    5. [gelöst] Ausführung trotz Triggern Zeitplan
      woupi @Thomas Braun last edited by
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : kvm
      Distributor ID: Ubuntu
      Description:    Ubuntu 20.04.6 LTS
      Release:        20.04
      Codename:       focal
      NAME="Ubuntu"
      VERSION="20.04.6 LTS (Focal Fossa)"
      ID=ubuntu
      ID_LIKE=debian
      PRETTY_NAME="Ubuntu 20.04.6 LTS"
      VERSION_ID="20.04"
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      VERSION_CODENAME=focal
      UBUNTU_CODENAME=focal
      Systemuptime and Load:
       21:24:21 up 7 days,  4:35,  1 user,  load average: 0.57, 0.76, 0.88
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Sat 2023-05-20 21:24:21 CEST
                 Universal time: Sat 2023-05-20 19:24:21 UTC
                       RTC time: Sat 2023-05-20 19:24:22
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      bernhard
      /home/bernhard
      bernhard adm cdrom sudo dip plugdev lxd iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           8.0G        1.0G        5.0G        1.0M        2.0G        6.6G
      Swap:          1.2G          0B        1.2G
      Total:         9.2G        1.0G        6.2G
               7957 M total memory
               1032 M used memory
               1717 M active memory
                817 M inactive memory
               4954 M free memory
                267 M buffer memory
               1702 M swap cache
               1224 M total swap
                  0 M used swap
               1224 M free swap
      *** FILESYSTEM ***
      Filesystem                        Type      Size  Used Avail Use% Mounted on
      udev                              devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs                             tmpfs     796M  1.2M  795M   1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4       49G   13G   34G  28% /
      tmpfs                             tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                             tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                             tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/sda2                         ext4      974M  209M  699M  23% /boot
      /dev/loop1                        squashfs   56M   56M     0 100% /snap/core18/2745
      /dev/loop0                        squashfs   56M   56M     0 100% /snap/core18/2721
      /dev/loop4                        squashfs   92M   92M     0 100% /snap/lxd/24061
      /dev/loop5                        squashfs   54M   54M     0 100% /snap/snapd/19122
      /dev/loop3                        squashfs   64M   64M     0 100% /snap/core20/1879
      /dev/loop6                        squashfs   92M   92M     0 100% /snap/lxd/23991
      /dev/loop7                        squashfs   54M   54M     0 100% /snap/snapd/18933
      /dev/loop8                        squashfs   64M   64M     0 100% /snap/core20/1891
      tmpfs                             tmpfs     796M     0  796M   0% /run/user/1000
      [Sat May 13 16:48:29 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
      [Sat May 13 16:48:30 2023] EXT4-fs (dm-0): re-mounted. Opts: (null)
      [Sat May 13 16:48:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      Show mounted filesystems (real ones only):
      TARGET                SOURCE                            FSTYPE   OPTIONS
      /                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
      |-/sys/kernel/tracing tracefs                           tracefs  rw,nosuid,nodev,noexec,relatime
      |-/boot               /dev/sda2                         ext4     rw,relatime
      |-/snap/core18/2745   /dev/loop1                        squashfs ro,nodev,relatime
      |-/snap/core18/2721   /dev/loop0                        squashfs ro,nodev,relatime
      |-/snap/lxd/24061     /dev/loop4                        squashfs ro,nodev,relatime
      |-/snap/snapd/19122   /dev/loop5                        squashfs ro,nodev,relatime
      |-/snap/core20/1879   /dev/loop3                        squashfs ro,nodev,relatime
      |-/snap/lxd/23991     /dev/loop6                        squashfs ro,nodev,relatime
      |-/snap/snapd/18933   /dev/loop7                        squashfs ro,nodev,relatime
      `-/snap/core20/1891   /dev/loop8                        squashfs ro,nodev,relatime
      /var:
      5.3G    /var/
      4.0G    /var/log/journal/b8deab8c07c0438d8db0cb002e27450e
      4.0G    /var/log
      1.2G    /var/lib
      Archived and active journals take up 3.9G in the file system.
