    4. [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana
      Martin1986_ERK last edited by
      Hey zusammen,
      ich bin absolut am verzweifeln und weiß nicht weiter. Ich hab einen SolarEdge SE5K mit Firmware 4.17.221.
      Modbus usw. ist alles Aktiviert am WR. Ich bekomme jedoch keine Werte geliefert.
      Am Wechselrichter hängt bei mir noch ein Senec Speicher dran. Diesem werden die daten über einen ENFLURI zur Verfügung gestellt.
      Im Debug vom Modbus-Adapter steht folgendes:
      modbus.1
      2023-05-03 13:19:46.495	info	Disconnected from slave 192.168.2.41
      modbus.1
      2023-05-03 13:19:46.494	debug	Closing client on purpose.
      modbus.1
      2023-05-03 13:19:45.509	debug	Cleaning up request fifo.
      modbus.1
      2023-05-03 13:19:45.508	debug	Clearing timeout of the current request.
      modbus.1
      2023-05-03 13:19:45.506	debug	Socket closed with error
      modbus.1
      2023-05-03 13:19:45.496	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
      modbus.1
      2023-05-03 13:19:45.493	error	Client in error state.
      modbus.1
      2023-05-03 13:19:45.491	error	Request timed out.
      modbus.1
      2023-05-03 13:19:45.490	warn	Error: undefined
      modbus.1
      2023-05-03 13:19:40.481	debug	[DevID_1/holdingRegs] Poll address 40021 - 16 registers
      modbus.1
      2023-05-03 13:19:40.480	debug	Initialization of scale factors done!
      modbus.1
      2023-05-03 13:19:40.478	debug	[DevID_1] Poll start ---------------------
      modbus.1
      2023-05-03 13:19:40.477	info	Connected to slave 192.168.2.41
      modbus.1
      2023-05-03 13:19:40.264	debug	Remove old object modbus.1.holdingRegisters.20_C_Modell
      modbus.1
      2023-05-03 13:19:40.251	debug	Add holdingRegisters.40021_C_Modell: {"_id":"holdingRegisters.40021_C_Modell","type":"state","common":{"name":"Spezifischer SolarEdge Wert","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":40021,"deviceId":1,"type":"string","len":16,"offset":0,"factor":1,"poll":true}}
      modbus.1
      2023-05-03 13:19:40.250	debug	Initialize Objects for holdingRegs: [{"_address":"40021","name":"C_Modell","description":"Spezifischer SolarEdge Wert","unit":"","type":"string","len":16,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"address":40021,"deviceId":1,"id":"holdingRegisters.40021_C_Modell"}]
      modbus.1
      2023-05-03 13:19:40.250	debug	Initialize Objects for inputRegs: []
      modbus.1
      2023-05-03 13:19:40.248	debug	Initialize Objects for coils: []
      modbus.1
      2023-05-03 13:19:40.247	debug	Initialize Objects for disInputs: []
      modbus.1
      2023-05-03 13:19:40.016	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.16.0, js-controller: 4.0.24
      Wenn ich den Haken bei "Abfragen" von diesem Wert entferne, ihn aber eingetragen lasse, bleibt die Modbus Verbindung Grün. Ansonsten kommt direkt dieser Poll error.
      Lg Martin
      • M-A Hueb
        M-A Hueb @Sammydk last edited by M-A Hueb
        @sammydk wie hast du es den realisiert? Also das dein PV-Leistungswert passt
          danielos @Chris87 last edited by
          @chris87 Herzlichen Dank für die Tabelle. Irgendwie klappt bei mir der Import nicht, aber ich konnte dank deiner Tabelle manuell die für mich wichtigen Werte übertragen und das läuft soweit bestens.
          Ein Problem habe ich jedoch. Der Wert 102853 (Ladestand der Batterie) stimmt, wenn ich den Adapter starte. Aber irgendwie aktualisiert es diesen Wert nicht, er bleibt einfach konstant. Wenn ich dann den Adapter restarte, stimmt er wieder. Gibt's da irgendwie einen Trick, damit dieser sich aktualisiert? Ich könnte natürlich als Umgehung einen zweiten Adapter installieren, der lediglich diesen Wert ausliest und dafür einmal pro xy Minuten restarted wird. Aber wenn's ohne Workaround geht, dann ist mir das natürlich lieber. Danke vielmals für deinen Rat!
          peppi 1 Reply Last reply Reply Quote 0
          • peppi
            peppi @danielos last edited by peppi
            @danielos sagte in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
            @danielos
            hättest du mir freundlicherweise auch die tabelle, die du von @chris87 erhalten hast?
            ich kann diese nicht finden.
