    3. Off Topic
    4. Proxmox
    5. Proxmox LXC mit Frigate
      exitus last edited by exitus
      Hallo was ist an diesem config falsch
      detectors:
        cpu1:
          type: cpu
      database:
          path: /db/frigate.db
      mqtt:
        host: 172.16.0.10
        port: 1689
        user: admin
        password: passwort
      cameras:
        Parkplatz:
          ffmpeg:
            output_args:
              record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -st>
              rtmp: -c:v copy -c:a aac -f flv
            inputs:
      	  - path: rtsp://admin:passwort@172.16.0.147:554/Streaming/Channels/102/?trans>
                roles:
                  - detect
                  - path: rtsp://admin:passwort1@172.16.0.147:554/Streaming/Channels/101?tr>
                roles:
                  - record
          rtmp:
            enabled: False
      detect:
            width: 640
            height: 480
      objects:
            track:
              - person
              - car
              - dog
      snapshots:
            enabled: true
      	  timestamp: true
            bounding_box: true
            retain:
              default: 2
      record:
            enabled: true
            retain:
              days: 10
      was sind das für errors
      [2023-05-10 06:39:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
      [2023-05-10 06:39:24] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
      [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
      [2023-05-10 06:39:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
      [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5613b818fec0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
      [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
      [2023-05-10 06:39:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
      [2023-05-10 06:39:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
      [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
      [2023-05-10 06:39:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
      [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x565490d5b080] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
      [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
      [2023-05-10 06:39:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
      [2023-05-10 06:39:45] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
      [2023-05-10 06:39:46] ws4py                          INFO    : Terminating websocket [Local => 127.0.0.1:5002 | Remote => 127.0.0.1:51710]
      [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
      [2023-05-10 06:39:51] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
      [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55d19e0b4f40] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
      [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
      [2023-05-10 06:39:51] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
      [2023-05-10 06:39:55] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
      [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
      [2023-05-10 06:40:01] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
      [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c154580500] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
      [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
      [2023-05-10 06:40:01] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
      [2023-05-10 06:40:04] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
      [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
      [2023-05-10 06:40:11] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
      [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x561611bada80] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
      [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
      [2023-05-10 06:40:11] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
      [2023-05-10 06:40:14] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
      [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
      [2023-05-10 06:40:21] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
      [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55cdb7c11380] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
      [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
      [2023-05-10 06:40:21] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
      [2023-05-10 06:40:25] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
      [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
      [2023-05-10 06:40:31] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
      [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x555cad1cc4c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
      [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
      [2023-05-10 06:40:31] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
      [2023-05-10 06:40:35] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
      [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
      [2023-05-10 06:40:41] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
      [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x55c7da0535c0] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
      [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
      [2023-05-10 06:40:41] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      [cont-finish.d] executing container finish scripts...
      [cont-finish.d] done.
      [s6-finish] waiting for services.
      [s6-finish] sending all processes the TERM signal.
      [s6-finish] sending all processes the KILL signal and exiting.
      [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
      [s6-init] ensuring user provided files have correct perms...exited 0.
      [fix-attrs.d] applying ownership & permissions fixes...
      [fix-attrs.d] done.
      [cont-init.d] executing container initialization scripts...
      [cont-init.d] done.
      [services.d] starting services
      [services.d] done.
      [2023-05-10 06:40:49] frigate.app                    INFO    : Starting Frigate (0.11.1-2eada21)
      Starting migrations
      [2023-05-10 06:40:49] peewee_migrate                 INFO    : Starting migrations
      There is nothing to migrate
      [2023-05-10 06:40:49] peewee_migrate                 INFO    : There is nothing to migrate
      [2023-05-10 06:40:49] detector.cpu1                  INFO    : Starting detection process: 216
      [2023-05-10 06:40:49] frigate.app                    INFO    : Output process started: 218
      [2023-05-10 06:40:49] frigate.edgetpu                WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
      [2023-05-10 06:40:49] ws4py                          INFO    : Using epoll
      [2023-05-10 06:40:49] frigate.app                    INFO    : Camera processor started for Parkplatz: 222
      [2023-05-10 06:40:49] frigate.app                    INFO    : Capture process started for Parkplatz: 224
      [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: Unable to read frames from ffmpeg process.
      [2023-05-10 06:40:53] frigate.video                  ERROR   : Parkplatz: ffmpeg process is not running. exiting capture thread...
      [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : Ffmpeg process crashed unexpectedly for Parkplatz.
