    5. Suche hilfe für ein Temperatur Regler Script
      Bernd 1337 @paul53 last edited by Homoran
        <variables>
          <variable id="9WOs.iA$_;F+Nt6}XDXZ">setzen auf</variable>
          <variable id="Nngn$qGMi,a]t/|lc#?{">StateNum</variable>
          <variable type="timeout" id="WarteBissel">WarteBissel</variable>
          <variable id="EtcJ.ZMC8|hiJX?2p9z!">Einschalt Temperatur</variable>
          <variable id="6T,fl=b,OU7zFuqs#9n2">Abschalt Temperatur</variable>
        </variables>
        <block type="on_ext" id="K2#.V[BShz?wc5YaB:Xa" x="838" y="138">
          <field name="ACK_CONDITION">true</field>
          <value name="OID0">
            <shadow type="field_oid" id="EA2571m53SBZ4{-;6dlz">
              <field name="oid">shelly.0.SHSW-25#3494547971EC#1.Relay0.Power</field>
            <block type="procedures_callnoreturn" id="f$lFS!hNj`q0Jzif8Bds">
              <mutation name="init"></mutation>
                <block type="controls_if" id="6t9~,p6FidwN`}`]u?M4">
                  <mutation elseif="3"></mutation>
                    <block type="logic_compare" id="JCl5xO7ojDQn^44RiSp,">
                      <field name="OP">EQ</field>
                        <block type="variables_get" id="4$$P9HQ)M`NUl{s1VE~F">
                          <field name="VAR" id="Nngn$qGMi,a]t/|lc#?{">StateNum</field>
                        <block type="math_number" id="lf,FcwXo:E?[h.(=yGt6">
                          <field name="NUM">0</field>
                    <block type="comment" id="ICp_/aW:$%cn-o0HvrQa">
                      <field name="COMMENT">Modus: Aus</field>
                  <value name="IF1">
                    <block type="logic_compare" id="3%|GqQPly)yB`IN7#y,`">
                        <block type="variables_get" id=".8{U{s3*3e1!sJOo/9D6">
                        <block type="math_number" id="hUec!BZSA.:|G(3=(+Lt">
                          <field name="NUM">1</field>
                  <statement name="DO1">
                    <block type="comment" id="nL6yYs(6sGU5H3e2Taxz">
                      <field name="COMMENT">Modus: Kerze</field>
                        <block type="controls_if" id="hc2nU}%;|[~nj~seBYjg">
                            <block type="logic_compare" id="A1fx8o=lFa]#g%7~,~E4">
                              <field name="OP">LT</field>
                                <block type="on_source" id="Ny*R^VVpN|F0/%U*AE};">
                                <block type="math_number" id="]G,eb/;~2DcnH{V*Rbma">
                                  <field name="NUM">100</field>
                            <block type="procedures_callnoreturn" id="l^6_NmMw7*Rr:M$*gQ7_">
                              <mutation name="Modus">
                                <arg name="setzen auf"></arg>
                              </mutation>
                              <value name="ARG0">
                                <block type="math_number" id="R+m@ZqFHMr@%_^w+^qOO">
                                  <field name="NUM">2</field>
                  <value name="IF2">
                    <block type="logic_compare" id=";hAF2.irdRUutWpZo;:d">
                        <block type="variables_get" id="FGT{I74}dY~WfC/PnVD/">
                        <block type="math_number" id="w7)Z{X|{3^6~AC1y+3{N">
                  <statement name="DO2">
                    <block type="comment" id="d;NS!%[1{?/P=8pO+WY0">
                      <field name="COMMENT">Modus: Aktiv</field>
                  <value name="IF3">
                    <block type="logic_compare" id="%Yw%3*w]I{fN|^S.ZS]=">
                        <block type="variables_get" id="-4j4^KiH7d:mHrXl#mT?">
                        <block type="math_number" id="$bd`2xwJ/X1l.Kr.6[ut">
                          <field name="NUM">3</field>
                  <statement name="DO3">
                    <block type="comment" id="gQznu+9U)Wye*A|S*O.(">
                      <field name="COMMENT">Modus: Abkühlen</field>
                        <block type="controls_if" id="@bq3#zrqBgf#5h#5Z#hS">
