    4. Daikin Cloud Adapter nodejs18 [gelöst]
      JoergH @Thomas Braun last edited by
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       21:58:16 up  9:41,  1 user,  load average: 1.19, 0.92, 1.02
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=51.6'C
      volt=0.9160V
      *** Time and Time Zones ***
                     Local time: Wed 2023-05-24 21:58:17 CEST
                 Universal time: Wed 2023-05-24 19:58:17 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.8G        2.4G        4.1G        1.0M        1.3G        5.3G
      Swap:            99M          0B         99M
      Total:          7.9G        2.4G        4.2G
               7811 M total memory
               2446 M used memory
               2593 M active memory
                912 M inactive memory
               4064 M free memory
                131 M buffer memory
               1169 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      118G   11G  103G  10% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Wed May 24 12:16:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:F1:62:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  usb-storage.quirk=152d:0579:u console=ttyS0,115200 console=tty1 root=PARTUUID=622a00f4-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed May 24 12:16:51 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed May 24 12:16:51 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Wed May 24 12:16:53 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
      6.9G    /var/
      5.3G    /var/log
      4.0G    /var/log/journal/ebf43f1ac9ac40f88ddf4138fee55e47
      929M    /var/lib
      Archived and active journals take up 3.9G in the file system.
      /opt/iobroker/backups:
      93M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      401M    /opt/iobroker/iobroker-data/
      270M    /opt/iobroker/iobroker-data/files
      87M     /opt/iobroker/iobroker-data/backup-objects
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/telegram.admin
      34M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      9.2M    /opt/iobroker/iobroker-data/states.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/vis.0/Homematic_Steuerung/img/Eigene_Bilder/20180322_153925_HDR.jpg
      7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
      + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
      + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
      + system.adapter.ham.0                    : ham                   : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
      + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
        system.adapter.odl.0                    : odl                   : raspberrypi                              -  enabled
        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
      + system.adapter.renault.0                : renault               : raspberrypi                              -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
        system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.vaillant.0               : vaillant              : raspberrypi                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
      Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
      Adapter    "denon"        : 1.15.0   , installed 1.15.0
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "exchangerates": 0.0.14   , installed 0.0.14
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "firetv"       : 1.0.0    , installed 1.0.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "go-e"         : 1.0.27   , installed 1.0.27
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
      Adapter    "odl"          : 2.0.5    , installed 2.0.5
      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
      Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
      Adapter    "renault"      : 0.0.15   , installed 0.0.17
      Adapter    "sayit"        : 1.12.3   , installed 1.12.3
      Adapter    "schoolfree"   : 1.1.1    , installed 1.1.1
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vaillant"     : 0.1.2    , installed 0.1.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Objects and States
      Objects:        19935
      States:         15758
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://packages.grafana.com/oss/deb stable InRelease
      Hit:7 https://repos.influxdata.com/debian bullseye InRelease
      Hit:8 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:9 https://apt.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       894933     36776/io.mqtt.0
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      111        15653      831/influxd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12799      937/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       897434     36528/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       895635     36528/iobroker.js-c
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12188      926/dnsmasq
      tcp        0      0 192.168.178.55:2010     0.0.0.0:*               LISTEN      1001       897012     36846/io.hm-rpc.1
      tcp        0      0 192.168.178.55:2001     0.0.0.0:*               LISTEN      1001       896833     36659/io.hm-rpc.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12801      937/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       900999     37344/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       894640     36549/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      111        15662      831/influxd
      tcp6       0      0 :::3000                 :::*                    LISTEN      112        15870      1325/grafana
      udp        0      0 0.0.0.0:51826           0.0.0.0:*                           0          12198      -
      udp        0      0 0.0.0.0:43971           0.0.0.0:*                           108        11970      430/avahi-daemon: r
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12187      926/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12184      926/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12633      593/dhclient
      udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       896912     36743/io.mihome-vac
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       897715     36618/io.ham.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11968      430/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       898088     36828/io.shelly.0
      udp6       0      0 :::51826                :::*                                0          12199      -
      udp6       0      0 :::33920                :::*                                108        11971      430/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        11969      430/avahi-daemon: r
      2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) hm-rpc.1.001B9BE9A05111.6.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
      2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) xml multicall <event>: raspberrypi:hm-rpc.1:3315ff8b2de0e5e6cb69b5a334400967,001B9BE9A05111:6,LEVEL,0.08
      2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) xmlrpc <- event ["raspberrypi:hm-rpc.1:3315ff8b2de0e5e6cb69b5a334400967","001B9BE9A05111:6","LEVEL",0.08]
      2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) hm-rpc.1.001B9BE9A05111.6.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0.08" => "8"
      2023-05-24 21:59:26.904  - debug: hm-rega.0 (36640) --> polling.fn
      2023-05-24 21:59:26.908  - debug: hm-rega.0 (36640) --> !# polling.fn 1.3 !# !# Dieses Script gibt die Werte aller Systemvariablen als J
      2023-05-24 21:59:26.917  - debug: hm-rega.0 (36640) <-- {"15191":[0,"2023-05-24 12:18:13"],
      "1033":[false,"1970-01-01 01:00:00"],
      "950":[true,"2023-05-24 12:18:14"],
      "7789":["Fensterstatus%20war%20ge%F6ffnet%20","2023-05-24 12:18:13"],
      "1395":[15.000000,"2023-05-24 12:18:13"],
      "16407":[false,"1970-01-01 01:00:00"],
      "10027":[false,"1970-01-01 01:00:00"],
      "40":[0,"2023-05-24 12:18:14"],
      "41":[4,"2023-05-24 21:59:24"]}
      2023-05-24 21:59:30.002  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 563.1808833333333
      2023-05-24 21:59:30.003  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
      2023-05-24 21:59:30.004  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
      2023-05-24 21:59:30.004  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
      2023-05-24 21:59:30.004  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom go-e bei TESLA Prio: 0
      2023-05-24 21:59:30.005  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -5 / -5
      2023-05-24 21:59:30.005  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Gemittelt GO-E: 0 - Restzeit go-e: 00:00
      2023-05-24 21:59:30.006  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
      2023-05-24 21:59:30.006  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: 0 - 3033.81 - 0
      2023-05-24 21:59:30.006  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: 0:00
        Was hat das mit Anregungen und Wünschen von Einsteigern zu tun???
