    3. Entwicklung
    4. Adapter: Worx Landroid v2.x.x
    • lobomau
      lobomau last edited by
      @Meistertr:
      Der Worx server scheint zur zeit offline zu sein `
      Ah. Deswegen. Da ich über app auch keine Verbindung bekomme, war schon klar, dass es nicht am Adapter liegt.
      Aber trotzdem steht auch im log "logged in as XXXX - user token retrieved from API." Deswegen dachte ich, es findet schon eine Verbindung zum worx server statt.
      landroid-s.0	2017-10-05 08:03:38.709	info	Downloaded guest token
      sql.0	2017-10-05 08:03:38.596	info	enabled logging of landroid-s.0.mower.totalTime
      sql.0	2017-10-05 08:03:38.596	info	enabled logging of landroid-s.0.mower.totalBladeTime
      sql.0	2017-10-05 08:03:38.582	info	enabled logging of landroid-s.0.mower.totalDistance
      landroid-s.0	2017-10-05 08:03:38.484	info	starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.4
      host.brix-3150	2017-10-05 08:03:37.195	info	instance system.adapter.landroid-s.0 started with pid 26579
      host.brix-3150	2017-10-05 08:03:07.182	info	Restart adapter system.adapter.landroid-s.0 because enabled
      host.brix-3150	2017-10-05 08:03:07.182	error	instance system.adapter.landroid-s.0 terminated with code 0 (OK)
      Caught	2017-10-05 08:03:07.182	error	by controller[0]: at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:440:38) code: 'CERT_HAS_EXPIRED' }
      Caught	2017-10-05 08:03:07.182	error	by controller[0]: at TLSSocket._finishInit (_tls_wrap.js:610:8)
      Caught	2017-10-05 08:03:07.182	error	by controller[0]: at TLSSocket.emit (events.js:185:7)
      Caught	2017-10-05 08:03:07.181	error	by controller[0]: at emitNone (events.js:86:13)
      Caught	2017-10-05 08:03:07.181	error	by controller[0]: at TLSSocket. (_tls_wrap.js:1092:38)
      Caught	2017-10-05 08:03:07.181	error	by controller[0]: at Error (native)
      Caught	2017-10-05 08:03:07.180	error	by controller[0]: { Error: certificate has expired
      landroid-s.0	2017-10-05 08:03:07.142	info	terminating
      landroid-s.0	2017-10-05 08:03:07.130	info	cleaned everything up...
      landroid-s.0	2017-10-05 08:03:07.128	error	at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:440:38)
      landroid-s.0	2017-10-05 08:03:07.128	error	at TLSSocket._finishInit (_tls_wrap.js:610:8)
      landroid-s.0	2017-10-05 08:03:07.128	error	at TLSSocket.emit (events.js:185:7)
      landroid-s.0	2017-10-05 08:03:07.128	error	at emitNone (events.js:86:13)
      landroid-s.0	2017-10-05 08:03:07.128	error	at TLSSocket. (_tls_wrap.js:1092:38)
      landroid-s.0	2017-10-05 08:03:07.128	error	at Error (native)
      landroid-s.0	2017-10-05 08:03:07.128	error	Error: certificate has expired
      landroid-s.0	2017-10-05 08:03:07.128	error	uncaught exception: certificate has expired
        bku last edited by
        meine App funktioniert (jetzt) aber, aber der iobroker-Adapter nicht und auch Eisha's Win-App geht nicht.
        Gruß Bernd
        • lobomau
          @bku:
          Gruß Bernd `
          Stimmt. Bei mir geht jetzt die Handy App, aber nicht der Adapter. Ist es normal, dass da zwei verschiedene API token geholt werden (beispielhaft 111111… und 22222...)?