                            <block type="logic_compare" id="`.6qUKEJ|K/,*0Tqh7X+">
                                <block type="on_source" id="`mL5[*!H`cyBnf9f?r^0">
                                <block type="math_number" id="0T2Sp8CcWbAThN_U-1mX">
                                  <field name="NUM">20</field>
                            <block type="procedures_callnoreturn" id="v8D{d#w^1=5hAKUO$Wb?">
                              </mutation>
                              <value name="ARG0">
                                <block type="math_number" id="sGO17n(^Qa?N)XGA@voq">
        <block type="on_ext" id="OtwKLd|WDL35?6l#wMO^" x="1313" y="138">
          <value name="OID0">
            <shadow type="field_oid" id="GQOm_-9Y(R8AMX;(QMD?">
              <field name="oid">mqtt.0.HeizungsWasser.Sensor.temperature</field>
            <block type="controls_if" id="f|L;-tv#*;ER)[p#V,nP">
                <block type="logic_operation" id="*:`ES_JmG*Y(:w{)//L(">
                  <field name="OP">AND</field>
                    <block type="logic_compare" id=":eot3H)-S7/~J4}[62x{">
                        <block type="variables_get" id="z%+gjj@TqUv8b9r%Ign,">
                        <block type="math_number" id="7iVpE*zF@kH.cZFsa{~)">
                    <block type="logic_compare" id=":{L1=rg,|!e^]3zvz}s]">
                        <block type="on_source" id="+o:kLG3|`[G/zOQA{@*V">
                        <block type="variables_get" id="MS1){jNAjphzCy+!d9~_">
                          <field name="VAR" id="EtcJ.ZMC8|hiJX?2p9z!">Einschalt Temperatur</field>
                <block type="procedures_callnoreturn" id="%|#*~aAq96]Uv-JS7TqJ">
                  <mutation name="Heizung Umschalten"></mutation>
                    <block type="procedures_callnoreturn" id="km$MF|~OB.oE)PJ?h)3~">
                      </mutation>
                      <value name="ARG0">
                        <block type="math_number" id="G?{p(eR}BhC7|!lN4l[H">
                        <block type="telegram" id="#:#H$3[bPRw8$*$y~^Kl">
                          <field name="LOG"></field>
                          <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
                          <value name="MESSAGE">
                            <shadow type="text" id="y[T,g0Rj)69}}[8Yqi[8">
                              <field name="TEXT">Heizung wurde Eingeschaltet !</field>
              <value name="IF1">
                <block type="logic_operation" id="`Vr@lX;*Pc4]J2@-gu:W">
                    <block type="logic_compare" id="j{)~Jj9Y^oxHCV{kv=uy">
                        <block type="variables_get" id="A)mtm?a!*vB7%tbufxyg">
                        <block type="math_number" id="]PxP{~|II!{NVf`e%C`d">
                    <block type="logic_compare" id="(r{RhyGx7bV(jg2G(sE+">
                      <field name="OP">GT</field>
                        <block type="on_source" id="n](6.WEo[c:[4t!oc}~@">
                        <block type="variables_get" id="O(VQ09bK%VrSW|3*Yiz@">
                          <field name="VAR" id="6T,fl=b,OU7zFuqs#9n2">Abschalt Temperatur</field>
                <block type="procedures_callnoreturn" id="N3@(j3a2?cU5b]N!vK%v">
                    <block type="procedures_callnoreturn" id="sN:_WX:8z.An,T8;pQ`c">
                      </mutation>
                      <value name="ARG0">
                        <block type="math_number" id="+qT3-uNK}y=QED[]AT~H">
                        <block type="telegram" id="3LY~@xt2e.([#Bj/078u">
                            <shadow type="text" id="}1#aA@4Kf(;cC!,6h!4z">
                              <field name="TEXT">Heizung wurde Ausgeschaltet !</field>
        <block type="procedures_defnoreturn" id="_e*8eR%rBPsV)Ayt5{lJ" x="138" y="213">
          <field name="NAME">init</field>
          <statement name="STACK">
            <block type="controls_if" id="=b:BYwaERGdel%5!wt1g">
                <block type="logic_compare" id="-V[qHh@@K*3POxLV|+wu">
                    <block type="variables_get" id="*?]AH:TOpb@t@LPkd~Yv">
