    • Marc Berg
      Marc Berg Most Active @simatec last edited by Marc Berg
      Es ist leider noch keine Änderung erkennbar, das Bucket "iobroker" kann wiederhergestellt werden, das Bucket "iobroker30d" nicht.
      Und das auch nur, wenn ich das Sichern mehrerer DBs abschalte. Ansonsten wird KEINE DB wiederhergestellt.
      2023-05-20 09:25:47.275 - silly: backitup.0 (6766) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"getFileSystemInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":76,"ack":false,"time":1684567547273},"_id":45720489}
      2023-05-20 09:25:47.279 - silly: backitup.0 (6766) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"getSystemInfo","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":77,"ack":false,"time":1684567547275},"_id":45720490}
      2023-05-20 09:25:47.279 - silly: backitup.0 (6766) sendTo "getSystemInfo" to system.adapter.admin.0 from system.adapter.backitup.0
      2023-05-20 09:25:47.332 - debug: backitup.0 (6766) The local storage check was completed successfully. On the host "iobroker" are currently 6602 MB free space available!
      2023-05-20 09:25:47.333 - silly: backitup.0 (6766) sendTo "getFileSystemInfo" to system.adapter.admin.0 from system.adapter.backitup.0
      2023-05-20 09:25:51.078 - silly: backitup.0 (6766) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"list","message":"local","from":"system.adapter.admin.0","callback":{"message":"local","id":78,"ack":false,"time":1684567551076},"_id":45720491}
      2023-05-20 09:25:51.080 - debug: backitup.0 (6766) Backup list be read ...
      2023-05-20 09:25:53.081 - silly: backitup.0 (6766) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
      2023-05-20 09:26:10.287 - silly: backitup.0 (6766) States system redis pmessage io.messagebox.system.adapter.backitup.0/io.messagebox.system.adapter.backitup.0:{"command":"restore","message":{"type":"local","fileName":"/opt/iobroker/backups/influxDB_2023_05_20-00_53_18_iob30_backupiobroker.tar.gz","currentTheme":"react-dark","stopIOB":false},"from":"system.adapter.admin.0","callback":{"message":{"type":"local","fileName":"/opt/iobroker/backups/influxDB_2023_05_20-00_53_18_iob30_backupiobroker.tar.gz","currentTheme":"react-dark","stopIOB":false},"id":79,"ack":false,"time":1684567570286},"_id":45720492}
      2023-05-20 09:26:10.289 - debug: backitup.0 (6766) set chmod for "/opt/iobroker/backups" successfully
      2023-05-20 09:26:10.290 - debug: backitup.0 (6766) [influxDB] Created tmp directory
      2023-05-20 09:26:10.290 - debug: backitup.0 (6766) [influxDB] Start infuxDB Restore ...
      2023-05-20 09:26:10.737 - debug: backitup.0 (6766) [influxDB] Try deleting the InfluxDB tmp directory
      2023-05-20 09:26:10.740 - debug: backitup.0 (6766) [influxDB] InfluxDB tmp directory was successfully deleted
      2023-05-20 09:26:10.741 - debug: backitup.0 (6766) [influxDB] infuxDB Restore completed successfully
      2023-05-20 09:26:10.741 - silly: backitup.0 (6766) sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.0
      • V
        vita-2002 last edited by
        ich habe gemerkt, dass die Backups nicht mehr in GoogleDrive gespeichert werden
        • Backitup 2.6.21
        • node.js v18.16.0
        • js-controller 4.0.24
        Started iobroker ...
        [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","debugging":true,"slaveBackup":"Single","everyXDays":"7","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backup_IObrocker","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [iobroker] - host.raspberry 9048 states saved
        [DEBUG] [iobroker] - host.raspberry 9647 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_05_21-13_21_31_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [googledrive] - Google Drive: Copy iobroker_2023_05_21-13_21_31_backupiobroker.tar.gz...
        [DEBUG] [googledrive] start with {"type":"storage","source":"googledrive","debugging":true,"deleteOldBackup":true,"accessJson":"****","newToken":false,"ownDir":false,"dir":"/backup_IObrocker","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"deleteBackupAfter":0}
        Hier bleibt es hängen.
        Ich kann auch die kopien nicht mehr abrufen.
          Thomas Braun Most Active @vita-2002 last edited by
          @vita-2002 sagte in Test Adapter ioBroker.backitup v2.6.x:
          Bei mir lief diese Nacht das Backup wie üblich.
          Kommst du an dein Google Drive grundsätzlich (außerhalb des iobrokers) ran?
          • V
            Sorry, es hat sich erledigt.
            Berechtigung bei GoogleDrive, gelöscht, wieder geholt, neue Zugangstoken eingetragen.
            Jetzt funktioniert es wieder.
            • simatec
              simatec Developer Most Active @Marc Berg last edited by
              @marc-berg Habe in v2.6.22 nochmal etwas modifiziert. Wenn MultiDB aktiv ist, sollten nun die kompletten Configs aus der Tabelle geholt werden.
              Kannst du bitte al testen?
              • Marc Berg
                @simatec sagte in Test Adapter ioBroker.backitup v2.6.x:
                Leider noch keine Änderung erkennbar. Keine Fehlermeldung, aber es werden keine Daten geschrieben.
