    5. [gelöst] Ausführung trotz Triggern Zeitplan
      Thomas Braun Most Active @woupi last edited by
      @woupi
      Doch. Aber dein System ist zu alt...
      iob stop
      iob fix
      iob start
      Wenn der ioBroker wieder läuft nochmal
      iob diag
        Homoran Global Moderator Administrators @woupi last edited by
        @woupi dann ist was faul
        curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
        Edit
        erst einmal Thomas' Weg!!
          woupi @Thomas Braun last edited by
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Architecture    : x86_64
          Docker          : false
          Virtualization  : kvm
          Distributor ID: Ubuntu
          Description:    Ubuntu 20.04.6 LTS
          Release:        20.04
          Codename:       focal
          NAME="Ubuntu"
          VERSION="20.04.6 LTS (Focal Fossa)"
          ID=ubuntu
          ID_LIKE=debian
          PRETTY_NAME="Ubuntu 20.04.6 LTS"
          VERSION_ID="20.04"
          HOME_URL="https://www.ubuntu.com/"
          SUPPORT_URL="https://help.ubuntu.com/"
          BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
          PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
          VERSION_CODENAME=focal
          UBUNTU_CODENAME=focal
          Systemuptime and Load:
           21:24:21 up 7 days,  4:35,  1 user,  load average: 0.57, 0.76, 0.88
          CPU threads: 8
          *** Time and Time Zones ***
                         Local time: Sat 2023-05-20 21:24:21 CEST
                     Universal time: Sat 2023-05-20 19:24:21 UTC
                           RTC time: Sat 2023-05-20 19:24:22
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          bernhard
          /home/bernhard
          bernhard adm cdrom sudo dip plugdev lxd iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           8.0G        1.0G        5.0G        1.0M        2.0G        6.6G
          Swap:          1.2G          0B        1.2G
          Total:         9.2G        1.0G        6.2G
                   7957 M total memory
                   1032 M used memory
                   1717 M active memory
                    817 M inactive memory
                   4954 M free memory
                    267 M buffer memory
                   1702 M swap cache
                   1224 M total swap
                      0 M used swap
                   1224 M free swap
          *** FILESYSTEM ***
          Filesystem                        Type      Size  Used Avail Use% Mounted on
          udev                              devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs                             tmpfs     796M  1.2M  795M   1% /run
          /dev/mapper/ubuntu--vg-ubuntu--lv ext4       49G   13G   34G  28% /
          tmpfs                             tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs                             tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs                             tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
          /dev/sda2                         ext4      974M  209M  699M  23% /boot
          /dev/loop1                        squashfs   56M   56M     0 100% /snap/core18/2745
          /dev/loop0                        squashfs   56M   56M     0 100% /snap/core18/2721
          /dev/loop4                        squashfs   92M   92M     0 100% /snap/lxd/24061
          /dev/loop5                        squashfs   54M   54M     0 100% /snap/snapd/19122
          /dev/loop3                        squashfs   64M   64M     0 100% /snap/core20/1879
          /dev/loop6                        squashfs   92M   92M     0 100% /snap/lxd/23991
          /dev/loop7                        squashfs   54M   54M     0 100% /snap/snapd/18933
          /dev/loop8                        squashfs   64M   64M     0 100% /snap/core20/1891
          tmpfs                             tmpfs     796M     0  796M   0% /run/user/1000
          [Sat May 13 16:48:29 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
          [Sat May 13 16:48:30 2023] EXT4-fs (dm-0): re-mounted. Opts: (null)
          [Sat May 13 16:48:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
          Show mounted filesystems (real ones only):
          TARGET                SOURCE                            FSTYPE   OPTIONS
          /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
          |-/sys/kernel/tracing tracefs                           tracefs  rw,nosuid,nodev,noexec,relatime
          |-/boot               /dev/sda2                         ext4     rw,relatime
          |-/snap/core18/2745   /dev/loop1                        squashfs ro,nodev,relatime
          |-/snap/core18/2721   /dev/loop0                        squashfs ro,nodev,relatime
          |-/snap/lxd/24061     /dev/loop4                        squashfs ro,nodev,relatime
          |-/snap/snapd/19122   /dev/loop5                        squashfs ro,nodev,relatime
          |-/snap/core20/1879   /dev/loop3                        squashfs ro,nodev,relatime
          |-/snap/lxd/23991     /dev/loop6                        squashfs ro,nodev,relatime
          |-/snap/snapd/18933   /dev/loop7                        squashfs ro,nodev,relatime
          `-/snap/core20/1891   /dev/loop8                        squashfs ro,nodev,relatime
          /var:
          5.3G    /var/
          4.0G    /var/log/journal/b8deab8c07c0438d8db0cb002e27450e
          4.0G    /var/log
          1.2G    /var/lib
          Archived and active journals take up 3.9G in the file system.
