      TT-Tom @eMd last edited by TT-Tom
      @eMd
      Welchen Wetter Adapter nutzt du?
      Wie sind deine Wetter Einstellungen am Panel?
      Welcher Screensaver läuft?
      Welche Script version?
      Welche Node version?
        PROcrastinator @Armilar last edited by
        @armilar @TT-Tom
        Danke für die vielen Ideen!
        Der Wert in mqtt.0.stat.nspanel.STATUS0 ist
        {"Status":{"Module":0,"DeviceName":"NSPanel","FriendlyName":["NSPanel",""],"Topic":"nspanel","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Software reset CPU","Uptime":"0T00:50:56","StartupUTC":"2023-05-07T14:30:24","Sleep":0,"CfgHolder":4617,"BootCount":10,"BCResetTime":"2023-05-07T11:21:45","SaveCount":28},"StatusFWR":{"Version":"12.5.0(nspanel)","BuildDateTime":"2023-04-17T08:07:02","Core":"2_0_7","SDK":"4.4.4.20230218","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 rev.3","CR":"445/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["Endoplasmatisches Retikulum 2,4",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":1526,"Free":1856,"Heap":131,"StackLowMark":3,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["00000809","9F9AD7CF","0015A001","B7F7BFCF","05DA9BC0","E0360DC7","480840D2","20200000","D4BC482D","000A80B1"],"Drivers":"1,2,3,4,5,7,8,9,10,11,12,14,16,17,20,21,24,26,27,29,34,35,38,50,52,59,60,62,63,66,67,82,86,87,88","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77"},"StatusNET":{"Hostname":"nspanel-2240","IPAddress":"192.168.178.200","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.10","DNSServer2":"0.0.0.0","Mac":"3C:E9:0E:89:48:C0","IP6Global":"","IP6Local":"fe80::3ee9:eff:fe89:48c0","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.10","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0},"StatusMQT":{"MqttHost":"192.168.178.100","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_8948C0","MqttUser":"mqtt","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2023-05-07T15:21:20","Local":"2023-05-07T16:21:20","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+01:00","Sunrise":"05:20","Sunset":"20:13"},"StatusSNS":{"Time":"2023-05-07T16:21:20","ANALOG":{"Temperature1":31.7},"ESP32":{"Temperature":60.0},"TempUnit":"C"},"StatusSTS":{"Time":"2023-05-07T16:21:20","Uptime":"0T00:50:56","UptimeSec":3056,"Heap":129,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":1000,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":239},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Endoplasmatisches Retikulum 2,4","BSSId":"E0:28:6D:3D:C1:69","Channel":8,"Mode":"11n","RSSI":92,"Signal":-54,"LinkCount":1,"Downtime":"0T00:00:05"}}}
        "Version" und "OnlineVersion" in 0_userdata sid beides string
        Gelöscht hatte ich beide schon. Bei nodeJs hab ich erst ein update gemacht.
        Nodejs ist jetzt bei 18.16.0, npm 9.5.1.
        Schönen Sonntag, Roland
        • Armilar
          Armilar Most Active Forum Testing @PROcrastinator last edited by
          @procrastinator
          Geht nicht um onlineVersion, sondern um:
          Tasmota_Firmware.currentVersion
          Was steht da drin?
          • Armilar
            Armilar Most Active Forum Testing @eMd last edited by
            @emd
            Der einzige Grund der mir einfallen würde, wäre dass sich Werte in die Datenpunkte:
            0_userdata.0.NSPanel.1.ScreensaverInfo.popupNotifyHeading
            und
            0_userdata.0.NSPanel.1.ScreensaverInfo.popupNotifyText
            verirren. Solange eine Screensaver Nachricht aktiv ist, wird nicht aktualisiert...
            T E 2 Replies Last reply Reply Quote 0
              TT-Tom @Armilar last edited by
              @armilar dann müsste aber doch eine Nachricht über das ganze untere Display sein, mit zwei Werten.