          host.brix-3150	2017-10-05 12:54:15.115	info	Restart adapter system.adapter.landroid-s.0 because enabled
          host.brix-3150	2017-10-05 12:54:15.114	error	instance system.adapter.landroid-s.0 terminated with code 0 (OK)
          host.brix-3150	2017-10-05 12:54:15.114	error	Caught by controller[0]: at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:440:38) code: 'CERT_HAS_EXPIRED' }
          host.brix-3150	2017-10-05 12:54:15.114	error	Caught by controller[0]: at TLSSocket._finishInit (_tls_wrap.js:610:8)
          host.brix-3150	2017-10-05 12:54:15.114	error	Caught by controller[0]: at TLSSocket.emit (events.js:185:7)
          host.brix-3150	2017-10-05 12:54:15.114	error	Caught by controller[0]: at emitNone (events.js:86:13)
          host.brix-3150	2017-10-05 12:54:15.114	error	Caught by controller[0]: at TLSSocket. (_tls_wrap.js:1092:38)
          host.brix-3150	2017-10-05 12:54:15.114	error	Caught by controller[0]: at Error (native)
          host.brix-3150	2017-10-05 12:54:15.113	error	Caught by controller[0]: { Error: certificate has expired
          landroid-s.0	2017-10-05 12:54:15.072	error	uncaught exception: certificate has expired
          landroid-s.0	2017-10-05 12:54:14.846	info	Connecting to MQTT broker
          landroid-s.0	2017-10-05 12:54:14.420	info	Fetching root CA
          landroid-s.0	2017-10-05 12:54:14.345	info	Certificate retrieved
          landroid-s.0	2017-10-05 12:53:57.095	info	API token set to 22222222222222222
          landroid-s.0	2017-10-05 12:53:57.094	info	Logged in as email@email.com - user token retrieved from API
          landroid-s.0	2017-10-05 12:53:42.939	info	API token set to 111111111111111111
          landroid-s.0	2017-10-05 12:53:42.936	info	Downloaded guest token
          • Meistertr
            Die App geht aber auch nicht vollkommen rund. Habe gerade gelesen dass das neu einrichten der App wohl auch zz nicht geht das ist das was die winapp und Adapter beim Start machen. Ich schau es mir noch genauer an, aber ich glaube die haben da gerade einfach nur Serverprobleme. Beim Start werden mehrere Server kontaktiert da die Daten dezentral sind. Das token sich ändert sollte normal sein.
            Gesendet von meinem Handy
            • Meistertr
              Bitte den Landroid-S Adapter updaten (Installieren über url und den Github Link angeben). Worx hat Heute nacht den Server umgestellt
              • lobomau
                Und Grad kam ein android App Update. Man erkennt jetzt ein Batterie und WiFi symbol.
                • lobomau
                  @Meistertr:
                  Bitte den Landroid-S Adapter updaten (Installieren über url und den Github Link angeben). Worx hat Heute nacht den Server umgestellt `
                  Hat leider noch nichts gebracht:
                  landroid-s.0	2017-10-05 18:32:57.471	info	Downloaded guest token
                  landroid-s.0	2017-10-05 18:32:57.284	info	starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.11.4
                  sql.0	2017-10-05 18:32:57.352	info	enabled logging of landroid-s.0.mower.totalTime
                  sql.0	2017-10-05 18:32:57.347	info	enabled logging of landroid-s.0.mower.totalBladeTime
                  sql.0	2017-10-05 18:32:57.337	info	enabled logging of landroid-s.0.mower.totalDistance
                  host.brix-3150	2017-10-05 18:32:55.905	info	instance system.adapter.landroid-s.0 started with pid 26024
                  host.brix-3150	2017-10-05 18:32:25.895	info	Restart adapter system.adapter.landroid-s.0 because enabled
                  host.brix-3150	2017-10-05 18:32:25.895	error	instance system.adapter.landroid-s.0 terminated with code 0 (OK)
                  host.brix-3150	2017-10-05 18:32:25.895	error	Caught by controller[0]: at Timer.listOnTimeout (timers.js:214:5)
                  host.brix-3150	2017-10-05 18:32:25.894	error	Caught by controller[0]: at tryOnTimeout (timers.js:250:5)
                  host.brix-3150	2017-10-05 18:32:25.894	error	Caught by controller[0]: at ontimeout (timers.js:386:11)
                  host.brix-3150	2017-10-05 18:32:25.894	error	Caught by controller[0]: at Timeout.checkStatus [as _onTimeout] (/opt/iobroker/node_modules/iobroker.landroid-s/main.js:682:14)
                  host.brix-3150	2017-10-05 18:32:25.894	error	Caught by controller[0]: at LandroidCloud.sendMessage (/opt/iobroker/node_modules/iobroker.landroid-s/lib/landroid-cloud.js:274:16)
                  host.brix-3150	2017-10-05 18:32:25.893	error	Caught by controller[0]: TypeError: Cannot read property 'publish' of undefined
                  landroid-s.0	2017-10-05 18:32:25.840	info	cleaned everything up...
