPOW/POWER = ON
      19:19:29 MQT: tele/SonoffPOW/STATE = {"Time":"2017-10-02T19:19:29", "Uptime":0, "Vcc":3.243, "POWER":"ON", "Wifi":{"AP":1, "SSId":"IOT", "RSSI":86, "APMac":"CC:CE:1E:2B:8D:4B"}}
      19:19:29 MQT: tele/SonoffPOW/ENERGY = {"Time":"2017-10-02T19:19:29", "Total":1.753, "Yesterday":0.308, "Today":0.205, "Period":0, "Power":3, "Factor":0.16, "Voltage":221, "Current":0.073}
      Bekomme nun:
      sonoff.0 2017-10-02 20:20:44.719 info Client [SonoffPOW] closed
      sonoff.0 2017-10-02 20:20:44.719 warn Client error [SonoffPOW]: Error: Invalid messageId
      sonoff.0 2017-10-02 20:20:44.718 info Client [SonoffPOW] closed
      Nen Debug schicke ich dir per PN
      Unter den Objekten habe ich einen Sonoff Power 3 stehen ka wie der dahin kommt siehe Screenshot in der PN. `  Hallo kmxak, ich hatte auch der gleiche Fehlermeldung. Nach ausschalten von mqtt Adapter hat alles funktioniert.
      Gesendet von meinem SM-G950F mit Tapatalk
        knopers1 last edited by
        Hi, will ich mal testen. Habe den ganzen Arschvoll von den Dingern mit Tasmota hier im Haus.
        Beim installieren bekomme ich ein paar Fehler:
        root@orangepiplus2e:~# cd /opt/iobroker
        root@orangepiplus2e:/opt/iobroker# npm i https://github.com/ioBroker/ioBroker.sonoff/tarball/master --production
        iobroker@1.0.0 /opt/iobroker
        └─┬ iobroker.sonoff@1.3.2
          └─┬ mqtt@2.13.0
            ├─┬ readable-stream@2.3.3
            │ ├── safe-buffer@5.1.1
            │ └── string_decoder@1.0.3
            └─┬ websocket-stream@5.0.1
              └─┬ ws@3.2.0
                └── async-limiter@1.0.0
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/greenlock/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/jszip/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/mdns/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/stk500/package.json'
        root@orangepiplus2e:/opt/iobroker# iobroker a sonoff
        host.orangepiplus2e install adapter sonoff
        got /opt/iobroker/node_modules/iobroker.sonoff/admin
        upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
        upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
        host.orangepiplus2e object system.adapter.sonoff created
        host.orangepiplus2e create instance sonoff
        host.orangepiplus2e object sonoff.0.info created
        host.orangepiplus2e object system.adapter.sonoff.0.outputCount created
        host.orangepiplus2e object system.adapter.sonoff.0.inputCount created
        host.orangepiplus2e object system.adapter.sonoff.0.uptime created
        host.orangepiplus2e object system.adapter.sonoff.0.memRss created
        host.orangepiplus2e object system.adapter.sonoff.0.memHeapTotal created
        host.orangepiplus2e object system.adapter.sonoff.0.memHeapUsed created
        host.orangepiplus2e object system.adapter.sonoff.0.connected created
        host.orangepiplus2e object system.adapter.sonoff.0.alive created
        host.orangepiplus2e object system.adapter.sonoff.0 created
        • kmxak
          der adapter scheint aber dennoch installiert worden zu sein oder?
            ja, es ist was neues da!
            die Frage ist, wie binde ich den Sonoff jetzt ein?
              @knopers1:
              Beim installieren bekomme ich ein paar Fehler: `
              Ich sehe keine Fehler!
              dort sind höchstens ein paar WARNungen
              also alles im grünen Bereich.
              Rainer
              • kmxak
                Deine IP und Port sowie User und PW eintragen und auf geht es. Client ID ist der Name vom Sonoff. So wird er im ioBroker angezeigt.
