    4. Adapter LightControl 0.4.x Stable
      kukoratsch @Schmakus last edited by kukoratsch
      lightcontrol.0
      	2023-05-16 11:11:59.707	debug	[ AdaptiveCt ] adaptiveCtLinear="5429" adaptiveCtSolar="5895"
      lightcontrol.0
      	2023-05-16 11:11:59.707	debug	[ AdaptiveCt ] minCT="2700", maxCt="6500", sunset="1684264539905", sunrise="1684208029297", solarNoon="1684236284601"
      lightcontrol.0
      	2023-05-16 11:11:59.707	debug	[ AdaptiveCt // getAstroDate] sunsetDate="Tue May 16 2023 21:15:39 GMT+0200 (Mitteleuropäische Sommerzeit)", sunriseDate="Tue May 16 2023 05:33:49 GMT+0200 (Mitteleuropäische Sommerzeit)", solarNoonDate="Tue May 16 2023 13:24:44 GMT+0200 (Mitteleuropäische Sommerzeit)"
      lightcontrol.0
      	2023-05-16 11:11:59.707	debug	[ getAstroDate ] getAstroDate(pattern=solarNoon, date=Tue May 16 2023 12:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)) => Tue May 16 2023 13:24:44 GMT+0200 (Mitteleuropäische Sommerzeit)
      lightcontrol.0
      	2023-05-16 11:11:59.706	debug	[ getAstroDate ] getAstroDate(pattern=sunrise, date=Tue May 16 2023 12:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)) => Tue May 16 2023 05:33:49 GMT+0200 (Mitteleuropäische Sommerzeit)
      lightcontrol.0
      	2023-05-16 11:11:59.706	debug	[ getAstroDate ] getAstroDate(pattern=sunset, date=Tue May 16 2023 12:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)) => Tue May 16 2023 21:15:39 GMT+0200 (Mitteleuropäische Sommerzeit)
      lightcontrol.0
      	2023-05-16 11:11:59.706	debug	[ AdaptiveCt ] minCT="2700", maxCt="6500", CtRange="3800"
      lightcontrol.0
      	2023-05-16 11:11:30.905	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.ct changed: 3300 (ack = true)
      lightcontrol.0
      	2023-05-16 11:11:30.812	debug	Reaching SetCt, Group="Wohnzimmer" Ct="3300"
      lightcontrol.0
      	2023-05-16 11:11:30.812	info	[ SetColorMode ] Device="0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch" Val="false
      lightcontrol.0
      	2023-05-16 11:11:30.809	info	[ SetColorMode ] Device="0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch" Val="false
      lightcontrol.0
      	2023-05-16 11:11:30.802	info	[ SetColorMode ] Device="milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode" Val="false
      lightcontrol.0
      	2023-05-16 11:11:30.796	info	[ SetColorMode ] Device="milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode" Val="false
      lightcontrol.0
      	2023-05-16 11:11:30.747	info	[ SetColorMode ] Reaching for Group="Wohnzimmer"
      lightcontrol.0
      	2023-05-16 11:11:30.747	info	[ WhiteSubstituteColor ] Reaching for Group="Wohnzimmer" = "Wohnzimmer" LightGroups[Group].power="true" LightGroups[Group].color="#FFFFFF
      lightcontrol.0
      	2023-05-16 11:11:30.747	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.color changed: #FFFFFF (ack = true)
      lightcontrol.0
      	2023-05-16 11:11:30.717	info	[ SetColor ] Reaching for Group="Wohnzimmer" power="true" Color="#FFFFFF"
      lightcontrol.0
      	2023-05-16 11:11:30.717	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.bri changed: 0 (ack = true)
      lightcontrol.0
      	2023-05-16 11:11:30.622	debug	[ setDeviceBri ] Switching with Power State is activated. Min. Brightness is defined with 2%. Actual Brightness = "0"
      lightcontrol.0