          Thomas Braun Most Active @JoergH last edited by
          @joergh
          Sollte eigentlich funktionieren.
          Hier bei mir geht's jedenfalls.
            @thomas-braun @apollon77
            Leider funktioniert es bei mir nach wie vor nicht. Ich kann keine Instanz hinzufügen, weil immer das Fenster aufgeht, dass es mit nodejs 18.x nicht funktioniert.
              apollon77 @JoergH last edited by
              @joergh Und du hast es gemacht wie auf den screens?
              Admin - Expertenmodus - Adapter - Custom Install/GitHub icon - von GitHub Tab - Adapter wählen - installieren
                JoergH @apollon77 last edited by
                @apollon77
                Ja, siehe Screenshot oben.
                Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                  @joergh
                  iobroker upload all
                    @joergh Bei installation über die Katze gibt es an sich keinerlei checks und auch keinerlei warnungen
                      @apollon77
                      Der Adapter wird ja auch installiert, aber wenn ich dann mit + eine Instanz erstellen will, dann kommt das Popup Fenster mit der Ansage, dass es mit nodejs 18.6 nicht geht und ich kann keine Instanz hinzufügen, sondern nur schließen auswählen.
                        @joergh Hast Du Single oder MultiHost system? Falls Multihost - hast DU auch den korrekten Host gewählt für die installation?
                          @apollon77 Ich habe ein Single Host System....
                            @joergh Dann ehrlich ... verstehe ich es nicht, wenn du alles gemacht hast wie oben gesagt sollte das nicht passieren
                              @apollon77
                              Nachdem ich gestern mal Schluß gemacht habe, habe ich heute den Rechner angeschaltet, mich eingeloggt und dann auf der Adapterseite einfach noch einmal probiert eine Instanz zu installieren und siehe da es ging!
                              Anscheinend muss es wohl wieder ein Cache Thema oder sowas gewesen sein. Gestern bin ich immer auf der Adapterseite geblieben und habe den Adapter mehrfach deinstalliert, per Github wieder installiert und dann direkt versucht eine Instanz er erstellen und immer kam das Popup Fenster.
                              Fazit: Immer besser mal den Browser schließen und neu öffnen 😕
                              Viele Dank für die Hinweise an alle!
                                @apollon77
                                Leider habe ich mich etwas zu früh gefreut, denn die Instanz ist zwar nun wieder da und er verbindet sich auch, aber er zieht keine Daten
                                Dafür aber einige Warnungen im Log:
                                daikin-cloud.0
                                	2023-05-25 14:09:54.815	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:09:54.814	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.climateControl.sensoryData.outdoorTemperature" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:09:54.397	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:08:54.590	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:08:54.167	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:07:54.399	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:07:53.950	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:06:54.008	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:06:54.007	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.climateControl.sensoryData.outdoorTemperature" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:06:54.006	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.gateway.wifiConnectionStrength" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:06:53.752	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:06:53.751	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.climateControl.sensoryData.outdoorTemperature" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:06:53.750	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.gateway.wifiConnectionStrength" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:05:53.714	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                daikin-cloud.0
                                	2023-05-25 14:05:53.548	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                                • Glasfaser
                                  Glasfaser @JoergH last edited by
                                  @joergh sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
                                  dann zeige bitte ein DEBUG Log Ausgabe .. so kann man nichts dazu sagen
                                    JoergH @Glasfaser last edited by
                                    @glasfaser Hat sich inzwischen erledigt. Nachdem ich ein paar Stunden nicht dran war sind sie da.
                                    • Elektroniker86
                                      Elektroniker86 last edited by Elektroniker86
                                      Mist bei mir lässt sich der Adapter nicht von Github installieren/updaten:
                                      $ iobroker url Apollon77/ioBroker.daikin-cloud --host iobroker --debug
                                      install Apollon77/ioBroker.daikin-cloud
                                      NPM version: 9.5.1
                                      Installing Apollon77/ioBroker.daikin-cloud... (System call)
                                      npm ERR! code EBADENGINE
                                      upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                                      Process exited with code 0
                                      Ich weiß jetzt nicht mehr weiter. Bin für jede Hilfe dankbar!
                                        Homoran Global Moderator Administrators @Elektroniker86 last edited by
                                        @elektroniker86 sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
                                        was für eine Hardware/OS?
                                        Elektroniker86 1 Reply Last reply Reply Quote 0
                                        • Elektroniker86
                                          Elektroniker86 @Homoran last edited by
                                          Der ioBroker läuft in einem Ubuntu 22.04.2 LTS auf einem Proxmox System als VM
                                          • Elektroniker86
                                            Ich habe vor ein paar Tagen das System laut dieser Anleitung:
                                            https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                                            von Nodejs 16 auf 18 aktualisiert. Keine Auffälligkeiten alles rund gelaufen.
                                            4937
