    4. Daikin Cloud Adapter nodejs18 [gelöst]
      JoergH @Glasfaser last edited by
      @glasfaser Achso...ja, wie gesagt der Adapter ist installiert, aber wenn ich eine Instanz hinzufügen will erscheint das Fenster.
      • Glasfaser
        Glasfaser @JoergH last edited by
        @joergh
        Zeige die Full-Ausgabe von
        iob diag
          @glasfaser
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Model : Raspberry Pi 4 Model B Rev 1.4
          Architecture : aarch64
          Docker : false
          Virtualization : none
          Distributor ID: Debian
          Description: Debian GNU/Linux 11 (bullseye)
          Release: 11
          Codename: bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
          21:22:25 up 9:05, 1 user, load average: 0.87, 0.71, 0.73
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          Other values than 0x0 hint to temperature/voltage problems
          temp=51.6'C
          volt=0.9160V
          *** Time and Time Zones ***
          Local time: Wed 2023-05-24 21:22:26 CEST
          Universal time: Wed 2023-05-24 19:22:26 UTC
          RTC time: n/a
          NTP service: active
          RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: false
          Desktop:
          Terminal: tty
          Boot Target: multi-user.target
          *** MEMORY ***
          total used free shared buff/cache available
          Mem: 7.8G 2.7G 4.1G 1.0M 954M 5.1G
          Swap: 99M 0B 99M
          Total: 7.9G 2.7G 4.2G
               7811 M total memory
               2729 M used memory
               2872 M active memory
                642 M inactive memory
               4127 M free memory
                 92 M buffer memory
                862 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          Filesystem Type Size Used Avail Use% Mounted on
          /dev/root ext4 118G 11G 103G 10% /
          devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev
          tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
          tmpfs tmpfs 1.6G 1.3M 1.6G 1% /run
          tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
          /dev/sda1 vfat 255M 31M 225M 13% /boot
          tmpfs tmpfs 782M 0 782M 0% /run/user/1000
          [Wed May 24 12:16:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:F1:62:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 usb-storage.quirk=152d:0579:u console=ttyS0,115200 console=tty1 root=PARTUUID=622a00f4-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Wed May 24 12:16:51 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed May 24 12:16:51 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Wed May 24 12:16:53 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET SOURCE FSTYPE OPTIONS
          / /dev/sda2 ext4 rw,noatime
          `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
          6.9G /var/
          5.3G /var/log
          4.0G /var/log/journal/ebf43f1ac9ac40f88ddf4138fee55e47
          925M /var/lib
          Archived and active journals take up 3.9G in the file system.
          /opt/iobroker/backups:
          93M /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          413M /opt/iobroker/iobroker-data/
          270M /opt/iobroker/iobroker-data/files
          87M /opt/iobroker/iobroker-data/backup-objects
          51M /opt/iobroker/iobroker-data/files/javascript.admin
          48M /opt/iobroker/iobroker-data/files/telegram.admin
          30M /opt/iobroker/iobroker-data/states.jsonl
          26M /opt/iobroker/iobroker-data/objects.jsonl
          15M /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
          8.5M /opt/iobroker/iobroker-data/files/vis.0/Homematic_Steuerung/img/Eigene_Bilder/20180322_153925_HDR.jpg
          7.2M /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
          *** NodeJS-Installation ***
          /usr/bin/nodejs v18.16.0
          /usr/bin/node v18.16.0
          /usr/bin/npm 9.5.1
          /usr/bin/npx 9.5.1
          nodejs:
          Installed: 18.16.0-deb-1nodesource1
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
          *** 18.16.0-deb-1nodesource1 500
          500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
          100 /var/lib/dpkg/status
          12.22.12~dfsg-1~deb11u4 500
          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          12.22.12~dfsg-1~deb11u3 500
          500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller: 4.0.24
          admin: 6.3.5
          javascript: 6.1.4
          Adapters from github: 3