      	2023-05-16 11:11:30.621	debug	[ setDeviceBri ] Switching with Brightness is activated. No min. Brightness needed. Actual Brightness = "0"
      lightcontrol.0
      	2023-05-16 11:11:30.621	debug	[ setDeviceBri ] Switching with Power State is activated. Min. Brightness is defined with 2%. Actual Brightness = "0"
      lightcontrol.0
      lightcontrol.0
      	2023-05-16 11:11:30.621	debug	[ SetBrightness ] Reaching for Group="Wohnzimmer", Brightness="0, PowerState="true"
      lightcontrol.0
      	2023-05-16 11:11:30.620	info	[ PowerOnAfterCare ] Now setting bri to 0% for Group="Wohnzimmer"
      lightcontrol.0
      	2023-05-16 11:11:30.620	info	[ PowerOnAfterCare ] Reaching for Group="Wohnzimmer" bri="0" ct="3300" color="#FFFFFF"
      lightcontrol.0
      	2023-05-16 11:11:30.620	debug	[ SetLightState ] Set State "All.anyOn" to true from function="GroupPowerOnOff"
      lightcontrol.0
      	2023-05-16 11:11:30.619	debug	[ onStateChange ] state lightcontrol.0.All.power changed: true (ack = true)
      lightcontrol.0
      	2023-05-16 11:11:30.615	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.power changed: true (ack = true)
      lightcontrol.0
      	2023-05-16 11:11:30.605	info	[ SimpleGroupPowerOnOff ] Simple power on without ramping for Group="Wohnzimmer"
      lightcontrol.0
      	2023-05-16 11:11:30.502	debug	[ SimpleGroupPowerOnOff ] Switching on Decke (0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power) with power state
      lightcontrol.0
      	2023-05-16 11:11:30.502	debug	[ SimpleGroupPowerOnOff ] Switching on Spot (0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri) with brightness state
      lightcontrol.0
      	2023-05-16 11:11:30.501	debug	[ setDeviceBri ] Switching with Brightness is activated. No min. Brightness needed. Actual Brightness = "0"
      lightcontrol.0
      	2023-05-16 11:11:30.501	warn	[ SimpleGroupPowerOnOff ] Can't switching on for Light = "Decke vorn" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}}
      lightcontrol.0
      	2023-05-16 11:11:30.501	debug	[ SimpleGroupPowerOnOff ] Switching on Decke vorne (alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne) with power state
      lightcontrol.0
      	2023-05-16 11:11:30.501	debug	[ SimpleGroupPowerOnOff ] Switching on Decke hinten (alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten) with power state
      lightcontrol.0
      	2023-05-16 11:11:30.501	warn	[ SimpleGroupPowerOnOff ] Can't switching on for Light = "hinten" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
      lightcontrol.0
      	2023-05-16 11:11:30.501	warn	[ SimpleGroupPowerOnOff ] Can't switching on for Light = "vorne" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
      lightcontrol.0
      	2023-05-16 11:11:30.500	debug	[ GroupPowerOnOff ] Reaching for Group="Wohnzimmer", OnOff="true" rampOn="false" - {"enabled":false,"time":10,"switchOutletsLast":true} rampOff="false" - {"enabled":false,"time":10,"switchOutletsLast":false}
      lightcontrol.0
      	2023-05-16 11:11:30.500	info	[ Controller ] Reaching, Group="Wohnzimmer" Property="power" NewVal="true", OldVal=false"
      lightcontrol.0
      	2023-05-16 11:11:30.500	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.power changed: true (ack = false)
      lightcontrol.0