          /opt/iobroker/backups:
          121M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          649M    /opt/iobroker/iobroker-data/
          380M    /opt/iobroker/iobroker-data/files
          110M    /opt/iobroker/iobroker-data/backup-objects
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          76M     /opt/iobroker/iobroker-data/history
          15M     /opt/iobroker/iobroker-data/objects.jsonl
          15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
          7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
          6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
          6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v14.21.3
          /usr/bin/node           v14.21.3
          /usr/bin/npm            6.14.18
          /usr/bin/npx            6.14.18
          nodejs:
            Installed: 14.21.3-deb-1nodesource1
            Candidate: 14.21.3-deb-1nodesource1
            Version table:
           *** 14.21.3-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x focal/main amd64 Packages
                  100 /var/lib/dpkg/status
               10.19.0~dfsg-3ubuntu1 500
                  500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     6.1.4
          npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
          Adapters from github:   18
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.ble.0                    : ble                   : iobroker                                 -  enabled
            system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
            system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
          + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.influxdb.3               : influxdb              : iobroker                                 -  enabled, port: 8086
            system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
          + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
          + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
            system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
            system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
            system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
            system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
            system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
            system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "backitup"     : 2.6.19   , installed 2.6.19
          Adapter    "ble"          : 0.13.0   , installed 0.13.0
          Adapter    "cloud"        : 4.3.0    , installed 4.3.0
          Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "flot"         : 1.11.0   , installed 1.11.0
          Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
          Adapter    "ical"         : 1.13.2   , installed 1.13.2
          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
          Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
          Adapter    "node-red"     : 4.0.0    , installed 4.0.0
          Adapter    "openweathermap": 0.3.3   , installed 0.3.3
          Adapter    "shelly"       : 6.3.1    , installed 6.3.1
          Adapter    "shuttercontrol": 1.4.29  , installed 1.4.29
          Adapter    "telegram"     : 1.15.2   , installed 1.15.2
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
          Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
          Adapter    "weatherunderground": 3.4.2, installed 3.4.2
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Objects and States
          Objects:        14226
          States:         12802
          Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
          Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
          Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
          Hit:4 https://deb.nodesource.com/node_14.x focal InRelease
          Hit:5 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
          Reading package lists...