                Änder aber bitte den Port da der Port vom MQTT Adapter schon genutzt wird.
                Alles speichern fertig.
                  stephan61 last edited by
                  Hallo Knoppers die warnmeldungen hatte ich beim update vom Host auch
                  habe mit
                  sudo npm install greenlock –production
                  sudo npm install jszip --production
                  und so weiter
                  die fehlenden Dateien installiert keine Ahnung was da passiert war
                  Gruß Stephan
                    ok,
                    es geht jetzt! Schalten geht auch. Super!
                    Jetzt möchte ich einen zweiten Tasmota einbinden. Kann ich den gleichen Port sowie Benutzername und Passwort nehmen?
                    Muß ich eine neue Instanz des Adapters installieren?
                    • kmxak
                      Auf jedem Sonoff die gleichen Daten eingeben. Ein Adapter. Aber immer eine andere Client ID vergeben.
                      • chucky666
                        chucky666 last edited by
                        Hallo
                        Der sonoff Th10 wird noch nicht unterstützt?
                        • kmxak
                          Ich denke Bluefox hat die Geräte nicht alle selber daher bat er uns Debugs zu schicken.
                          Aktivier mal bitte Debug bei dem Adapter und schau mal ob der Sonoff Daten sendet. Schick das ganze mal Bluefox oder füg es hier an dann kann er das im Adapter aufnehmen.
                          • chucky666
                            Weiß nicht ob das richtig ist
                            mqtt.0	2017-10-03 14:49:50.648	info	publishOnSubscribe send all known states
                            mqtt.0	2017-10-03 14:49:50.648	info	Client [DVES_0736F2] subscribes on "cmnd.DVES_0736F2.#" with regex /^mqtt\.0\.cmnd\.DVES_0736F2\..*/
                            mqtt.0	2017-10-03 14:49:50.647	info	Client [DVES_0736F2] subscribes on "cmnd.DVES_0736F2.#" with regex /^cmnd\.DVES_0736F2\..*/
                            mqtt.0	2017-10-03 14:49:50.407	info	publishOnSubscribe send all known states
                            mqtt.0	2017-10-03 14:49:50.407	info	Client [DVES_0736F2] subscribes on "cmnd.sonoffs.#" with regex /^mqtt\.0\.cmnd\.sonoffs\..*/
                            mqtt.0	2017-10-03 14:49:50.406	info	Client [DVES_0736F2] subscribes on "cmnd.sonoffs.#" with regex /^cmnd\.sonoffs\..*/
                            mqtt.0	2017-10-03 14:49:50.274	info	publishOnSubscribe send all known states
                            mqtt.0	2017-10-03 14:49:50.274	info	Client [DVES_0736F2] subscribes on "cmnd.sonoff5.#" with regex /^mqtt\.0\.cmnd\.sonoff5\..*/
                            mqtt.0	2017-10-03 14:49:50.273	info	Client [DVES_0736F2] subscribes on "cmnd.sonoff5.#" with regex /^cmnd\.sonoff5\..*/
                            Gesendet von iPad mit Tapatalk Pro
                            geändert: Code in Code-Tags; Homoran (Mod)
                            • kmxak
                              du hast den mqtt adapter geloggt xD
                              Hast du unter Instanzen den Adapter auf Debug gesetzt? (Expertenansicht aktivieren)
                              Nimm lieber den Sonoff und benutze die```
                              <code>[code]hier den code einfügen[/code]</code>
                              • chucky666
                                sonoff.0 2017-10-03 15:03:08.830 debug Client [DVES_0736F2] pingreq
                                sonoff.0 2017-10-03 15:03:08.340 debug Client [DVES_42009A] pingreq
                                sonoff.0 2017-10-03 15:03:05.018 debug Client [DVES_41ECEC] pingreq
                                sonoff.0 2017-10-03 15:02:53.830 debug Client [DVES_0736F2] pingreq
                                sonoff.0 2017-10-03 15:02:53.340 debug Client [DVES_42009A] pingreq
                                sonoff.0 2017-10-03 15:02:50.017 debug Client [DVES_41ECEC] pingreq
                                sonoff.0 2017-10-03 15:02:38.829 debug Client [DVES_0736F2] pingreq