      	2023-05-16 11:11:26.485	debug	[ SetLightState ] Set State "All.anyOn" to false from function="GroupPowerOnOff"
      lightcontrol.0
      	2023-05-16 11:11:26.441	debug	[ onStateChange ] state lightcontrol.0.All.power changed: false (ack = true)
      lightcontrol.0
      	2023-05-16 11:11:26.439	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.power changed: false (ack = true)
      lightcontrol.0
      	2023-05-16 11:11:26.432	info	[ SimpleGroupPowerOnOff ] Simple power off without ramping for Group="Wohnzimmer"
      lightcontrol.0
      	2023-05-16 11:11:26.325	debug	[ SimpleGroupPowerOnOff ] Switching off Decke (0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power) with power state
      lightcontrol.0
      	2023-05-16 11:11:26.324	debug	[ SimpleGroupPowerOnOff ] Switching off Spot (0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri) with brightness state
      lightcontrol.0
      	2023-05-16 11:11:26.324	debug	[ setDeviceBri ] Switching with Brightness is activated. No min. Brightness needed. Actual Brightness = "0"
      lightcontrol.0
      	2023-05-16 11:11:26.324	warn	[ SimpleGroupPowerOnOff ] Can't switching off for Light = "Decke vorn" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}}
      lightcontrol.0
      	2023-05-16 11:11:26.324	debug	[ SimpleGroupPowerOnOff ] Switching off Decke vorne (alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne) with power state
      lightcontrol.0
      	2023-05-16 11:11:26.324	debug	[ SimpleGroupPowerOnOff ] Switching off Decke hinten (alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten) with power state
      lightcontrol.0
      	2023-05-16 11:11:26.323	warn	[ SimpleGroupPowerOnOff ] Can't switching off for Light = "hinten" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
      lightcontrol.0
      	2023-05-16 11:11:26.323	warn	[ SimpleGroupPowerOnOff ] Can't switching off for Light = "vorne" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
      lightcontrol.0
      	2023-05-16 11:11:26.323	debug	[ GroupPowerOnOff ] Reaching for Group="Wohnzimmer", OnOff="false" rampOn="false" - {"enabled":false,"time":10,"switchOutletsLast":true} rampOff="false" - {"enabled":false,"time":10,"switchOutletsLast":false}
      lightcontrol.0
      	2023-05-16 11:11:26.322	info	[ Controller ] Reaching, Group="Wohnzimmer" Property="power" NewVal="false", OldVal=true"
      lightcontrol.0
      	2023-05-16 11:11:26.322	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.power changed: false (ack = false)
      lightcontrol.0
      	2023-05-16 11:10:59.917	debug	[ SetLightState ] Set State "All.anyOn" to true from function="noFunction"
      lightcontrol.0
      	2023-05-16 11:10:59.874	debug	[ onStateChange ] state lightcontrol.0.All.power changed: true (ack = true)
      lightcontrol.0
      	2023-05-16 11:10:59.825	info	Successfully activated LightControl for 22 of 22 states, will do my Job until you stop me!
      lightcontrol.0
      	2023-05-16 11:10:59.825	debug	[ InitCustomStates ] subscribed all foreign objects to detect (de)activation of LightControl enabled states
      lightcontrol.0
      	2023-05-16 11:10:59.823	info	Initialization of 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch successfully
      lightcontrol.0
      	2023-05-16 11:10:59.823	debug	[ buildStateDetailsArray ] completed for 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch.