          Pending Updates: 1
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12560150   53281/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12560149   53281/iobroker.js-c
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15672      1/init
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        23980      706/systemd-resolve
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27180      776/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       12558229   53440/node-red
          tcp6       0      0 :::111                  :::*                    LISTEN      0          17744      1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12560197   53316/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          27193      776/sshd: /usr/sbin
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        23979      706/systemd-resolve
          udp        0      0 192.168.1.133:68        0.0.0.0:*                           100        8733747    704/systemd-network
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17741      1/init
          udp6       0      0 :::111                  :::*                                0          16735      1/init
          udp6       0      0 fe80::24bc:3cff:fe9:546 :::*                                100        23013      704/systemd-network
          2023-05-20 21:24:36.460  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
          2023-05-20 21:24:37.727  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
          2023-05-20 21:24:37.779  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
          2023-05-20 21:24:39.334  - info: host.iobroker instance system.adapter.mielecloudservice.0 started with pid 53732
          2023-05-20 21:24:40.099  - info: mielecloudservice.0 (53732) starting. Version 6.5.4 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v14.21.3, js-controller: 4.0.24
          2023-05-20 21:24:40.111  - info: mielecloudservice.0 (53732) Login attempt #1 @Miele-API
          2023-05-20 21:24:40.450  - info: mielecloudservice.0 (53732) Access token expires on: 19.6.2023, 21:24:00
          2023-05-20 21:24:40.450  - info: mielecloudservice.0 (53732) Registering for all appliance events at Miele API.
          2023-05-20 21:24:40.452  - info: mielecloudservice.0 (53732) Initializing SSE watchdog.
          2023-05-20 21:24:40.523  - info: mielecloudservice.0 (53732) Server Sent Events-Connection has been established @Miele-API.
          2023-05-20 21:24:40.778  - info: mielecloudservice.0 (53732) Sorry. No programs to add for device: Trockner (000125877256). Reason: Device 000125877256 is not in the correct state.
          2023-05-20 21:24:43.363  - info: host.iobroker instance scheduled system.adapter.weatherunderground.0 2 * * * *
          2023-05-20 21:24:43.372  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 53771
          2023-05-20 21:24:44.256  - info: weatherunderground.0 (53771) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.21.3, js-controller: 4.0.24
          2023-05-20 21:24:44.860  - info: weatherunderground.0 (53771) WUnderground API returned 204, no data available. The configured station might be offline
          2023-05-20 21:24:45.240  - error: weatherunderground.0 (53771) No current observation data found in response
          2023-05-20 21:24:47.323  - info: host.iobroker instance scheduled system.adapter.ical.0 0,30 * * * *
          2023-05-20 21:24:47.331  - info: host.iobroker instance system.adapter.ical.0 started with pid 53798
          2023-05-20 21:24:48.222  - info: ical.0 (53798) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.21.3, js-controller: 4.0.24
          2023-05-20 21:24:48.772  - info: weatherunderground.0 (53771) Terminated (NO_ERROR): Without reason
          2023-05-20 21:24:49.313  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
          2023-05-20 21:24:49.761  - info: ical.0 (53798) processing URL: Müll https://calendar.google.com/calendar/ical/s.w.bernhard%40gmail.com/private-21faa25aa0eb243313582d9996cb7327/basic.ics
          2023-05-20 21:24:51.326  - info: host.iobroker instance scheduled system.adapter.openweathermap.0 23 * * * *
          2023-05-20 21:24:51.338  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 54645
          2023-05-20 21:24:52.137  - info: openweathermap.0 (54645) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.21.3, js-controller: 4.0.24
          iob diag has finished.
          Press any key for a summary
            @woupi sagte in Ausführung trotz Triggern Zeitplan:
            Ansich nichts wirklich wildes.
            Nur
            nodejs v14.21.3
            solltest du auf nodejs@18 updaten.
            W Homoran 2 Replies Last reply Reply Quote 1
              Ok, vielen Dank, werde ich morgen Früh gleich erledigen.
              Wie oft sollte man das mit dem iob fix erledigen?
                Kann man ab und an mal machen.
                  @thomas-braun sagte in Ausführung trotz Triggern Zeitplan:
                  Nur
                  nodejs v14.21.3
                  ich hab auch nichts gesehen, hatte orphans vermutet oder RO
                  Lediglich
                    Danke, so lernt man jeden Tag was dazu, auch in dem fast Rentenalter 😊
                      woupi @Homoran last edited by
                      @homoran sagte in Ausführung trotz Triggern Zeitplan:
                        @woupi @Homoran
                        aber die Hälfte der Adapter aus dem github geangelt...