                    <block type="logic_null" id="J*!5M.8W+d]NtDl:4,A~"></block>
                <block type="variables_set" id="Lf+.@w0i]IS/gNw{qa6L">
                    <block type="math_number" id="KhrGvql?l=E@bi|rli_W">
                    <block type="comment" id="g7**0ftH^lphgAHQ.O2]">
                      <field name="COMMENT">Nur die Unteren ändern!</field>
                        <block type="variables_set" id="5^B22A[#jHWN^c(kT#g{">
                            <block type="math_number" id="z,/fep^F_DrO5C2wSJ@c">
                              <field name="NUM">50</field>
                            <block type="variables_set" id="#xUi.p{Q%+976oK5^-fs">
                                <block type="math_number" id="V*GFyqdB6JaU^:bYH#IE">
                                  <field name="NUM">60</field>
        <block type="procedures_defnoreturn" id="{X.J-_W%YqP=Luhx.A*}" x="888" y="763">
          <mutation>
            <arg name="setzen auf" varid="9WOs.iA$_;F+Nt6}XDXZ"></arg>
          </mutation>
          <field name="NAME">Modus</field>
            <block type="variables_set" id="EoKG+uyhNG8,PWY;nu%Q">
                <block type="variables_get" id="@J`xB.-_?L}5:{5zYM8O">
                  <field name="VAR" id="9WOs.iA$_;F+Nt6}XDXZ">setzen auf</field>
        <block type="procedures_defnoreturn" id=".F]sXJcTp=@W3(Y(=EeK" x="1313" y="963">
          <field name="NAME">Heizung Umschalten</field>
            <block type="request" id=";cmmm{:YO0yNze=#lDOT">
              <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
              <field name="WITH_STATEMENT">FALSE</field>
              <value name="URL">
                <shadow type="text" id="E@lHsR]E-y+Rc@,Vincw">
                  <field name="TEXT">http://192.168.1.5/control?cmd=gpio,14,1</field>
                <block type="timeouts_settimeout" id="0+Nf.N=vWpAxzI;KPUfH">
                  <field name="NAME">WarteBissel</field>
                  <field name="DELAY">4</field>
                    <block type="request" id="%aA0/#=TLCMJ(5fu/)`P">
                      <value name="URL">
                        <shadow type="text" id="bb9#YKR)@Rx9jjdXvBp%">
                          <field name="TEXT">http://192.168.1.5/control?cmd=gpio,14,0</field>
        @paul53 kannst du es selbst anpassen und makieren wo was rein kommt
          paul53 @Bernd 1337 last edited by
          @bernd-1337
          Bitte diese Version posten, damit ich auch die Datenpunkte importiere. Code tags sind oben das 5. Symbol: </>
            @paul53 du meinst so ja
              <variables>
              </variables>
              <block type="procedures_defnoreturn" id="_e*8eR%rBPsV)Ayt5{lJ" x="88" y="163">
                                  <block type="get_value" id="DqXK^aSt(YszonMp(9Q#">
                                    <field name="OID">Heizung.0.Ein</field>
                                      <block type="get_value" id="_}+,`ko4-p~+jF;Ly|Z8">
                                        <field name="OID">Heizung.0.Aus</field>
                <value name="OID0">
                        <value name="IF1">
                                    </mutation>
                                    <value name="ARG0">
                        <value name="IF2">
                        <value name="IF3">
                                    </mutation>
                                    <value name="ARG0">
                <value name="OID0">
                            </mutation>
                            <value name="ARG0">
                    <value name="IF1">
                            </mutation>
                            <value name="ARG0">
                <mutation>
                </mutation>
                    <value name="URL">
                            <value name="URL">
              @bernd-1337
              Ich habe die überflüssigen Funktionen Modus und init entfernt und die Variablen mit den Ein- und Abschalttemperaturen durch die zugehörigen Datenpunkte ersetzt.
