    4. JavaScript
    5. [Vorlage] Denon HEOS Script
    • NWH
      NWH @NWH last edited by
      @withstu
      Ich hätte eine Frage zu den Protokolleinträgen, bekomme plötzlich diese Warnmeldungnen
      heos.0
      Zeit
      debug
      Nachricht
      heos.0
      2022-11-15 08:51:24.698	warn	[Marantz SR7013] [setError] Player Marantz SR7013 has to many leader failures. Reboot. Activate "reboot on failure" in the configuration or reboot manually the device.
      heos.0
      2022-11-15 08:51:09.696	warn	[Marantz SR7013] [setError] Player Marantz SR7013 has to many leader failures. Reboot. Activate "reboot on failure" in the configuration or reboot manually the device.
      heos.0
      2022-11-15 08:50:54.695	warn	[Marantz SR7013] [setError] Player Marantz SR7013 has to many leader failures. Reboot. Activate "reboot on failure" in the configuration or reboot manually the device.
      heos.0
      2022-11-15 08:50:42.984	warn	[setLastError] result=fail,text=ID Not Valid,command=player/get_play_state
      heos.0
      2022-11-15 08:50:42.981	warn	[checkDuplicateRequest] Response timed out: player/get_play_state?pid=1784603970. Increase leader failure counter.
      heos.0
      heos.0
      2022-11-15 08:50:42.980	warn	[Werkstatt ] [setError] HEOS is not responding as expected. Request timed out. Update play state.
      heos.0
      2022-11-15 08:50:42.980	warn	[Werkstatt ] [setError] Player Werkstatt has to many failures. Reboot. Activate "reboot on failure" in the configuration or reboot manually the device.
      heos.0
      2022-11-15 08:50:42.980	warn	[Werkstatt ] [setError] Player Werkstatt has to many upnp failures. Reboot. Activate "reboot on failure" in the configuration or reboot manually the device.
      heos.0
      2022-11-15 08:50:42.979	warn	[Werkstatt ] [setError] Player Werkstatt has to many timeouts. Reboot. Activate "reboot on failure" in the configuration or reboot manually the device.
      Was ist hier nicht Richtig?
      • Olli_M
        Olli_M last edited by
        @withstu
        Hi
        also über mein Blockly schreibt er zwar die DP aber der Denon Ansich verändert nicht seine Laustärke.
        Es geht aber über diesen JS Befehl:
        setState('denon.0.zoneMain.volume', 47.5);
        Jetzt meine Frage bekomme ich da auch eine Bedinung rein wenn z.b. der Input auf TV ist Lautstärke XY
        Hätte 3 Bedingungen wo er die Lautstärke verändern müsste anhand vom Eingang.
        TV
        BD
        DVD
        Geht das mit JS?
        • Negalein
          Negalein Global Moderator @Olli_M last edited by
          @olli_m sagte in [Vorlage] Denon HEOS Script:
          siehe dazu deinen anderen Thread.
          Du musst nicht JS und Blockly mischen.
          Geht easy mit denon.0.zoneMain.volume und denon.0.zoneMain.selectInput
          Olli_M 1 Reply Last reply Reply Quote 0
          • Olli_M
            Olli_M @Negalein last edited by
            @negalein
            es geht ja eben nicht. Hab das Blockly nochmal neu aufgesetzt ohne den Aufruf des JS.
            Und wenn ich nur den JS Befehl nutze geht es ja nur da hab ich die Bedinung nicht drin.
            Aktuell ist nichts vermischt 🙂
            • Negalein
              hab dir drüben geantwortet
                Ratze last edited by
                Liebe HEOS Gemeinde vielleicht kann mir hier geholfen werden...
                Nach welchen Kriterien wird das Heos / Denon Gerät gesucht?
                Lediglich auf Port 1255?
                Muss das Heos Gerät im gleich Netzwerk wie der Adapter / IoBroker sein?
                Falls ja, gibt es eine einfache Möglichkeit eine feste IP-Adresse zu hinterlegen?
                Beides, der HEOS-Adapter und auch das Uhula Script finden keinen Player.
                Aus allen Netzen kann ich den Denon Home Player via IP-Adresse über Telnet mit Port 1255
                ansprechen.
