    4. [Aufruf] js-controller 1.2.0 Testen
    • wendy2702
      wendy2702 last edited by
      Habe eben ein backup einspielen müssen und dann den Upgrade des controllers durchgeführt. Dabei das im Log bekommen:
      by controller[0]: Cannot parse "/opt/iobroker/node_modules/iobroker.vis/lib/../../iobroker.vis-mywidgets/io-package.json": Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/i
      Bekomme ich das so weg wie Looxer es ein paar Posts vorher mit den PLUMB Widgets gemacht hat?
      Und gerade noch gesehen das beim HMM jetzt das kommt:
      hmm.0	2017-10-02 20:06:26.227	info	hmm exited with 1
      hmm.0	2017-10-02 20:06:26.224	error	events.js:141 throw er; // Unhandled 'error' event ^ Error: listen EADDRINUSE :::8090 at Object.exports._errnoException (util.js:907:11) at exports._exceptionWithHostPort (util.js
      hmm.0	2017-10-02 20:06:25.948	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-10-02 20:06:20.946	info	hmm exited with 1
      hmm.0	2017-10-02 20:06:20.944	error	events.js:141 throw er; // Unhandled 'error' event ^ Error: listen EADDRINUSE :::8090 at Object.exports._errnoException (util.js:907:11) at exports._exceptionWithHostPort (util.js
      hmm.0	2017-10-02 20:06:20.649	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      smartmeter.0	2017-10-02 20:06:17.981	info	Received 10 values, 3 updated
      hmm.0	2017-10-02 20:06:15.642	info	hmm exited with 1
      hmm.0	2017-10-02 20:06:15.639	error	events.js:141 throw er; // Unhandled 'error' event ^ Error: listen EADDRINUSE :::8090 at Object.exports._errnoException (util.js:907:11) at exports._exceptionWithHostPort (util.js
      hmm.0	2017-10-02 20:06:15.353	info	Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
      hmm.0	2017-10-02 20:06:10.340	info	hmm exited with 1
      hmm.0	2017-10-02 20:06:10.337	error	at FSReqWrap.readFileAfterOpen [as oncomplete] (fs.js:303:13)
      hmm.0	2017-10-02 20:06:10.337	error	at ReadFileContext.callback (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:375:13)
      hmm.0	2017-10-02 20:06:10.337	error	at /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:63:13
      hmm.0	2017-10-02 20:06:10.337	error	at initWebServer (/opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js:333:12)
      hmm.0	2017-10-02 20:06:10.337	error	at Server.listen (net.js:1385:5)
      hmm.0	2017-10-02 20:06:10.337	error	at listen (net.js:1289:10)
      hmm.0	2017-10-02 20:06:10.337	error	at Server._listen2 (net.js:1253:14)
      hmm.0	2017-10-02 20:06:10.337	error	at exports._exceptionWithHostPort (util.js:930:20)
      hmm.0	2017-10-02 20:06:10.337	error	at Object.exports._errnoException (util.js:907:11)
      hmm.0	2017-10-02 20:06:10.337	error	Error: listen EADDRINUSE :::8090
      hmm.0	2017-10-02 20:06:10.337	error	^
      hmm.0	2017-10-02 20:06:10.337	error	throw er; // Unhandled 'error' event
      hmm.0	2017-10-02 20:06:10.337	error	events.js:141
        @wendy2702:
        Und gerade noch gesehen das beim HMM jetzt das kommt: `
        Hast du sonst noch irgendwo den Port :8090 vergeben?
        Rainer
        • wendy2702
          Nicht das ich wusste.
          Konnte den mit netstat auch nich finden.
            dtp last edited by
            @stephan61:
            habe winston und andere fehlende Dateeine mit npmn installiert geht wieder `
            War bei mir genauso. Ein direktes Update des js-controllers von Version 1.1.3 auf Version 1.2.0 mit "sudo iobroker upgrade self" schlug zunächst fehl.