                  landroid-s.0	2017-10-05 18:32:25.840	error	TypeError: Cannot read property 'publish' of undefined at LandroidCloud.sendMessage (/opt/iobroker/node_modules/iobroker.landroid-s/lib/landroid-cloud.js:274:16) at Timeout.checkStatus [as _on
                  landroid-s.0	2017-10-05 18:32:25.839	error	uncaught exception: Cannot read property 'publish' of undefined
                  • Meistertr
                    Bitte einmal die 1.1.4 über url installieren:
                    https://github.com/MeisterTR/ioBroker.l … withoutssl
                    befindet sich gerade im test. Bei mir läuft sie gerade auf 4 Systemen ohne probleme
                      poessi last edited by
                      Mit der 1.1.4 funktioniert es wieder einwandfrei.
                      Vielen Dank für das schnelle Update.
                        R32er last edited by
                        und ich habe mich schon gewundert das keine mails mehr kommen. Danke für das update 🙂
                          bku last edited by
                          Läuft, Danke!
                            bku last edited by
                            habe seit 01:06h keine Verbindung mehr: Nach der DSL-Provider-Zwangstrennung ist die Verbindung weg.
                            • im Netz ist der Landi,
                            • Eishas-App läuft (jetzt wieder, ging auch heute früh nicht)
                            • Android-App geht (jetzt wieder, ging auch zwischendurch mal nicht)
                            Nur: iobroker-Adapter bekomm ich nicht zum Laufen (Versionen: 1.0.3, 1.0.4, 1.1.6)
                            Kannst Du helfen?
                            Gruß Bernd
                            ! host.DiskStation 2017-10-11 10:54:21.462 info Restart adapter system.adapter.landroid-s.0 because enabled
                            ! host.DiskStation 2017-10-11 10:54:21.462 error instance system.adapter.landroid-s.0 terminated with code 0 (OK)
                            ! host.DiskStation 2017-10-11 10:54:21.462 error Caught by controller[2]: at IncomingMessage.emit (events.js:166:7)
                            ! host.DiskStation 2017-10-11 10:54:21.462 error Caught by controller[2]: at emitNone (events.js:72:20)
                            ! host.DiskStation 2017-10-11 10:54:21.462 error Caught by controller[2]: at IncomingMessage. (/opt/iobroker/node_modules/iobroker.landroid-s/lib/landroid-cloud-2.js:179:37)
                            ! host.DiskStation 2017-10-11 10:54:21.462 error Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.landroid-s/lib/landroid-cloud-2.js:71:14
                            ! host.DiskStation 2017-10-11 10:54:21.462 error Caught by controller[2]: at LandroidCloud.retrieveAwsCert (/opt/iobroker/node_modules/iobroker.landroid-s/lib/landroid-cloud-2.js:84:10)
                            ! host.DiskStation 2017-10-11 10:54:21.462 error Caught by controller[2]: at LandroidCloud.worx (/opt/iobroker/node_modules/iobroker.landroid-s/lib/landroid-cloud-2.js:200:21)
                            ! host.DiskStation 2017-10-11 10:54:21.462 error Caught by controller[2]: at Object.socket.once.exports.request (https.js:189:15)
                            ! host.DiskStation 2017-10-11 10:54:21.462 error Caught by controller[2]: at Object.exports.request (http.js:31:10)
                            ! host.DiskStation 2017-10-11 10:54:21.461 error Caught by controller[2]: at new ClientRequest (_http_client.js:79:14)
                            ! host.DiskStation 2017-10-11 10:54:21.461 error Caught by controller[2]: at ClientRequest.OutgoingMessage.setHeader (_http_outgoing.js:354:11)
                            ! host.DiskStation 2017-10-11 10:54:21.460 error Caught by controller[2]: 2017-10-11 10:54:21.421 - landroid-s.0 Error: value required in setHeader("X-Auth-Token", value).