                Bei Anfrage über IP-Adresse funktioniert das Routing anscheinend nur auf Port-Ebene evtl. nicht bis schlecht 😉 im Netzwerk
                Bin für jede Hilfe bzw. Tipps dankbar
                  withstu @Ratze last edited by withstu
                  @ratze Für die Suche der Player wird das Protokoll SSDP verwendet (https://de.m.wikipedia.org/wiki/Simple_Service_Discovery_Protocol), welches die Multicast Pakete der Player über UDP findet. Ich schaue mal, ob ich als Fallback zur automatischen Suche auch einen manuelle IP Konfiguration ermögliche. Die IP sollte dann aber statisch sein.
                  Zum Testen der SSDP Suche hatte ich mal folgendes Script im Adapter hinzugefügt. Vielleicht hilft es ja beim Debuggen:
                  https://github.com/withstu/ioBroker.heos/blob/main/test/node-ssdp/index.js
                    Ratze @withstu last edited by Ratze
                    @withstu
                    Super für die schnelle Antwort... 🙂
                    Habe gestern Abend noch den Home350 ins IoBroker Netz (gleiche 192.xxx.xxx.xxx/24) gehangen.
                    Über den UPNP Adapter wird er erkannt.
                    Also SSDP sagt mir inziwschen etwas und ich kann auch sehen wo er aktiv ist.
                    pi@Iobroker:~ $ npm list node-ssdp
                    /home/pi
                    `-- (empty)
                    pi@Iobroker:~ $ cd /opt/iobroker
                    pi@Iobroker:/opt/iobroker $ npm list node-ssdp
                    iobroker.inst@3.0.0 /opt/iobroker
                    +-- iobroker.discovery@3.1.0
                    | `-- node-ssdp@4.0.1 deduped
                    +-- iobroker.heos@1.10.0
                    +-- iobroker.javascript@6.1.4
                    | `-- node-ssdp@4.0.1
                    +-- iobroker.upnp@1.0.21
                    `-- node-ssdp@4.0.1
                    Über Telnet kann ich allerdings die Zustände / Statis des Home350 abfragen.
                    const searchTargetName = 'urn:schemas-denon-com:device:ACT-Denon:1'
                    Ich gehe mal davon aus, dass ACT-Denon:1 nicht unbedingt über Telnet mit Port 1255
                    zurückgegeben wird.
                    Der UPNP Adapter zeigt folgendes Ergebnis an
                      "type": "device",
                      "common": {
                        "name": "350SLE",
                        "extIcon": "http://192.xxx.xxx.xxx:60006"
                      "native": {
                        "ip": "192.xxx.xxx.xxx",
                        "port": 60006,
                        "uuid": "b63f6000-af30-1683-0080-00a96f0fdfe4",
                        "deviceType": "urn:schemas-denon-com:device:AiosDevice:1",
                        "manufacturer": "Denon",
                        "manufacturerURL": "http://www.denon.com",
                        "modelNumber": "Aios 6.0S",
                        "modelDescription": "",
                        "modelName": "Denon Home 350",
                        "modelURL": "",
                        "name": "350SLE"
                      "from": "system.adapter.upnp.0",
                      "user": "system.user.admin",
                      "ts": 1676664594189,
                      "_id": "upnp.0.350SLE.AiosDevice",
                      "acl": {
                        "object": 1636,
                        "owner": "system.user.admin",
                    Der Überblick was Telnet über heos://player/get_player_info? zurückgibt
                    heos://player/get_player_info?pid=-1234567890
                    {"heos": {"command": "player/get_player_info",
                    "result": "success", "message": "                     pid=-1234567890"},
                    "payload": {"name": "350SLE", "pid": -1234567890, "model": "D                     enon Home 350",
                    "version": "2.71.510", "ip": "192.xxx.xxxx.xxx", "network": "wifi"                     ,
                    "lineout": 0,
                    "serial": "BME27234567899"}}
                    Das Script ist im Einsatz, Debug gibt invalid Response State aus... macht aber eine Schleife
                    beide der Player Suche... Ich vermute das mein Home350 evtl. ein anderes Ergebnis als
                    zurück gibt.
                    Was ich noch gefunden habe...
                    https://support-de.denon.com/app/answers/detail/a_id/4720/~/netzwerk-anforderungen-fÜr-heos
                    Laut Denon Support-Seite sind folgende Voraussetzungen zu erfüllen
                    Der Bereich zwischen 50000 und 64999 für MediaRenderer und 60006 für Media Server.