      /opt/iobroker/backups:
      121M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      649M    /opt/iobroker/iobroker-data/
      380M    /opt/iobroker/iobroker-data/files
      110M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      76M     /opt/iobroker/iobroker-data/history
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
      6.9M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v14.21.3
      /usr/bin/node           v14.21.3
      /usr/bin/npm            6.14.18
      /usr/bin/npx            6.14.18
      nodejs:
        Installed: 14.21.3-deb-1nodesource1
        Candidate: 14.21.3-deb-1nodesource1
        Version table:
       *** 14.21.3-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x focal/main amd64 Packages
              100 /var/lib/dpkg/status
           10.19.0~dfsg-3ubuntu1 500
              500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
      Adapters from github:   18
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.ble.0                    : ble                   : iobroker                                 -  enabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
        system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
      + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.influxdb.3               : influxdb              : iobroker                                 -  enabled, port: 8086
        system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
        system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
        system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
        system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
        system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "ble"          : 0.13.0   , installed 0.13.0
      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
      Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "shuttercontrol": 1.4.29  , installed 1.4.29
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Objects and States
      Objects:        14226
      States:         12802
      Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
      Hit:4 https://deb.nodesource.com/node_14.x focal InRelease
      Hit:5 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12560150   53281/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12560149   53281/iobroker.js-c
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15672      1/init
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        23980      706/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27180      776/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       12558229   53440/node-red
      tcp6       0      0 :::111                  :::*                    LISTEN      0          17744      1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12560197   53316/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          27193      776/sshd: /usr/sbin
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        23979      706/systemd-resolve
      udp        0      0 192.168.1.133:68        0.0.0.0:*                           100        8733747    704/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17741      1/init
      udp6       0      0 :::111                  :::*                                0          16735      1/init
      udp6       0      0 fe80::24bc:3cff:fe9:546 :::*                                100        23013      704/systemd-network
      2023-05-20 21:24:36.460  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
      2023-05-20 21:24:37.727  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
      2023-05-20 21:24:37.779  - info: admin.0 (53316) failed connection to socket.io from ::ffff:192.168.1.108: Passport was not initialized
      2023-05-20 21:24:39.334  - info: host.iobroker instance system.adapter.mielecloudservice.0 started with pid 53732
      2023-05-20 21:24:40.099  - info: mielecloudservice.0 (53732) starting. Version 6.5.4 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v14.21.3, js-controller: 4.0.24
      2023-05-20 21:24:40.111  - info: mielecloudservice.0 (53732) Login attempt #1 @Miele-API
      2023-05-20 21:24:40.450  - info: mielecloudservice.0 (53732) Access token expires on: 19.6.2023, 21:24:00
      2023-05-20 21:24:40.450  - info: mielecloudservice.0 (53732) Registering for all appliance events at Miele API.
      2023-05-20 21:24:40.452  - info: mielecloudservice.0 (53732) Initializing SSE watchdog.
      2023-05-20 21:24:40.523  - info: mielecloudservice.0 (53732) Server Sent Events-Connection has been established @Miele-API.
      2023-05-20 21:24:40.778  - info: mielecloudservice.0 (53732) Sorry. No programs to add for device: Trockner (000125877256). Reason: Device 000125877256 is not in the correct state.
      2023-05-20 21:24:43.363  - info: host.iobroker instance scheduled system.adapter.weatherunderground.0 2 * * * *
      2023-05-20 21:24:43.372  - info: host.iobroker instance system.adapter.weatherunderground.0 started with pid 53771
      2023-05-20 21:24:44.256  - info: weatherunderground.0 (53771) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v14.21.3, js-controller: 4.0.24
      2023-05-20 21:24:44.860  - info: weatherunderground.0 (53771) WUnderground API returned 204, no data available. The configured station might be offline
      2023-05-20 21:24:45.240  - error: weatherunderground.0 (53771) No current observation data found in response
      2023-05-20 21:24:47.323  - info: host.iobroker instance scheduled system.adapter.ical.0 0,30 * * * *
      2023-05-20 21:24:47.331  - info: host.iobroker instance system.adapter.ical.0 started with pid 53798
      2023-05-20 21:24:48.222  - info: ical.0 (53798) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.21.3, js-controller: 4.0.24
      2023-05-20 21:24:48.772  - info: weatherunderground.0 (53771) Terminated (NO_ERROR): Without reason
      2023-05-20 21:24:49.313  - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2023-05-20 21:24:49.761  - info: ical.0 (53798) processing URL: Müll https://calendar.google.com/calendar/ical/s.w.bernhard%40gmail.com/private-21faa25aa0eb243313582d9996cb7327/basic.ics
      2023-05-20 21:24:51.326  - info: host.iobroker instance scheduled system.adapter.openweathermap.0 23 * * * *
      2023-05-20 21:24:51.338  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 54645
      2023-05-20 21:24:52.137  - info: openweathermap.0 (54645) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.21.3, js-controller: 4.0.24
      iob diag has finished.
      Press any key for a summary
        Thomas Braun Most Active @woupi last edited by
        @woupi sagte in Ausführung trotz Triggern Zeitplan:
        Ansich nichts wirklich wildes.
        Nur
        nodejs v14.21.3
        solltest du auf nodejs@18 updaten.
        W Homoran 2 Replies Last reply Reply Quote 1
          Ok, vielen Dank, werde ich morgen Früh gleich erledigen.
