    4. [Gelöst] Update Admin 4.2.2 -> 6.3.5 schlägt fehl
      Thomas Braun Most Active @cimba007 last edited by
      @cimba007
      https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
      C 1 Reply Last reply Reply Quote 1
        cimba007 @Thomas Braun last edited by
        @thomas-braun Danke ... leider hat das Upgrade erstmal das wlan zerschossen .. wieder 2 Stunden werkeln 🙂
          @cimba007
          Kann nicht sein, weil Server nicht per WLAN angebunden werden.
          Und selbst wenn, WLAN sollte in 0,nix wieder eingerichtet sein.
            cimba007 @Thomas Braun last edited by cimba007
            @thomas-braun Hat am Ende auch funktioniert. Mit der Anleitung habe ich jetzt sowohl bullseye, als auch nodejs auf die Version 18 gehoben.
            rflink sorgt jedoch immernoch für probleme.
            pi@raspberrypi:~ $ cd /opt/iobroker && npm prune
            npm WARN deprecated serialport@4.0.7: This version is no longer supported, to receive security updates and bug fixes upgrade to the latest version.
            npm WARN skipping integrity check for git dependency ssh://git@github.com/noopkat/js-stk500v1.git
            npm WARN deprecated debug@4.2.0: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. ()
            npm WARN cleanup Failed to remove some directories [
            npm WARN cleanup [
            npm WARN cleanup '/opt/iobroker/node_modules/avrgirl-arduino',
            npm WARN cleanup [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/build'] {
            npm WARN cleanup errno: -39,
            npm WARN cleanup code: 'ENOTEMPTY',
            npm WARN cleanup syscall: 'rmdir',
            npm WARN cleanup path: '/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/build'
            npm WARN cleanup }
            npm WARN cleanup ],
            npm WARN cleanup [
            npm WARN cleanup }
            npm WARN cleanup ]
            npm WARN cleanup ]
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings
            npm ERR! command failed
            npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
            npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build“ wird betreten
            npm ERR! CXX(target) Release/obj.target/bindings/src/serialport.o
            npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build“ wird verlassen
            npm ERR! gyp info it worked if it ends with ok
            npm ERR! gyp info using node-gyp@9.3.1
            npm ERR! gyp info using node@18.16.0 | linux | arm
            npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
            npm ERR! gyp info spawn /usr/bin/python3
            npm ERR! gyp info spawn args [
            npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
            npm ERR! gyp info spawn args 'binding.gyp',
            npm ERR! gyp info spawn args '-f',
            npm ERR! gyp info spawn args 'make',
            npm ERR! gyp info spawn args '-I',
            npm ERR! gyp info spawn args '/opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/config.gypi',
            npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
            npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.16.0/include/node/common.gypi',
            npm ERR! gyp info spawn args '-Dlibrary=shared_library',
            npm ERR! gyp info spawn args '-Dvisibility=default',
            npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.16.0',
            npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
            npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.16.0/<(target_arch)/node.lib',
            npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings',
            npm ERR! gyp info spawn args '-Dnode_engine=v8',
            npm ERR! gyp info spawn args '--depth=.',
            npm ERR! gyp info spawn args '--no-parallel',
            npm ERR! gyp info spawn args '--generator-output',
            npm ERR! gyp info spawn args 'build',
            npm ERR! gyp info spawn args '-Goutput_dir=.'
            npm ERR! gyp info spawn args ]
            npm ERR! gyp info spawn make
            npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
            npm ERR! make: g++: Datei oder Verzeichnis nicht gefunden
            npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Fehler 127
            npm ERR! gyp ERR! build error
            npm ERR! gyp ERR! stack Error: make failed with exit code: 2
            npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
            npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
            npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)
            npm ERR! gyp ERR! System Linux 5.10.103-v7+
            npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings
            npm ERR! gyp ERR! node -v v18.16.0
            npm ERR! gyp ERR! node-gyp -v v9.3.1
            npm ERR! gyp ERR! not ok
            npm ERR! /home/iobroker/.npm/_logs/2023-05-20T20_20_15_646Z-debug-0.log
              @cimba007
              iob stop
              iob fix
              iob start
              Wenn es wieder läuft:
              iob diag
                @cimba007
                build-essential
                installiert?
                apt policy build-essential
                Ggf. nachinstallieren.
