    4. Huawei Sun2000 & ioBroker via JS script funktioniert
    • O
      OliWit82 @badsnoopy667 last edited by
      @badsnoopy667
      Danke.
      Gibt es da vielleicht schon ein fertiges blockly?
        badsnoopy667 @OliWit82 last edited by
        @oliwit82
        Das sollte sich mit dem sourceanalytix Adapter am einfachsten realisieren lassen.
        • Atifan
          Atifan @juggi1962 last edited by
          @juggi1962 sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
          @baumiliciousnessss
          Ja, ich habe das Skript von @Alex-Warkentin und das funktioniert jetzt.
          Er hat das Original Skript ein wenig abgespeckt und den Batterie Teil rausgenommen da er und ich keine Haben.
          // License: Beerware! Do what ever you like with this, but I'm not liable for anything that you do with it.
          // If you like this code, feel free to buy me a beer ...
          // Have fun with it! der Kachel
          // @ts-ignore
          var modbusRTU = require("modbus-serial");
          var client = new modbusRTU();
          var modbusErrorMessages = [
              "Unknown error",
              "Illegal function (device does not support this read/write function)",
              "Illegal data address (register not supported by device)",
              "Illegal data value (value cannot be written to this register)",
              "Slave device failure (device reports internal error)",
              "Acknowledge (requested data will be available later)",
              // "Slave device busy (retry request again later)"
          // Enter your inverter modbus IP and port here:
          const modbusHost = "xxx.xxx.x.x";
          const modbusPort = 502;
          // Enter the Modbus-IDs of your Sun2000 inverters here:
          const modbusID = [1];
          // On which Modbus-ID can we reach the power meter? (via Sun2000!)
          const powerMeterID = 0;
          // Connect to modbus client
          ConnectModbus();
          // These register spaces need to be read:
          const registerSpacesToReadContinuously = [[37100, 114],[32000, 116]];
          var registerSpacesToReadContinuouslyPtr = 0;
          var globalDataBuffer = new Array(1);
          globalDataBuffer[0] = new Array(50000); // not optimized....
          // Some helper functions:
          function ReadUnsignedInt16(array) {
              var value = array[0];
              return value;
          function ReadUnsignedInt32(array) {
              var value = array[0] * 256 * 256 + array[1];
              return value;
          function ReadSignedInt16(array) {
              var value = 0;
              if (array[0] > 32767)
                  value = array[0] - 65535;
              else
                  value = array[0];
              return value;
          function ReadSignedInt32(array) {
              var value = 0;
              for (var i = 0; i < 2; i++) {
                  value = (value << 16) | array[i];
              return value;
          function GetU16(dataarray, index) {
              var value = ReadUnsignedInt16(dataarray.slice(index, index+1));
              return value;
          function GetU32(dataarray, index) {
              var value = ReadUnsignedInt32(dataarray.slice(index, index+2));
              return value;
          function GetI16(dataarray, index) {
              var value = ReadSignedInt16(dataarray.slice(index, index+1));
              return value;
          function GetI32(dataarray, index) {
              var value = ReadSignedInt32(dataarray.slice(index, index+2));
              return value;
          function GetString(dataarray, index, length) {
              var shortarray = dataarray.slice(index, index+length);
              var bytearray = [];
              for(var i = 0; i < length; i++) {
                  bytearray.push(dataarray[index+i] >> 8);
                  bytearray.push(dataarray[index+i] & 0xff);
              var value =  String.fromCharCode.apply(null, bytearray);
              return value;
          function GetZeroTerminatedString(dataarray, index, length) {
              var bytearray = [];
              var value2 = new String(value).trim();
              return value2;
          // Funktion zum Herstellen einer Modbus-Verbindung
          function ConnectModbus() {
              console.log("Init connection to: " + modbusHost +":" + modbusPort);
              // set requests parameters
              client.setTimeout (10000);
              // try to connect
              client.connectTCP (modbusHost, { port: modbusPort })
                  .then(function()
                      console.log("Connected, wait for reading...");
                  .catch(function(e)
                      console.log(e);
          // Funktion zum Anlegen und Beschreiben eines Datenpunkts
          function ForceSetState(objectname, value, options) {
              if(!existsState("javascript.0." + objectname))      createState(objectname, value, options);
              else                                                setState(objectname, value);
          // Functions to map registers into ioBreaker objects:
          function ProcessPowerMeterStatus() {
              ForceSetState("Solarpower.Huawei.Meter.Status",                     GetU16(globalDataBuffer[powerMeterID], 37100),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Meter.VoltageL1",                  GetI32(globalDataBuffer[powerMeterID], 37101) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Meter.VoltageL2",                  GetI32(globalDataBuffer[powerMeterID], 37103) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Meter.VoltageL3",                  GetI32(globalDataBuffer[powerMeterID], 37105) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Meter.CurrentL1",                  GetI32(globalDataBuffer[powerMeterID], 37107) / 100,    {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Meter.CurrentL2",                  GetI32(globalDataBuffer[powerMeterID], 37109) / 100,    {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Meter.CurrentL3",                  GetI32(globalDataBuffer[powerMeterID], 37111) / 100,    {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Meter.ActivePower",                GetI32(globalDataBuffer[powerMeterID], 37113) / 1,      {name: "", unit: "W"});
              ForceSetState("Solarpower.Huawei.Meter.ReactivePower",              GetI32(globalDataBuffer[powerMeterID], 37115) / 1,      {name: "", unit: "Var"});
              ForceSetState("Solarpower.Huawei.Meter.PowerFactor",                GetI16(globalDataBuffer[powerMeterID], 37117) / 1000,   {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Meter.GridFrequency",              GetI16(globalDataBuffer[powerMeterID], 37118) / 100,    {name: "", unit: "Hz"});
              ForceSetState("Solarpower.Huawei.Meter.PositiveActiveEnergy",       GetI32(globalDataBuffer[powerMeterID], 37119) / 100,    {name: "", unit: "kWh"});
              ForceSetState("Solarpower.Huawei.Meter.ReverseActiveEnergy",        GetI32(globalDataBuffer[powerMeterID], 37121) / 100,    {name: "", unit: "kWh"});
              ForceSetState("Solarpower.Huawei.Meter.AccumulatedReactivePower",   GetI32(globalDataBuffer[powerMeterID], 37123) / 100,    {name: "", unit: "kVarh"});
              //ForceSetState("Solarpower.Huawei.Meter.MeterType",                  GetU16(globalDataBuffer[powerMeterID], 37125),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Meter.VoltageL1-L2",               GetI32(globalDataBuffer[powerMeterID], 37126) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Meter.VoltageL2-L3",               GetI32(globalDataBuffer[powerMeterID], 37128) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Meter.VoltageL3-L1",               GetI32(globalDataBuffer[powerMeterID], 37130) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Meter.ActivePowerL1",              GetI32(globalDataBuffer[powerMeterID], 37132) / 1,      {name: "", unit: "W"});