            Musste dann im Verzeichnis /opt/iobroker den js-controller 1.1.3 mit
            sudo rm -R /opt/iobroker/node_modules/iobroker.js-controller
            deinstallieren, um dann folgende Schritte auszuführen:
            sudo npm i iobroker.js-controller@1.2.0
            sudo npm install winston --production
            sudo npm install greenlock --production
            sudo npm install jszip --production
            sudo iobroker start
            Jetzt läuft der ioBroker wieder. Aber kann mir jemand sagen, warum es nicht mit dem normalen Update- und Upgrade-Prozess funktioniert?
            Gruß,
            Thorsten
              apollon77 last edited by
              Was gab es denn für Fehler bei dir?!
                dtp last edited by
                Beim direkten Update und Upgrade erhalte ich seit der 1.0.3 immer die folgende Fehlermeldung: http://forum.iobroker.net/viewtopic.php?f=22&t=7188#p76543 bzw. http://forum.iobroker.net/viewtopic.php?f=22&t=7188#p76657!
                Könnte das mit nicht ausreichenden Rechten zu tun haben?
                Gruß,
                Thorsten
                  Conquest last edited by
                  @dtp:
                  Gruß,
                  Thorsten ` Kann ich bestätigen hatte die gleichen Fehlermeldungen. Und konnte es auch nur so wie im vorherigen Text beschrieben installieren.
                  LG Torsten
                    tesso last edited by
                    Jupp, war bei mir auch so.
                    Zum Glück wusste ich mir selbst zu helfen.
                    • Bluefox
                      Bluefox last edited by
                      @dtp:
                      Gruß,
                      Thorsten `
                      Platz genug? Auf SD Karte?
                      "df -h"
                        Ich habe genug Platz.
                        Kann gerade nicht nachschauen.
                        Notebook getauscht und vergessen meinen Home Zugang zu kopieren. Muß ich am Wochenende nachholen.
                          Bei mir war es eine SSD Festplatte sind noch 9GB frei dürfte also nicht am Platz gelegen haben bei mir.
                          LG Torsten
                          • frankjoke
                            frankjoke last edited by
                            Hallo mitsammen!
                            Habe mit````
                            sudo iobroker stop
                            sudo iobroker start
                            Mein Entwicklungssystem basieren auf einen orangepi erfolgreich upgedated.
                            Habe dann radar probiert und es hat auch geklappt. Als ich Radar gestoppt havbe hab' ich auch dei neue Funktion im 1.2 gesehen: Caught….
                            Allerdings gabs vom Host auch eine Fehlermeldung: Siehe unten:
                            host.opi 2017-10-05 22:45:31.206 error Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/discovery.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/no ... irgendwas mit discovery/_data.json
                            iobroker 2017-10-05 22:45:30.509 info exit 0
                            iobroker 2017-10-05 22:45:30.220 info host.opi no instances of adapter discovery found
                            iobroker 2017-10-05 22:45:29.952 info host.opi delete /opt/iobroker/node_modules/iobroker.discovery
                            iobroker 2017-10-05 22:45:27.156 info del discovery
                            host.opi 2017-10-05 22:37:44.536 info instance system.adapter.radar.0 terminated with code 0 (OK)
                            Caught 2017-10-05 22:37:44.534 error by controller[1]: noble warning: unknown handle 12 disconnected!
                            radar.0 2017-10-05 22:37:44.409 info terminating
                            host.opi 2017-10-05 22:37:43.886 info stopInstance system.adapter.radar.0 killing pid 2594
                            host.opi 2017-10-05 22:37:43.883 info stopInstance system.adapter.radar.0
                            radar.0 2017-10-05 22:37:43.898 warn Adapter disconnected and stopped with false
                            Kann es sein dass der js-controller nicht mag wenn man den discovery-adapter löscht (verwend den nie…)?
                              dtp last edited by
                              @Bluefox:
                              "df -h" `
                              Daran sollte es eigentlich nicht liegen:
                              df -h
                              Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                              /dev/root        14G    5,2G  7,5G   42% /
                              devtmpfs        458M       0  458M    0% /dev
                              tmpfs           462M       0  462M    0% /dev/shm
                              tmpfs           462M    6,3M  456M    2% /run
                              tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                              tmpfs           462M       0  462M    0% /sys/fs/cgroup
                              /dev/mmcblk0p6   63M     22M   42M   34% /boot
                              tmpfs            93M       0   93M    0% /run/user/1000
                              52
                              8182
