    5. [gelöst] Ausführung trotz Triggern Zeitplan
      woupi @Homoran last edited by
      @homoran sagte in Ausführung trotz Triggern Zeitplan:
      @woupi sagte in Ausführung trotz Triggern Zeitplan:
      meinst du den log komplett?
      die komplette Ausgabe, nicht nur das Summary
      Sorry, keine Ahnung was Du genau meinst. Ich habe gerade versucht den curent log unter "log Herunterladen" hierein zu kopieren. Zu Lang.
        Thomas Braun Most Active @woupi last edited by
        @woupi
        iob diag
        ausführen und den Output nach dem ersten Tastendruck vollständig hier rein kopieren.
          woupi @Thomas Braun last edited by
          bernhard@iobroker:~$ iob diag
          iobroker [command]
          Commands:
            iobroker setup                                               Setup ioBroker
            iobroker start [all|<adapter>.<instance>]                    Starts the js-con        troller or a specified adapter instance
            iobroker stop [<adapter>.<instance>]                         stops the js-cont        roller or a specified adapter instance
            iobroker restart [<adapter>.<instance>]                      Restarts js-contr        oller or a specified adapter instance  [aliases: r]
            iobroker debug <adapter>[.<instance>]                        Starts a Node.js        debugging session for the adapter instance
            iobroker info                                                Shows the host in        fo
            iobroker logs [<adapter>]                                    Monitor log
            iobroker add <adapter> [desiredNumber]                       Add instance of a        dapter  [aliases: a]
            iobroker install <adapter>                                   Installs a specif        ied adapter  [aliases: i]
            iobroker rebuild [<module>]                                  Rebuild all nativ        e modules or path
            iobroker url <url> [<name>]                                  Install adapter f        rom specified url, e.g. GitHub
            iobroker del <adapter>                                       Remove adapter an        d all instances from this host  [aliases: delete]
            iobroker del <adapter>.<instance>                            Remove adapter in        stance  [aliases: delete]
            iobroker update [<repositoryUrl>]                            Update repository        and list adapters
            iobroker upgrade                                             Upgrade managemen        t
            iobroker upload [all|<adapter>]                              Upload management        [aliases: u]
            iobroker object                                              Object management        [aliases: o]
            iobroker state                                               State management        [aliases: s]
            iobroker message <adapter>[.instance] <command> [<message>]  Send message to a        dapter instance/s
            iobroker list <type> [<filter>]                              List all entries,        like objects
            iobroker chmod <mode> <file>                                 Change file right        s
            iobroker chown <user> <group> <file>                         Change file owner        ship
            iobroker touch <file>                                        Touch file
            iobroker rm <file>                                           Remove file
            iobroker file                                                File management
            iobroker user                                                User commands
            iobroker group                                               group management
            iobroker host <hostname>                                     Set host to given        hostname
            iobroker set <adapter>.<instance>                            Change settings o        f adapter config
            iobroker license <license.file or license.text>              Update license by        given file
            iobroker cert                                                Certificate manag        ement
            iobroker clean <yes>                                         Clears all object        s and states
            iobroker backup                                              Create backup
            iobroker restore <backup name or path>                       Restore a specifi        ed backup
            iobroker validate <backup name or path>                      Validate a specif        ied backup
            iobroker status [all|<adapter>.<instance>]                   Status of ioBroke        r or adapter instance  [aliases: isrun]
            iobroker repo [<name>]                                       Show repo informa        tion
            iobroker uuid                                                Show uuid of the        installation  [aliases: id]
            iobroker unsetup                                             Reset license, in        stallation secret and language
            iobroker fix                                                 Execute the insta        llation fixer script, this updates your ioBroker installation
            iobroker multihost                                           Multihost managem        ent
            iobroker compact                                             compact group man        agement
            iobroker plugin                                              Plugin management
            iobroker version [<adapter>]                                 Show version of j        s-controller or specified adapter  [aliases: v]
          Options:
            --help  Show help  [boolean]
          Ich glaube, dass war nicht das was Du meintest, oder?
            Homoran Global Moderator Administrators @woupi last edited by
            doch!
            wie alt ist deine Installation?
              ca. 1 Jahr
                @woupi
                Doch. Aber dein System ist zu alt...
                iob stop
                iob fix
                iob start
                Wenn der ioBroker wieder läuft nochmal
                iob diag
                  @woupi dann ist was faul
                  curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                  Edit
                  erst einmal Thomas' Weg!!