                  @thomas-braun Ausgabe beider Scripte:
                  pi@raspberrypi:/opt/iobroker $ apt policy build-essential
                  build-essential:
                  Installiert: 12.9
                  Installationskandidat: 12.9
                  Versionstabelle:
                  *** 12.9 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Model: Raspberry Pi 2 Model B Rev 1.1
                  Architecture    : armv7l
                  Docker          : false
                  Virtualization  : none
                  Distributor ID:Raspbian
                  Description:Raspbian GNU/Linux 11 (bullseye)
                  Release:11
                  Codename:bullseye
                  PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                  NAME="Raspbian GNU/Linux"
                  VERSION_ID="11"
                  VERSION="11 (bullseye)"
                  VERSION_CODENAME=bullseye
                  ID=raspbian
                  ID_LIKE=debian
                  HOME_URL="http://www.raspbian.org/"
                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                  Systemuptime and Load:
                   22:34:04 up 26 min,  3 users,  load average: 1.63, 2.01, 1.96
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  Other values than 0x0 hint to temperature/voltage problems
                  temp=44.4'C
                  volt=1.3125V
                  *** Time and Time Zones ***
                                 Local time: Sat 2023-05-20 22:34:05 CEST
                             Universal time: Sat 2023-05-20 20:34:05 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server: true
                  Desktop:
                  Terminal: tty
                  Boot Target: graphical.target
                  *** MEMORY ***
                  Mem:            923M        128M        112M        7.0M        681M        723M
                  Swap:            99M         87M         12M
                  Total:          1.0G        216M        125M
                            923 M total memory
                            129 M used memory
                            337 M active memory
                            213 M inactive memory
                            112 M free memory
                            236 M buffer memory
                            445 M swap cache
                             99 M total swap
                             87 M used swap
                             12 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4       15G   11G  3.6G  75% /
                  devtmpfs       devtmpfs  430M     0  430M   0% /dev
                  tmpfs          tmpfs     462M     0  462M   0% /dev/shm
                  tmpfs          tmpfs     185M  736K  184M   1% /run
                  /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                  tmpfs          tmpfs      93M   32K   93M   1% /run/user/1000
                  [Sat May 20 22:07:47 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=bf3459a2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Sat May 20 22:07:50 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                  [Sat May 20 22:07:50 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Sat May 20 22:07:54 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                  Show mounted filesystems (real ones only):
                  TARGET  SOURCE         FSTYPE OPTIONS
                  /       /dev/mmcblk0p2 ext4   rw,noatime
                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                  /var:
                  2.2G/var/
                  1.8G/var/cache/apt
                  1.8G/var/cache
                  1.7G/var/cache/apt/archives
                  194M/var/log
                  Archived and active journals take up 176.0M in the file system.