                @paul53 okay sieht gut aus kannst du den code posten um es wieder einfügen zu können
                  @bernd-1337 sagte: kannst du den code posten
                   <variables>
                   </variables>
                   <block type="procedures_defnoreturn" id=".F]sXJcTp=@W3(Y(=EeK" x="163" y="112">
                         <value name="URL">
                                 <value name="URL">
                                   <block type="logic_ternary" id="f}9^C%JV786Jh}ZmKErJ">
                                     <value name="IF">
                                       <block type="logic_compare" id="KHYb(LnPd=HL|U!{1zoO">
                                           <block type="variables_get" id="cwD(ukIy)S1Dv{tI_V18">
                                           <block type="math_number" id="xcofx23G.^hn$mt+^:`d">
                                     <value name="THEN">
                                       <block type="text" id="`NF)FWl95`{6h8Yq;G3v">
                                     <value name="ELSE">
                                       <block type="text" id="i#mQW*k:Jk%qt`Eu)Vvj">
                   <block type="variables_set" id="Lf+.@w0i]IS/gNw{qa6L" x="838" y="112">
                       <block type="on_ext" id="K2#.V[BShz?wc5YaB:Xa">
                         <value name="OID0">
                           <block type="controls_if" id="6t9~,p6FidwN}]u?M4">
                                   <block type="variables_get" id="4$$P9HQ)MNUl{s1VE~F">
                             <value name="IF1">
                               <block type="logic_compare" id="3%|GqQPly)yBIN7#y,">
                                       <block type="variables_set" id="}Zh9j34tYu[ebF)N,40,">
                             <value name="IF2">
                             <value name="IF3">
                                   <block type="math_number" id="$bd2xwJ/X1l.Kr.6[ut">
                               <block type="comment" id="gQznu+9U)WyeA|SO.(">
                                       <block type="logic_compare" id=".6qUKEJ|K/,*0Tqh7X+">
                                           <block type="on_source" id="mL5[!HcyBnf9f?r^0">
                                       <block type="variables_set" id="^Lqch?=mdtATs]!,HV.N">
                           <block type="on_ext" id="OtwKLd|WDL35?6l#wMO^">
                             <value name="OID0">
                                   <block type="logic_operation" id="*:ES_JmGY(:w{)//L(">
                                           <block type="on_source" id="+o:kLG3|[G/zOQA{@*V">
                                   <block type="variables_set" id="@1(if5NGK9EG:Dil(4Cd">
                                 <value name="IF1">
                                   <block type="logic_operation" id="Vr@lX;*Pc4]J2@-gu:W">
                                           <block type="variables_get" id="A)mtm?a!vB7%tbufxyg">
                                           <block type="math_number" id="]PxP{~|II!{NVfe%Cd">
                                           <block type="get_value" id="}+,ko4-p~+jF;Ly|Z8">
                                   <block type="variables_set" id="4^w`_tzL*$RzyAS%[U})">
                    @paul53 okay bist jetzt funzt es also gestartet hat sie ich melde mich zurück ob es komplett funzt
                      @paul53 jawoll es tut was es soll es reagiert nun auf die einstellung die ich auf dem tablet eingestellt habe du bist ein engel ich bedanke mich herzlich bei dir und sorry für deine gestohlene zeit aber ich habe wie gesagt davon 0 plan
                        @bernd-1337 sagte: es tut was es soll
                        Das sollte auch noch um unnütze Prüfungen bereinigt werden:
                        B 3 Replies Last reply Reply Quote 0
                          @paul53 okay mal gucken ich lass es jetzt erst mal so und schaue mal ob es weiterhin so funzt wie es jetzt ist also bis jetzt startet die ganz normal und stopt bei den angegebenen Temps
                            @paul53 hey paul bist du anwesend wenn ja sag mal kennst du dich mit Nodered und alexa aus wegen offline modus ich weiß wie es geht geräte anlegen und sowas aber es geht noch mal um die Temp steuerung das was wir gestern gemacht haben will einfach nur die 2 datenpunkte ein und aus temp mit alexa setzen Screenshot_1.png
                            paul53 DJMarc75 2 Replies Last reply Reply Quote 0
                              @bernd-1337 sagte: kennst du dich mit Nodered und alexa aus
                              Nein, weder noch.
                              • DJMarc75
                                DJMarc75 @Bernd 1337 last edited by
                                @bernd-1337 sagte in Suche hilfe für ein Temperatur Regler Script:
                                Wenn jetzt hier NodeRed gefragt ist dann bitte einen neuen Beitrag im entsprechenden Unterforum aufmachen !