      lightcontrol.0
      	2023-05-16 11:10:59.822	debug	[ buildStateDetailsArray ] Type: Light, in Group: Wohnzimmer with Lights: [{"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke hinten","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_brightness_hinten","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_hinten","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorne","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}},{"description":"Spot","bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri","minVal":0,"maxVal":100,"defaultBri":100,"useBri":true},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct","minVal":0,"maxVal":100,"sendCt":true},"color":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}] and Light: {"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}} with Index: 6
      lightcontrol.0
      	2023-05-16 11:10:59.823	debug	[ buildStateDetailsArray ] Updated LightGroups: {"Wohnzimmer":{"description":"Wohnzimmer","LuxSensor":"","lights":[{"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke hinten","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_brightness_hinten","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_hinten","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorne","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}},{"description":"Spot","bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri","minVal":0,"maxVal":100,"defaultBri":100,"useBri":true},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct","minVal":0,"maxVal":100,"sendCt":true},"color":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}],"sensors":[],"actualLux":0,"powerNewVal":true,"power":true,"dimmUp":false,"dimmDown":false,"dimmAmount":10,"bri":0,"ct":3300,"color":"#FFFFFF","adaptiveBri":false,"adaptiveCt":false,"adaptiveCtMode":"solar","adaptiveCtTime":"06:00","powerCleaningLight":false,"isMotion":false,"autoOffTimed":{"enabled":false,"autoOffTime":120,"noAutoOffWhenMotion":true,"noticeEnabled":false,"noticeBri":10,"noticeTime":10},"autoOffLux":{"enabled":false,"minLux":500,"dailyLock":false,"operator":">","dailyLockCounter":0},"autoOnMotion":{"enabled":false,"minLux":300,"bri":0,"color":"#FFFFFF"},"autoOnLux":{"enabled":false,"minLux":50,"bri":0,"color":"#FFFFFF","switchOnlyWhenPresence":true,"switchOnlyWhenNoPresence":false,"dailyLock":false,"operator":"<","dailyLockCounter":0},"autoOnPresenceIncrease":{"enabled":false,"minLux":50,"bri":0,"color":"#FFFFFF"},"rampOn":{"enabled":false,"time":10,"switchOutletsLast":true},"rampOff":{"enabled":false,"time":10,"switchOutletsLast":false},"blink":{"enabled":false,"start":false,"frequency":1,"blinks":3,"bri":100,"color":"#FF0000"}},"All":{"powerNewVal":true,"power":true,"anyOn":true}}
      lightcontrol.0
      	2023-05-16 11:10:59.822	debug	[ buildLightGroupParameter ] customData {"enabled":true,"CtReverse":false,"defaultBri":"100","whiteModeVal":"false","colorModeVal":"true","colorType":"hex","defaultColor":"#FFFFFF","sendCt":true,"sendSat":true,"sendColor":true,"sendModeswitch":true,"useBri":true,"type":"light","func":"modeswitch","onVal":1,"offVal":0,"minVal":0,"maxVal":100,"motionVal":"On","noMotionVal":"Off","group":"Wohnzimmer","description":"Decke"}
      lightcontrol.0
      	2023-05-16 11:10:59.820	debug	[ buildStateDetailsArray ] started for 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch
      lightcontrol.0
      	2023-05-16 11:10:59.820	info	Initialization of 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct successfully
      lightcontrol.0
      	2023-05-16 11:10:59.820	debug	[ buildStateDetailsArray ] Updated LightGroups: {"Wohnzimmer":{"description":"Wohnzimmer","LuxSensor":"","lights":[{"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke hinten","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_brightness_hinten","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_hinten","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorne","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}},{"description":"Spot","bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri","minVal":0,"maxVal":100,"defaultBri":100,"useBri":true},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct","minVal":0,"maxVal":100,"sendCt":true},"color":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true}}],"sensors":[],"actualLux":0,"powerNewVal":true,"power":true,"dimmUp":false,"dimmDown":false,"dimmAmount":10,"bri":0,"ct":3300,"color":"#FFFFFF","adaptiveBri":false,"adaptiveCt":false,"adaptiveCtMode":"solar","adaptiveCtTime":"06:00","powerCleaningLight":false,"isMotion":false,"autoOffTimed":{"enabled":false,"autoOffTime":120,"noAutoOffWhenMotion":true,"noticeEnabled":false,"noticeBri":10,"noticeTime":10},"autoOffLux":{"enabled":false,"minLux":500,"dailyLock":false,"operator":">","dailyLockCounter":0},"autoOnMotion":{"enabled":false,"minLux":300,"bri":0,"color":"#FFFFFF"},"autoOnLux":{"enabled":false,"minLux":50,"bri":0,"color":"#FFFFFF","switchOnlyWhenPresence":true,"switchOnlyWhenNoPresence":false,"dailyLock":false,"operator":"<","dailyLockCounter":0},"autoOnPresenceIncrease":{"enabled":false,"minLux":50,"bri":0,"color":"#FFFFFF"},"rampOn":{"enabled":false,"time":10,"switchOutletsLast":true},"rampOff":{"enabled":false,"time":10,"switchOutletsLast":false},"blink":{"enabled":false,"start":false,"frequency":1,"blinks":3,"bri":100,"color":"#FF0000"}},"All":{"powerNewVal":true,"power":true,"anyOn":true}}
      lightcontrol.0
      	2023-05-16 11:10:59.819	debug	[ buildStateDetailsArray ] Type: Light, in Group: Wohnzimmer with Lights: [{"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke hinten","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_brightness_hinten","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_hinten","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorne","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}},{"description":"Spot","bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri","minVal":0,"maxVal":100,"defaultBri":100,"useBri":true},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct","minVal":0,"maxVal":100,"sendCt":true},"color":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true}}] and Light: {"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true}} with Index: 6
      lightcontrol.0
      	2023-05-16 11:10:59.820	debug	[ InitCustomStates ] Initialising (22 of 22) "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch"
      lightcontrol.0
      	2023-05-16 11:10:59.819	debug	[ buildLightGroupParameter ] customData {"enabled":true,"CtReverse":false,"defaultBri":"100","whiteModeVal":"false","colorModeVal":"true","colorType":"hex","defaultColor":"#FFFFFF","sendCt":true,"sendSat":true,"sendColor":true,"sendModeswitch":true,"useBri":true,"type":"light","func":"ct","onVal":1,"offVal":0,"minVal":2700,"maxVal":6500,"motionVal":"On","noMotionVal":"Off","group":"Wohnzimmer","description":"Decke"}
      lightcontrol.0
      	2023-05-16 11:10:59.819	debug	[ buildStateDetailsArray ] completed for 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct.
      lightcontrol.0
      	2023-05-16 11:10:59.817	debug	[ buildStateDetailsArray ] started for 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct
      lightcontrol.0
      	2023-05-16 11:10:59.817	debug	[ InitCustomStates ] Initialising (21 of 22) "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct"
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      lightcontrol.0
      Schmakus 1 Reply Last reply Reply Quote 0
      • Schmakus
        Schmakus Developer @kukoratsch last edited by
        @kukoratsch Das ist nicht das gesamte logging. bitte Adapter einmal neustarten. Welche Version ist installiert? bitte Namen der Lichter prüfen.
        K 2 Replies Last reply Reply Quote 0
          @schmakus Verision 1.2.16 Log ist zu gross
          neu 2.txt
            @schmakus sagte in Adapter LightControl 0.2.x Latest:
            @kukoratsch bitte Namen der Lichter prüfen.
            Das wahr mein Fehler. Danke
            • Schmakus
              Schmakus Developer @kukoratsch last edited by Schmakus
              @kukoratsch sagte in Adapter LightControl 0.2.x Latest:
              neu 2.txt
              Also:
              Lampe "vorne" hat keinen power oder state Datenpunkt
              Lampe "hinten" hat keinen power oder state Datenpunkt
              Lampe "Decke vorne" hat keinen power oder state Datenpunkt
              Und bitte lösche den ganzen Baum 0_userdata.0.lightcontrol_DEV.Lamps. Aufgrund eines Fehlers meinerseits hat es Datenpunkte bei dir angelegt, wo keine sein dürften. 😉
              Und zu guter Letzt: Bitte künftig bei den Logs auf LightControl filtern. Sonst suche ich mir einen Hirsch, wenn noch Logs von SourceAnalytix usw. dabei sind.