                                sonoff.0 2017-10-03 15:02:38.340 debug Client [DVES_42009A] pingreq
                                sonoff.0 2017-10-03 15:02:34.968 debug [DVES_41ECEC] Received: cmnd/sonoff2/POWER =
                                sonoff.0 2017-10-03 15:02:34.940 debug stateChange sonoff.0.DVES_41ECEC.alive: {"val":true,"ack":true,"ts":1507035754933,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754933}
                                sonoff.0 2017-10-03 15:02:34.938 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_41ECEC.alive {"val":true,"ack":true,"ts":1507035754933,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754933}
                                sonoff.0 2017-10-03 15:02:34.929 debug stateChange sonoff.0.info.connection: {"val":"DVES_42009A,DVES_0736F2,DVES_41ECEC","ack":true,"ts":1507035754925,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754925}
                                sonoff.0 2017-10-03 15:02:34.928 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_42009A,DVES_0736F2,DVES_41ECEC","ack":true,"ts":1507035754925,"q":0,"from":"system.adapter.sonoff.0","lc":1507035754925}
                                sonoff.0 2017-10-03 15:02:34.924 info Client [DVES_41ECEC] connected
                                sonoff.0 2017-10-03 15:02:25.972 debug [DVES_0736F2] Received: tele/sonoff5/SENSOR = {"Time":"2017-10-03T14:02:25", "AM2301-14":{"Temperature":21.6, "Humidity":54.7}, "TempUnit":"C"}
                                sonoff.0 2017-10-03 15:02:25.910 debug stateChange sonoff.0.DVES_0736F2.POWER: {"val":false,"ack":true,"ts":1507035745898,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745898}
                                sonoff.0 2017-10-03 15:02:25.907 debug stateChange sonoff.0.DVES_0736F2.RSSI: {"val":84,"ack":true,"ts":1507035745897,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745897}
                                sonoff.0 2017-10-03 15:02:25.906 debug stateChange sonoff.0.DVES_0736F2.Vcc: {"val":3.177,"ack":true,"ts":1507035745896,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745896}
                                sonoff.0 2017-10-03 15:02:25.906 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.POWER {"val":false,"ack":true,"ts":1507035745898,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745898}
                                sonoff.0 2017-10-03 15:02:25.905 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.RSSI {"val":84,"ack":true,"ts":1507035745897,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745897}
                                sonoff.0 2017-10-03 15:02:25.904 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.Vcc {"val":3.177,"ack":true,"ts":1507035745896,"q":0,"from":"system.adapter.sonoff.0","lc":1507035745896}
                                sonoff.0 2017-10-03 15:02:25.886 debug [DVES_0736F2] Received: tele/sonoff5/STATE = {"Time":"2017-10-03T14:02:25", "Uptime":16, "Vcc":3.177, "POWER":"OFF", "Wifi":{"AP":1, "SSId":"Chucky", "RSSI":84, "APMac":"CC:CE:1E:A3:6C:D3"}}
                                sonoff.0 2017-10-03 15:02:23.693 debug [DVES_0736F2] Received: cmnd/sonoff5/POWER =
                                sonoff.0 2017-10-03 15:02:23.666 debug stateChange sonoff.0.DVES_0736F2.alive: {"val":true,"ack":true,"ts":1507035743661,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743661}
                                sonoff.0 2017-10-03 15:02:23.663 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.alive {"val":true,"ack":true,"ts":1507035743661,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743661}
                                sonoff.0 2017-10-03 15:02:23.659 debug stateChange sonoff.0.info.connection: {"val":"DVES_42009A,DVES_0736F2","ack":true,"ts":1507035743648,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743648}
                                sonoff.0 2017-10-03 15:02:23.655 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_42009A,DVES_0736F2","ack":true,"ts":1507035743648,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743648}