          Adapter State
          • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          • system.adapter.backitup.0 : backitup : raspberrypi - enabled
            system.adapter.birthdays.0 : birthdays : raspberrypi - enabled
          • system.adapter.denon.0 : denon : raspberrypi - enabled
          • system.adapter.discovery.0 : discovery : raspberrypi - enabled
            system.adapter.dwd.0 : dwd : raspberrypi - enabled
          • system.adapter.exchangerates.0 : exchangerates : raspberrypi - enabled
          • system.adapter.fb-checkpresence.0 : fb-checkpresence : raspberrypi - enabled
          • system.adapter.firetv.0 : firetv : raspberrypi - enabled
          • system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - enabled
          • system.adapter.go-e.0 : go-e : raspberrypi - enabled
          • system.adapter.ham.0 : ham : raspberrypi - enabled
          • system.adapter.hm-rega.0 : hm-rega : raspberrypi - enabled
          • system.adapter.hm-rpc.0 : hm-rpc : raspberrypi - enabled, port: 0
          • system.adapter.hm-rpc.1 : hm-rpc : raspberrypi - enabled, port: 0
            system.adapter.ical.0 : ical : raspberrypi - enabled
            system.adapter.ical.1 : ical : raspberrypi - enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi - disabled
            system.adapter.icons-icons8.0 : icons-icons8 : raspberrypi - disabled
            system.adapter.icons-material-png.0 : icons-material-png : raspberrypi - disabled
            system.adapter.icons-material-svg.0 : icons-material-svg : raspberrypi - disabled
            system.adapter.icons-mfd-png.0 : icons-mfd-png : raspberrypi - disabled
            system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled
          • system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086
          • system.adapter.info.0 : info : raspberrypi - enabled
          • system.adapter.javascript.0 : javascript : raspberrypi - enabled
          • system.adapter.mielecloudservice.0 : mielecloudservice : raspberrypi - enabled
          • system.adapter.mihome-vacuum.1 : mihome-vacuum : raspberrypi - enabled, port: 54321
          • system.adapter.modbus.0 : modbus : raspberrypi - enabled
          • system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1883, bind: 0.0.0.0
            system.adapter.netatmo-crawler.0 : netatmo-crawler : raspberrypi - enabled
          • system.adapter.octoprint.0 : octoprint : raspberrypi - enabled
            system.adapter.odl.0 : odl : raspberrypi - enabled
            system.adapter.openweathermap.0 : openweathermap : raspberrypi - enabled
          • system.adapter.pollenflug.0 : pollenflug : raspberrypi - enabled
          • system.adapter.powerfox2.0 : powerfox2 : raspberrypi - enabled
          • system.adapter.pvforecast.0 : pvforecast : raspberrypi - enabled
          • system.adapter.renault.0 : renault : raspberrypi - enabled
          • system.adapter.sayit.0 : sayit : raspberrypi - enabled, port: 0
            system.adapter.schoolfree.0 : schoolfree : raspberrypi - enabled
          • system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0
          • system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi - enabled
          • system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0
          • system.adapter.tesla-motors.0 : tesla-motors : raspberrypi - enabled
          • system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled
          • system.adapter.vaillant.0 : vaillant : raspberrypi - enabled
            system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : raspberrypi - disabled
            system.adapter.vis-fancyswitch.0 : vis-fancyswitch : raspberrypi - disabled
            system.adapter.vis-google-fonts.0 : vis-google-fonts : raspberrypi - enabled
            system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled
            system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - disabled
          • system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled
            system.adapter.vis-justgage.0 : vis-justgage : raspberrypi - disabled
            system.adapter.vis-material-advanced.0 : vis-material-advanced : raspberrypi - disabled
            system.adapter.vis-plumb.0 : vis-plumb : raspberrypi - disabled
            system.adapter.vis-rgraph.0 : vis-rgraph : raspberrypi - disabled
            system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - disabled
            system.adapter.vis-weather.0 : vis-weather : raspberrypi - disabled