      [2023-05-10 06:41:09] watchdog.Parkplatz             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
      [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : [hevc_mp4toannexb @ 0x5621d50b8800] Codec 'h264' (27) is not supported by the bitstream filter 'hevc_mp4toannexb'. Supported codecs are: hevc (173)
      [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing bitstream filter: hevc_mp4toannexb
      [2023-05-10 06:41:09] ffmpeg.Parkplatz.detect        ERROR   : Error initializing output stream 0:0 --
      snapshot bewegung wird erkannt aber ich habe keine aufnahmen oder clips
      • Wal
        Wal Developer @exitus last edited by
        @exitus sagte in Proxmox LXC mit Frigate:
        output_args:
        Was möchtest du damit erreichen ?
        Wenn du was transcodieren möchtest nimmt man in frigate 0.12.0 go2rtc das ist mit dabei.
          exitus @Wal last edited by
          @wal eigentlich garnichts habe es irgendwo gefunden und eingefügt damit ich kein greenscreen habe.
          haben annke nc400 möchte das es erkennt und aufnimmt.
          Bei mir werden bilder gemach aber keine clips.
          Mein kamera sendet h264
          Wal 2 Replies Last reply Reply Quote 0
          • Wal
            Wal Developer @exitus last edited by Wal
            @exitus ,
            meine reolink auch und habe keinen Greenscreen.
              camera1:
                ffmpeg:
                  hwaccel_args: preset-vaapi
                  inputs:
                    - path: rtsp://admin:08154711@192.168.122.100:554/h264Preview_01_sub
                      roles:
                        - detect
                    - path: rtsp://admin:08154711@192.168.122.122:554/h264Preview_01_main
                      roles:
                        - record
                detect:
                  width: 640
                  height: 360
                mqtt:
                  enabled: False
            Greenscreen hatte ich mit einem Raspi4 mit aktivierter Hardwarebeschleunigung.
            • Wal
              @exitus ,
              lese gerade das die Kamera auch h265 kann.
              Hier ist ein Video für das Einbinden einer nc400, zwar für Hass aber das geht auch über frigate. Etwa bei 8:30 min
                wäre jemand nett und könnte mir helfen wie ich synology nas freigabe in meinem container wo frigate läuft mounten damit ich die aufnahmen auf dem nas habe.
                wäre nett wenn jemand schritt für schritt erklärt.
                gemout habe ich es bekommen aber wenn ich den frigate container starten möchte steht immer acces denied
                • Wal
                  @exitus ,
                  du machst das Laufwerk unter dem Proxmox Host verfügbar z.B. unter '/media/synology' so als wäre es ein normales Laufwerk.
                  Danach gibst du in der lxc.conf den Ordner für den Frigate LXC frei.
                  arch: amd64
                  cores: 4
                  features: keyctl=1,nesting=1
                  hostname: testfrigate
                  memory: 8192
                  mp0: /media/synology,mp=/media/frigate
                  danach ist der Ordner im LXC unter '/media/frigate' verfügbar und du kannst ihn im Docker hinzufügen.
                      volumes:
                        - /etc/localtime:/etc/localtime:ro
                        - /home/frigate/config/config.yml:/config/config.yml
                        - /media/frigate:/media/frigate
                    @wal das habe ich gemacht, ich kann auch über die Konsole vom lxc kann ich die freigabe sehen aber habe kein schreib zugriff.
                    Ich habe über den Host in fstab die freigabe eingetragen , über den Host habe ich die schreib und leserechte von der nas aber über die lxc container vo docker und frigate läuft nicht
                    • Wal
                      @exitus,
                      ok da kann ich jetzt nicht helfen.
                      Ich mache es anders rum, habe eine USB Festplatte als LXC-Backup und Datenspeicher eingerichtet und gebe diese über einen Samba LXC im Netzwerk frei. Damit habe ich Zugriff auf alle Dateien die ich im Proxmox speichere.
                      • Wal
                        @exitus ,
                        schau dir das mal an, könnte helfen.