                Ergänzung: Es muss in Zeile 22 der "influxDB.js" nicht "json.buckets.bucketName", sondern "json.buckets[0].bucketName" heißen. Dann funktioniert es.
                • JB_Sullivan
                  JB_Sullivan last edited by
                  @simatec
                  Ich hätte mal eine Frage, bzw. einen Wunsch zum Restore. Ist es ggf. möglich, das man auswählen kann, was "restored" werden soll?
                  Hintergrund der Frage ist die VIS. Wenn es in der VIS mal Probleme gegeben hat, könnte man diese separat wieder zurück sichern. Ein Full Restore, wie er derzeit abläuft, wäre im Falle einer defekten VIS mit Kanonen auf Spatzen schießen.
                  Das es die VIS durchaus mal erwischen kann, ist nicht ungewöhnlich, da die Funktionen der Gruppierung in der VIS gerne mal für Chaos sorgt und dann mitunter weder Editor noch Laufzeit bedienbar ist.
                  Über BackItUp ein einzelner Restore des VIS Ordner, würde da auf die schnelle für Heilung sorgen.
                  simatec Homoran 2 Replies Last reply Reply Quote 0
                  • simatec
                    @marc-berg Kannst du mal den Inhalt deiner .manifest zeigen?
                    Also mir reicht der Anfang bis bucketName... Bei mir im habe ich den Bucket Name ohne die [0] auslesen können.
                    • simatec
                      simatec Developer Most Active @JB_Sullivan last edited by
                      @jb_sullivan Dies ist aktuell nicht möglich, aber auf der langen Todo vom js-controller.
                      Backitup nutzt die Backup Funktion des js-controllers
                      • Marc Berg
                        20230524T225316Z.manifest
                          Homoran Global Moderator Administrators @JB_Sullivan last edited by
                          @jb_sullivan sagte in Test Adapter ioBroker.backitup v2.6.x:
                          dann sicher sir doch einfach die vis-views.json
                          da ist die gesamte Vis drin
                          • simatec
                            @marc-berg Sollte nun mit der v2.6.23 funktionieren
                            • Marc Berg
                              Marc Berg Most Active last edited by
                              Jup, funktioniert jetzt. Danke!
                                Laser @Marc Berg last edited by
                                @simatec backitup soll ja influx Daten sichern und wiederherstellen können. Beim Sichern kommt schon diese Fehlermeldung:
                                [DEBUG] [mount] - mount activ... umount is started before mount!!
                                [DEBUG] [mount] - umount successfully completed
                                [DEBUG] [mount] - noserverino option: false
                                [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.57/backup /opt/iobroker/backups"
                                [DEBUG] [mount] - mount successfully completed
                                [DEBUG] [mount] - done
                                [DEBUG] [iobroker] - host.raspberrypi 2956 states saved
                                [DEBUG] [iobroker] - host.raspberrypi 3663 objects saved
                                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_06_01-18_22_41_backupiobroker.tar.gz
                                [DEBUG] [influxDB] - InfluxDB-Backup started ...
                                [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_06_01-18_22_52_backupiobroker"
                                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_06_01-18_22_52_backupiobroker" successfully deleted
                                [ERROR] [influxDB] - Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2023_06_01-18_22_52_backupiobroker"
                                Error: unknown shorthand flag: 'p' in -portable
                                See 'influxd -h' for help
                                • Marc Berg
                                  @laser sagte in Test Adapter ioBroker.backitup v2.6.x:
                                  Du hast den Backitup Adapter falsch konfiguriert. Du hast ne 2.x Datenbank und versuchst, mit 1.x Befehlen zu sichern.
                                    Laser @Marc Berg last edited by Laser
                                    @marc-berg OK, jetzt habe ich schon mal einen Ansatz. Was will ich genau machen? Ich möchte meinen "alten" PI mit Influx sichern und die Datenbank auf dem "Neuen" wieder herstellen. Ich hoffe, das geht. Das Sichern lief schon mal ohne Fehler durch. Eigentlich möchte ich nur die Influx- Daten erhalten/ übertragen. Der Rest soll bleiben. Wenn ich IO Broker abwähle, nur Influx lasse, kann ich kein Backup machen.
                                    Marc Berg 2 Replies Last reply Reply Quote 0
                                    • Marc Berg
                                      Marc Berg Most Active @Laser last edited by
                                      Die Sicherungsdatei rüberkopieren und am Zielsystem auf "Get Backups" gehen (keine Ahnung, wie das im Deutschen übersetzt wurde). Vorher natürlich den Backitup Adapter konfigurieren. Wenn dort die DB frisch installiert wurde, musst du den NEUEN Token benutzen.
                                      • Marc Berg
                                        ja, isso. Aber nicht schlimm, du muss den ioBroker ja nicht wiederherstellen.
                                          @marc-berg Da habe ich aber immer meine fehlerhafte IOBroker Konfig wiederhergestellt. Das wollte ich eigentlich nicht.
                                          • Marc Berg
                                            Marc Berg Most Active @Laser last edited by Marc Berg
                                            Das InfluxDB Backup lässt sich doch beim Wiederherstellen separat auswählen. Es sind auch zwei separate Dateien, die beim Backup erstellt werden.
                                            170
                                            2780
                                            2367078