              Ich habe es so verstanden das er alle Daten sieht nur nicht aktuell.
                eMd @Armilar last edited by
                @armilar
                Dann könnte das DWD Popup Script schuld gewesen sein, habe es mal pausiert. Das lief zwar habe aber nie eine Nachricht gesehen auf dem Display...
                Vermutlich wurde deshalb nicht aktualisiert.
                Wetter lief über den Adapter aus der Wiki und nur die Temperatur aktuell kommt von einem eigenen sensor...
                Ich teste und melde mich bei miserfolg 🙂
                MfG
                eMd
                  tobiasp @eMd last edited by tobiasp
                  @emd
                  hat jemand ein Blockly oder kann mir helfen ein Blockly für ein Popup zu kreieren.
                  Ich möchte einen Popup am Display wenn der Müll abgeholt wird als Erinnerung (1 Tag Vorher)
                  Danke schonmal
                  T draexler 2 Replies Last reply Reply Quote 0
                    TT-Tom @tobiasp last edited by
                    @tobiasp
                    In welcher Form liegen den die Abholtage vor. Nutzt du ein Adapter?
                    • draexler
                      draexler @tobiasp last edited by
                      @tobiasp Es ist ein PopUp möglich? An dem wäre ich auch intressiert, das z.B. nach zehn Sekunden wieder verschwindet.
                        tobiasp @TT-Tom last edited by
                        @tt-tom
                        Trashshedule
                        trashschedule.0.next.daysLeft 1Day left ...
                        Genial wäre es wen eine Meldung aufploppen würde, die man dann bestätigen muss.
                        Ich hab mal das DWD Blockly drauf aber bekommme hier eine Fehlermeldung in Iobroker.
                        State "0.userdata.0.NSPanel.1.ScreensaverInfo.popupNotifyHeading" not found
                        State "0.userdata.0.NSPanel.1.ScreensaverInfo.popupNotifyText" not found
                        Armilar T 2 Replies Last reply Reply Quote 0
                          @armilar Sorry, hab ich Mißverstanden. im Datenpunkt "0_userdata.0.NSPanel.1.Tasmota_Firmware.currentVersion" steht 12.5.0, die Gleiche wie im Datenpunkt OnlineVersion
                          • Armilar
                            Armilar Most Active Forum Testing @tobiasp last edited by
                            @tobiasp
                            Mache mal kurz einen Screenshot von deinem Panel Verzeichnis.
                            Aber wenn das die States sind, dann stimmt der Pfad auch nicht:
                            0_userdata.0. --> nicht 0.userdata.0.
                            • Armilar
                              @procrastinator
                              Interessant, aber dann kann ich den Fehler ebenfalls nicht wirklich nachvollziehen
                              • Armilar
                                Armilar Most Active Forum Testing @draexler last edited by
                                @draexler
                                Ja klar, ist auf zwei Arten möglich.
                                popupNotify:
                                https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)#popupnotify---layout-2
                                Über den Datenpunkt popupNotifySleepTimeout kann die Zeit (in Sekunden) eingestellt werden, für die das popupNotify sichbar ist.
                                screensaverNotify:
                                https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen#3-info-screensaver-info-auf-request
                                Wenn die 2 Datenpunkte wieder leer sind "", dann verschwindet die Screensaver-Nachricht
                                draexler 1 Reply Last reply Reply Quote 0
                                  PROcrastinator @TT-Tom last edited by PROcrastinator
                                  @tt-tom said in SONOFF NSPanel mit Lovelace UI:
                                  1. Und noch was anderes Ich habe eine Karte vom Typ cardLChart für die Gewächshaustemperatur angelegt. Welcher Typ muss der Datenpunkt sein, in den das JS für den history Adapter die Daten rein schreibt?
                                  Hast du das Script aus dem Wiki genommen, dort ist auch alles beschrieben.