                          @wal habe es geschafft jetz anderes problem habe 2 cameras beide machen screenshots dedection klappt bei einen habe ich clips bei den anderen nur bilder ohne clips wo kein clips sind ist die kamera mit der bezeichnung back
                          ier mein config
                          database:
                            path: /media/frigate/db/frigate.db
                          detectors:
                            cpu1:
                              type: cpu
                          ui:
                            use_experimental: false
                            live_mode: mse
                          mqtt:
                            host: 172.16.0.10
                            port: 12345
                            user: xxxxxxx
                            password: exxxxx
                          cameras:
                            back1:
                              ffmpeg:
                                inputs:
                                  - path: rtsp://admin:xxxxx@172.16.0.177:554/channel=2
                                    roles:
                                      - detect
                                      - rtmp
                                  - path: rtsp://admin:xxxxxxx@172.16.0.177:554/channel=1
                                    roles:
                                      - record
                            back:
                              ffmpeg:
                                inputs:
                                  - path: rtsp://admin:xxxxxxxx@172.16.0.147:554/Streaming/Channels/102?transportmode=unicast&profile=Profile_2
                                    roles:
                                      - detect
                                      - rtmp
                                    roles:
                                      - record
                          detect:
                                width: 640
                                height: 480
                                fps: 5
                          objects:
                                track:
                                  - person
                                  - dog
                                  - bicycle
                                  - cat
                                filters:
                                  person:
                                    min_score: 0.7
                                    threshold: 0.5
                                    min_area: 700
                          snapshots:
                                enabled: true
                                timestamp: true
                                bounding_box: true
                                crop: True
                                height: 500
                                retain:
                                  default: 1
                          record:
                            enabled: True
                            events:
                              retain:
                                default: 10
                          birdseye:
                            enabled: True
                            mode: continuous
                          • Wal
                            @exitus ,
                            schau mal im Adapter ob das dort eingeschaltet ist.
                              @wal bei mir steht OFF wo kann man es den einschalten im config ist ja true,
                              warum ist der eine on und der andere off
                              • Wal
                                @exitus ,
                                state ist nur der Status und mit Set kann man an und ausschalten.
                                  mein coral cpu ist das was habe ich gemacht habe unter proxmox wie auf der seite von coral installiert
                                  ausgabe lsusb
                                  Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                  Bus 003 Device 002: ID 8087:0029 Intel Corp. AX200 Bluetooth
                                  Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                  Bus 002 Device 002: ID 1a6e:089a Global Unichip Corp.
                                  Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                  Bus 001 Device 003: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                                  Bus 001 Device 002: ID 0451:16c8 Texas Instruments, Inc. CC2538 USB CDC
                                  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                  ls -l /dev/bus/usb/002/002
                                  crw-rw-r-- 1 root plugdev 189, 129 May 24 16:13 /dev/bus/usb/002/002
                                  lxc 117.conf
                                  arch: amd64
                                  cores: 6
                                  hostname: frigate
                                  memory: 8096
                                  net0: name=eth0,bridge=vmbr0,firewall=1,gw=172.16.0.1,hwaddr=22:88:33:2D:28:77,ip=172.1>
                                  ostype: debian
                                  rootfs: local-lvm:vm-117-disk-1,size=30G
                                  swap: 512
                                  lxc.cgroup.devices.allow: c 226:0 rwm
                                  lxc.cgroup.devices.allow: c 226:128 rwm
                                  lxc.cgroup.devices.allow: c 29:0 rwm
                                  lxc.cgroup.devices.allow: c 189:* rwm
                                  lxc.apparmor.profile: unconfined
                                  lxc.cgroup.devices.allow: a
                                  lxc.mount.entry: /dev/dri/renderD128 dev/dri/renderD128 none bind,optional,create=file >
                                  lxc.mount.entry: /dev/bus/usb/002/ dev/bus/usb/002/ none bind,optional,create=dir 0, 0
                                  lxc.cap.drop:
                                  lxc.mount.auto: cgroup:rw
                                  frigate conf
                                  database:
                                  detectors:
                                    coral:
                                      type: edgetpu
                                      device: usb
                                  ui:
                                    live_mode: mse
                                  mqtt:
                                    host: 172.16.0.10
                                    port: 1689
                                    user: so
                                    password: xxxxx
                                  record:
                                    enabled: True
                                    retain:
                                      days: 7
                                      mode: all
                                    events:
                                      retain:
                                        default: 30
                                  snapshots:
                                    enabled: True
                                    timestamp: False
                                    bounding_box: true
                                    retain:
                                      default: 90