                    Darüber hinaus ist für UPnP ein Multicast-Zugriff zu 239.255.255.250:1900 zusammen mit den entsprechenden "IGMP Control Messages" zu ermöglichen.
                    Wirklich vielen Dank... an alle die sich die Mühe machen Scripte und Adapter
                    für uns zu erstellen und dann die bereit sind Mensche wie mir zu helfen!!!
                    Dankesehr
                    Zum UPNP-Adapter https://github.com/Jey-Cee/ioBroker.upnp/blob/master/main.js
                    Dieser hat tatsähclich im Skript den Aufruf bzgl. SSDP-IP zu 239.255.255.250
                     let server = new Server({ssdpIp: '239.255.255.250'});
                    Und den Parameter bei der Suche
                    client.search('ssdp:all');
                    (Was mir bewusst ist, dass alle möglichen UPNP Geräte über die UPNP-Adapter Suche gefunden werden sollen)
                      Ratze last edited by Ratze
                      Danke für die Hilfe, habe in der Zwischenzeit den Player Home 350 eingebunden.
                      Netzwerke nochmals kontrolliert Multicast auf dem Wifi-Netz freigegeben.
                      Änderung im Script
                      const searchTargetName = 'urn:schemas-denon-com:device:AiosDevice:1';
                      Zappp... Ist der HEOS-Player aufgetaucht.
                      danke danke... Danke @Uhula für das Script... Super arbeit!
                      Ups mit ist da etwas entgangen!
                      Herr @withstu ... ich möchte mich für den HEOS-Adapter Bedanken (WOW)
                      und noch mal Danke für den Einsatz.
                        bouster last edited by
                        ich hatte das Skript etwa 2 Jahr am laufen jetzt und es hat alles problemlos für meine Zwecke (Umschalten des Eingangs, Start, Stop, Pause, Weiter, Zurück, Lauter, Leiser) geklappt.
                        Seit Februar wird leider kein Player mehr erkannt.
                        Ich finde das alte skript aus 2019, das neue aus 2020 und auch im HEOS adapter keine Player mehr. Der Heos adapter startet jedoch den im Netzwerk befindlichen HEOS Amp etwa alle 5-10 min neu.
                        Mit ist noch aufgefallen, dass das Skript keine meldung signed in gibt und auch der signed in status false zurück gibt, obwohl ich sowohl im HEOS adapter als auch im Skript die Logindaten angegeben habe und mehrfach auf richtigkeit geprüft (sie haben ja auch 2 Jahre lang funktioniert).
                        Da ich aber nichts an den Einstellungen noch am Skript verändert habe ist es mir ein Rätsel wo der Fehler liegen könnte der sich eingeschlichen hat.
                        Leider sind meine Kenntnisse in diesem Bereich nicht so groß und ich habe das meiste mit Hilfe diverser Tutorials eingerichtet. Meine Fehlersuche beschränkt sich bis jetzt auf das verstehen der Log Meldungen. Wenn ich das Skript starte erhalte ich folgende Log Einträge:
                        javascript.1
                        	15550	2023-05-17 12:02:16.818	info	script.js.Heos.Heos_2020: [Heos] still searching for HEOS devices ...
                        javascript.1
                        	15550	2023-05-17 12:01:46.817	info	script.js.Heos.Heos_2020: [Heos] still searching for HEOS devices ...
                        javascript.1
                        	15550	2023-05-17 12:01:16.817	info	script.js.Heos.Heos_2020: [Heos] still searching for HEOS devices ...
                        javascript.1
                        	15550	2023-05-17 12:00:46.817	info	script.js.Heos.Heos_2020: [Heos] still searching for HEOS devices ...
                        javascript.1
                        	15550	2023-05-17 12:00:16.815	info	script.js.Heos.Heos_2020: [Heos] still searching for HEOS devices ...
                        javascript.1
                        	15550	2023-05-17 11:59:46.815	info	script.js.Heos.Heos_2020: [Heos] still searching for HEOS devices ...
                        javascript.1
                        	15550	2023-05-17 11:59:16.814	info	script.js.Heos.Heos_2020: [Heos] still searching for HEOS devices ...
                        javascript.1
                        	15550	2023-05-17 11:58:46.814	info	script.js.Heos.Heos_2020: [Heos] still searching for HEOS devices ...