                            ! host.DiskStation 2017-10-11 10:54:21.460 error Caught by controller[1]: 2017-10-11 10:54:21.416 - landroid-s.0 uncaught exception: value required in setHeader("X-Auth-Token", value).
                            ! host.DiskStation 2017-10-11 10:54:21.460 error Caught by controller[0]: [Error: value required in setHeader("X-Auth-Token", value).]
                            ! landroid-s.0 2017-10-11 10:54:21.433 info cleaned everything up…
                            ! landroid-s.0 2017-10-11 10:54:21.427 error Error: value required in setHeader("X-Auth-Token", value). at ClientRequest.OutgoingMessage.setHeader (_http_outgoing.js:354:11) at new ClientRequest (_http_client.js:79:14) at Object.ex
                            ! landroid-s.0 2017-10-11 10:54:21.427 error uncaught exception: value required in setHeader("X-Auth-Token", value).
                            ! landroid-s.0 2017-10-11 10:54:21.426 info undefined
                            ! landroid-s.0 2017-10-11 10:54:21.426 info CA certificate done
                            ! landroid-s.0 2017-10-11 10:54:21.252 info Mqtt Server: undefined
                            ! landroid-s.0 2017-10-11 10:54:21.251 info Logged in as xxxxxxxx API Token Set to : undefined
                            ! landroid-s.0 2017-10-11 10:54:20.998 info
                            ! landroid-s.0 2017-10-11 10:54:20.998 info post:{"email":"xxxxxxxx","password":"xxxxxxxx","uuid":"c591d8e0-ae61-11e7-8faf-63fa9536b470","type":"app","platform":"android"}
                            ! landroid-s.0 2017-10-11 10:54:20.998 info API token set to
                            ! landroid-s.0 2017-10-11 10:54:20.997 info Downloaded guest token
                            ! landroid-s.0 2017-10-11 10:54:20.841 info UUID: c591d8e0-ae61-11e7-8faf-63fa9536b470
                            ! landroid-s.0 2017-10-11 10:54:20.841 info starting. Version 1.1.6 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v4.8.0
                            ! host.DiskStation 2017-10-11 10:54:19.842 info instance system.adapter.landroid-s.0 started with pid 30447
                            ! host.DiskStation 2017-10-11 10:53:49.832 info Restart adapter system.adapter.landroid-s.0 because enabled
                            • Meistertr
                              @bku:
                              Kannst Du helfen?
                              Gruß Bernd
                              ! host.DiskStation 2017-10-11 10:53:49.832 info Restart adapter system.adapter.landroid-s.0 because enabled `
                              Bitte noch einmal updaten, der Accesskey war abgelaufen, habs gefixed
                                bku last edited by
                                Läuft - Danke!
                                  Stoni last edited by
                                  Hallo, ich habe auch auf 1.1.6 geupdatet, nachdem der Landi auf Alexa nicht reagiert hat. Tut sich immer noch nichts. Die Instanz sagt:
                                  Verbunden mit Host falsch
                                  Lebenszeichen falsch
                                  Verbunden Landroid s wahr
                                  Die Apps für Android und iOS funktionieren beide…
                                  Gruß Stoni
                                    bku last edited by
                                    Mit diesem Link updaten:
                                    https://github.com/MeisterTR/ioBroker.landroid-s
                                      @bku:
                                      https://github.com/MeisterTR/ioBroker.landroid-s `
                                      Danke. Habe es über github geupdatet. Hat funktioniert.
                                        ist wieder was mit dem Adapter? habe keine Verbindung über iobroker.
                                        • Meistertr
                                          Kommt drauf an wann das letzte Update war. Installiere mal von git und schau ob es geht…
                                            ah war noch auf 1.1.4 hab 1.1.6 installiert und jetzt geht es wieder.
                                            hier geht es aber auch schlag auf schlag 😉
                                            1194
                                            451946