                                  detect:
                                    stationary:
                                      max_frames:
                                        objects:
                                          person: 1200
                                  cameras:
                                    back1:
                                      ffmpeg:
                                        inputs:
                                          - path: rtsp://admin:xxxxxx@172.16.0.177:554/channel=2
                                            roles:
                                              - detect
                                              - rtmp
                                          - path: rtsp://admin:xxxxx@172.16.0.177:554/channel=1
                                            roles:
                                              - record
                                        output_args:
                                          record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c:v copy -c:a aac
                                      detect:
                                        width: 1280
                                        height: 720
                                      objects:
                                        track:
                                          - person
                                          - car
                                      record:
                                        events:
                                          required_zones:
                                            - street
                                            - all
                                      zones:
                                        street:
                                          coordinates: 352,544,416,519,476,513,502,334,472,199,391,107,325,127,261,136,62,162,45,347,59,430,207,535
                                          objects:
                                            - car
                                        all:
                                          objects:
                                            - person
                                      motion:
                                        mask:
                                          - 254,79,503,44,848,24,1113,43,1111,0,439,0,291,0,226,0,0,0,0,159
                                    back:
                                      ffmpeg:
                                        inputs:
                                          - path: rtsp://admin:xxxxxx@172.16.0.147:554/Streaming/Channels/102?transportmode=unicast&profile=Profile_2
                                            roles:
                                              - detect
                                              - rtmp
                                            roles:
                                              - record
                                      detect:
                                        width: 1280
                                        height: 720
                                      objects:
                                        track:
                                          - person
                                          - car
                                      record:
                                        events:
                                          required_zones:
                                            - street
                                            - all
                                      zones:
                                        street:
                                          coordinates: 470,676,592,583,1051,569,1257,341,1147,254,1063,247,779,299,536,378,476,471,389,399,332,473,241,427,293,647
                                          objects:
                                            - person
                                        #all:
                                          #coordinates: 472,57,526,64,1031,129,1060,95,941,30,504,26,376,0,175,0,0,0,33,169,191,143,360,110
                                          #objects:
                                           # - person
                                  ohne edge tpu ging es , habe detector auf edgetpu geänder seit dem habe ich kein bild kommt so für 1 sekunde und wider alles schwarz wie auf dem bild
                                  mein log vom docker
                                  2023-05-24 16:34:48.086320180
                                  2023-05-24 16:34:53.211082426  [2023-05-24 16:34:53] frigate.watchdog               INFO    : Detection appears to have stopped. Exiting Frigate...
                                  s6-rc: info: service legacy-services: stopping
                                  s6-rc: info: service legacy-services successfully stopped
                                  s6-rc: info: service nginx: stopping
                                  s6-rc: info: service go2rtc-healthcheck: stopping
                                  2023-05-24 16:34:53.227039323  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
                                  s6-rc: info: service go2rtc-healthcheck successfully stopped
                                  2023-05-24 16:34:53.305962172  [INFO] Service NGINX exited with code 0 (by signal 0)
                                  s6-rc: info: service nginx successfully stopped
                                  s6-rc: info: service nginx-log: stopping
                                  s6-rc: info: service frigate: stopping
                                  2023-05-24 16:34:53.309352767  [2023-05-24 16:34:53] frigate.app                    INFO    : Stopping...
                                  s6-rc: info: service nginx-log successfully stopped
                                  2023-05-24 16:34:53.311354844  [2023-05-24 16:34:53] frigate.watchdog               INFO    : Exiting watchdog...
                                  2023-05-24 16:34:53.312088389  [2023-05-24 16:34:53] frigate.storage                INFO    : Exiting storage maintainer...
                                  2023-05-24 16:34:53.312100611  [2023-05-24 16:34:53] frigate.stats                  INFO    : Exiting stats emitter...
                                  2023-05-24 16:34:53.312107805  [2023-05-24 16:34:53] frigate.record                 INFO    : Exiting recording maintenance...
                                  2023-05-24 16:34:53.320612754  [2023-05-24 16:34:53] frigate.record                 INFO    : Exiting recording cleanup...
                                  2023-05-24 16:34:53.321374794  [2023-05-24 16:34:53] frigate.events                 INFO    : Exiting event cleanup...
                                  2023-05-24 16:34:53.321393162  [2023-05-24 16:34:53] frigate.object_processing      INFO    : Exiting object processor...
                                  2023-05-24 16:34:53.571418465  [2023-05-24 16:34:53] frigate.comms.ws               INFO    : Exiting websocket client...
                                  2023-05-24 16:34:54.249977376  [2023-05-24 16:34:54] frigate.events                 INFO    : Exiting event processor...
                                  2023-05-24 16:34:54.250550076  [2023-05-24 16:34:54] peewee.sqliteq                 INFO    : writer received shutdown request, exiting.