            system.adapter.vis.0 : vis : raspberrypi - enabled
          • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
          • instance is alive
          ioBroker-Repositories
          stable : http://download.iobroker.net/sources-dist.json
          beta : http://download.iobroker.net/sources-dist-latest.json
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter "admin" : 6.3.5 , installed 6.3.5
          Adapter "backitup" : 2.6.19 , installed 2.6.19
          Adapter "birthdays" : 2.2.0 , installed 2.2.0
          Adapter "daikin-cloud" : 0.2.3 , installed 0.2.3
          Adapter "denon" : 1.15.0 , installed 1.15.0
          Adapter "discovery" : 3.1.0 , installed 3.1.0
          Adapter "dwd" : 2.8.3 , installed 2.8.3
          Adapter "exchangerates": 0.0.14 , installed 0.0.14
          Adapter "fb-checkpresence": 1.1.26, installed 1.1.26
          Adapter "firetv" : 1.0.0 , installed 1.0.0
          Adapter "fullybrowser" : 2.1.2 , installed 2.1.2
          Adapter "go-e" : 1.0.27 , installed 1.0.27
          Adapter "ham" : 5.3.1 , installed 5.3.1
          Adapter "hm-rega" : 3.0.46 , installed 3.0.46
          Adapter "hm-rpc" : 1.15.16 , installed 1.15.16
          Adapter "ical" : 1.13.2 , installed 1.13.2
          Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
          Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
          Adapter "icons-material-png": 0.1.0, installed 0.1.0
          Adapter "icons-material-svg": 0.1.0, installed 0.1.0
          Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
          Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
          Adapter "influxdb" : 3.2.0 , installed 3.2.0
          Adapter "info" : 1.9.26 , installed 1.9.26
          Adapter "javascript" : 6.1.4 , installed 6.1.4
          Controller "js-controller": 4.0.24 , installed 4.0.24
          Adapter "mielecloudservice": 6.5.4, installed 6.5.4
          Adapter "mihome-vacuum": 3.9.5 , installed 3.9.5
          Adapter "modbus" : 5.0.11 , installed 5.0.11
          Adapter "mqtt" : 4.0.7 , installed 4.0.7
          Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1
          Adapter "octoprint" : 4.0.0 , installed 4.0.0
          Adapter "odl" : 2.0.5 , installed 2.0.5
          Adapter "openweathermap": 0.3.3 , installed 0.3.3
          Adapter "pollenflug" : 1.0.6 , installed 1.0.6
          Adapter "powerfox2" : 0.0.12 , installed 0.0.12
          Adapter "pvforecast" : 2.3.0 , installed 2.3.0
          Adapter "renault" : 0.0.15 , installed 0.0.17
          Adapter "sayit" : 1.12.3 , installed 1.12.3
          Adapter "schoolfree" : 1.1.1 , installed 1.1.1
          Adapter "shelly" : 6.3.1 , installed 6.3.1
          Adapter "simple-api" : 2.7.2 , installed 2.7.2
          Adapter "socketio" : 4.2.0 , installed 4.2.0
          Adapter "telegram" : 1.15.2 , installed 1.15.2
          Adapter "tesla-motors" : 1.3.2 , installed 1.3.2
          Adapter "trashschedule": 2.2.0 , installed 2.2.0
          Adapter "vaillant" : 0.1.2 , installed 0.1.2
          Adapter "vis" : 1.4.16 , installed 1.4.16
          Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
          Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
          Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
          Adapter "vis-hqwidgets": 1.3.0 , installed 1.3.0
          Adapter "vis-icontwo" : 0.93.0 , installed 0.93.0
          Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1
          Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
          Adapter "vis-material-advanced": 1.7.2, installed 1.7.2
          Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
          Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
          Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
          Adapter "vis-weather" : 2.5.6 , installed 2.5.6
          Adapter "web" : 4.3.0 , installed 4.3.0
          Adapter "ws" : 1.3.0 , installed 1.3.0
          Objects and States
          Objects: 19935
          States: 15757
          W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Translations (main/i18n/Translation-de_DE) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Translations (main/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
          Hit:7 https://packages.grafana.com/oss/deb stable InRelease
          Hit:8 https://repos.influxdata.com/debian bullseye InRelease
          Hit:9 https://apt.pivccu.de/piVCCU stable InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
          tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 17545 2305/io.mqtt.0
          tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 111 15653 831/influxd
          tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12799 937/sshd: /usr/sbin
          tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 15143 1326/iobroker.js-co
          tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 12922 1326/iobroker.js-co
          tcp 0 0 10.0.3.1:53 0.0.0.0:* LISTEN 0 12188 926/dnsmasq
          tcp 0 0 192.168.178.55:2010 0.0.0.0:* LISTEN 1001 13293 2389/io.hm-rpc.1
          tcp 0 0 192.168.178.55:2001 0.0.0.0:* LISTEN 1001 16179 2017/io.hm-rpc.0
          tcp6 0 0 :::22 :::* LISTEN 0 12801 937/sshd: /usr/sbin
          tcp6 0 0 :::8082 :::* LISTEN 1001 18380 3243/io.web.0
          tcp6 0 0 :::8081 :::* LISTEN 1001 15243 1672/io.admin.0
          tcp6 0 0 :::8086 :::* LISTEN 111 15662 831/influxd
          tcp6 0 0 :::3000 :::* LISTEN 112 15870 1325/grafana
          udp 0 0 0.0.0.0:51826 0.0.0.0:* 0 12198 -
          udp 0 0 0.0.0.0:43971 0.0.0.0:* 108 11970 430/avahi-daemon: r
          udp 0 0 10.0.3.1:53 0.0.0.0:* 0 12187 926/dnsmasq
          udp 0 0 0.0.0.0:67 0.0.0.0:* 0 12184 926/dnsmasq
          udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12633 593/dhclient
          udp 0 0 0.0.0.0:53422 0.0.0.0:* 1001 17503 2191/io.mihome-vacu
          udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 17274 1933/io.ham.0
          udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11968 430/avahi-daemon: r
          udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 17259 2368/io.shelly.0
          udp6 0 0 :::51826 :::* 0 12199 -
          udp6 0 0 :::33920 :::* 108 11971 430/avahi-daemon: r
          udp6 0 0 :::5353 :::* 108 11969 430/avahi-daemon: r
          "1033":[false,"1970-01-01 01:00:00"],
          "950":[true,"2023-05-24 12:18:14"],
          "7789":["Fensterstatus%20war%20ge%F6ffnet%20","2023-05-24 12:18:13"],
          "1395":[15.000000,"2023-05-24 12:18:13"],
          "16407":[false,"1970-01-01 01:00:00"],
          "10027":[false,"1970-01-01 01:00:00"],
          "40":[0,"2023-05-24 12:18:14"],
          "41":[3,"2023-05-24 21:23:10"]}
          2023-05-24 21:24:00.003 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 527.6809
          2023-05-24 21:24:00.005 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
          2023-05-24 21:24:00.006 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
          2023-05-24 21:24:00.006 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
          2023-05-24 21:24:00.007 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: Ladestrom go-e bei TESLA Prio: 0
          2023-05-24 21:24:00.008 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -5 / -5
          2023-05-24 21:24:00.008 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: Gemittelt GO-E: 0 - Restzeit go-e: 00:00
          2023-05-24 21:24:00.009 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
          2023-05-24 21:24:00.010 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: 0 - 3024.19 - 0
          2023-05-24 21:24:00.011 - info: javascript.0 (1854) script.js.Energiemanagement.PV_Laden_neu: 0:00
          2023-05-24 21:24:00.060 - info: javascript.0 (1854) script.js.Energiemanagement.Loadmanagement_Geräte: Erforderliche Leistung Kfz.: 0
          2023-05-24 21:24:00.061 - info: javascript.0 (1854) script.js.Energiemanagement.Loadmanagement_Geräte: Geschirrspüle remaining time (bis morgen): 17:23
          2023-05-24 21:24:00.062 - info: javascript.0 (1854) script.js.Energiemanagement.Loadmanagement_Geräte: Waschmaschine remaining time (bis morgen): 18:36
          2023-05-24 21:24:00.063 - info: javascript.0 (1854) script.js.Energiemanagement.Loadmanagement_Geräte: Remaining time Geschirrspüler (lt. Gerät): 00:00 Remaining time Waschmaschine (lt. Gerät): 00:00
          2023-05-24 21:24:00.063 - info: javascript.0 (1854) script.js.Energiemanagement.Loadmanagement_Geräte: Komplettüberschuss aktuell (inkl. Autos): -700 Erforderliche Leistung: 0
          2023-05-24 21:24:00.074 - info: javascript.0 (1854) script.js.Energiemanagement.Loadmanagement_Geräte: Erforderlicher Mindestüberschuss: 0
          2023-05-24 21:24:00.123 - info: host.raspberrypi instance system.adapter.powerfox2.0 started with pid 36185
          [/s]
            Thomas Braun Most Active @JoergH last edited by Thomas Braun
            @joergh
            Deine /etc/apt/sources.list.d/grafana.list beinhaltet Doubletten.