            • Glasfaser
              Glasfaser last edited by
              @peppi sagte in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
              https://forum.iobroker.net/post/854380
              • M-A Hueb
                M-A Hueb last edited by
                Hat das schon jemand hinbekommen, dass die leistung wie in der App berechnet wird?
                • Glasfaser
                  Glasfaser @M-A Hueb last edited by
                  @m-a-hueb sagte in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
                  Welche Leistung ... was meinst du !?
                  ist eigenlich alles hier im Thread !
                  • M-A Hueb
                    @glasfaser ich meinte das was samy hier https://forum.iobroker.net/post/983433
                    schon angesprochen hatte. Er meinte dann das er eine Lösung hat. Hat diese aber nicht näher erläutert
                      dawoern @hennerich last edited by
                      @hennerich: Super Thread mit vielen Details. Echt genial! Eine vollkommene Laienfrage habe ich noch (sorry im Voraus): Ich bekomme demnächst auch einen SE Wechselrichter SE7K. Diesen möchte ich (zwecks PV-Überschussladen) auch in meinen iobroker (auf einem Raspi) einbinden (die Wallbox habe ich erfolgreich über Modbus RS485 angebunden). Meine Frage bezieht sich auf die Modbus TCP/IP-Schnittstelle: Ist hier eigentlich zwangsläufig eine Kabelverbindung vom WR zum Router (wahlweise natürlich Repeater mit Ethernet-Anschluss) notwendig (und dann auch vom Router/Repeater wieder zum Raspi? Oder funktioniert diese Datenübertragung auch über WLAN? Oder ginge alternativ auch eine Twisted-Pair-Verbindung direkt zwischen Wechselrichter und Raspi? Zur Not würde ich natürlich auch den WR über Modbus RS485 mit zweiadrigem Kabel anbinden. Aber schöner fände ich schon die Variante über WLAN. Danke!
                      • eule66
                        eule66 last edited by
                        Hallo Zusammen
                        habe ein kleines Problem, habe soweit alles am laufen, auch wird mir die aktuelle Produktion angezeigt und passt mit dem Wert aus dem Solaredgeportal überein. Auch der Gesamtproduzierte Wert seit Inbetriebnahme passt.
                        Was aber nicht passt ist die Produktion vom gesamten Tag. Hier sollte ja der Wert 40206 MeterPowerTotal angezogen werden, siehe auch Bilder. Welchen wert muss ich nehmen um die gesamte Produktion vom Tag zu sehen?
                        Danke für eure Hilfe
                        • Longbow
                          Longbow last edited by
                          ich versuche es erneut, da ich leider wohl der Einzige bin, was ich mir nicht verstellen kann.
                          Ich habe einen SolarEdge Wechselrichter und einen LG Resum Batteriespeicher.
                          Die Werte werden sauber im Modbus ausgelesen.
                          Wie stelle ich nun das sauber dar, was das Haus genau verbraucht, ohne das Problem mit dem Speicher zu haben, wenn der bei PV Produktion und Überschuss von der PV-Anlage geladen wird.
                          Ich komme es nicht hin, bin dazu einfach noch zu neu im Gebiet Iobroker.
                          • Glasfaser
                            Glasfaser @eule66 last edited by
                            @eule66 sagte in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
                            Dazu ist das Script da ...
                            steht alles im Thread :
                            https://forum.iobroker.net/post/515138
                            Longbow 1 Reply Last reply Reply Quote 0
                            • Longbow
                              Longbow @Glasfaser last edited by
                              @glasfaser ja, das habe ich, nur ist da es ohne Batteriespeicher. Wenn die Batterie das Haus verzogt, dann wird von dem Script gesagt, dass die PV Anlage produziert. dass ist aber nicht ja nicht richtig, bei Usern die eine Batterie/ Akku haben.
                              • Glasfaser
                                Glasfaser @Longbow last edited by
                                @longbow sagte in [Tutorial] SolarEdge -> Modbus -> ioBroker -> Grafana:
                                Deshalb ziehe ich mit einem Script die Batterie ab , dann ist nur die die aktuelle PV Leistung zu sehen .
                                javascript.0.Solar.Wechselrichter.PVLeistungAktuell - javascript.0.Solar.Wechselrichter.Batterie Entlade-Leistung = javascript.0.Solar.Wechselrichter.PVLeistungAktuell_ohneSpeicher
                                • Longbow
                                  Weiß keiner das oder so? 😞 keiner der untersützen mag?
                                  • Longbow
                                    Longbow @Glasfaser last edited by Longbow
                                    @glasfaser Kannst du mir dein Script mal zukommen lassen ?