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Architecture    : x86_64
                    Docker          : false
                    Virtualization  : kvm
                    Distributor ID: Ubuntu
                    Description:    Ubuntu 20.04.6 LTS
                    Release:        20.04
                    Codename:       focal
                    NAME="Ubuntu"
                    VERSION="20.04.6 LTS (Focal Fossa)"
                    ID=ubuntu
                    ID_LIKE=debian
                    PRETTY_NAME="Ubuntu 20.04.6 LTS"
                    VERSION_ID="20.04"
                    HOME_URL="https://www.ubuntu.com/"
                    SUPPORT_URL="https://help.ubuntu.com/"
                    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                    VERSION_CODENAME=focal
                    UBUNTU_CODENAME=focal
                    Systemuptime and Load:
                     21:24:21 up 7 days,  4:35,  1 user,  load average: 0.57, 0.76, 0.88
                    CPU threads: 8
                    *** Time and Time Zones ***
                                   Local time: Sat 2023-05-20 21:24:21 CEST
                               Universal time: Sat 2023-05-20 19:24:21 UTC
                                     RTC time: Sat 2023-05-20 19:24:22
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    bernhard
                    /home/bernhard
                    bernhard adm cdrom sudo dip plugdev lxd iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:           8.0G        1.0G        5.0G        1.0M        2.0G        6.6G
                    Swap:          1.2G          0B        1.2G
                    Total:         9.2G        1.0G        6.2G
                             7957 M total memory
                             1032 M used memory
                             1717 M active memory
                              817 M inactive memory
                             4954 M free memory
                              267 M buffer memory
                             1702 M swap cache
                             1224 M total swap
                                0 M used swap
                             1224 M free swap
                    *** FILESYSTEM ***
                    Filesystem                        Type      Size  Used Avail Use% Mounted on
                    udev                              devtmpfs  3.9G     0  3.9G   0% /dev
                    tmpfs                             tmpfs     796M  1.2M  795M   1% /run
                    /dev/mapper/ubuntu--vg-ubuntu--lv ext4       49G   13G   34G  28% /
                    tmpfs                             tmpfs     3.9G     0  3.9G   0% /dev/shm
                    tmpfs                             tmpfs     5.0M     0  5.0M   0% /run/lock
                    tmpfs                             tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                    /dev/sda2                         ext4      974M  209M  699M  23% /boot
                    /dev/loop1                        squashfs   56M   56M     0 100% /snap/core18/2745
                    /dev/loop0                        squashfs   56M   56M     0 100% /snap/core18/2721
                    /dev/loop4                        squashfs   92M   92M     0 100% /snap/lxd/24061
                    /dev/loop5                        squashfs   54M   54M     0 100% /snap/snapd/19122
                    /dev/loop3                        squashfs   64M   64M     0 100% /snap/core20/1879
                    /dev/loop6                        squashfs   92M   92M     0 100% /snap/lxd/23991
                    /dev/loop7                        squashfs   54M   54M     0 100% /snap/snapd/18933
                    /dev/loop8                        squashfs   64M   64M     0 100% /snap/core20/1891
                    tmpfs                             tmpfs     796M     0  796M   0% /run/user/1000
                    [Sat May 13 16:48:29 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
                    [Sat May 13 16:48:30 2023] EXT4-fs (dm-0): re-mounted. Opts: (null)
                    [Sat May 13 16:48:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                    Show mounted filesystems (real ones only):
                    TARGET                SOURCE                            FSTYPE   OPTIONS
                    /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
                    |-/sys/kernel/tracing tracefs                           tracefs  rw,nosuid,nodev,noexec,relatime
                    |-/boot               /dev/sda2                         ext4     rw,relatime
                    |-/snap/core18/2745   /dev/loop1                        squashfs ro,nodev,relatime
                    |-/snap/core18/2721   /dev/loop0                        squashfs ro,nodev,relatime
                    |-/snap/lxd/24061     /dev/loop4                        squashfs ro,nodev,relatime
                    |-/snap/snapd/19122   /dev/loop5                        squashfs ro,nodev,relatime
                    |-/snap/core20/1879   /dev/loop3                        squashfs ro,nodev,relatime
                    |-/snap/lxd/23991     /dev/loop6                        squashfs ro,nodev,relatime
                    |-/snap/snapd/18933   /dev/loop7                        squashfs ro,nodev,relatime
                    `-/snap/core20/1891   /dev/loop8                        squashfs ro,nodev,relatime
                    /var:
                    5.3G    /var/
                    4.0G    /var/log/journal/b8deab8c07c0438d8db0cb002e27450e
                    4.0G    /var/log
                    1.2G    /var/lib
                    Archived and active journals take up 3.9G in the file system.