            Und die Codetags wurden in den Output nicht zu Spaß gesetzt. Vermeide SpoilerTags, verwende Codetags.
              JoergH @Thomas Braun last edited by
              @thomas-braun Sowas hat er beim letzten update auch gesagt. Wie kriege ich die los?
                @joergh
                Die doppelte Zeile löschen.
                  @thomas-braun Ok, danke. War ja nur eine 🙂
                    @joergh
                    cd /opt/iobroker
                    npm ls
                      iobroker.inst@3.0.0 /opt/iobroker
                      ├── buffer-shims@1.0.0 extraneous
                      ├── decimal.js@10.4.3 extraneous
                      ├── futoin-hkdf@1.4.3 extraneous
                      ├── homebridge-plugin-wrapper@3.2.0 extraneous
                      ├── iobroker.admin@6.3.5
                      ├── iobroker.backitup@2.6.19
                      ├── iobroker.birthdays@2.2.0
                      ├── iobroker.daikin-cloud@0.2.3 (git+ssh://git@github.com/Apollon77/ioBroker.daikin-cloud.git#03b831dac009b1d9cd0a7399f7e9a38486d06d19)
                      ├── iobroker.denon@1.15.0
                      ├── iobroker.discovery@3.1.0
                      ├── iobroker.dwd@2.8.3
                      ├── iobroker.exchangerates@0.0.14
                      ├── iobroker.fb-checkpresence@1.1.26
                      ├── iobroker.firetv@1.0.0
                      ├── iobroker.fullybrowser@2.1.2
                      ├── iobroker.go-e@1.0.27
                      ├── iobroker.ham@5.3.1
                      ├── iobroker.hm-rega@3.0.46
                      ├── iobroker.hm-rpc@1.15.16
                      ├── iobroker.ical@1.13.2
                      ├── iobroker.icons-addictive-flavour-png@0.1.0
                      ├── iobroker.icons-icons8@0.0.1
                      ├── iobroker.icons-material-png@0.1.0
                      ├── iobroker.icons-material-svg@0.1.0
                      ├── iobroker.icons-mfd-png@1.1.0
                      ├── iobroker.icons-mfd-svg@1.1.0
                      ├── iobroker.influxdb@3.2.0
                      ├── iobroker.info@1.9.26
                      ├── iobroker.javascript@6.1.4
                      ├── iobroker.js-controller@4.0.24
                      ├── iobroker.mielecloudservice@6.5.4
                      ├── iobroker.mihome-vacuum@3.9.5
                      ├── iobroker.modbus@5.0.11
                      ├── iobroker.mqtt@4.0.7
                      ├── iobroker.netatmo-crawler@0.8.1
                      ├── iobroker.octoprint@4.0.0
                      ├── iobroker.odl@2.0.5
                      ├── iobroker.openweathermap@0.3.3
                      ├── iobroker.pollenflug@1.0.6
                      ├── iobroker.powerfox2@0.0.12
                      ├── iobroker.pvforecast@2.3.0
                      ├── iobroker.renault@0.0.17 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#83425a80b23e2ae84ec1768b0fd1024ae3b557aa)
                      ├── iobroker.sayit@1.12.3
                      ├── iobroker.schoolfree@1.1.1
                      ├── iobroker.shelly@6.3.1
                      ├── iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
                      ├── iobroker.telegram@1.15.2
                      ├── iobroker.tesla-motors@1.3.2
                      ├── iobroker.trashschedule@2.2.0
                      ├── iobroker.vaillant@0.1.2
                      ├── iobroker.vis-canvas-gauges@1.0.1
                      ├── iobroker.vis-fancyswitch@1.1.0
                      ├── iobroker.vis-google-fonts@1.0.4
                      ├── iobroker.vis-hqwidgets@1.3.0
                      ├── iobroker.vis-icontwo@0.93.0
                      ├── iobroker.vis-inventwo@3.3.1
                      ├── iobroker.vis-justgage@1.0.2
                      ├── iobroker.vis-material-advanced@1.7.2
                      ├── iobroker.vis-plumb@1.0.2
                      ├── iobroker.vis-rgraph@0.0.2
                      ├── iobroker.vis-timeandweather@1.2.2
                      ├── iobroker.vis-weather@2.5.6
                      ├── iobroker.vis@1.4.16
                      ├── iobroker.web@4.3.0
                      ├── mock-require@3.0.3 extraneous
                      ├── node-persist@0.0.11 extraneous
                      ├── q@1.1.2 extraneous
                      ├── remove-trailing-separator@1.1.0 extraneous
                      └── string-argv@0.3.1 extraneous
                        @joergh
                        npm prune
                        Und dann bitte nochmal