                  /opt/iobroker/backups:
                  1.4G/opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  165M/opt/iobroker/iobroker-data/
                  96M/opt/iobroker/iobroker-data/files
                  49M/opt/iobroker/iobroker-data/backup-objects
                  41M/opt/iobroker/iobroker-data/files/javascript.admin
                  27M/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  8.9M/opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
                  6.2M/opt/iobroker/iobroker-data/files/iot.admin/static/js/2.998ec878.chunk.js.map
                  6.2M/opt/iobroker/iobroker-data/files/iot.admin/static/js/2.09585381.chunk.js.map
                  5.6M/opt/iobroker/iobroker-data/objects.jsonl
                  5.5M/opt/iobroker/iobroker-data/objects.json.migrated
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs v18.16.0
                  /usr/bin/node v18.16.0
                  /usr/bin/npm 9.5.1
                  /usr/bin/npx 9.5.1
                  nodejs:
                    Installed: 18.16.0-deb-1nodesource1
                    Candidate: 18.16.0-deb-1nodesource1
                    Version table:
                   *** 18.16.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                       12.22.12~dfsg-1~deb11u4 500
                  No problems detected
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  MULTIHOSTSERVICE/enabled: false
                  Core adapters versions
                  js-controller: 4.0.24
                  admin: 4.2.2
                  javascript: 5.0.14
                  Adapters from github: 1
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                    system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
                    system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                    system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
                    system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                    system.adapter.history.0                : history               : raspberrypi                              - disabled
                    system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                    system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                    system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
                    system.adapter.mobile.0                 : mobile                : raspberrypi                              -  enabled
                    system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
                    system.adapter.mysensors.0              : mysensors             : raspberrypi                              - disabled, port: 5003, bind: 0.0.0.0
                    system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
                    system.adapter.parser.0                 : parser                : raspberrypi                              - disabled
                    system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                    system.adapter.radar2.0                 : radar2                : raspberrypi                              - disabled
                    system.adapter.rflink.0                 : rflink                : raspberrypi                              -  enabled
                    system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
                    system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
                    system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
                    system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                    system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                    system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
                    system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                    system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                    system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
                    system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              -  enabled
                    system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyUSB0
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 6.3.5    , installed 4.2.2  [Updatable]
                  Adapter    "backitup"     : 2.6.19   , installed 1.6.9  [Updatable]
                  Adapter    "ble"          : 0.13.0   , installed 0.11.8 [Updatable]
                  Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
                  Adapter    "cloud"        : 4.3.0    , installed 2.8.0  [Updatable]
                  Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                  Adapter    "dwd"          : 2.8.3    , installed 2.4.10 [Updatable]
                  Adapter    "email"        : 1.1.4    , installed 1.0.7  [Updatable]
                  Adapter    "flot"         : 1.11.0   , installed 1.10.2 [Updatable]
                  Adapter    "history"      : 2.2.4    , installed 1.9.10 [Updatable]
                  Adapter    "info"         : 1.9.26   , installed 1.7.2  [Updatable]
                  Adapter    "iot"          : 1.14.2   , installed 1.5.3  [Updatable]
                  Adapter    "javascript"   : 6.1.4    , installed 5.0.14 [Updatable]
                  Controller "js-controller": 4.0.24   , installed 4.0.24
                  Adapter    "mihome"       : 1.4.0    , installed 1.3.5  [Updatable]
                  Adapter    "mobile"       : 1.0.1    , installed 0.4.11 [Updatable]
                  Adapter    "mqtt"         : 4.0.7    , installed 2.3.4  [Updatable]
                  Adapter    "mysensors"    : 3.0.0    , installed 1.2.2  [Updatable]
                  Adapter    "openweathermap": 0.3.3   , installed 0.1.0  [Updatable]
                  Adapter    "parser"       : 1.1.8    , installed 1.0.7  [Updatable]
                  Adapter    "ping"         : 1.5.3    , installed 1.4.12 [Updatable]
                  Adapter    "radar2"       : 2.0.3    , installed 1.2.5  [Updatable]
                  Adapter    "rflink"       : 2.1.6    , installed 2.1.6
                  Adapter    "rpi2"         : 1.3.2    , installed 0.3.2  [Updatable]
                  Adapter    "sayit"        : 1.12.3   , installed 1.12.0 [Updatable]