              	"Wohnzimmer": {
              		"description": "Wohnzimmer",
              		"LuxSensor": "",
              		"lights": [{
              			"description": "vorne",
              			"modeswitch": {
              				"oid": "milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode",
              				"whiteModeVal": false,
              				"colorModeVal": true,
              				"sendModeswitch": true
              			"description": "hinten",
              			"modeswitch": {
              				"oid": "milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode",
              			"description": "Decke hinten",
              			"bri": {
              				"oid": "alias.0.Wohnzimmer.Licht.Decke_brightness_hinten",
              				"minVal": 0,
              				"maxVal": 100,
              				"defaultBri": 100,
              				"useBri": false
              			"color": {
              				"oid": "alias.0.Wohnzimmer.Licht.Decke_RGB_hinten",
              				"colorType": "hex",
              				"defaultColor": "#FFFFFF",
              				"sendColor": true
              			"sat": {
              				"oid": "alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten",
              				"minVal": 0,
              				"maxVal": 100,
              				"sendCt": true
              			"power": {
              				"oid": "alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten",
              				"onVal": true,
              				"offVal": false
              			"ct": {
              				"oid": "alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten",
              				"minVal": 0,
              				"maxVal": 100,
              				"sendCt": true
              			"description": "Decke vorne",
              			"bri": {
              				"oid": "alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne",
              				"minVal": 0,
              				"maxVal": 100,
              				"defaultBri": 100,
              				"useBri": false
              			"sat": {
              				"oid": "alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne",
              				"minVal": 0,
              				"maxVal": 100,
              				"sendCt": true
              			"power": {
              				"oid": "alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne",
              				"onVal": true,
              				"offVal": false
              			"ct": {
              				"oid": "alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne",
              				"minVal": 0,
              				"maxVal": 100,
              				"sendCt": true
              			"description": "Decke vorn",
              			"color": {
              				"oid": "alias.0.Wohnzimmer.Licht.Decke_RGB_vorne",
              				"colorType": "hex",
              				"sendColor": true
              			"description": "Spot",
              			"bri": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri",
              				"minVal": 0,
              				"maxVal": 100,
              				"defaultBri": 100,
              				"useBri": true
              			"sat": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat",
              				"minVal": 0,
              				"maxVal": 100,
              				"sendCt": true
              			"ct": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct",
              				"minVal": 0,
              				"maxVal": 100,
              				"sendCt": true
              			"color": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX",
              				"colorType": "hex",
              				"sendColor": true
              			"modeswitch": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch",
              			"description": "Decke",
              			"power": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power",
              				"onVal": true,
              				"offVal": false
              			"bri": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri",
              				"minVal": 0,
              				"maxVal": 254,
              				"defaultBri": 254,
              				"useBri": false
              			"sat": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat",
              				"minVal": 0,
              				"maxVal": 100,
              				"sendCt": true
              			"ct": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct",
              				"minVal": 2700,
              				"maxVal": 6500,
              				"sendCt": true
              			"modeswitch": {
              				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch",
              		"sensors": [],
              		"actualLux": 0,
              		"powerNewVal": false,
              		"power": false,
              		"dimmUp": false,
              		"dimmDown": false,
              		"dimmAmount": 10,
              		"bri": 100,
              		"ct": 3300,
              		"color": "#FFFFFF",
              		"adaptiveBri": false,
              		"adaptiveCt": false,
              		"adaptiveCtMode": "solar",
              		"adaptiveCtTime": "06:00",
              		"powerCleaningLight": false,
              		"isMotion": false,
              		"autoOffTimed": {
              			"enabled": false,
              			"autoOffTime": 120,
              			"noAutoOffWhenMotion": true,
              			"noticeEnabled": false,
              			"noticeBri": 10,
              			"noticeTime": 10
              		"autoOffLux": {
              			"enabled": false,
              			"minLux": 500,
              			"dailyLock": false,
              			"operator": ">",
              			"dailyLockCounter": 0
              		"autoOnMotion": {
              			"enabled": false,
              			"minLux": 300,
              			"bri": 0,
              			"color": "#FFFFFF"
              		"autoOnLux": {
              			"enabled": false,
              			"minLux": 50,
              			"bri": 0,
              			"color": "#FFFFFF",
              			"switchOnlyWhenPresence": true,
              			"switchOnlyWhenNoPresence": false,
              			"dailyLock": false,
              			"operator": "<",
              		"autoOnPresenceIncrease": {
              			"enabled": false,
              			"minLux": 50,
              			"bri": 0,
              			"color": "#FFFFFF"
              		"rampOn": {
              			"enabled": false,
              			"time": 10,
              			"switchOutletsLast": true
              		"rampOff": {
              			"enabled": false,
              			"time": 10,
              			"switchOutletsLast": false
              		"blink": {
              			"enabled": false,
              			"start": false,
              			"frequency": 1,
              			"blinks": 3,
              			"bri": 100,
              			"color": "#FF0000"
              	"All": {
              		"powerNewVal": true,
              		"power": true,
              		"anyOn": true
                @schmakus Dankeschön jetzt läuft alles.