                        iob diag
                        aber in CodeTags, nicht als Spoiler.
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=debian
                           21:58:16 up  9:41,  1 user,  load average: 1.19, 0.92, 1.02
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=51.6'C
                          volt=0.9160V
                                         Local time: Wed 2023-05-24 21:58:17 CEST
                                     Universal time: Wed 2023-05-24 19:58:17 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            7.8G        2.4G        4.1G        1.0M        1.3G        5.3G
                          Swap:            99M          0B         99M
                          Total:          7.9G        2.4G        4.2G
                                   7811 M total memory
                                   2446 M used memory
                                   2593 M active memory
                                    912 M inactive memory
                                   4064 M free memory
                                    131 M buffer memory
                                   1169 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          6.9G    /var/
                          5.3G    /var/log
                          929M    /var/lib
                          401M    /opt/iobroker/iobroker-data/
                          34M     /opt/iobroker/iobroker-data/objects.jsonl
                          9.2M    /opt/iobroker/iobroker-data/states.jsonl
                          /usr/bin/npm            9.5.1
                          /usr/bin/npx            9.5.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.3.5
                          javascript:     6.1.4
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                          + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                          + system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              -  enabled
                          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                          + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
                          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                          + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
                          + system.adapter.ham.0                    : ham                   : raspberrypi                              -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                          + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                          + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
                          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                          + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
                          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                          + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                          + system.adapter.renault.0                : renault               : raspberrypi                              -  enabled
                          + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
                          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                          + system.adapter.vaillant.0               : vaillant              : raspberrypi                              -  enabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + instance is alive
                          Objects and States
                          Objects:        19935
                          States:         15758
                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                          Hit:7 https://repos.influxdata.com/debian bullseye InRelease
                          Hit:8 https://deb.nodesource.com/node_18.x bullseye InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       894933     36776/io.mqtt.0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       897434     36528/iobroker.js-c
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       895635     36528/iobroker.js-c
                          tcp        0      0 192.168.178.55:2010     0.0.0.0:*               LISTEN      1001       897012     36846/io.hm-rpc.1
                          tcp        0      0 192.168.178.55:2001     0.0.0.0:*               LISTEN      1001       896833     36659/io.hm-rpc.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       900999     37344/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       894640     36549/io.admin.0