                        admin.0
                        	4495	2023-05-17 11:58:19.744	info	<== Disconnect system.user.admin from ::ffff:192.xxx.xxx.xxx javascript
                        admin.0
                        javascript.1
                        	15550	2023-05-17 11:58:16.867	warn	Object of state "0_userdata.0.heos.connected" is missing the required property "common.type"
                        javascript.1
                        	15550	2023-05-17 11:58:16.814	info	script.js.Heos.Heos_2020: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        javascript.1
                        	15550	2023-05-17 11:58:16.806	info	script.js.Heos.Heos_2020: [Heos] searching for HEOS devices ...
                        javascript.1
                        	15550	2023-05-17 11:58:16.775	info	Start javascript script.js.Heos.Heos_2020
                        Für den Heos Adapter sieht es wie folgt aus:
                        heos.0
                        	19051	2023-05-17 12:03:06.253	info	searching for HEOS devices ...
                        heos.0
                        	19051	2023-05-17 12:03:06.025	info	starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.heos, node: v14.21.3, js-controller: 4.0.23
                        host.raspberrypi
                        		2023-05-17 12:03:03.125	info	instance system.adapter.heos.0 started with pid 19051
                        host.raspberrypi
                        		2023-05-17 12:03:02.944	info	"system.adapter.heos.0" enabled
                        Kann mir jemand bei der Fehlersuche behilflich sein? Gibt es einen anderen Ansatzpunkt (HEOS Adapter Update, JS Adapter Update?), warum die Verbindung plötzlich nicht mehr funktioniert?
                        • DJMarc75
                          DJMarc75 @bouster last edited by
                          @bouster sagte in [Vorlage] Denon HEOS Script:
                          Vermutlich das System noch nie so richtig auf Stand gebracht.
                          Zeig mal bitte die Ausgabe von
                          iob diag
                            bouster @DJMarc75 last edited by
                            @djmarc75
                            iob diag gibt folgendes aus:
                            iobroker [command]
                            Commands:
                              iobroker setup                                               Setup ioBroker
                              iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                              iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                              iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                              iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                              iobroker info                                                Shows the host info
                              iobroker logs [<adapter>]                                    Monitor log
                              iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                              iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                              iobroker rebuild [<module>]                                  Rebuild all native modules or path
                              iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                              iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                              iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                              iobroker update [<repositoryUrl>]                            Update repository and list adapters
                              iobroker upgrade                                             Upgrade management
                              iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                              iobroker object                                              Object management  [aliases: o]
                              iobroker state                                               State management  [aliases: s]
                              iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                              iobroker list <type> [<filter>]                              List all entries, like objects
                              iobroker chmod <mode> <file>                                 Change file rights
                              iobroker chown <user> <group> <file>                         Change file ownership
                              iobroker touch <file>                                        Touch file
                              iobroker rm <file>                                           Remove file
                              iobroker file                                                File management
                              iobroker user                                                User commands
                              iobroker group                                               group management
                              iobroker host <hostname>                                     Set host to given hostname
                              iobroker set <adapter>.<instance>                            Change settings of adapter config
                              iobroker license <license.file or license.text>              Update license by given file
                              iobroker cert                                                Certificate management
                              iobroker clean <yes>                                         Clears all objects and states
                              iobroker backup                                              Create backup
                              iobroker restore <backup name or path>                       Restore a specified backup
                              iobroker validate <backup name or path>                      Validate a specified backup
                              iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                              iobroker repo [<name>]                                       Show repo information
                              iobroker uuid                                                Show uuid of the installation  [aliases: id]
                              iobroker unsetup                                             Reset license, installation secret and language
                              iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                              iobroker multihost                                           Multihost management
                              iobroker compact                                             compact group management
                              iobroker plugin                                              Plugin management
                              iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                            Options:
                              --help  Show help  [boolean]
                              Über folgendes skirpt https://forum.iobroker.net/topic/59549/iob-diag-skript bekomme ich eine Menge sensible Informationen. Ich habe mal das was ich denke wichtig ist angehängt:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              No configuration change needed.