              ForceSetState("Solarpower.Huawei.Meter.ActivePowerL2",              GetI32(globalDataBuffer[powerMeterID], 37134) / 1,      {name: "", unit: "W"});
              ForceSetState("Solarpower.Huawei.Meter.ActivePowerL3",              GetI32(globalDataBuffer[powerMeterID], 37136) / 1,      {name: "", unit: "W"});
              //ForceSetState("Solarpower.Huawei.Meter.MeterModel",                 GetU16(globalDataBuffer[powerMeterID], 37138),          {name: "", unit: ""});
          function ProcessInverterStatus(id) {
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".State1",                   GetU16(globalDataBuffer[id-1], 32000),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".State2",                   GetU16(globalDataBuffer[id-1], 32002),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".State3",                   GetU32(globalDataBuffer[id-1], 32003),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm1",                   GetU16(globalDataBuffer[id-1], 32008),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm2",                   GetU16(globalDataBuffer[id-1], 32009),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm3",                   GetU16(globalDataBuffer[id-1], 32010),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage",         GetI16(globalDataBuffer[id-1], 32016) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current",         GetI16(globalDataBuffer[id-1], 32017) / 100,    {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",         GetI16(globalDataBuffer[id-1], 32018) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",         GetI16(globalDataBuffer[id-1], 32019) / 100,    {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.3_Voltage",         GetI16(globalDataBuffer[id-1], 32020) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.3_Current",         GetI16(globalDataBuffer[id-1], 32021) / 100,    {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.4_Voltage",         GetI16(globalDataBuffer[id-1], 32022) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.4_Current",         GetI16(globalDataBuffer[id-1], 32023) / 100,    {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".InputPower",               GetI32(globalDataBuffer[id-1], 32064) / 1000,   {name: "", unit: "kW"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",       GetU16(globalDataBuffer[id-1], 32066) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",       GetU16(globalDataBuffer[id-1], 32067) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",       GetU16(globalDataBuffer[id-1], 32068) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage",          GetU16(globalDataBuffer[id-1], 32069) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage",          GetU16(globalDataBuffer[id-1], 32070) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage",          GetU16(globalDataBuffer[id-1], 32071) / 10,     {name: "", unit: "V"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current",          GetI32(globalDataBuffer[id-1], 32072) / 1000,   {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current",          GetI32(globalDataBuffer[id-1], 32074) / 1000,   {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current",          GetI32(globalDataBuffer[id-1], 32076) / 1000,   {name: "", unit: "A"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay",       GetI32(globalDataBuffer[id-1], 32078) / 1000,   {name: "", unit: "kW"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".ActivePower",              GetI32(globalDataBuffer[id-1], 32080) / 1000,   {name: "", unit: "kW"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower",            GetI32(globalDataBuffer[id-1], 32082) / 1000,   {name: "", unit: "kVar"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor",              GetI16(globalDataBuffer[id-1], 32084) / 1000,   {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency",            GetU16(globalDataBuffer[id-1], 32085) / 100,    {name: "", unit: "Hz"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".Efficiency",               GetU16(globalDataBuffer[id-1], 32086) / 100,    {name: "", unit: "%"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature",      GetI16(globalDataBuffer[id-1], 32087) / 10,     {name: "", unit: "°C"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance",     GetU16(globalDataBuffer[id-1], 32088) / 1000,   {name: "", unit: "MOhm"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus",             GetU16(globalDataBuffer[id-1], 32089),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".FaultCode",                GetU16(globalDataBuffer[id-1], 32090),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",              String(new Date(GetU32(globalDataBuffer[id-1], 32091)*1000)),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",             String(new Date(GetU32(globalDataBuffer[id-1], 32093)*1000)),          {name: "", unit: ""});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",   GetU32(globalDataBuffer[id-1], 32106) / 100,          {name: "", unit: "kWh"});
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",         GetU32(globalDataBuffer[id-1], 32114) / 100,          {name: "", unit: "kWh"});
          function ReadRegisterSpace(id, address, length) {
              client.setID(modbusID[id-1]);
              client.readHoldingRegisters(address, length, function(err, data) {
                  if (err) {
                      if (err.modbusCode == null) {
                          console.warn("Lost connection to client. Trying to reconnect...");
                          ConnectModbus();
                      else console.warn("Error received reading address " + address + " from id: " + modbusID[id-1] + " with error: " + err.modbusCode);
                  else
                      console.debug("Read data from id/address " + modbusID[id-1] + "/" + address + "\nData is: " + data.data);
                          globalDataBuffer[id-1][address+i] = data.data[i];
          function ProcessData() {
              //console.log("Processing new data...");
              for(var i = 1; i <= modbusID.length; i++) {
                  ProcessInverterStatus(i);
              ProcessPowerMeterStatus();
              //console.log("Processing done!");
          // This is the main function triggering a  read via modbus-tcp every two seconds.
          // Processing of data is triggered as soon as one complete set of registers is copied.
          var triggerprocessing = 0;
          var currentinverter = 1;
          setInterval(function() {
              if(triggerprocessing == 1) {
                  ProcessData();
              //console.log("Triggering read of inverter " + currentinverter + " at address " + registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][0] + " with length " +  registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][1]);
              ReadRegisterSpace(currentinverter, registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][0], registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][1]);
              registerSpacesToReadContinuouslyPtr++;
              if(registerSpacesToReadContinuouslyPtr >= registerSpacesToReadContinuously.length) {
                  currentinverter++
                  if(currentinverter > modbusID.length){
                      triggerprocessing = 1;
          }, 4000);
          Die Fehler die bei mir gekommen sind, sind jetzt fast weg, seit ich die Abfragezeit auf 4000 ms geändert habe.