                        Die räudige Katze ist NICHT der Standardweg um Adapter zu installieren, auch wenn das offenbar warum auch immer weit verbreitet zu sein scheint.
                        W 1 Reply Last reply Reply Quote 2
                          TT-Tom @woupi last edited by
                          @woupi
                          Du setzt die Variable mit dem Datenpunkt und möchtest du zwei Schritte weiter die Variable als Liste nutzen, das geht nicht. Du musst beim setzten der Variable Liste _PV eine leere Liste erzeugen. Dann kannst du die Variable auch als Liste nutzen.
                          Zum Schluss schreibt man die Liste in den Datenpunkt.
                          W Homoran 3 Replies Last reply Reply Quote 1
                            ist mir so gar nicht bewusst gewesen, also ja an 2 kann ich mich direkt erinnern, aber 18.
                            Kann ich irgendwie erkennen welche das sind?
                              Thomas Braun Most Active @woupi last edited by Thomas Braun
                              cd /opt/iobroker
                              npm ls | grep github
                                woupi @TT-Tom last edited by
                                @tt-tom sagte in Ausführung trotz Triggern Zeitplan:
                                @woupi
                                das hatte ich oben am Anfang so bekommen:
                                meins war so:
                                W T 2 Replies Last reply Reply Quote 0
                                  woupi @woupi last edited by
                                  ├─┬ iobroker.energiefluss@3.6.0 (github:SKB-CGN/ioBroker.energiefluss#53944cad71449ceaa41c275f432df5423f218054)
                                  ├─┬ iobroker.icons-icons8@0.0.1 (github:ioBroker/ioBroker.icons-icons8#c0fcc9a6aa79b281951215cf86726f45622c8409)
                                  ├─┬ iobroker.icons-open-icon-library-png@0.1.3 (github:ioBroker/ioBroker.icons-open-icon-library-png#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                                  ├─┬ iobroker.shuttercontrol@1.4.29 (github:simatec/ioBroker.shuttercontrol#2c423fe0c8b2f0e0b385abaf912e93c3e1d39f36)
                                  ├─┬ iobroker.sourceanalytix@0.4.14 (github:DrozmotiX/ioBroker.sourceanalytix#42c45d3e9a581869b0ba9cf710dbecb42ca3e574)
                                  │   ├── github-url-from-git@1.5.0
                                  │   ├─┬ new-github-release-url@1.0.0
                                  ├── iobroker.vis-map@1.0.4 (github:ioBroker/ioBroker.vis-map#b4a286f8d954e09b1b96e51914386ae73b09eecf)
                                  ├── iobroker.vis-materialdesign@0.5.76 (github:Scrounger/ioBroker.vis-materialdesign#43f3a07d7b48f367612c19ef678935709f718aae)
                                  bernhard@iobroker:/opt/iobroker$
                                  Das sind 7, oder sehe ich das falsch und keine 18.
                                  Wenn ich euch richtig verstanden habe, sollte ich die alle deinstallieren, oder?
                                    Nein, aber die Herangehensweise an Installationen überdenken. Zuerst immer aus den Repos nehmen, erst wenn es einen sehr guten Grund dafür gibt (z. B. weil der Maintainer was testen will) fischt man im github.
                                      @woupi
                                      Dann musst du nochmal prüfen, ob in dem DP wirklich eine Liste ist.
                                        Das habe ich auch versucht zu beachten.
                                        Shuttercontrol und energiefluss gibt es allerdings z.B. nur über die Katze.
                                        Mir war nicht klar, dass man die Adapter dann besser gar nicht installiert.
                                          Homoran Global Moderator Administrators @woupi last edited by Homoran
                                          Shuttercontrol ... gibt es allerdings z.B. nur über die Katze.
                                          whattt???
                                          schon jahrelang im stable
                                            @woupi
                                            Könntest Du mir sagen, wie ich das raus bekomme?
                                            Unter Wert steht (Null)
                                            19302