                • Schmakus
                  👍 Perfekt. Wenn noch was sein sollte, einfach hier melden oder auf Github ein Issue aufmachen.
                  Aktuell bin ich dran, die erste Stable zu veröffentlichen.
                  • M-A Hueb
                    M-A Hueb last edited by
                    Hat jemand diesen Adapter schon erfolgreich mit dem Shelly RGBW2 im Einsatz? Ich verwende den mit einem RGBWW-LED Streifen und würde gerne das im Tagesverlauf anpassende Licht verwenden.
                    Neuschwansteini Schmakus 2 Replies Last reply Reply Quote 0
                    • Neuschwansteini
                      Neuschwansteini @M-A Hueb last edited by
                      @m-a-hueb
                      ich hab 2 Instanzen, eine testet die Beleuchtung im Buero-Bad, das funktioniert von Anfang an sehr gut.
                      Leuchte ist ne Zigbee, die Helligkeitsregelung klappt.
                      Die andere Instanz ist fuer die Muellanzeige, steuert diverse Yeelight's mit verschiedenen Farben und blinkt, wenn die Tonne noch nicht draussen steht.
                      Ist die Tonne draussen, schalte ich in der Vis das Blinken aus. Spart mir hier einige Scripte und funktioniert seit langen auch sehr gut!
                      • Schmakus
                        Schmakus Developer @Neuschwansteini last edited by
                        @ilovegym sagte in Adapter LightControl 0.2.x Latest:
                        @m-a-hueb
                        Danke fürs Feedback, jedoch wieso 2 Instanzen? Weil du keine Lampe in mehreren Gruppen zuweisen kannst? Wenn ja, das ist eigentlich vorgesehen, jedoch gibt es seitens jsonCustom noch einen Bug, den ich aber selbst nicht beheben kann.
                        Neuschwansteini 1 Reply Last reply Reply Quote 0
                        • Schmakus
                          Schmakus Developer @M-A Hueb last edited by
                          @m-a-hueb sagte in Adapter LightControl 0.2.x Latest:
                          Shelly RGBW ist noch so ein Thema und ne offene Baustelle.... weil hier müsste auf den 8-stelligen HEX Code umgerechnet werden.
                          • M-A Hueb
                            @schmakus wäre es nicht leichter Hue einzubinden?
                            das kann der RGBW2 ja auch
                            • Schmakus
                              @m-a-hueb sagte in Adapter LightControl 0.2.x Stable:
                              Prinzipiell würde es keine Rolle spielen. Aktuell arbeitet AdaptiveCt ausschließlich mit der Farbtemperatur einer Lampe. Hier müsste man eventuell die Möglichkeit hinzufügen, die über die Farbe zu regeln. Kannst du hierzu ein Issue auf Github einstellen? Danke
                              • Neuschwansteini
                                Neuschwansteini @Schmakus last edited by
                                @schmakus
                                Hi, genau, ich möchte meine yeelights einmal in der Müllgruppe steuern und einmal mit dem Adapter in der Gruppe Wohnzimmer.. von daher hab ich nicht lange rumprobiert und einfach ne zweite Instanz angelegt.