                          udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       896912     36743/io.mihome-vac
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       897715     36618/io.ham.0
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       898088     36828/io.shelly.0
                          2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) hm-rpc.1.001B9BE9A05111.6.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
                          2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) xml multicall <event>: raspberrypi:hm-rpc.1:3315ff8b2de0e5e6cb69b5a334400967,001B9BE9A05111:6,LEVEL,0.08
                          2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) xmlrpc <- event ["raspberrypi:hm-rpc.1:3315ff8b2de0e5e6cb69b5a334400967","001B9BE9A05111:6","LEVEL",0.08]
                          2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) hm-rpc.1.001B9BE9A05111.6.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0.08" => "8"
                          2023-05-24 21:59:26.904  - debug: hm-rega.0 (36640) --> polling.fn
                          2023-05-24 21:59:26.908  - debug: hm-rega.0 (36640) --> !# polling.fn 1.3 !# !# Dieses Script gibt die Werte aller Systemvariablen als J
                          2023-05-24 21:59:26.917  - debug: hm-rega.0 (36640) <-- {"15191":[0,"2023-05-24 12:18:13"],
                          "41":[4,"2023-05-24 21:59:24"]}
                          2023-05-24 21:59:30.002  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 563.1808833333333
                          2023-05-24 21:59:30.003  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
                          2023-05-24 21:59:30.004  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
                          2023-05-24 21:59:30.004  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
                          2023-05-24 21:59:30.004  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom go-e bei TESLA Prio: 0
                          2023-05-24 21:59:30.005  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -5 / -5
                          2023-05-24 21:59:30.005  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Gemittelt GO-E: 0 - Restzeit go-e: 00:00
                          2023-05-24 21:59:30.006  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
                          2023-05-24 21:59:30.006  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: 0 - 3033.81 - 0
                          2023-05-24 21:59:30.006  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: 0:00
                            Was hat das mit Anregungen und Wünschen von Einsteigern zu tun???
                              @joergh
                              Sollte eigentlich funktionieren.
                              Hier bei mir geht's jedenfalls.
                                @thomas-braun @apollon77
                                Leider funktioniert es bei mir nach wie vor nicht. Ich kann keine Instanz hinzufügen, weil immer das Fenster aufgeht, dass es mit nodejs 18.x nicht funktioniert.
                                  apollon77 @JoergH last edited by
                                  @joergh Und du hast es gemacht wie auf den screens?
                                  Admin - Expertenmodus - Adapter - Custom Install/GitHub icon - von GitHub Tab - Adapter wählen - installieren
                                    JoergH @apollon77 last edited by
                                    @apollon77
                                    Ja, siehe Screenshot oben.
                                    Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                                      @joergh
                                      iobroker upload all
                                        @joergh Bei installation über die Katze gibt es an sich keinerlei checks und auch keinerlei warnungen
                                          @apollon77
                                          Der Adapter wird ja auch installiert, aber wenn ich dann mit + eine Instanz erstellen will, dann kommt das Popup Fenster mit der Ansage, dass es mit nodejs 18.6 nicht geht und ich kann keine Instanz hinzufügen, sondern nur schließen auswählen.
                                            @joergh Hast Du Single oder MultiHost system? Falls Multihost - hast DU auch den korrekten Host gewählt für die installation?
                                            4916