          Ich hoffe ich konnte helfen, Gruß Jürgen
          Hallo, habe auch diese Skript genommen und funktioniert bei mir auch.
          Nur habe ich noch eine LUNA2000 Batterie mit 10kWh und würde die gerne mit einbinden.
          Kann mir einer sagen was ich noch mit einfügen muss, damit der Speicher mit drin ist?
          Danke!
          • Alex Warkentin
            Alex Warkentin last edited by
            Du solltest dann das Ursprungs-Script von Kachel aus dem ersten Post nehmen und beide ggf. kombinieren.
              g.polat last edited by g.polat
              habe nun das Script ebenfalls zum laufen bekommen, habe jedoch einige Verständnisfragen.
              Was ist der Unterschied zwischen:
              javascript.0.Solarpower.Huawei.Meter.ActivePower und javascript.0.Solarpower.Huawei.Meter.ActivePower
              Welche Datenpunkte muss ich für den Energiefluss nehmen betreffend: Hausverbrauch; Netzeinspeisung; Netzausspeisung?
              Wäre für Hilfestellung dankbar, da die Werte aus der APP nicht mit den ausgelesenen Werten bis auf den Akku übereinstimmen.
              Laut AP aktuell:
              Produktion 4,79 KW
              Batterie wird mit 2,47 KW geladen
              Ins Netz gehen 1,96 KW
              Ins Haus 0,35KW
              Ausgelesen per Script:
              javascript.0.Solarpower.Huawei.Inverter.1.ActivePower 1.249 KW
              javascript.0.Solarpower.Huawei.Inverter.1.InputPower 4.42 KW
              javascript.0.Solarpower.Huawei.Meter.ActivePower 260 W
              javascript.0.Solarpower.Huawei.Meter.PositiveActiveEnergy 1.49 KW
              Hier mein Scrpt:
              var ModbusRTU = require("modbus-serial");
              var client = new ModbusRTU();
                  "Unknown error",
              // open connection to a tcp line
              client.setTimeout(10000);
              client.connectTCP("192.168.0.45", { port: 502 });
              const ModBusIDs = [1];
              const PowerMeterID = 0;
              // Enter your battery stack setup. 2 dimensional array.
              // e.g. [[3, 2], [3, 0]] means:
              // First inverter has two battery stacks with 3 + 2 battery modules
              // while second inverter has only one battery stack with 3 battery modules
              const BatteryUnits = [[3, 0], [3, 0]];
              const RegisterSpacesToReadContinuously = [[30000, 81], [37100, 114], [32000, 116], [37000, 68],  [37700, 100], [37800, 100], [38200, 100], [38300, 100], [38400, 100], [35300, 40]];
              var RegisterSpacesToReadContinuouslyPtr = 0;
              var GlobalDataBuffer = new Array(2);
              for(var i=0; i<ModBusIDs.length; i++) {
                  GlobalDataBuffer[i] = new Array(50000); // not optimized....
              function readUnsignedInt16(array) {
                  return value;
              function readUnsignedInt32(array) {
                  return value;
              function readSignedInt16(array) {
                  var value = 0;
                  else
                      value = array[0];
                  return value;
              function readSignedInt32(array) {
                  var value = 0;
                  return value;
              function getU16(dataarray, index) {
                  var value = readUnsignedInt16(dataarray.slice(index, index+1));
                  return value;
              function getU32(dataarray, index) {
                  var value = readUnsignedInt32(dataarray.slice(index, index+2));
                  return value;
              function getI16(dataarray, index) {
                  var value = readSignedInt16(dataarray.slice(index, index+1));
                  return value;
              function getI32(dataarray, index) {
                  var value = readSignedInt32(dataarray.slice(index, index+2));
                  return value;
              function getString(dataarray, index, length) {
                  var bytearray = [];
                  return value;
              function getZeroTerminatedString(dataarray, index, length) {
                  var bytearray = [];
                  return value2;
              function forcesetState(objectname, value, options) {
                  if(!existsState("javascript.0." + objectname)) {
                      console.log("createstate " +  objectname + " to value " + value);
              function processOptimizers(id) {
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 35200), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 35201), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 35202), {name: "", unit: ""});
              function processInverterPowerAdjustments(id) {
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode",     getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue",    getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand",  getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode",   getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue",  getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower",     getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
              function processBattery(id) {
                  // Battery registers 1-15 (Stack 1 related)
                  if(BatteryUnits[id-1][0] > 0) {
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode",            getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower",       getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower",    getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.FaultID",                getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37015) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime", getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",            getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",             getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
                  // Battery registers 16+17 (Storage-related)
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.MaximumChargePower",                getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.MaximumDischargePower",             getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
                  // Battery register 18-20 (Stack 1 related)
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.SN",                         getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                getU32(GlobalDataBuffer[id-1], 37066) / 100, {name: "", unit: "kWh"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",             getU32(GlobalDataBuffer[id-1], 37068) / 100, {name: "", unit: "kWh"});
                  // Battery register 21-31 (Stack 2 related)
                  if(BatteryUnits[id-1][1] > 0) {
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.SN",                     getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) / 100, {name: "", unit: "kWh"});
                  // Battery register 32-41 (Storage related)
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.RatedCapacity", getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.SOC", getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.RunningStatus", getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.BusVoltage", getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.BusCurrent", getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.TotalCharge", getU32(GlobalDataBuffer[id-1], 37780) / 100, {name: "", unit: "kWh"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.TotalDischarge", getU32(GlobalDataBuffer[id-1], 37782) / 100, {name: "", unit: "kWh"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37784) / 100, {name: "", unit: "kWh"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37786) / 100, {name: "Current DayDiscarge ", unit: "kWh"});
                  // Battery registers 42+43 (Battery stack related)
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
                  // Registers 44 to 98: (Battery pack related)
                  for(var i = 1; i <= 2; i++){
                      if(BatteryUnits[id-1][i-1] >= 0) {
                          for(var j = 1; j <= BatteryUnits[id-1][i-1]; j++) {
                              //[[38200, 38242, 38284] [38326, 38368, 38410]]; (+42 for each battery pack, +126 for each stack)
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",                getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion",   getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",     getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",        getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",           getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",           getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",       getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",    getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                              // [[38452, 38454, 38456][38458, 38460, 38462]] ( +2 for each pack, +6 for each stack)
                              createState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                              createState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                  // Battery registers 110-141 are not supported by this script yet!