                  Adapter    "simple-api"   : 2.7.2    , installed 2.4.8  [Updatable]
                  Adapter    "socketio"     : 4.2.0    , installed 1.8.6  [Updatable]
                  Adapter    "sonoff"       : 2.5.1    , installed 2.4.7  [Updatable]
                  Adapter    "tr-064"       : 4.2.18   , installed 0.4.18 [Updatable]
                  Adapter    "vis"          : 1.4.16   , installed 1.3.4  [Updatable]
                  Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                  Adapter    "vis-history"  : 1.0.0    , installed 0.2.7  [Updatable]
                  Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                  Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
                  Adapter    "weatherunderground": 3.4.2, installed 3.2.1 [Updatable]
                  Adapter    "web"          : 4.3.0    , installed 2.4.10 [Updatable]
                  Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
                  Adapter    "zigbee"       : 1.8.10   , installed 1.6.6  [Updatable]
                  Objects and States
                  Objects: 2759
                  States: 1269
                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       51063      11772/iobroker.js-c
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       51056      11772/iobroker.js-c
                  tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      0          11062      269/connmand
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11122      414/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          11828      380/cupsd
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       51878      11907/io.mqtt.1
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       53977      11877/io.sonoff.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       51807      11808/io.admin.0
                  tcp6       0      0 ::1:53                  :::*                    LISTEN      0          11066      269/connmand
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          11132      414/sshd: /usr/sbin
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          11827      380/cupsd
                  udp        0      0 127.0.0.1:53            0.0.0.0:*                           0          11054      269/connmand
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13276      333/dhcpcd
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13985      416/cups-browsed
                  udp        0      0 0.0.0.0:36486           0.0.0.0:*                           0          15658      269/connmand
                  udp        0      0 0.0.0.0:42161           0.0.0.0:*                           108        12902      266/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12900      266/avahi-daemon: r
                  udp6       0      0 ::1:53                  :::*                                0          11058      269/connmand
                  udp6       0      0 :::5353                 :::*                                108        12901      266/avahi-daemon: r
                  udp6       0      0 :::59732                :::*                                108        12903      266/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          14339      333/dhcpcd
                  2023-05-20 22:38:01.827  - error: host.raspberrypi Caught by controller[0]:   /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/Release/bindings.node
                  2023-05-20 22:38:01.860  - error: host.raspberrypi Caught by controller[0]:   /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/default/bindings.node
                  2023-05-20 22:38:01.862  - error: host.raspberrypi Caught by controller[0]:   /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/compiled/18.16.0/linux/arm/bindings.node
                  2023-05-20 22:38:01.864  - error: host.raspberrypi Caught by controller[0]:   /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                  2023-05-20 22:38:01.865  - error: host.raspberrypi Caught by controller[0]:   /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                  2023-05-20 22:38:01.882  - error: host.raspberrypi Caught by controller[0]:   /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                  2023-05-20 22:38:01.884  - error: host.raspberrypi Caught by controller[0]:   /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/lib/binding/node-v108-linux-arm/bindings.node
                  2023-05-20 22:38:01.887  - error: host.raspberrypi Caught by controller[1]: /opt/iobroker/node_modules/iobroker.rflink/main.js:17
                  2023-05-20 22:38:01.889  - error: host.raspberrypi Caught by controller[1]:     if (adapter.supportsFeature && !adapter.supportsFeature('CONTROLLER_NPM_AUTO_REBUILD')) {
                  2023-05-20 22:38:01.911  - error: host.raspberrypi Caught by controller[1]:                 ^
                  2023-05-20 22:38:01.913  - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'supportsFeature')
                  2023-05-20 22:38:01.916  - error: host.raspberrypi Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.rflink/main.js:17:17)
                  2023-05-20 22:38:01.918  - error: host.raspberrypi Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1254:14)
                  2023-05-20 22:38:01.951  - error: host.raspberrypi Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                  2023-05-20 22:38:01.953  - error: host.raspberrypi Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1117:32)
                  2023-05-20 22:38:01.956  - error: host.raspberrypi Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:958:12)
                  2023-05-20 22:38:01.958  - error: host.raspberrypi Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                  2023-05-20 22:38:01.971  - error: host.raspberrypi Caught by controller[1]:     at node:internal/main/run_main_module:23:47
                  2023-05-20 22:38:01.973  - error: host.raspberrypi Caught by controller[1]: Node.js v18.16.0
                  2023-05-20 22:38:01.976  - error: host.raspberrypi instance system.adapter.rflink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2023-05-20 22:38:01.978  - info: host.raspberrypi Adapter system.adapter.rflink.0 needs rebuild and will be restarted afterwards.