                                  Ich habe alles nach der Anleitung im Wiki gemacht:
                                  1. Datenpunkt 0_userdata.0.NSPanel.1.Charts.temp_gewaechshaus angelegt. Dieser ist ein Datenpunkt vom Typ string (Typ ist in der Anleitung nicht spezifiziert).
                                  2. In Geräte Alias vom Typ "Info" angelegt. der Alias "alias.0.NSPanel_1.Chart_temp_gewaechshaus" zeigt auf den Datenpunkt aus 1.
                                  3. Gerät vom Typ Temperatur angelegt, das auf den Sensor im Gewächshaus zeigt. (Das steht auch nicht in der Anleitung, aber irgendwoher muss das Skript ja die Temperatur bekommen?). Im Influx2 Skript wird der Sensor explizit genannt, im History Skript fehlt der Verweis.
                                  4. Javascript für History Adapter kopiert und als JS Skript eingefügt
                                  5. Skript angepasst
                                  const sourceDP = 'alias.0.NSPanel_1.Sensor_temp_gewächshaus.ACTUAL';
                                  const targetDP = '0_userdata.0.NSPanel.1.Charts.temp_gewaechshaus';
                                  Den Datenpunkt ACTUAL zeigt auch die derzeitige Temperatur an. Der targetDP ist allerdings leer. Sollte der sofort gefüllt werden, da ja der history adapter mit im Spiel ist oder füllt der sich erst mit der Zeit?
                                  1. Die Karte in meinem Panelskript sieht so aus:
                                  let Temp_Gewaechshaus = <PageChart>
                                      "type": "cardLChart",
                                      "heading": "Gewächsthaus Temperatur",
                                      "useColor": true,
                                      'items': [<PageItem>{
                                                  yAxis: 'Temperatur [°C]',
                                                  yAxisTicks: [160,170,180,190,200,210,220,230],
                                                  onColor: Yellow
                                  Die Beschriftung, X- und Y Achse sind zu sehen, allerdings kein Diagramm.
                                  Ich nehme an, ich hab wieder irgendwas mit den Geräten falsch gemacht... Da steh ich echt etwas auf dem Schlauch.
                                  Edit: nun bekomme ich in dem Skript eine Warnung:
                                  11:28:51.575	warn	javascript.0 (3809) TypeError: Cannot read properties of undefined (reading 'ts') at Object.cb (script.js.NSPanel.Chart_Gewächshaus:6976:54) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5809:71) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37) at processImmediate (node:internal/timers:476:21)
                                    TT-Tom @tobiasp last edited by TT-Tom
                                    @tobiasp
                                    Der Pfad beginnt mit einer 0_userdata.
                                      TT-Tom @PROcrastinator last edited by TT-Tom
                                      @procrastinator
                                      Welche Datenbank nutzt du eigentlich?? Du solltest nicht alles vermischen. Den Alias auf den Sensor ist okay. Auf den Alias musst du dann auch die Datenbank verknüpfen. Dann müssen auch erstmal Daten sammeln, um sie auszulesen.
                                        tobiasp @Armilar last edited by
                                        @armilar
                                        sorry mein fehler
                                        State "0_userdata.0.NSPanel.1.0_userdata.0.NSPanel.1.ScreensaverInfo.popupNotifyHeading" not found
                                        liegen tut dieser State bei
                                        Ich hab das Script von oben genommen
                                          @tobiasp sagte in SONOFF NSPanel mit Lovelace UI:
                                          @armilar
                                          sorry mein fehler
                                          Diesen Pfad gibt es bestimmt nicht.
                                          Das stimmt. Du kannst ohne Script die Werte in den Datenpunkten ändern. Dann sollte auf dem Screensaver etwas zu sehen sein. So lange es da Probleme gibt, wird das Script auch nicht funktionieren.
                                            @tt-tom
                                            AAah jetzt hab ich es gefunden. Da war echt in der Vorlage ein FEhler im Script. Danke für die Hilfe.
                                            lovelace ui nspanel sonoff
                                            270
                                            7680
                                            6496340