                              Multihost discovery server: disabled
                              Discovery authentication:   enabled
                              Persistent activation:      disabled
                              Objects:                    jsonl on 127.xxx.xxx.xxx
                              States:                     jsonl on 127.xxx.xxx.xxx
                              Core adapters versions
                              admin:          6.3.5
                              javascript:     6.1.4
                              Adapters from github:   1
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
                              + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                              + system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
                              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: xxxx
                              + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                              + system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
                              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: xxxx, bind: 192.xxx.xxx.xxx
                              + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                              + system.adapter.signal-cmb.0             : signal-cmb            : raspberrypi                              -  enabled
                              + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: xxxx, bind: 192.xxx.xxx.xxx (SSL), run as: admin
                              + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: xxxx, bind: 0.0.0.0
                                system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
                              + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: xxxx, bind: 0.0.0.0 (SSL), run as: admin
                              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Contr
                              + instance is alive
                              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: xxxx, bind: 0.0.0.0 (SSL), run as: admin
                              + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: xxxx, bind: 192.xxx.xxx.xxx(SSL), run as: admin
                              ioBroker-Repositories
                              Active repo(s): stable
                              Installed ioBroker-Instances
                              Used repository: stable
                              Adapter    "admin"        : 6.3.5    , installed 6.3.5
                              Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                              Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                              Adapter    "heos"         : 1.10.0   , installed 1.10.0
                              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                              Adapter    "info"         : 1.9.26   , installed 1.9.26
                              Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                              Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
                              Adapter    "mqtt"         : 4.0.7    , installed 2.7.4  [Updatable]
                              Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
                              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                              Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
                              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                              Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                              • DJMarc75
                                ok, dann bitte folgende Befehle ausführen
                                iob stop
                                iob fix
                                iob start
                                iob diag
                                Um Dir helfen zu können die Ausgabe von iob diag komplett inklusive Eingabe und Ausgabe posten - sonst wird das nix 🙂
                                  @djmarc75
                                  ok, also das hat schonmal funktioniert. Jetzt läuft es mit dem Befehl 🙂
                                  Da ich etwas paranoid bin (evtl auch gerade weil ich mich nicht so gut auskenne) habe ich den Teil der IP adressen entfernt, wenn der auch nötig ist würde ich ihn lieber nicht ganz so öffentlich teilen.
                                  Ich hoffe hiermit lässt sich arbeiten.
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Model           : Raspberry Pi 4 Model B Rev 1.5
                                  Architecture    : aarch64
                                  Docker          : false
                                  Virtualization  : none
                                  Distributor ID: Raspbian
                                  Description:    Raspbian GNU/Linux 11 (bullseye)
                                  Release:        11
                                  Codename:       bullseye
                                  PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                                  NAME="Raspbian GNU/Linux"
                                  VERSION_ID="11"
                                  VERSION="11 (bullseye)"
                                  VERSION_CODENAME=bullseye
                                  ID=raspbian
                                  ID_LIKE=debian
                                  HOME_URL="http://www.raspbian.org/"
                                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                  Systemuptime and Load:
                                   15:26:29 up 20:50,  3 users,  load average: 2.51, 1.95, 1.15
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  Other values than 0x0 hint to temperature/voltage problems
                                  temp=43.3'C
                                  volt=0.8900V
                                  *** Time and Time Zones ***
                                                 Local time: Wed 2023-05-17 15:26:29 CEST
                                             Universal time: Wed 2023-05-17 13:26:29 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  xxxxx
                                  /home/xxxxx
                                  xxxxx adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi iobroker
                                  *** X-Server-Setup ***
                                  X-Server:       true
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            3.8G        1.3G        246M         40M        2.2G        2.5G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        1.3G        346M
                                           3794 M total memory
                                           1349 M used memory
                                           1887 M active memory
                                            796 M inactive memory
                                            246 M free memory
                                            303 M buffer memory
                                           1895 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       29G   19G  9.3G  67% /
                                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                  tmpfs          tmpfs     759M  2.7M  757M   1% /run
                                  /dev/loop0     squashfs   47M   47M     0 100% /snap/core18/2723
                                  /dev/loop2     squashfs  225M  225M     0 100% /snap/nextcloud/21522
                                  /dev/loop1     squashfs   47M   47M     0 100% /snap/core18/2748
                                  /dev/loop3     squashfs   44M   44M     0 100% /snap/snapd/18936
                                  /dev/loop4     squashfs   44M   44M     0 100% /snap/snapd/19124
                                  /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                  tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
                                  Show mounted filesystems (real ones only):
                                  TARGET                  SOURCE         FSTYPE   OPTIONS
                                  /                       /dev/mmcblk0p2 ext4     rw,noatime
                                  |-/snap/core18/2723     /dev/loop0     squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/nextcloud/21522 /dev/loop2     squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/core18/2748     /dev/loop1     squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/snapd/18936     /dev/loop3     squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/snapd/19124     /dev/loop4     squashfs ro,nodev,relatime,errors=continue
                                  `-/boot                 /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                  /var:
                                  8.4G    /var/
                                  6.9G    /var/lib
                                  4.7G    /var/lib/docker/overlay2
                                  1.9G    /var/lib/snapd
                                  Archived and active journals take up 136.0M in the file system.