                                • Schmakus
                                  @ilovegym sagte in Adapter LightControl 0.2.x Stable:
                                  @schmakus
                                  Perfekt. 😂 Aber wie erwähnt gibts noch nen Bug in der jsonConfig, was jedoch nichts mit dem Adapter zu tun hat. Ich hoffe, es wird bald gefixt. Dann benötigst keine 2 Instanzen mehr.
                                    thoml @Schmakus last edited by
                                    @schmakus
                                    Ich hab gleich mehrere Probleme..
                                    Ich hab eine Xiaomi Schreibtischlampe die über den Homekit-Controller gesteuert wird, der Farbtemparaturwert liegt zwischen 400 (warmweiß) und 208 (kaltweiß).
                                    Leider wird die nicht richtig angesteuert, wenn ich den ct Wert ändere wird in den Datenpunkt der Lampe '(null)' geschrieben.
                                    lightcontrol.0
                                    	2023-07-04 01:01:23.524	info	[ WhiteSubstituteColor ] Reaching for Group="BueroSchreibtisch" = "BueroSchreibtisch" LightGroups[Group].power="true" LightGroups[Group].color="#FFFFFF
                                    lightcontrol.0
                                    	2023-07-04 01:01:23.524	debug	[ onStateChange ] state lightcontrol.0.BueroSchreibtisch.ct changed: 3000 (ack = true)
                                    lightcontrol.0
                                    	2023-07-04 01:01:23.524	silly	States user redis pmessage lightcontrol.0.BueroSchreibtisch.ct/lightcontrol.0.BueroSchreibtisch.ct:{"val":3000,"ack":true,"ts":1688425283520,"q":0,"from":"system.adapter.lightcontrol.0","user":"system.user.admin","lc":1688425120310}
                                    lightcontrol.0
                                    	2023-07-04 01:01:23.468	debug	Reaching SetCt, Group="BueroSchreibtisch" Ct="3000"
                                    lightcontrol.0
                                    	2023-07-04 01:01:23.468	info	[ Controller ] Reaching, Group="BueroSchreibtisch" Property="ct" NewVal="3000", "
                                    lightcontrol.0
                                    	2023-07-04 01:01:23.468	debug	[ onStateChange ] state lightcontrol.0.BueroSchreibtisch.ct changed: 3000 (ack = false)
                                    lightcontrol.0
                                    	2023-07-04 01:01:23.468	silly	States user redis pmessage lightcontrol.0.BueroSchreibtisch.ct/lightcontrol.0.BueroSchreibtisch.ct:{"val":3000,"ack":false,"ts":1688425283462,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1688425120310}
                                    Unter der 0.2.17 läuft bei mir garnichts:
                                    [ GroupPowerOnOff ] No rampOn or rampOff datapoints available for Group = "FlurWohnen". Please check your config and restart the adapter!!
                                    Die Meldung gibt es für jede Gruppe.
                                    • Schmakus
                                      Schmakus Developer @thoml last edited by
                                      @thoml Hi, ich bräuchte einen Debug-Log.
                                      Bitte das logging des Adapters auf Debug Umstellen.
                                      Danach im Logging nach LightControl filtern und das logging posten. Danke!
                                        @schmakus Ups, den hatte ich eigenlich schon mit vorbereitet..
                                        lightcontrol_0-2-17.log
                                        • Schmakus
                                          @thoml Ich kann keinen Fehler beim Erstellen der Datenpunkte oder des internen Memory feststellen! Außer dass in der Gruppe "FlurGesammt" keine Lampen definiert sind.
                                          Du schreibst, dass die Farbtemperatur nicht richtig gesetzt wird?
                                            @schmakus
                                            Richtig, in den Datenpunkt für die Farbtemperatur der Lampe wird '(null)' geschrieben.
                                            Geht hier explizit um die Gruppe 'BueroSchreibtisch', mehr lampen mit CT hab ich aktuell nicht.
                                            31.7k
                                            79.8k
                                            light light control lightcontrol motion motion detection
                                            18
                                            117
                                            11147