                  forcesetState("Solarpower2.Huawei.Meter.Status",          getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Meter.VoltageL1",        getI32(GlobalDataBuffer[PowerMeterID], 37101)  / 10, {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Meter.VoltageL2",        getI32(GlobalDataBuffer[PowerMeterID], 37103)  / 10, {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Meter.VoltageL3",        getI32(GlobalDataBuffer[PowerMeterID], 37105)  / 10, {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Meter.CurrentL1",        getI32(GlobalDataBuffer[PowerMeterID], 37107)  / 100, {name: "", unit: "A"});
                  forcesetState("Solarpower2.Huawei.Meter.CurrentL2",        getI32(GlobalDataBuffer[PowerMeterID], 37109)  / 100, {name: "", unit: "A"});
                  forcesetState("Solarpower2.Huawei.Meter.CurrentL3",        getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
                  forcesetState("Solarpower2.Huawei.Meter.ActivePower",     getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
                  forcesetState("Solarpower2.Huawei.Meter.ReactivePower",   getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
                  forcesetState("Solarpower2.Huawei.Meter.PowerFactor",     getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Meter.GridFrequency",   getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
                  forcesetState("Solarpower2.Huawei.Meter.PositiveActiveEnergy",     getI32(GlobalDataBuffer[PowerMeterID], 37119) / 100, {name: "", unit: "kWh"});
                  forcesetState("Solarpower2.Huawei.Meter.ReverseActiveEnergy",      getI32(GlobalDataBuffer[PowerMeterID], 37121) / 100, {name: "", unit: "kWh"});
                  forcesetState("Solarpower2.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
                  forcesetState("Solarpower2.Huawei.Meter.MeterType",       getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Meter.VoltageL1-L2",       getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Meter.VoltageL2-L3",       getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Meter.VoltageL3-L1",       getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Meter.ActivePowerL1",    getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
                  forcesetState("Solarpower2.Huawei.Meter.ActivePowerL2",    getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
                  forcesetState("Solarpower2.Huawei.Meter.ActivePowerL3",    getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
                  forcesetState("Solarpower2.Huawei.Meter.MeterModel",      getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
              function processInverterStatus(id) {
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".State1", getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".State2", getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".State3", getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm1", getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm2", getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm3", getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.1_Voltage",       getI16(GlobalDataBuffer[id-1], 32016) / 10  , {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.1_Current",       getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.2_Voltage",       getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.2_Current",       getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".InputPower",             getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",           getU16(GlobalDataBuffer[id-1], 32066) / 10  , {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",           getU16(GlobalDataBuffer[id-1], 32067) / 10  , {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",           getU16(GlobalDataBuffer[id-1], 32068) / 10  , {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1_Voltage",            getU16(GlobalDataBuffer[id-1], 32069) / 10  , {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2_Voltage",            getU16(GlobalDataBuffer[id-1], 32070) / 10  , {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3_Voltage",            getU16(GlobalDataBuffer[id-1], 32071) / 10  , {name: "", unit: "V"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1_Current",         getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2_Current",         getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3_Current",         getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".PeakActivePowerDay",     getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActivePower",            getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ReactivePower",          getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".PowerFactor",            getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".GridFrequency",          getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Efficiency",             getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".InternalTemperature",    getI16(GlobalDataBuffer[id-1], 32087) / 10  , {name: "", unit: "°C"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".InsulationResistance",   getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".DeviceStatus",              getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".FaultCode",                 getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".StartupTime",               getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ShutdownTime",              getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".AccomulatedEnergyYield",   getU32(GlobalDataBuffer[id-1], 32106) / 100, {name: "", unit: "kWh"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".DailyEnergyYield",         getU32(GlobalDataBuffer[id-1], 32114) / 100, {name: "", unit: "kWh"});
                  //forcesetState("Solarpower2.Huawei.Inverter." + id + ".AccomulatedEnergyYield",    getU16(GlobalDataBuffer[id-1], 32106), {name: "", unit: "kWh"});
                  //forcesetState("Solarpower2.Huawei.Inverter." + id + ".DailyEnergyYield",          getU16(GlobalDataBuffer[id-1], 32114), {name: "", unit: "kWh"});
              function ProcessDeviceInfo(id) {
                  // Note: Manual says its quantitiy is 15, but that is the number (+1) of 8bit characters
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Model",  getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".SN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".PN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".ModelID",           getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".PVStrings",         getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".MPPTrackers",       getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxRatedPower",     getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxActivePower",    getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxApparentPower",  getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxReactivePowerToGrid",        getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid",      getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
              function readRegisterSpace(id, address, length) {
                  client.setID(ModBusIDs[id-1]);
                      if (err) {
                          console.warn("Error received reading address " + address + " from id: " + ModBusIDs[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
                      else
                          console.debug("Read data from id/address " + ModBusIDs[id-1] + "/" + address + "\nData is: " + data.data);
                              GlobalDataBuffer[id-1][address+i] = data.data[i];
              function processData() {
                  for(var i = 1; i <= ModBusIDs.length; i++) {
                      ProcessDeviceInfo(i);
                      processInverterStatus(i);
                      processBattery(i);
                      processInverterPowerAdjustments(i);
                      processOptimizers(i);
                      processData();
                  console.log("Triggering read of inverter " + currentinverter + " at address " + RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0] + " with length " +  RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
                  readRegisterSpace(currentinverter, RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0], RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
                  RegisterSpacesToReadContinuouslyPtr++;
                  if(RegisterSpacesToReadContinuouslyPtr >= RegisterSpacesToReadContinuously.length) {
                      currentinverter++
                      if(currentinverter > ModBusIDs.length){
              }, 4000);
              GP
              • X
                Xanon @Alex Warkentin last edited by Xanon
                @alex-warkentin
                Hallo, auch bei mir ist jetzt ein Speicher dazugekommen.