                                  /opt/iobroker/backups:
                                  710M    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  273M    /opt/iobroker/iobroker-data/
                                  128M    /opt/iobroker/iobroker-data/files
                                  118M    /opt/iobroker/iobroker-data/backup-objects
                                  51M     /opt/iobroker/iobroker-data/files/javascript.admin
                                  38M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
                                  8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
                                  8.7M    /opt/iobroker/iobroker-data/objects.jsonl
                                  7.5M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.2afdfa2c.chunk.js.map
                                  7.1M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.21829349.chunk.js.map
                                  7.0M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.5d4fbf6a.chunk.js.map
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v14.21.3
                                  /usr/bin/node           v14.21.3
                                  /usr/bin/npm            6.14.18
                                  /usr/bin/npx            6.14.18
                                  nodejs:
                                    Installed: 14.21.3-deb-1nodesource1
                                    Candidate: 14.21.3-deb-1nodesource1
                                    Version table:
                                   *** 14.21.3-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                          100 /var/lib/dpkg/status
                                       12.22.12~dfsg-1~deb11u4 500
                                          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                  No problems detected
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  MULTIHOSTSERVICE/enabled: false
                                  admin:          6.3.5
                                  javascript:     6.1.4
                                  Adapter State
                                    system.adapter.heos.0                   : heos                  : raspberrypi                              - disabled
                                    system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
                                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_2ce58c1eff92eb11b66e214f3d98b6d1-if00-port0
                                  + instance is alive
                                  Objects and States
                                  Objects:        5151
                                  States:         3396
                                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  Hit:2 https://deb.nodesource.com/node_14.x buster InRelease
                                  Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:4 https://download.docker.com/linux/raspbian bullseye InRelease
                                  Reading package lists...
                                  Pending Updates: 3
                                  *** Listening Ports ***
                                  xxx
                                  2023-05-17 15:25:55.948  - info: info.0 (8811) Reading/updating systemdata.
                                  2023-05-17 15:25:57.044  - info: info.0 (8811) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                                  2023-05-17 15:25:57.201  - info: info.0 (8811) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                                  2023-05-17 15:25:57.421  - info: info.0 (8811) cpu Temp res = {"main":45.764,"cores":[],"max":45.764,"socket":[],"chipset":null}
                                  2023-05-17 15:25:59.584  - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 9066
                                  2023-05-17 15:25:59.658  - info: web.0 (8850) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v14.21.3, js-controller: 4.0.23
                                  2023-05-17 15:26:00.277  - info: web.0 (8850) Secure socket.io server listening on port 8082
                                  2023-05-17 15:26:00.309  - info: web.0 (8850) https server listening on port 8082
                                  2023-05-17 15:26:01.923  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x0017880109409518 LWA009
                                  2023-05-17 15:26:02.100  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x001788010c3c16d7 929003046301_03
                                  2023-05-17 15:26:02.700  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x0017880108d9874f LWA009
                                  2023-05-17 15:26:02.934  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x001788010c429b4b 929003046301_02
                                  2023-05-17 15:26:03.586  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 9141
                                  2023-05-17 15:26:03.915  - info: simple-api.0 (9066) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v14.21.3, js-controller: 4.0.23
                                  2023-05-17 15:26:04.063  - info: simple-api.0 (9066) Secure simpleAPI server listening on port 8087
                                  2023-05-17 15:26:04.064  - info: simple-api.0 (9066) Allow states only when user is owner: false
                                  2023-05-17 15:26:04.093  - info: simple-api.0 (9066) https server listening on port 8087
                                  2023-05-17 15:26:06.590  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x0017880109898696 440400982841
                                  2023-05-17 15:26:06.912  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x7cb03eaa0a0061c9 LIGHTIFY Indoor Flex RGBW
                                  2023-05-17 15:26:07.009  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x7cb03eaa0a0091da LIGHTIFY Indoor Flex RGBW