                                    Also ich habe es so lösen wollen, geht nicht :
                                    Glasfaser 1 Reply Last reply Reply Quote -1
                                    • Glasfaser
                                      @longbow
                                      Einmal die Berechnung wie schon oben erwähnt und der Hauptteil um es zu trennen .
                                       <block type="procedures_defcustomnoreturn" id="Yo~vdCDoW+:y6C:Z%jLM" x="363" y="-87">
                                         <mutation statements="false"></mutation>
                                         <field name="NAME">etwas tun</field>
                                         <field name="SCRIPT">Y3JlYXRlU3RhdGUoJ1NvbGFyLldlY2hzZWxyaWNodGVyLlBWTGVpc3R1bmdBa3R1ZWxsX29obmVTcGVpY2hlcicsIHsNCg0KCW5hbWU6ICdQVkxlaXN0dW5nQWt0dWVsbF9vaG5lU3BlaWNoZXInLA0KDQoJdW5pdDogJ1cnLA0KDQoJbWluOiAgMCwNCg0KCXR5cGU6ICdudW1iZXInLA0KDQoJcm9sZTogJ3ZhbHVlLmVuZXJneScNCn0pOw0K</field>
                                       <block type="on_ext" id="0WNw^]CyfADZ9h[46/yr" x="88" y="113">
                                         <value name="OID0">
                                           <shadow type="field_oid" id="aHInbBr3)gU07u~$!]S=">
                                             <field name="oid">javascript.0.Solar.Wechselrichter.PVLeistungAktuell</field>
                                           <block type="update" id="=U8B5_HREC.%ywC@*NUX">
                                             <field name="OID">javascript.0.Solar.Wechselrichter.PVLeistungAktuell_ohneSpeicher</field>
                                               <block type="math_arithmetic" id="k1ql[z$jjxr4y2epe^yv">
                                                   <shadow type="math_number" id="sJp~@vx71!N=60lSV@tn">
                                                     <field name="NUM">1</field>
                                                   <block type="on_source" id="veT._9tKCvSl?bikEiqC">
                                                   <shadow type="math_number" id="Npe:FP|KT.MC?$=;iBKQ">
                                                   <block type="get_value" id="t;_RJ9`t0KjSVRPVS#lg">
                                                     <field name="OID">javascript.0.Solar.Wechselrichter.Batterie Entlade-Leistung</field>
                                       <block type="on_ext" id="k45?g2mKWmgfdq7;,dPT" x="25" y="-361">
                                         <value name="OID0">
                                           <shadow type="field_oid" id="b=h=4l_d/L.t^2xVlW{w">
                                             <field name="oid">modbus.3.holdingRegisters.57722_Battery_1_Lifetime_Import_Energy_Counter</field>
                                         <value name="OID1">
                                           <shadow type="field_oid" id="`G_.p|N^6?HKSmHdu:d7">
                                             <field name="oid">modbus.3.holdingRegisters.57718_Battery_1_Lifetime_Export_Energy_Counter</field>
                                           <block type="controls_if" id="zoPV5Y;ayeDo`9Md{5Jl">
                                               <block type="logic_compare" id="FZ.$pBN9%8g:nQ,4-UBH">
                                                 <field name="OP">EQ</field>
                                                   <block type="get_value" id="gDKsLDA+oomqdmT4$*O_">
                                                     <field name="OID">modbus.3.holdingRegisters.57734_Battery_1_Status</field>
                                                   <block type="math_number" id="grmYB/^YD_we.HUD?fHq">
                                                     <field name="NUM">3</field>
                                               <block type="update" id="$/tKM:#f=E|SakpP@5Jf">
                                                 <field name="OID">javascript.0.Solar.Wechselrichter.Batterie Lade-Leistung</field>
                                                   <block type="get_value" id="hIg8K`UH5DrkS;W}^GGE">
                                                     <field name="OID">modbus.3.holdingRegisters.57716_Battery_1_Instantaneous_Power</field>
                                             <statement name="ELSE">
                                               <block type="update" id="#vn-5e-d9Oi=xJW9;EV9">
                                                   <block type="math_number" id="nInZPnS5nZ].qC#5QgA}">
                                                     <field name="NUM">0</field>
                                           <block type="on_ext" id="IYUoYtHY#:$j42W4$52T">
                                             <value name="OID0">
                                               <shadow type="field_oid" id="qB5J{KMn!Pi`P$)7*_a6">
                                             <value name="OID1">
                                               <shadow type="field_oid" id="8JrVVmBx:))bQh(P+EJG">
                                               <block type="controls_if" id="=O?ZxB:x9Dp-6KF[9SaP">