                                sonoff.0 2017-10-03 15:02:23.645 info Client [DVES_0736F2] connected
                                sonoff.0 2017-10-03 15:02:23.348 debug stateChange sonoff.0.DVES_42009A.alive: {"val":true,"ack":true,"ts":1507035743342,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743342}
                                sonoff.0 2017-10-03 15:02:23.347 debug stateChange sonoff.0.DVES_42009A.alive: {"val":true,"ack":true,"ts":1507035743341,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743341}
                                sonoff.0 2017-10-03 15:02:23.347 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_42009A.alive {"val":true,"ack":true,"ts":1507035743342,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743342}
                                sonoff.0 2017-10-03 15:02:23.346 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_42009A.alive {"val":true,"ack":true,"ts":1507035743341,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743341}
                                sonoff.0 2017-10-03 15:02:23.328 debug [DVES_42009A] Received: cmnd/sonoff3/POWER =
                                sonoff.0 2017-10-03 15:02:23.258 debug stateChange sonoff.0.info.connection: {"val":"DVES_42009A","ack":true,"ts":1507035743241,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743241}
                                sonoff.0 2017-10-03 15:02:23.254 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_42009A","ack":true,"ts":1507035743241,"q":0,"from":"system.adapter.sonoff.0","lc":1507035743241}
                                sonoff.0 2017-10-03 15:02:23.239 debug stateChange sonoff.0.DVES_41ECEC.alive: {"val":false,"ack":true,"ts":1507035743194,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409102}
                                sonoff.0 2017-10-03 15:02:23.239 debug stateChange sonoff.0.DVES_42009A.alive: {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409099}
                                sonoff.0 2017-10-03 15:02:23.238 debug stateChange sonoff.0.DVES_0736F2.alive: {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409098}
                                sonoff.0 2017-10-03 15:02:23.237 debug stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1507035743192,"q":0,"from":"system.adapter.sonoff.0","lc":1506975964976}
                                sonoff.0 2017-10-03 15:02:23.222 info Client [DVES_42009A] connected
                                sonoff.0 2017-10-03 15:02:23.206 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_41ECEC.alive {"val":false,"ack":true,"ts":1507035743194,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409102}
                                sonoff.0 2017-10-03 15:02:23.204 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_42009A.alive {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409099}
                                sonoff.0 2017-10-03 15:02:23.203 debug redis pmessage io.sonoff.0.* io.sonoff.0.DVES_0736F2.alive {"val":false,"ack":true,"ts":1507035743193,"q":0,"from":"system.adapter.sonoff.0","lc":1506976409098}
                                sonoff.0 2017-10-03 15:02:23.197 debug redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"","ack":true,"ts":1507035743192,"q":0,"from":"system.adapter.sonoff.0","lc":1506975964976}
                                sonoff.0 2017-10-03 15:02:23.121 info Starting MQTT authenticated server on port 1883
                                ****geändert: Code in Code-Tags und spoiler; Homoran (Mod)****
                                  habe vorerst 4 Stück an den Sonoff Adapter gekoppelt. Bis jetzt nichts negatives zu berichten.
                                  Die hue Instanzen wurden gelöscht, dadurch um die 100MB RAM frei geworden. Geil, darauf habe ich gewartet.
                                  • N
                                    noxx last edited by
                                    läuft, trotz fehler beim installieren
                                    https://pastebin.com/raw/5AyQYApp
                                    Aber, wieso bekomme ich die Temperatur nicht angezeigt im iobroker?