                                  2023-05-17 15:26:07.373  - info: backitup.0 (9141) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.21.3, js-controller: 4.0.23
                                  2023-05-17 15:26:07.407  - warn: zigbee.0 (8546) DeviceAvailability:Failed to ping 0x00178801098986f7 440400982841
                                  2023-05-17 15:26:07.539  - info: host.raspberrypi instance system.adapter.signal-cmb.0 started with pid 9461
                                  2023-05-17 15:26:07.596  - info: backitup.0 (9141) [iobroker] backup will be activated at 02:40 every 1 day(s)
                                  2023-05-17 15:26:10.877  - info: signal-cmb.0 (9461) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.signal-cmb, node: v14.21.3, js-controller: 4.0.23
                                  W Thomas Braun 2 Replies Last reply Reply Quote 0
                                    withstu @bouster last edited by
                                    @bouster Du könntest das Logging Level der Heos Instanz mal von Info auf Debug oder Silly ändern und schauen, was der Adapter so ausgibt. Ich habe bei mir übrigens die empfohlene Node Version 18 und npm 9 laufen. Vielleicht hilft bei dir bereits ein Update.
                                      bouster @withstu last edited by
                                      @withstu Das komische ist, dass es bis vor ca 2 Monaten problemlos funktioniert hat und von einem auf den anderen Tag nicht mehr. Das Update muss ich dann wohl mal angehen...
                                        @withstu ich habe nun alle geupdated. Raspbian von Buster auf Bullseye. Node auf 18 und npm auf 9. Dann ging der Adapter für ca. 10 min. Dann habe ich das Skript gestartet und kurz darauf läuft es nicht mehr. Skript wieder aus HEOS adapter neu starten hilft nicht. Beides verbindet wieder nicht mehr...
                                        DJMarc75 W 2 Replies Last reply Reply Quote 0
                                        • DJMarc75
                                          @bouster Ausgabe von
                                          iob diag
                                          nochmal bitte
                                            @djmarc75 said in [Vorlage] Denon HEOS Script:
                                            iob diag
                                            Skript v.2023-04-16
                                            *** BASE SYSTEM ***
                                            Docker          : false
                                            Release:        11
                                            Codename:       bullseye
                                            VERSION_ID="11"
                                            ID=raspbian
                                            ID_LIKE=debian
                                             20:16:29 up 58 min,  3 users,  load average: 6.77, 2.36, 1.62
                                            CPU threads: 4
                                            Raspberry only:
                                            throttled=0x0
                                            temp=40.4'C
                                            volt=0.8900V
                                                           Local time: Sun 2023-05-21 20:16:29 CEST
                                                       Universal time: Sun 2023-05-21 18:16:29 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            pi
                                            /home/pi
                                            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi iobroker
                                            X-Server:       true
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            3.8G        1.2G        707M         40M        1.9G        2.5G
                                            Swap:            99M          0B         99M
                                            Total:          3.9G        1.2G        807M
                                                     3794 M total memory
                                                     1200 M used memory
                                                     1853 M active memory
                                                      646 M inactive memory
                                                      707 M free memory
                                                      245 M buffer memory
                                                     1640 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            Raspberry only:
                                            oom events: 0
                                            *** FILESYSTEM ***
                                            /dev/root      ext4       29G   22G  6.7G  76% /
                                            /dev/loop0     squashfs   47M   47M     0 100% /snap/core18/2748
                                            /dev/loop1     squashfs   47M   47M     0 100% /snap/core18/2723
                                            /dev/mmcblk0p3 ext4       88G   24K   84G   1% /media/pi/b6462cb4-edb3-a74c-b924-794fd764376a
                                            |-/snap/core18/2748                                   /dev/loop0     squashfs ro,nodev,relatime,errors=continue
                                            |-/snap/core18/2723                                   /dev/loop1     squashfs ro,nodev,relatime,errors=continue
                                            `-/media/pi/b6462cb4-edb3-a74c-b924-794fd764376a /dev/mmcblk0p3 ext4     rw,nosuid,nodev,relatime,errors=remount-ro
                                            /var:
                                            11G     /var/
                                            6.9G    /var/lib
                                            4.8G    /var/lib/docker
                                            3.8G    /var/log
                                            Archived and active journals take up 1.7G in the file system.