                  2023-05-20 22:38:01.993  - info: host.raspberrypi system.adapter.rflink.0 will be rebuilt
                  2023-05-20 22:38:02.011  - warn: host.raspberrypi adapter "rflink" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                  2023-05-20 22:38:02.014  - info: host.raspberrypi iobroker rebuild
                  2023-05-20 22:38:10.574  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules ...
                  2023-05-20 22:42:06.670 - error: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules failed
                  2023-05-20 22:42:07.717 - info: host.raspberrypi iobroker npm-rebuild: exit 1
                  2023-05-20 22:42:07.879 - info: host.raspberrypi instance system.adapter.rflink.0 started with pid 13859
                  2023-05-20 22:42:15.215 - error: host.raspberrypi Caught by controller[0]: Cannot load serialport module : Error: Could not locate the bindings file. Tried:
                  2023-05-20 22:42:15.218 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/bindings.node
                  2023-05-20 22:42:15.220 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/Debug/bindings.node
                  2023-05-20 22:42:15.220 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/Release/bindings.node
                  2023-05-20 22:42:15.221 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/out/Debug/bindings.node
                  2023-05-20 22:42:15.222 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/Debug/bindings.node
                  2023-05-20 22:42:15.223 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/out/Release/bindings.node
                  2023-05-20 22:42:15.223 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/Release/bindings.node
                  2023-05-20 22:42:15.224 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/default/bindings.node
                  2023-05-20 22:42:15.225 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/compiled/18.16.0/linux/arm/bindings.node
                  2023-05-20 22:42:15.225 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                  2023-05-20 22:42:15.226 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                  2023-05-20 22:42:15.227 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                  2023-05-20 22:42:15.227 - error: host.raspberrypi Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/lib/binding/node-v108-linux-arm/bindings.node
                  2023-05-20 22:42:15.228 - error: host.raspberrypi Caught by controller[1]: /opt/iobroker/node_modules/iobroker.rflink/main.js:17
                  2023-05-20 22:42:15.229 - error: host.raspberrypi Caught by controller[1]: if (adapter.supportsFeature && !adapter.supportsFeature('CONTROLLER_NPM_AUTO_REBUILD')) {
                  2023-05-20 22:42:15.230 - error: host.raspberrypi Caught by controller[1]: ^
                  2023-05-20 22:42:15.231 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'supportsFeature')
                  2023-05-20 22:42:15.232 - error: host.raspberrypi Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.rflink/main.js:17:17)
                  2023-05-20 22:42:15.233 - error: host.raspberrypi Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
                  2023-05-20 22:42:15.234 - error: host.raspberrypi Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                  2023-05-20 22:42:15.235 - error: host.raspberrypi Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1117:32)
                  2023-05-20 22:42:15.236 - error: host.raspberrypi Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:958:12)
                  2023-05-20 22:42:15.237 - error: host.raspberrypi Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                  2023-05-20 22:42:15.238 - error: host.raspberrypi Caught by controller[1]: at node:internal/main/run_main_module:23:47
                  2023-05-20 22:42:15.240 - error: host.raspberrypi Caught by controller[2]: Node.js v18.16.0
                  2023-05-20 22:42:15.241 - error: host.raspberrypi instance system.adapter.rflink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2023-05-20 22:42:15.242 - info: host.raspberrypi Rebuild for adapter system.adapter.rflink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                    @cimba007 sagte in Update Admin 4.2.2 -> 6.3.5 schlägt fehl:
                    cd /opt/iobroker/node_modules/iobroker.rflink
                    npm install --omit=dev
                      Soweit erstmal keine Änderung. Ich würde sonst rflink gerne mal komplett neu installieren - möchte aber keine der configs und zuordnungen der Geräte verlieren.