                    /opt/iobroker/backups:
                    121M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    649M    /opt/iobroker/iobroker-data/
                    380M    /opt/iobroker/iobroker-data/files
                    110M    /opt/iobroker/iobroker-data/backup-objects
                    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                    76M     /opt/iobroker/iobroker-data/history
                    15M     /opt/iobroker/iobroker-data/objects.jsonl
                    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                    7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
                    6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
                    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v14.21.3
                    /usr/bin/node           v14.21.3
                    /usr/bin/npm            6.14.18
                    /usr/bin/npx            6.14.18
                    nodejs:
                      Installed: 14.21.3-deb-1nodesource1
                      Candidate: 14.21.3-deb-1nodesource1
                      Version table:
                     *** 14.21.3-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_14.x focal/main amd64 Packages
                            100 /var/lib/dpkg/status
                         10.19.0~dfsg-3ubuntu1 500
                            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                    No problems detected
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    MULTIHOSTSERVICE/enabled: false
                    Core adapters versions
                    js-controller:  4.0.24
                    admin:          6.3.5
                    javascript:     6.1.4
                    npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                    Adapters from github:   18
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      system.adapter.ble.0                    : ble                   : iobroker                                 -  enabled
                      system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                      system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                      system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.influxdb.3               : influxdb              : iobroker                                 -  enabled, port: 8086
                      system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
                    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                      system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
                      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                      system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                      system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
                      system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                      system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                      system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                      system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
                      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "admin"        : 6.3.5    , installed 6.3.5
                    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                    Adapter    "ble"          : 0.13.0   , installed 0.13.0
                    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
                    Adapter    "ical"         : 1.13.2   , installed 1.13.2
                    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                    Adapter    "info"         : 1.9.26   , installed 1.9.26
                    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                    Controller "js-controller": 4.0.24   , installed 4.0.24
                    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
                    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
                    Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                    Adapter    "shuttercontrol": 1.4.29  , installed 1.4.29
                    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                    Adapter    "vis"          : 1.4.16   , installed 1.4.16
                    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
                    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                    Objects and States
                    Objects:        14226
                    States:         12802
                    Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
                    Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                    Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
                    Hit:4 https://deb.nodesource.com/node_14.x focal InRelease
                    Hit:5 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
                    Reading package lists...
                    Pending Updates: 1
                    *** Listening Ports ***
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12560150   53281/iobroker.js-c
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12560149   53281/iobroker.js-c
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15672      1/init
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        23980      706/systemd-resolve
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27180      776/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       12558229   53440/node-red
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          17744      1/init
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12560197   53316/io.admin.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          27193      776/sshd: /usr/sbin
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        23979      706/systemd-resolve
                    udp        0      0 192.168.1.133:68        0.0.0.0:*                           100        8733747    704/systemd-network
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17741      1/init
                    udp6       0      0 :::111                  :::*                                0          16735      1/init
                    udp6       0      0 fe80::24bc:3cff:fe9:546 :::*                                100        23013      704/systemd-network
                    2023-05-20 21:24:36.460  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
                    2023-05-20 21:24:37.727  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
                    2023-05-20 21:24:37.779  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
                    2023-05-20 21:24:39.334  - info: host.iobroker instance system.adapter.mielecloudservice.0 started with pid 53732
                    2023-05-20 21:24:40.099  - info: mielecloudservice.0 (53732) starting. Version 6.5.4 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v14.21.3, js-controller: 4.0.24
                    2023-05-20 21:24:40.111  - info: mielecloudservice.0 (53732) Login attempt #1 @Miele-API
                    2023-05-20 21:24:40.450  - info: mielecloudservice.0 (53732) Access token expires on: 19.6.2023, 21:24:00
                    2023-05-20 21:24:40.450  - info: mielecloudservice.0 (53732) Registering for all appliance events at Miele API.
                    2023-05-20 21:24:40.452  - info: mielecloudservice.0 (53732) Initializing SSE watchdog.
                    2023-05-20 21:24:40.523  - info: mielecloudservice.0 (53732) Server Sent Events-Connection has been established @Miele-API.
                    2023-05-20 21:24:40.778  - info: mielecloudservice.0 (53732) Sorry. No programs to add for device: Trockner (000125877256). Reason: Device 000125877256 is not in the correct state.