                Ich habe wie du empfohlen hast auch das AnfangsScript genommen, allerdings fehlen mir die Kenntnisse alle Optimierungen wie z.B. (den täglichen Ertrag (DailyEnergyYield)) oder (die Zeit für Wechselrichter Shutdown / Start als Uhrzeit / Datum) nachträglich mit einzubauen und ich bekomme immer wieder Fehlermeldungen ins Log und weiss nicht wie ich Sie behandeln kann.
                2023-05-20 11:34:33.284	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 38300 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:33:29.251	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 37800 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:32:27.244	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 37700 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:31:23.234	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 32000 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:31:13.244	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 38300 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:30:19.236	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 30000 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:30:03.237	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 32000 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:29:15.196	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 38400 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:28:13.192	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 38300 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:27:09.180	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 37800 from id: 1 with error: undefined
                javascript.0
                2023-05-20 11:26:05.178	warn	script.js.Solar.PV_mit_Speicher_Berechnung: Error received reading address 37000 from id: 1 with error: undefined
                Wärst du oder vielleicht jemand anderes so freundlich und würde mir sein Skript welches den Batterie Speicher beinhaltet und optimiert / verbessert ist zur Verfügung stellen?
                Vielen Dank
                  Chris_B last edited by
                  @Kachel
                  Ich habe Deine Skript auch bei mir implementiert (5KWp, 15 kWh Speicher).
                  Es läuft, ich hatte aber folgendes Problem bei meiner iobroker Installation: Die Funktion forcesetState() funktioniert bei mir nicht. Dadurch werden das erste Mal die Werte gelesen, danach aber nicht mehr, da nur createState() aufgerufen wird. Ich musste das folgendermassen abändern:
                  if (!existsState("javascript.0." + objectname))
                  D.h. ich muss beim Prüfen des State javascript.0 voranstellen.
                  Danach läuft das Skript gut.
                  Ich habe eine weitere Optimierung vorgenommen: Jetzt wird bei jedem Setzen der States geprüft ob der State existiert. Das ist ziemlich aufwendig. Ich mache das nun nur ein Mal pro 'Runde', und merke mir das in einer Variable. Dadurch wird nicht dauernd geprüft; spart etwas Processing Power...
                  • X
                    Xanon @Chris_B last edited by
                    @chris_b
                    Würdest du dein Skript hier zur Verfügung stellen?
                    G C 2 Replies Last reply Reply Quote 0
                      g.polat @Xanon last edited by
                      @xanon sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
                      @chris_b
                      Funktioniert bei mir mir 10kw Akku perfekt.
                          "Unknown error",
                          return value;
                          return value;
                          var value = 0;
                          else
                              value = array[0];
                          return value;
                          var value = 0;
                          return value;
                          return value;
                          return value;
                          return value;
                          return value;
                          var bytearray = [];
                          return value;
                          var bytearray = [];
                          return value2;
                              forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",     getU16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
                          //forcesetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",    getU32(GlobalDataBuffer[id-1], 32106) / 100, {name: "", unit: "kWh"});
                          //forcesetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",          getU32(GlobalDataBuffer[id-1], 32114) / 100, {name: "", unit: "kWh"});
                              if (err) {
                              else
                              processBattery(i);
                              processData();
                              currentinverter++
                      }, 4000);
                        Chris_B @Xanon last edited by
                        @xanon Mach' ich in den nächsten 1-2 Tagen. Ich möchte noch ein paar weitere Verbesserungen vornehmen, dann stelle ich das Skript zur Verfügung.
                        • X
                          Xanon @g.polat last edited by
                          @g-polat Super Vielen Dank
                          Werde ich mal testen 👍
                          • X
                            @chris_b
                            Ok, bin gespannt, was du noch aus dem Skript heraus zauberst.😊
                            Danke für deine Mühe.👍
                              @xanon
                              Hier schon einmal vorab mein aktueller Stand des Skripts. Dazu folgende Bemerkungen:
                              • Das Skript ist noch nicht wirklich fertig. Ich komme aber erst am Wochenende dazu noch mehr Funktionalität einzubauen. Ich werde dann ein Update posten.
                              • Die Sache mit createState() ist jetzt optimiert.
                              • Neuer State: javascript.0.Solarpower.Dervied.PeakPower --> Zeigt den Max Wert der Panels an einem Tag an.
                              • Neuer State: javascript.0.Solarpower.Dervied.BatteryOverview --> hier werden die % Werte jedes Battery Packs angezeigt, momentan fix für 3, sollte ich allgemeiner schreiben.
                              Ich werde am Wochenende weiter am Skript arbeiten und weitere Funktionen einfügen. Habe aber bis dann keine Zeit.