                      2023-05-20 22:51:46.132  - info: host.raspberrypi "system.adapter.rflink.0" enabled
                      2023-05-20 22:53:00.069  - info: javascript.0 (14088) script.js.common.wifi_beacon.garbagecollector: Cleanup of vacant wifi_macs
                      2023-05-20 22:53:02.606  - error: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules failed
                      2023-05-20 22:53:03.648  - info: host.raspberrypi iobroker npm-rebuild: exit 1
                      2023-05-20 22:53:03.888  - info: host.raspberrypi instance system.adapter.rflink.0 started with pid 14562
                      2023-05-20 22:53:11.034  - error: host.raspberrypi Caught by controller[0]: Cannot load serialport module : Error: Could not locate the bindings file. Tried:
                      2023-05-20 22:53:11.037  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/bindings.node
                      2023-05-20 22:53:11.039  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/Debug/bindings.node
                      2023-05-20 22:53:11.040  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/Release/bindings.node
                      2023-05-20 22:53:11.041  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/out/Debug/bindings.node
                      2023-05-20 22:53:11.041  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/Debug/bindings.node
                      2023-05-20 22:53:11.042  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/out/Release/bindings.node
                      2023-05-20 22:53:11.043  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/Release/bindings.node
                      2023-05-20 22:53:11.044  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/build/default/bindings.node
                      2023-05-20 22:53:11.044  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/compiled/18.16.0/linux/arm/bindings.node
                      2023-05-20 22:53:11.045  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                      2023-05-20 22:53:11.046  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                      2023-05-20 22:53:11.046  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                      2023-05-20 22:53:11.047  - error: host.raspberrypi Caught by controller[0]:  → /opt/iobroker/node_modules/iobroker.rflink/node_modules/@serialport/bindings/lib/binding/node-v108-linux-arm/bindings.node
                      2023-05-20 22:53:11.048  - error: host.raspberrypi Caught by controller[1]: /opt/iobroker/node_modules/iobroker.rflink/main.js:17
                      2023-05-20 22:53:11.048  - error: host.raspberrypi Caught by controller[1]:     if (adapter.supportsFeature && !adapter.supportsFeature('CONTROLLER_NPM_AUTO_REBUILD')) {
                      2023-05-20 22:53:11.049  - error: host.raspberrypi Caught by controller[1]:                 ^
                      2023-05-20 22:53:11.050  - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'supportsFeature')
                      2023-05-20 22:53:11.051  - error: host.raspberrypi Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.rflink/main.js:17:17)
                      2023-05-20 22:53:11.051  - error: host.raspberrypi Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1254:14)
                      2023-05-20 22:53:11.052  - error: host.raspberrypi Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                      2023-05-20 22:53:11.053  - error: host.raspberrypi Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1117:32)
                      2023-05-20 22:53:11.053  - error: host.raspberrypi Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:958:12)
                      2023-05-20 22:53:11.054  - error: host.raspberrypi Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      2023-05-20 22:53:11.055  - error: host.raspberrypi Caught by controller[1]:     at node:internal/main/run_main_module:23:47
                      2023-05-20 22:53:11.055  - error: host.raspberrypi Caught by controller[1]: Node.js v18.16.0
                      2023-05-20 22:53:11.056  - error: host.raspberrypi instance system.adapter.rflink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2023-05-20 22:53:11.057  - info: host.raspberrypi Adapter system.adapter.rflink.0 needs rebuild and will be restarted afterwards.
                      2023-05-20 22:53:11.058  - info: host.raspberrypi system.adapter.rflink.0 will be rebuilt
                      2023-05-20 22:53:11.059  - warn: host.raspberrypi adapter "rflink" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                      2023-05-20 22:53:11.060  - info: host.raspberrypi iobroker rebuild
                      2023-05-20 22:53:16.836  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules ...
                        Homoran Global Moderator Administrators @cimba007 last edited by
                        @cimba007 auch im Spoiler code-tags benutzen!
                          Den Adapter rflink zu entfernen und das Packet serialport zu löschen und anschließend neu zu installieren hat wohl geholfen.
                          Jetzt bleibt noch der letzte Schritt .. admin zu aktualisieren. .. and its done .. 6.3.5.
                          Danke für die viele unterstützung.
                          658