                                    Tasmota-console:
                                    17:40:55 MQTT: cmnd/sonoff/POWER =
                                    17:40:56 UPnP: Multicast (re)joined
                                    17:41:33 MQTT: stat/sonoff/RESULT = {"POWER1":"ON"}
                                    17:41:33 MQTT: stat/sonoff/POWER1 = ON
                                    17:41:34 MQTT: stat/sonoff/RESULT = {"POWER2":"ON"}
                                    17:41:34 MQTT: stat/sonoff/POWER2 = ON
                                    17:41:35 MQTT: stat/sonoff/RESULT = {"POWER3":"ON"}
                                    17:41:35 MQTT: stat/sonoff/POWER3 = ON
                                    17:41:40 MQTT: stat/sonoff/RESULT = {"POWER4":"ON"}
                                    17:41:40 MQTT: stat/sonoff/POWER4 = ON
                                    17:41:43 MQTT: stat/sonoff/RESULT = {"POWER2":"OFF"}
                                    17:41:43 MQTT: stat/sonoff/POWER2 = OFF
                                    17:41:44 MQTT: stat/sonoff/RESULT = {"POWER3":"OFF"}
                                    17:41:44 MQTT: stat/sonoff/POWER3 = OFF
                                    17:41:45 MQTT: stat/sonoff/RESULT = {"POWER4":"OFF"}
                                    17:41:45 MQTT: stat/sonoff/POWER4 = OFF
                                    17:41:46 MQTT: stat/sonoff/RESULT = {"POWER1":"OFF"}
                                    17:41:46 MQTT: stat/sonoff/POWER1 = OFF
                                    17:43:19 MQTT: tele/sonoff/STATE = {"Time":"2017-10-05T17:43:19", "Uptime":21, "Vcc":3.249, "POWER1":"OFF", "POWER2":"OFF", "POWER3":"OFF", "POWER4":"OFF", "Wifi":{"AP":2, "SSID":"myhome2_AP", "RSSI":52, "APMac":"F8:1A:67:3D:F2:81"}}
                                    17:43:19 MQTT: tele/sonoff/SENSOR = {"Time":"2017-10-05T17:43:19", "DS18x20":{"DS1":{"Type":"DS18B20", "Address":"28FF9ABC7115022A", "Temperature":12.2}}, "TempUnit":"C"}
                                    [2880_01.png](/assets/uploads/files/2880_01.png)
                                    [2880_02.png](/assets/uploads/files/2880_02.png)
                                    • kmxak
                                      Die Daten werden schon mal gesendet. Es wird nicht angezeigt weil es aktuell noch nicht eingefügt ist.
                                      Bluefox schreibt in seinem letzten Satz: > Ich habe nur DH28xx angebunden. Für weitere Sensoren brauche ich debug outputs. Am besten per PR :) Mit PR meint er wohl PN
                                      • Bluefox
                                        Bluefox last edited by
                                        Es gibt updates. 0.2.0
                                        • Bluefox
                                          @kmxak:
                                          Bluefox schreibt in seinem letzten Satz: > Ich habe nur DH28xx angebunden. Für weitere Sensoren brauche ich debug outputs. Am besten per PR :) Mit PR meint er wohl PN `
                                          Mit PR meine ich Pull Request auf dem Github 🙂
                                          • chucky666
                                            Danke für den Adapter
                                            Wäre schön wenn du den Sonoff Th10 mit Temperatur Sensor einbinden könntest.
                                            sonoff.0	2017-10-05 21:10:39.820	debug	stateChange sonoff.0.info.connection: {"val":"DVES_0736F2","ack":true,"ts":1507230639811,"q":0,"from":"system.adapter.sonoff.0","lc":1507230639811}
                                            sonoff.0	2017-10-05 21:10:39.818	debug	redis pmessage io.sonoff.0.* io.sonoff.0.info.connection {"val":"DVES_0736F2","ack":true,"ts":1507230639811,"q":0,"from":"system.adapter.sonoff.0","lc":1507230639811}
                                            sonoff.0	2017-10-05 21:10:39.599	info	Client [DVES_0736F2] connected
                                            720
                                            202151