                              // From iobroker Forum: Huawei Sun2000 & ioBroker via JS script funktioniert
                              // https://forum.iobroker.net/topic/53005/huawei-sun2000-iobroker-via-js-script-funktioniert
                              createState("javascript.0.Solarpower.Dervied.PeakPower", 0,  {read: true, write: true, name: "Peak Solar Panel Power today"});
                              createState("javascript.0.Solarpower.Dervied.BatteryOverview", "",  {read: true, write: true, name: "Battery Overview SOC"});
                              var testCreateState = 0;
                              [   "Unknown error",
                              client.connectTCP("192.168.1.127", { port: 502 });
                              // Enter the Modbus-IDs of your Sun2000 inverters here (example for two inverters): const ModBusIDs = [16, 1];
                              // Enter your battery stack setup. 2 dimensional array, e.g. [[3, 2], [3, 0]] means:
                              const BatteryUnits = [[3, 0]];
                              for ( var i=0; i < ModBusIDs.length; i++)
                              {   return array[0];
                              {   return array[0] * 256 * 256 + array[1];
                              {   var value = 0;
                                  if (array[0] > 32767)   value = array[0] - 65535;
                                      else                value = array[0];
                                  return value;
                              {   var value = 0;
                                  for (var i = 0; i < 2; i++) { value = (value << 16) | array[i]; }
                                  return value;
                              {   return readUnsignedInt16(dataarray.slice(index, index+1));
                              {   return readUnsignedInt32(dataarray.slice(index, index+2));
                              {   return readSignedInt16(dataarray.slice(index, index+1));
                              {   return readSignedInt32(dataarray.slice(index, index+2));
                              {   var shortarray = dataarray.slice(index, index+length);
                                  var bytearray = [];
                                  for (var i = 0; i < length; i++)
                                  {   bytearray.push(dataarray[index+i] >> 8);
                                  return value;
                                  var bytearray = [];
                                  return value2;
                              // perform createState() only if variable does not yet exist, and perform the check via existsState() only once for each processing round
                              {   if (testCreateState == 0)
                                  {   if (!existsState("javascript.0." + objectname)) { createState(objectname, value, options); }
                                      else                                            { setState(objectname, value); testCreateState = 1; }
                                  } else
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 35200), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 35201), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 35202), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode",     getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue",    getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand",  getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode",   getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue",  getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower",     getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
                                  if ( BatteryUnits[id-1][0] > 0)
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus",               getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",     getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage",                  getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC",                  getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode",                 getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower",            getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower",         getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.FaultID",                     getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37015) / 100, {name: "", unit: "kWh"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) / 100, {name: "", unit: "kWh"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent",                  getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature",          getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime",getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",                 getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",                  getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumChargePower",                     getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumDischargePower",                  getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
                                  if (BatteryUnits[id-1][0] > 0)
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SN",                          getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37066) / 100, {name: "", unit: "kWh"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37068) / 100, {name: "", unit: "kWh"});
                                  if ( BatteryUnits[id-1][1] > 0)
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SN",                          getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",                  getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",               getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",     getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",                  getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",                  getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",          getI16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) / 100, {name: "", unit: "kWh"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) / 100, {name: "", unit: "kWh"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RatedCapacity", getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.SOC", getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RunningStatus", getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusVoltage", getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusCurrent", getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalCharge", getU32(GlobalDataBuffer[id-1], 37780) / 100, {name: "", unit: "kWh"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalDischarge", getU32(GlobalDataBuffer[id-1], 37782) / 100, {name: "", unit: "kWh"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37784) / 100, {name: "", unit: "kWh"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37786) / 100, {name: "Current DayDiscarge ", unit: "kWh"});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
                                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",                getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion",   getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",     getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",        getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",           getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",           getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",       getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",    getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                                              createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                                              createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                                  forcesetState("Solarpower.Huawei.Meter.Status",                   getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Meter.VoltageL1",                getI32(GlobalDataBuffer[PowerMeterID], 37101)  / 10, {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Meter.VoltageL2",                getI32(GlobalDataBuffer[PowerMeterID], 37103)  / 10, {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Meter.VoltageL3",                getI32(GlobalDataBuffer[PowerMeterID], 37105)  / 10, {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Meter.CurrentL1",                getI32(GlobalDataBuffer[PowerMeterID], 37107)  / 100, {name: "", unit: "A"});
                                  forcesetState("Solarpower.Huawei.Meter.CurrentL2",                getI32(GlobalDataBuffer[PowerMeterID], 37109)  / 100, {name: "", unit: "A"});
                                  forcesetState("Solarpower.Huawei.Meter.CurrentL3",                getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
                                  forcesetState("Solarpower.Huawei.Meter.ActivePower",              getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
                                  forcesetState("Solarpower.Huawei.Meter.ReactivePower",            getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
                                  forcesetState("Solarpower.Huawei.Meter.PowerFactor",              getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Meter.GridFrequency",            getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
                                  forcesetState("Solarpower.Huawei.Meter.PositiveActiveEnergy",     getI32(GlobalDataBuffer[PowerMeterID], 37119) / 100, {name: "", unit: "kWh"});
                                  forcesetState("Solarpower.Huawei.Meter.ReverseActiveEnergy",      getI32(GlobalDataBuffer[PowerMeterID], 37121) / 100, {name: "", unit: "kWh"});
                                  forcesetState("Solarpower.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
                                  forcesetState("Solarpower.Huawei.Meter.MeterType",                getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Meter.VoltageL1-L2",             getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Meter.VoltageL2-L3",             getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Meter.VoltageL3-L1",             getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Meter.ActivePowerL1",            getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
                                  forcesetState("Solarpower.Huawei.Meter.ActivePowerL2",            getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
                                  forcesetState("Solarpower.Huawei.Meter.ActivePowerL3",            getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
                                  forcesetState("Solarpower.Huawei.Meter.MeterModel",               getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".State1", getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".State2", getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".State3", getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm1", getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm2", getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm3", getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage",       getI16(GlobalDataBuffer[id-1], 32016) / 10  , {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current",       getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",       getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",       getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".InputPower",             getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",           getU16(GlobalDataBuffer[id-1], 32066) / 10  , {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",           getU16(GlobalDataBuffer[id-1], 32067) / 10  , {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",           getU16(GlobalDataBuffer[id-1], 32068) / 10  , {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage",            getU16(GlobalDataBuffer[id-1], 32069) / 10  , {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage",            getU16(GlobalDataBuffer[id-1], 32070) / 10  , {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage",            getU16(GlobalDataBuffer[id-1], 32071) / 10  , {name: "", unit: "V"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current",         getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current",         getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current",         getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay",     getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ActivePower",            getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower",          getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor",            getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency",          getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Efficiency",             getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature",    getI16(GlobalDataBuffer[id-1], 32087) / 10  , {name: "", unit: "°C"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance",   getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus",              getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".FaultCode",                 getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",               getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",              getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",    getU16(GlobalDataBuffer[id-1], 32106), {name: "", unit: "kWh"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",          getU16(GlobalDataBuffer[id-1], 32114), {name: "", unit: "kWh"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".Model",  getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".SN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".PN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".ModelID",           getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".PVStrings",         getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".MPPTrackers",       getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxRatedPower",     getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxActivePower",    getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxApparentPower",  getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerToGrid",        getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
                                  forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid",      getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
                                      if (err)
                                      {   console.warn("Error received reading address " + address + " from id: " + ModBusIDs[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
                                      else
                                      {   console.debug("Read data from id/address " + ModBusIDs[id-1] + "/" + address + "\nData is: " + data.data);
                                          for (var i = 0; i < length; i++) GlobalDataBuffer[id-1][address+i] = data.data[i];
                                  console.debug("Processing new data...");   // this was originally .log
                                  for ( var i = 1; i <= ModBusIDs.length; i++)
                                      processBattery(i);
                                  // get SOC of all batteries and combine to one string
                                  var BatOverview = getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery1.BatterySOC").val + "%, " +
                                      getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery2.BatterySOC").val + "%, " +
                                      getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery3.BatterySOC").val + "%";
                                  setState("javascript.0.Solarpower.Dervied.BatteryOverview", BatOverview);
                                  // determine maximum power delivery of today (this is reset at midnight)
                                  var PeakPV = parseFloat(getState("javascript.0.Solarpower.Huawei.Inverter.1.InputPower").val);
                                  PeakPV = max(PeakPV, getState("javascript.0.Solarpower.Dervied.PeakPower").val);
                                  setState("javascript.0.Solarpower.Dervied.PeakPower", PeakPV);
                                  console.debug("Processing done!");  // this was originally .log
                              // one minute before midnight: reset min/max variables
                              schedule("59 23 * * *", function ()
                                  setState("javascript.0.Solarpower.Dervied.PeakPower", 0);
                              // This is the main function triggering a  read via modbus-tcp every 2 seconds - changed to 5 seconds
                              // with 5 seconds, new values are displyed every 50 seconds
                                  if (triggerprocessing == 1)
                                      processData();
                                  // this was originally also a .log
                                  console.debug("Triggering read of inverter " + currentinverter + " at address " +
                                  if (RegisterSpacesToReadContinuouslyPtr >= RegisterSpacesToReadContinuously.length)
                                      currentinverter++
                                      if (currentinverter > ModBusIDs.length)
                              }, 5000);
                              Hier noch ein Screenshot meiner Vis. Auch diese ist erst im Aufbau, möchte ich noch stark verbessern...