                    2023-05-20 21:24:43.363  - info: host.iobroker instance scheduled system.adapter.weatherunderground.0 2 * * * *
                    2023-05-20 21:24:43.372  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 53771
                    2023-05-20 21:24:44.256  - info: weatherunderground.0 (53771) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.21.3, js-controller: 4.0.24
                    2023-05-20 21:24:44.860  - info: weatherunderground.0 (53771) WUnderground API returned 204, no data available. The configured station might be offline
                    2023-05-20 21:24:45.240  - error: weatherunderground.0 (53771) No current observation data found in response
                    2023-05-20 21:24:47.323  - info: host.iobroker instance scheduled system.adapter.ical.0 0,30 * * * *
                    2023-05-20 21:24:47.331  - info: host.iobroker instance system.adapter.ical.0 started with pid 53798
                    2023-05-20 21:24:48.222  - info: ical.0 (53798) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.21.3, js-controller: 4.0.24
                    2023-05-20 21:24:48.772  - info: weatherunderground.0 (53771) Terminated (NO_ERROR): Without reason
                    2023-05-20 21:24:49.313  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                    2023-05-20 21:24:49.761  - info: ical.0 (53798) processing URL: Müll https://calendar.google.com/calendar/ical/s.w.bernhard%40gmail.com/private-21faa25aa0eb243313582d9996cb7327/basic.ics
                    2023-05-20 21:24:51.326  - info: host.iobroker instance scheduled system.adapter.openweathermap.0 23 * * * *
                    2023-05-20 21:24:51.338  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 54645
                    2023-05-20 21:24:52.137  - info: openweathermap.0 (54645) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.21.3, js-controller: 4.0.24
                    iob diag has finished.
                    Press any key for a summary
                      Ansich nichts wirklich wildes.
                      Nur
                      nodejs v14.21.3
                      solltest du auf nodejs@18 updaten.
                      W Homoran 2 Replies Last reply Reply Quote 1
                        Ok, vielen Dank, werde ich morgen Früh gleich erledigen.
                        Wie oft sollte man das mit dem iob fix erledigen?
                          Kann man ab und an mal machen.
                            @thomas-braun sagte in Ausführung trotz Triggern Zeitplan:
                            Nur
                            nodejs v14.21.3
                            ich hab auch nichts gesehen, hatte orphans vermutet oder RO
                            Lediglich
                              Danke, so lernt man jeden Tag was dazu, auch in dem fast Rentenalter 😊
                                  @woupi @Homoran
                                  aber die Hälfte der Adapter aus dem github geangelt...
                                  Die räudige Katze ist NICHT der Standardweg um Adapter zu installieren, auch wenn das offenbar warum auch immer weit verbreitet zu sein scheint.
                                  W 1 Reply Last reply Reply Quote 2
                                    TT-Tom @woupi last edited by
                                    @woupi
                                    Du setzt die Variable mit dem Datenpunkt und möchtest du zwei Schritte weiter die Variable als Liste nutzen, das geht nicht. Du musst beim setzten der Variable Liste _PV eine leere Liste erzeugen. Dann kannst du die Variable auch als Liste nutzen.
                                    Zum Schluss schreibt man die Liste in den Datenpunkt.
                                    W Homoran 3 Replies Last reply Reply Quote 1
                                      ist mir so gar nicht bewusst gewesen, also ja an 2 kann ich mich direkt erinnern, aber 18.
                                      Kann ich irgendwie erkennen welche das sind?
                                        Thomas Braun Most Active @woupi last edited by Thomas Braun
                                        cd /opt/iobroker
                                        npm ls | grep github
                                          woupi @TT-Tom last edited by
                                          @tt-tom sagte in Ausführung trotz Triggern Zeitplan:
                                          @woupi
                                          das hatte ich oben am Anfang so bekommen:
                                          meins war so:
                                          W T 2 Replies Last reply Reply Quote 0
                                            woupi @woupi last edited by
                                            ├─┬ iobroker.energiefluss@3.6.0 (github:SKB-CGN/ioBroker.energiefluss#53944cad71449ceaa41c275f432df5423f218054)
                                            ├─┬ iobroker.icons-icons8@0.0.1 (github:ioBroker/ioBroker.icons-icons8#c0fcc9a6aa79b281951215cf86726f45622c8409)
                                            ├─┬ iobroker.icons-open-icon-library-png@0.1.3 (github:ioBroker/ioBroker.icons-open-icon-library-png#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                                            ├─┬ iobroker.shuttercontrol@1.4.29 (github:simatec/ioBroker.shuttercontrol#2c423fe0c8b2f0e0b385abaf912e93c3e1d39f36)
                                            ├─┬ iobroker.sourceanalytix@0.4.14 (github:DrozmotiX/ioBroker.sourceanalytix#42c45d3e9a581869b0ba9cf710dbecb42ca3e574)
                                            │   ├── github-url-from-git@1.5.0
                                            │   ├─┬ new-github-release-url@1.0.0
                                            ├── iobroker.vis-map@1.0.4 (github:ioBroker/ioBroker.vis-map#b4a286f8d954e09b1b96e51914386ae73b09eecf)
                                            ├── iobroker.vis-materialdesign@0.5.76 (github:Scrounger/ioBroker.vis-materialdesign#43f3a07d7b48f367612c19ef678935709f718aae)
                                            bernhard@iobroker:/opt/iobroker$
                                            Das sind 7, oder sehe ich das falsch und keine 18.
                                            Wenn ich euch richtig verstanden habe, sollte ich die alle deinstallieren, oder?
                                            19195