                                  2023-05-24 16:34:54.259106288  [2023-05-24 16:34:54] watchdog.back                  INFO    : Terminating the existing ffmpeg process...
                                  2023-05-24 16:34:54.259777814  [2023-05-24 16:34:54] watchdog.back                  INFO    : Waiting for ffmpeg to exit gracefully...
                                  2023-05-24 16:34:54.266624376  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Terminating the existing ffmpeg process...
                                  2023-05-24 16:34:54.266775374  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Waiting for ffmpeg to exit gracefully...
                                  2023-05-24 16:34:54.383145698  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Terminating the existing ffmpeg process...
                                  2023-05-24 16:34:54.383311572  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Waiting for ffmpeg to exit gracefully...
                                  2023-05-24 16:34:54.415749456  [2023-05-24 16:34:54] watchdog.back                  INFO    : Terminating the existing ffmpeg process...
                                  2023-05-24 16:34:54.415853799  [2023-05-24 16:34:54] watchdog.back                  INFO    : Waiting for ffmpeg to exit gracefully...
                                  2023-05-24 16:34:54.637141769  [2023-05-24 16:34:54] frigate.output                 INFO    : exiting output process...
                                  2023-05-24 16:34:58.559268884  /usr/lib/python3.9/multiprocessing/resource_tracker.py:216: UserWarning: resource_tracker: There appear to be 13 leaked shared_memory objects to clean up at shutdown
                                  2023-05-24 16:34:58.559280338    warnings.warn('resource_tracker: There appear to be %d '
                                  2023-05-24 16:34:58.560386418  [INFO] Service Frigate exited with code 0 (by signal 0)
                                  s6-rc: info: service frigate successfully stopped
                                  s6-rc: info: service go2rtc: stopping
                                  s6-rc: info: service frigate-log: stopping
                                  2023-05-24 16:34:58.563280091  exit OK
                                  s6-rc: info: service frigate-log successfully stopped
                                  2023-05-24 16:34:58.570563372  [INFO] The go2rtc service exited with code 0 (by signal 0)
                                  s6-rc: info: service go2rtc successfully stopped
                                  s6-rc: info: service go2rtc-log: stopping
                                  s6-rc: info: service go2rtc-log successfully stopped
                                  s6-rc: info: service log-prepare: stopping
                                  s6-rc: info: service s6rc-fdholder: stopping
                                  s6-rc: info: service log-prepare successfully stopped
                                  s6-rc: info: service legacy-cont-init: stopping
                                  s6-rc: info: service s6rc-fdholder successfully stopped
                                  s6-rc: info: service legacy-cont-init successfully stopped
                                  s6-rc: info: service fix-attrs: stopping
                                  s6-rc: info: service fix-attrs successfully stopped
                                  s6-rc: info: service s6rc-oneshot-runner: stopping
                                  s6-rc: info: service s6rc-oneshot-runner successfully stopped
                                  s6-rc: info: service s6rc-fdholder: starting
                                  s6-rc: info: service s6rc-oneshot-runner: starting
                                  s6-rc: info: service s6rc-oneshot-runner successfully started
                                  s6-rc: info: service fix-attrs: starting
                                  s6-rc: info: service s6rc-fdholder successfully started
                                  s6-rc: info: service fix-attrs successfully started
                                  s6-rc: info: service legacy-cont-init: starting
                                  s6-rc: info: service legacy-cont-init successfully started
                                  s6-rc: info: service log-prepare: starting
                                  s6-rc: info: service log-prepare successfully started
                                  s6-rc: info: service nginx-log: starting
                                  s6-rc: info: service go2rtc-log: starting
                                  s6-rc: info: service frigate-log: starting
                                  s6-rc: info: service nginx-log successfully started
                                  s6-rc: info: service go2rtc-log successfully started
                                  s6-rc: info: service go2rtc: starting
                                  s6-rc: info: service frigate-log successfully started
                                  s6-rc: info: service go2rtc successfully started
                                  s6-rc: info: service go2rtc-healthcheck: starting
                                  s6-rc: info: service frigate: starting
                                  s6-rc: info: service go2rtc-healthcheck successfully started
                                  s6-rc: info: service frigate successfully started
                                  s6-rc: info: service nginx: starting
                                  2023-05-24 16:35:03.269511637  [INFO] Preparing go2rtc config...
                                  s6-rc: info: service nginx successfully started
                                  s6-rc: info: service legacy-services: starting
                                  2023-05-24 16:35:03.274350536  [INFO] Starting Frigate...