                                                   <block type="logic_compare" id="Z%%c?(bX!S]cXE!QG1}O">
                                                       <block type="get_value" id="@S+7kZzCI#oocHBd_IOx">
                                                       <block type="math_number" id="V*e~V8NRtAlq.?d1tf(S">
                                                         <field name="NUM">4</field>
                                                   <block type="update" id="2hGqM}FPzMh.mKJ[*Hp`">
                                                       <block type="math_arithmetic" id="DinQ%]SCa4xep[8$l=xA">
                                                           <shadow type="math_number" id="9/Lb{:E41Fv/V$,g6pU:">
                                                           <block type="get_value" id="bPpe:so:?[e1wW`.HEND">
                                                           <shadow type="math_number" id="D6/-%3x8U1%bNh]N{Fik">
                                                           <block type="math_number" id="h(MF*U8_7T}mN`?^84!L">
                                                             <field name="NUM">-1</field>
                                                   <block type="update" id="u*7N6fSCWh/-lJN|/+Fm">
                                                       <block type="math_number" id=",~yC~+^(CJ`{1]Zb:T7l">
                                               <block type="on_ext" id="BIpz4MNqK/131l(^or2*">
                                                 <value name="OID0">
                                                   <shadow type="field_oid" id="l01KdIA4%L[oEbTfl6Uq">
                                                     <field name="oid">modbus.3.holdingRegisters.57734_Battery_1_Status</field>
                                                   <block type="comment" id="y=8J39[C8RX1HzEe[sL6">
                                                     <field name="COMMENT">10 dazu bei Leerlauf 6</field>
                                                       <block type="controls_if" id="Gn7qIJD2Tho~Td{bA6($">
                                                           <block type="logic_operation" id="e*!S|Ef$A#DS[};W#HN{" inline="false">
                                                             <field name="OP">OR</field>
                                                               <block type="logic_compare" id="b*-M-%0!}n,`FPNc/ihm">
        <block type="on_source" id="JN,/%O8[=ZW%kqSDfF|]">
        <block type="math_number" id="1Z^`AQHD=fT+7,JGt_pw">
        <field name="NUM">6</field>
                                                               <block type="logic_compare" id="{_GCnEG]krZnG}%a.wna">
        <block type="on_source" id="2ieUK{V!UM]rt7oyGzU#">
        <block type="math_number" id="(0rP!KYw~b@]g{!9U3no">
        <field name="NUM">10</field>
                                                           <block type="update" id="nb:]?y2e5OH)0?lUC~oR">
                                                             <field name="DELAY_MS">1000</field>
                                                             <field name="UNIT">ms</field>
                                                               <block type="math_number" id="mj$wkgX8qd;vH?`#i!Tf">
                                                               <block type="update" id="?4S5eZ0;hW!*Z#tk~8Qh">
        <block type="math_number" id="=4sQbPv*bjFl4HG7db8p">
                                       <block type="procedures_defcustomnoreturn" id="Yo~vdCDoW+:y6C:Z%jLM" x="513" y="-287">
                                         <field name="SCRIPT">Y3JlYXRlU3RhdGUoJ1NvbGFyLldlY2hzZWxyaWNodGVyLkJhdHRlcmllIEVudGxhZGUtTGVpc3R1bmcnLCB7DQoNCgluYW1lOiAnQmF0dGVyaWUgRW50bGFkZS1MZWlzdHVuZycsDQoNCgl1bml0OiAnVycsDQoNCgltaW46ICAwLA0KDQoJdHlwZTogJ251bWJlcicsDQoNCglyb2xlOiAndmFsdWUuZW5lcmd5Jw0KfSk7DQpjcmVhdGVTdGF0ZSgnU29sYXIuV2VjaHNlbHJpY2h0ZXIuQmF0dGVyaWUgTGFkZS1MZWlzdHVuZycsIHsNCg0KCW5hbWU6ICdCYXR0ZXJpZSBMYWRlLUxlaXN0dW5nJywNCg0KCXVuaXQ6ICdXJywNCg0KCW1pbjogIDAsDQoNCgl0eXBlOiAnbnVtYmVyJywNCg0KCXJvbGU6ICd2YWx1ZS5lbmVyZ3knDQp9KTsNCg0K</field>
                                      • Longbow
                                        @glasfaser
                                        Vielen Dank, aber irgendwie klappt das bei mir nicht.
                                        Update, gelöst
                                        Longbow Glasfaser 2 Replies Last reply Reply Quote 0
                                        • Longbow
                                          Longbow @Longbow last edited by
                                          @Glasfaser Danke, habe es nochmals kopiert und die Datenpunkte angepasst, jetzt geht es wohl...
                                          • Glasfaser
                                            @glasfaser aber irgendwie klappt das bei mir nicht.
                                            freut mich das ich helfen konnte 🙂
                                            grafana modbus solaredge
                                            91
                                            606
                                            199596