                              S C 2 Replies Last reply Reply Quote 0
                                spooky82 @Chris_B last edited by
                                @chris_b
                                ich habe wohl ein Verständnisproblem.
                                Ich habe das Skript und den easee Adapter eingerichtet und alle Datenpunkte mMn korrekt gesetzt.
                                Das Laden geht jedoch nicht los.
                                Habt ihr Ideen?
                                3c553291-ba34-461a-8ab6-484a46857849-image.png 050572b2-4e9d-48b9-aa2c-9f57c6a49de9-image.png
                                Dankeschön
                                  Chris_B @spooky82 last edited by
                                  @spooky82 Sorry, aber da muss eine Verwechslung voliegen. Das von mir abgeänderte Skript oben ist für Huawei Sun2000 / Luna2000 Anlagen. Für das Auslesen der Anlagen via TCP / Modbus braucht man ausschliesslich das Skript, wie oben in diversen Beiträgen beschrieben.
                                  Die Datenpunkte dafür befinden sich dann unter javascript.0.Solarpower....
                                  Gruss
                                    Chris_B @Chris_B last edited by
                                    @chris_b Ich bin immer noch an der Anänderung des Skripts. Habe noch ein paar Fehler darin gefunden (falsche Skalierung der Werte). Ich brauche noch etwas mehr Zeit. Hier mein aktueller Stand für das UI (im Wesentlichen eine Nachbildung der Huawei App, aber, wenn ich dann fertig bin, so, wie es mir passt, und mit zusätzlicher Information.
                                    (Dies ist ein noch fehlerhafter Zwischenstand)
                                      @chris_b
                                      Sorry, hast absolut Recht. Falsches Forum.
                                      Danke dir!
                                        Sweatchuck @Chris_B last edited by
                                        @chris_b
                                        Hallo Chris,
                                        ich hätte starkes Interesse an deinem Script. Node-red ist leider nichts für mich 😉
                                        Meine PV-Konfiguration ist sehr ähnlich.
                                        2 Strings (Ost/West), Powermeter, Optimierer und 1x Akkuturm mit 3x 5kwh Packs.
                                        Würde mich freuen wenn du deine Arbeit mit uns/mir teilen würdest.
                                          Chris_B @Sweatchuck last edited by
                                          @sweatchuck
                                          Hallo
                                          Hier mein aktueller Stand des Skripts. Bitte beachten:
                                          • Das Skript ist noch NICHT fertig. Ich werde in den nächsten Tagen noch weitere Verbesserungen vornehmen.
                                          • Unter client.connectTCP("192.168.0.0", { port: 502 }); die eigene TCP-IP Adresse des INverters angeben
                                          • Verwendung des Skripts auf eigene Verantwortung.
                                            Das Skript erzeugt neu noch zusätzliche Variable unter Solarpower.Derived.XXX. Die Beschreibung der Variable ist meist selbsterklärend.
                                            Ich werde in den nächsten Tagen und Wochen noch folgendes erweitern:
                                          1. Am Ende jedes Tages die aktuellen Werte in ein File schreiben, zur Analyse in bspw. Excel.
                                          2. Den Tagesverbrauch ausgeben (wie im Huawei Portal)
                                          3. Den Modbus-Trafic verringern (bspw. Nachts)
                                          4. Mein UI verbessern
                                            Hier mein aktuelles UI und das Skript.