                                            737M    /opt/iobroker/backups/
                                            275M    /opt/iobroker/iobroker-data/
                                            119M    /opt/iobroker/iobroker-data/backup-objects
                                            9.1M    /opt/iobroker/iobroker-data/objects.jsonl
                                            /usr/bin/nodejs         v18.16.0
                                            /usr/bin/node           v18.16.0
                                            /usr/bin/npm            9.5.1
                                            /usr/bin/npx            9.5.1
                                            nodejs:
                                              Installed: 18.16.0-deb-1nodesource1
                                              Candidate: 18.16.0-deb-1nodesource1
                                              Version table:
                                             *** 18.16.0-deb-1nodesource1 500
                                                    500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            js-controller:  4.0.24
                                            admin:          6.3.5
                                            javascript:     6.1.4
                                            Adapters from github:   0
                                            Adapter State
                                            + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                            + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 192.168.178.101
                                            + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 192.168.178.101 (SSL), run as: admin
                                            + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
                                            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
                                            + instance is alive
                                            Controller "js-controller": 4.0.24   , installed 4.0.24
                                            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                            Objects and States
                                            Objects:        5151
                                            States:         3385
                                            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                                            Pending Updates: 0
                                            xxx
                                            2023-05-21 20:09:38.649  - info: host.raspberrypi object deleted system.adapter.heos.1
                                            2023-05-21 20:09:38.653  - info: host.raspberrypi iobroker host.raspberrypi Deleting 22 state(s).
                                            2023-05-21 20:09:39.753  - info: host.raspberrypi iobroker exit 0
                                            2023-05-21 20:09:41.703  - info: admin.0 (22943) ==> Connected system.user.admin from ::ffff:192.168.178.84
                                            2023-05-21 20:10:16.793  - info: admin.0 (22943) <== Disconnect system.user.admin from ::ffff:192.168.178.84
                                            2023-05-21 20:10:33.806  - error: rpi2.0 (345) GPIO is not initialized!
                                            2023-05-21 20:11:33.780  - error: rpi2.0 (345) GPIO is not initialized!
                                            2023-05-21 20:12:33.774  - error: rpi2.0 (345) GPIO is not initialized!
                                            2023-05-21 20:13:21.759  - info: admin.0 (22943) ==> Connected system.user.admin from ::ffff:192.168.178.84
                                            2023-05-21 20:13:29.605  - info: admin.0 (22943) <== Disconnect system.user.admin from ::ffff:192.168.178.84
                                            2023-05-21 20:13:33.772  - error: rpi2.0 (345) GPIO is not initialized!
                                            2023-05-21 20:14:15.071  - info: heos.0 (3089) searching for HEOS devices ...
                                            2023-05-21 20:14:23.164  - info: heos.0 (3089) searching for HEOS devices ...
                                            2023-05-21 20:14:31.254  - info: heos.0 (3089) searching for HEOS devices ...
                                            2023-05-21 20:14:31.272  - warn: heos.0 (3089) rebooting player 192.168.178.23
                                            2023-05-21 20:14:37.186  - info: heos.0 (3089) searching for HEOS devices ...
                                            2023-05-21 20:14:46.836  - info: host.raspberrypi "system.adapter.heos.0" disabled
                                            2023-05-21 20:14:46.839  - info: host.raspberrypi stopInstance system.adapter.heos.0 (force=false, process=true)
                                            2023-05-21 20:14:46.851  - info: heos.0 (3089) Got terminate signal TERMINATE_YOURSELF
                                            2023-05-21 20:14:46.852  - info: heos.0 (3089) disconnecting from HEOS ...
                                            2023-05-21 20:14:46.855  - info: heos.0 (3089) disconnected from HEOS
                                            2023-05-21 20:14:46.857  - info: heos.0 (3089) terminating
                                            2023-05-21 20:14:46.859  - info: heos.0 (3089) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2023-05-21 20:14:46.933  - info: host.raspberrypi stopInstance system.adapter.heos.0 send kill signal
                                            2023-05-21 20:14:47.456  - info: host.raspberrypi instance system.adapter.heos.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            javascript template
                                            47
                                            349
                                            63816