                                  @paul53 Hey Paul schau mal ich habe in dem Heizungs script was du mir damals Gebastelt hast etwas eingefügt ist das richtig weil jetzt Reagiert es nicht mehr Screenshot_2.png
                                    <variables>
                                    </variables>
                                          <value name="OID0">
                                              <value name="IF1">
                                              <value name="IF2">
                                              <value name="IF3">
                                              <value name="OID0">
                                                  <value name="IF1">
                                    <block type="procedures_defnoreturn" id=".F]sXJcTp=@W3(Y(=EeK" x="-312" y="213">
                                          <value name="URL">
                                              <field name="DELAY">6</field>
                                                  <value name="URL">
                                                <block type="update" id="9*ti~%Pz1Q`s)`v|1x|p">
                                                  <field name="OID">0_userdata.0.example_state</field>
                                                    <block type="logic_ternary" id="a-jd(c]$i3K13wXlD^`U">
                                                      <value name="IF">
                                                        <block type="logic_compare" id="!H8SUz*o7a:qQecXgD!B">
                                                            <block type="variables_get" id="j+(+6p%535lyAO?F$kd3">
                                                            <block type="math_number" id="=guGNGu(8VqX=3u`ah.*">
                                                      <value name="THEN">
                                                        <block type="text_join" id="ACy5F:oct#wjMXVSWl@]">
                                                          <value name="ADD0">
                                                            <block type="text" id="{.z?{^yL)FfDp^vqK1Mg">
                                                              <field name="TEXT">Heizung wurde Eingeschaltet mit einer Temperatur von ! </field>
                                                          <value name="ADD1">
                                                            <block type="text_newline" id="uGY3`U`aNIL~a;dJrQ)I">
                                                              <field name="Type">\n</field>
                                                          <value name="ADD2">
                                                            <block type="get_value" id="WhPX7;1G!8KAbEd_wSG]">
                                                              <field name="OID">mqtt.0.HeizungsWasser.Sensor.temperature</field>
                                                      <value name="ELSE">
                                                        <block type="text_join" id="d27Xy~Lq.mNRAO6B1hMZ">
                                                          <value name="ADD0">
                                                            <block type="text" id="z%aG}*M}|`B;mrV6Z$e~">
                                                              <field name="TEXT">Heizung wurde Ausgeschaltet mit einer Temperatur von ! </field>
                                                          <value name="ADD1">
                                                            <block type="text_newline" id="LC!_{d7]dSwjm)H6xm5r">
                                                          <value name="ADD2">
                                                            <block type="get_value" id="3Dv[J8ok3T`=zv.ZSdFG">
                                                      <field name="ESCAPING">FALSE</field>
                                                          <value name="IF">
                                                          <value name="THEN">
                                                            <block type="text_join" id="QbL0O8/z;~l!n2st|G}5">
                                                              <value name="ADD0">
                                                              <value name="ADD1">
        <block type="text_newline" id="A-QG:Ig4YObizhB~]da(">
                                                              <value name="ADD2">
        <block type="get_value" id="seYhIcXy9|4kQxrn{1{)">
                                                          <value name="ELSE">
                                                            <block type="text_join" id="vxzalkvdQv(0g:RZzH,4">
                                                              <value name="ADD0">
                                                              <value name="ADD1">
        <block type="text_newline" id="A]K{Qi$do2-4F,kmkLEZ">
                                                              <value name="ADD2">
        <block type="get_value" id="Y8;|lZ0`~Pq33,[rY(V:">
                                    paul53 @Bernd 1337 last edited by paul53
                                    @bernd-1337 sagte: jetzt Reagiert es nicht mehr
                                    Ich kann keinen funktionellen Unterschied erkennen.
                                    Anstatt gleiche Texte zweimal zu erstellen, verwendet man besser eine Variable:
                                    • DJMarc75
                                      @bernd-1337 ob Du den XML Code auch bitte in Codetags packen würdest ?
                                        Bernd 1337 @DJMarc75 last edited by
                                        @djmarc75 habe ich zeigt er es nicht so an
                                            @bernd-1337 sagte: ist es richtig
                                            Nein. Vergleiche die Bilder!
                                            "°C" kannst du durchaus anhängen.
                                            2392