                                          // From iobroker Forum: "Huawei Sun2000 & ioBroker via JS script funktioniert"
                                          createState("javascript.0.Solarpower.Derived.BatteryOverview", "",  {read: true, write: true, name: "Battery Overview SOC"});
                                          createState("javascript.0.Solarpower.Derived.HouseConsumption", "",  {read: true, write: true, name: "Consumption of House", unit: "W"});
                                          createState("javascript.0.Solarpower.Derived.YieldToday", "",  {read: true, write: true, name: "Yield Today", unit: "kW"});
                                          createState("javascript.0.Solarpower.Derived.IsBatteryLoading", 0,  {read: true, write: true, name: "Luna 2000 Battery is loading", type: "number"});
                                          createState("javascript.0.Solarpower.Derived.IsGridExporting", 0,  {read: true, write: true, name: "Exporting Power to Grid", type: "number"});
                                          createState("javascript.0.Solarpower.Derived.PeakPanelPower", 0,  {read: true, write: true, name: "Peak panel power today"});
                                          createState("javascript.0.Solarpower.Derived.GridExportSum", 0,  {read: true, write: true, name: "Total export to grid", unit: "kWh"});
                                          createState("javascript.0.Solarpower.Derived.GridImportSum", 0,  {read: true, write: true, name: "Total import from grid", unit: "kWh"});
                                          createState("javascript.0.Solarpower.Derived.GridExportToday", 0,  {read: true, write: true, name: "Export to grid today", unit: "kWh"});
                                          createState("javascript.0.Solarpower.Derived.GridImportToday", 0,  {read: true, write: true, name: "Import from grid today", unit: "kWh"});
                                          var modbusErrorMessages =
                                          [   "Unknown error",
                                              "Illegal function (device does not support this read/write function)",
                                              "Illegal data address (register not supported by device)",
                                              "Illegal data value (value cannot be written to this register)",
                                              "Slave device failure (device reports internal error)",
                                              "Acknowledge (requested data will be available later)",
                                              "Slave device busy (retry request again later)"
                                          // Enter your inverter modbus IP and port here:
                                          // On which Modbus-ID can we reach the power meter? (via Sun2000!)
                                          // These register spaces need to be read:
                                          // Some helper functions:
                                          {   return array[0];
                                          {   var value = 0;
                                              return value;
                                          {   var value = 0;
                                              return value;
                                              var bytearray = [];
                                                  bytearray.push(dataarray[index+i] & 0xff);
                                              var value =  String.fromCharCode.apply(null, bytearray);
                                              return value;
                                              var bytearray = [];
                                              for(var i = 0; i < length; i++)
                                              var value2 = new String(value).trim();
                                              return value2;
                                              } else
                                          // Functions to map registers into ioBreaker objects
                                          function ProcessOptimizers(id)
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 37200), {name: "", unit: ""});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 37201), {name: "", unit: ""});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 37202), {name: "", unit: ""});
                                          function ProcessInverterPowerAdjustments(id)
                                          function ProcessBattery(id)
                                                  //forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",                 getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
                                                  //forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",                  getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
                                          function ProcessPowerMeterStatus()
                                              //forcesetState("Solarpower.Huawei.Meter.MeterType",                getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
                                              //forcesetState("Solarpower.Huawei.Meter.MeterModel",               getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
                                          function ProcessInverterStatus(id)
                                              //forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",       getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
                                              //forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",       getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
                                              forcesetState("Solarpower.Huawei.Inverter." + id + ".AccumulatedEnergyYield",    getU32(GlobalDataBuffer[id-1], 32106) / 100, {name: "", unit: "kWh"});
                                              client.readHoldingRegisters(address, length, function(err, data)
                                                  if (err)
                                                  else
                                          function ProcessData()
                                                  ProcessInverterStatus(i);
                                                  ProcessBattery(i);
                                                  //ProcessInverterPowerAdjustments(i);
                                                  ProcessOptimizers(i);
                                              ProcessPowerMeterStatus();
                                              setState("javascript.0.Solarpower.Derived.BatteryOverview", BatOverview);
                                              // determine peak panel power
                                              var PanelPower = getState("javascript.0.Solarpower.Huawei.Inverter.1.InputPower").val;
                                              var PanelMax = getState("javascript.0.Solarpower.Derived.PeakPanelPower").val;
                                              if (PanelPower > PanelMax) setState("javascript.0.Solarpower.Derived.PeakPanelPower", PanelPower);
                                              // determine power used by house
                                              setState("javascript.0.Solarpower.Derived.HouseConsumption", getState("javascript.0.Solarpower.Huawei.Inverter.1.ActivePower").val * 1000 -
                                                  getState("javascript.0.Solarpower.Huawei.Meter.ActivePower").val);
                                              // determine yield today
                                              setState("javascript.0.Solarpower.Derived.YieldToday", getState("javascript.0.Solarpower.Huawei.Inverter.1.DailyEnergyYield").val +
                                                  getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayChargeCapacity").val -
                                                  getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.CurrentDayDischargeCapacity").val)
                                              // determine if battery is loading
                                              setState("javascript.0.Solarpower.Derived.IsBatteryLoading", getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.ChargeAndDischargePower").val > 0 ? 0 : 1);
                                              // determine if power is imported or exported
                                              setState("javascript.0.Solarpower.Derived.IsGridExporting", getState("javascript.0.Solarpower.Huawei.Meter.ActivePower").val > 0 ? 1 : 0);
                                              // compute export and import today
                                              setState("javascript.0.Solarpower.Derived.GridExportToday", getState("javascript.0.Solarpower.Huawei.Meter.PositiveActiveEnergy").val - getState("javascript.0.Solarpower.Derived.GridExportSum").val);
                                              setState("javascript.0.Solarpower.Derived.GridImportToday", getState("javascript.0.Solarpower.Huawei.Meter.ReverseActiveEnergy").val - getState("javascript.0.Solarpower.Derived.GridImportSum").val);
                                          var triggerprocessing = 0;
                                          var currentinverter = 1;
                                          setInterval(function()
                                          // Processing of data is triggered as soon as one complete set of registers is copied
                                                  ProcessData();
                                                  RegisterSpacesToReadContinuouslyPtr = 0;
                                                  currentinverter++
                                                      triggerprocessing = 1;
                                          }, 5000);
                                          // one minute before midnight - perform housekeeping actions
                                              // reset peak power for next day
                                              setState("javascript.0.Solarpower.Derived.PeakPanelPower", 0);
                                              // copy current export/import kWh - used to compute daily import/export in kWh
                                              setState("javascript.0.Solarpower.Derived.GridExportSum", getState("javascript.0.Solarpower.Huawei.Meter.PositiveActiveEnergy").val);
                                              setState("javascript.0.Solarpower.Derived.GridImportSum", getState("javascript.0.Solarpower.Huawei.Meter.ReverseActiveEnergy").val);
                                          S S 2 Replies Last reply Reply Quote 1
                                            @chris_b
                                            Vielen herzlichen Dank.
                                            Deine Updates/Verbesserungen würde ich natürlich gerne auch bei mir integrieren.
                                            Wenn ich bei der Entwicklung/Weiterentwicklung unterstützen kann (Tester etc.), lass es mich wissen!
                                            477
                                            90548