          Wie oft sollte man das mit dem iob fix erledigen?
            Kann man ab und an mal machen.
              @thomas-braun sagte in Ausführung trotz Triggern Zeitplan:
              Nur
              nodejs v14.21.3
              ich hab auch nichts gesehen, hatte orphans vermutet oder RO
              Lediglich
                Danke, so lernt man jeden Tag was dazu, auch in dem fast Rentenalter 😊
                  woupi @Homoran last edited by
                  @homoran sagte in Ausführung trotz Triggern Zeitplan:
                    @woupi @Homoran
                    aber die Hälfte der Adapter aus dem github geangelt...
                    Die räudige Katze ist NICHT der Standardweg um Adapter zu installieren, auch wenn das offenbar warum auch immer weit verbreitet zu sein scheint.
                    W 1 Reply Last reply Reply Quote 2
                      TT-Tom @woupi last edited by
                      @woupi
                      Du setzt die Variable mit dem Datenpunkt und möchtest du zwei Schritte weiter die Variable als Liste nutzen, das geht nicht. Du musst beim setzten der Variable Liste _PV eine leere Liste erzeugen. Dann kannst du die Variable auch als Liste nutzen.
                      Zum Schluss schreibt man die Liste in den Datenpunkt.
                      W Homoran 3 Replies Last reply Reply Quote 1
                        ist mir so gar nicht bewusst gewesen, also ja an 2 kann ich mich direkt erinnern, aber 18.
                        Kann ich irgendwie erkennen welche das sind?
                          Thomas Braun Most Active @woupi last edited by Thomas Braun
                          cd /opt/iobroker
                          npm ls | grep github
                            woupi @TT-Tom last edited by
                            @tt-tom sagte in Ausführung trotz Triggern Zeitplan:
                            @woupi
                            das hatte ich oben am Anfang so bekommen:
                            meins war so:
                            W T 2 Replies Last reply Reply Quote 0
                              woupi @woupi last edited by
                              ├─┬ iobroker.energiefluss@3.6.0 (github:SKB-CGN/ioBroker.energiefluss#53944cad71449ceaa41c275f432df5423f218054)
                              ├─┬ iobroker.icons-icons8@0.0.1 (github:ioBroker/ioBroker.icons-icons8#c0fcc9a6aa79b281951215cf86726f45622c8409)
                              ├─┬ iobroker.icons-open-icon-library-png@0.1.3 (github:ioBroker/ioBroker.icons-open-icon-library-png#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                              ├─┬ iobroker.shuttercontrol@1.4.29 (github:simatec/ioBroker.shuttercontrol#2c423fe0c8b2f0e0b385abaf912e93c3e1d39f36)
                              ├─┬ iobroker.sourceanalytix@0.4.14 (github:DrozmotiX/ioBroker.sourceanalytix#42c45d3e9a581869b0ba9cf710dbecb42ca3e574)
                              │   ├── github-url-from-git@1.5.0
                              │   ├─┬ new-github-release-url@1.0.0
                              ├── iobroker.vis-map@1.0.4 (github:ioBroker/ioBroker.vis-map#b4a286f8d954e09b1b96e51914386ae73b09eecf)
                              ├── iobroker.vis-materialdesign@0.5.76 (github:Scrounger/ioBroker.vis-materialdesign#43f3a07d7b48f367612c19ef678935709f718aae)
                              bernhard@iobroker:/opt/iobroker$
                              Das sind 7, oder sehe ich das falsch und keine 18.
                              Wenn ich euch richtig verstanden habe, sollte ich die alle deinstallieren, oder?
                                Nein, aber die Herangehensweise an Installationen überdenken. Zuerst immer aus den Repos nehmen, erst wenn es einen sehr guten Grund dafür gibt (z. B. weil der Maintainer was testen will) fischt man im github.
                                  @woupi
                                  Dann musst du nochmal prüfen, ob in dem DP wirklich eine Liste ist.
                                    Das habe ich auch versucht zu beachten.
                                    Shuttercontrol und energiefluss gibt es allerdings z.B. nur über die Katze.
                                    Mir war nicht klar, dass man die Adapter dann besser gar nicht installiert.
                                      Homoran Global Moderator Administrators @woupi last edited by Homoran
                                      Shuttercontrol ... gibt es allerdings z.B. nur über die Katze.
                                      whattt???
                                      schon jahrelang im stable
                                        @woupi
                                        Könntest Du mir sagen, wie ich das raus bekomme?
                                        Unter Wert steht (Null)
                                          meine ich, also, sonst hätte ich das auch normal installiert.
                                          Ist aber auch schon wieder etwas her, kann mich da auch jetzt vertun.
                                            19205