                                  2023-05-24 16:35:03.274655883  [INFO] Starting NGINX...
                                  s6-rc: info: service legacy-services successfully started
                                  2023-05-24 16:35:03.544117376  [INFO] Starting go2rtc...
                                  2023-05-24 16:35:03.635953359  16:35:03.635 INF go2rtc version 1.2.0 linux/amd64
                                  2023-05-24 16:35:03.636486320  16:35:03.636 INF [api] listen addr=:1984
                                  2023-05-24 16:35:03.636814435  16:35:03.636 INF [rtsp] listen addr=:8554
                                  2023-05-24 16:35:03.637127674  16:35:03.637 INF [srtp] listen addr=:8443
                                  2023-05-24 16:35:03.637534711  16:35:03.637 INF [webrtc] listen addr=:8555
                                  2023-05-24 16:35:04.485742533  [2023-05-24 16:35:04] frigate.app                    INFO    : Starting Frigate (0.12.0-da3e197)
                                  2023-05-24 16:35:04.527219793  [2023-05-24 16:35:04] peewee_migrate                 INFO    : Starting migrations
                                  2023-05-24 16:35:04.531970132  [2023-05-24 16:35:04] peewee_migrate                 INFO    : There is nothing to migrate
                                  2023-05-24 16:35:04.549606158  [2023-05-24 16:35:04] detector.coral                 INFO    : Starting detection process: 429
                                  2023-05-24 16:35:04.554122319  [2023-05-24 16:35:04] frigate.app                    INFO    : Output process started: 431
                                  2023-05-24 16:35:04.561305867  [2023-05-24 16:35:04] frigate.app                    INFO    : Camera processor started for back1: 437
                                  2023-05-24 16:35:04.570196340  [2023-05-24 16:35:04] frigate.app                    INFO    : Camera processor started for back: 439
                                  2023-05-24 16:35:04.576351891  [2023-05-24 16:35:04] frigate.app                    INFO    : Capture process started for back1: 440
                                  2023-05-24 16:35:04.582484533  [2023-05-24 16:35:04] frigate.app                    INFO    : Capture process started for back: 444
                                  2023-05-24 16:35:13.274499111  [INFO] Starting go2rtc healthcheck service...
                                  • Wal
                                    @exitus ,
                                    in der docker.yml hast du die coral usb auch durchgereicht ?
                                    Die Treiber im Proxmox-Host sind auch installiert ?
                                      exitus @Wal last edited by exitus
                                      @wal proxmox host sind die treiber installiert die ausgabe von lsusb ist vom host
                                      mit der rechte meinst du doch
                                      /dev/bus/usb:/dev/bus/usb
                                      habe frigate so getstartet
                                      docker run --name frigate --privileged --shm-size=1g --mount type=tmpfs,target=/tmp/cache,tmpfs-size=2000000000 -v /shared/frigate/config:/config:rw -v /dev/bus/usb:/dev/bus/usb -v /etc/localtime:/etc/localtime:ro -v /shared/frigate:/media/frigate/clips:rw -v /shared/frigate/recordings:/media/frigate/recordings:rw -v /home/frigate:/media/frigate/db:rw --device-cgroup-rule="c 189:* rmw" --device=/dev/dri/renderD128 -d -p 5000:5000 -e FRIGATE_RTSP_PASSWORD='elajelaj-61' ghcr.io/blakeblackshear/frigate:stable
                                      • Wal
                                        das ist mir schon klar, heisst aber nicht das du das gemacht hast:
                                        echo "deb https://packages.cloud.google.com/apt coral-edgetpu-stable main" | sudo tee /etc/apt/sources.list.d/coral-edgetpu.list
                                        curl https://packages.cloud.google.com/apt/doc/apt-key.gpg | sudo apt-key add -
                                        sudo apt-get update
                                        sudo apt-get install libedgetpu1-std gasket-dkms
                                        und der aktuelle pve-kernel-header muss vorher auch installiert sein, wobei der gasket-dkms evtl. auch nur für die PCI Version installiert werden muss, weiß ich aber nicht da ich keine USB-Verdion habe.
                                          @wal
                                          sudo apt-get update
                                          Install the Edge TPU runtime:
                                          das habe ich gemacht unter proxmox host und im container
                                          • Wal
                                            @exitus ,
                                            ok da würde ich mal auf github beim frigate Projekt nachfragen, da man aus dem Log nicht viel herausziehen kann.
                                            176
                                            42728
