    4. Server Cannot start inMem-objects on port 9001
      bot1000 @crunchip last edited by
      @crunchip
      Timeout beide auf 30000 gesetzt. Immer noch der gleiche Fehler
      • DJMarc75
        DJMarc75 @bot1000 last edited by
        @bot1000 sagte in Server Cannot start inMem-objects on port 9001:
        System aktualisiert -> Fehler ist gleich
        keine Nacherzählungen sonder auch jetzt wieder zeigen:
        iob diag
          bot1000 @apollon77 last edited by
          @apollon77
          System upgedatet
          Und dann "iob fix" nochmal ausgeführt. Object file immer noch so groß:
          iob fix Ausgabe:
          library: loaded
          Library version=2022-12-09
              Welcome to the ioBroker installation fixer!
              Script version: 2023-04-02
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
          Get:4 https://repos.influxdata.com/debian stable InRelease [6,892 B]
          Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
          Err:4 https://repos.influxdata.com/debian stable InRelease
            The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY D8FF8E1F7DF8B07E
          Err:5 https://packages.grafana.com/oss/deb stable InRelease
            The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY 9E439B102CF3C0C6
          Fetched 6,892 B in 4s (1,829 B/s)
          Reading package lists... Done
          W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://repos.influx        data.com/debian stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          W: An error occurred during the signature verification. The repository is not up        dated and the previous index files will be used. GPG error: https://packages.gra        fana.com/oss/deb stable InRelease: The following signatures couldn't be verified        because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
          W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease        The following signatures couldn't be verified because the public key is not avai        lable: NO_PUBKEY 9E439B102CF3C0C6
          W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  T        he following signatures couldn't be verified because the public key is not avail        able: NO_PUBKEY D8FF8E1F7DF8B07E
          W: Some index files failed to download. They have been ignored, or old ones used        instead.
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/5)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobr        oker-data/objects.jsonl"!
              at JsonlDB.open (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alc        alzone/jsonl-db/build/lib/db.js:185:19)
              at async compressDB (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/        @iobroker/jsonltool/index.js:37:9)
              at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobro        ker/jsonltool/index.js:93:17)
          Compressed 1 JSONL files. Done
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          iob diag Ausgabe "Summary":
                               v.2023-04-16
          Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
          Kernel:                 6.1.21-v7+
          Installation:           Native
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1000
          X-Server:               false
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v16.20.0
                                  /usr/bin/node           v16.20.0
                                  /usr/bin/npm            8.19.4
                                  /usr/bin/npx            8.19.4
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:            921M        213M        101M        0.0K        606M        684M
          Swap:            99M         32M         67M
          Total:          1.0G        245M        169M
          Active iob-Instances:   0
          Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          ioBroker Core:          js-controller           4.0.23
                                  admin                   6.2.22
          ioBroker Status:        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          Objects:                1
          States:                 1
          Size of iob-Database:
          628M    /opt/iobroker/iobroker-data/objects.jsonl
          88K     /opt/iobroker/iobroker-data/states.jsonl
            bot1000 @bot1000 last edited by
            Jemand noch ne Idee?
            • DJMarc75
              ja, wie wäre es wenn Du tatsächlich Deine Installation auf den aktuellen Stand bringen würdest ?
              Also Node auf die empfohlene Version bringen.
              https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                crunchip Forum Testing Most Active @bot1000 last edited by
                @bot1000 dann probier spasseshalber mal mit 60000
                Ausserdem musst du deine keys für grafana und influx anpassen
                  @crunchip
                  Kurzen Tipp wo ich weitere Infos bekomme wie das funktioniert?
                    Thomas Braun Most Active @bot1000 last edited by
                    @bot1000
                    https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                    Für influx steht auch was im weiteren Verlauf des Threads dabei.
                      Worn @Thomas Braun last edited by
                      Moin, ich hatte den Fehler heute auch wieder. Es hat also 3 Monate gedauert, bis das wieder aufgetreten ist. Der iob Fixer hat geholfen. Mein System ist stark veraltet, der neue PI etc. ist in Arbeit, aber es läuft wieder alles.
                      Compressed 2 JSONL files. Done
                      Meine Frage: Die JSON Files sollen doch automatisch komprimiert werden, richtig? JS Controller ist die 4.0.23 aktuell. Wie könnte ich denn mal prüfen, wieso das automatische Komprimieren nicht funktioniert. Vielleicht "muss" man das irgendwo mal enablen?
                        Thomas Braun Most Active @Worn last edited by Thomas Braun
                        @worn sagte in Server Cannot start inMem-objects on port 9001:
                        Vielleicht muss man sein System auch nur aktuell halten?
                        js-controller
                        latest:	4.0.24 for 5 months
                        stable:	4.0.24 for 5 months
                          Da hast du absolut Recht. Mich wunderte nur, dass irgendwo stand, die Komprimierung sollte bei JS 4.0.23 schon drin sein (meine ich hier gelesen zu haben), daher interessiert mich, ob da woanders ein Fehler steckt. Aktualisieren mache ich natürlich jetzt. Mal sehen, was dann in ~3 Monaten passiert (bzw. dann ist sicher der neue Raspi mit allem neu im Einsatz).
                            Wo stehst du denn im Moment?
                            iob diag
                            hilft dir da evtl. weiter.
                              Wie gesagt ist veraltet :). Dennoch läuft alles noch einwandfrei.
                              Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                @worn
                                Keine Screenshots von Text.
                                  crunchip Forum Testing Most Active @Worn last edited by
                                  @worn also mit stretch und nodejs12 haste aber Glück bzw die passenden Adapter am laufen, denn einige bzw viele Adapter unterstützen dies in der aktuellen Version gar nicht mehr
                                    Worn @crunchip last edited by
                                    @crunchip : Raspi befindet sich eh in Ablöse :).
                                    @Thomas-Braun : Danke für die Info.
                                      bot1000 @DJMarc75 last edited by
                                      @djmarc75 Nach dem Update funktioniert alles wieder!
                                        @bot1000 Was wird eigentlich in iobroker-data/objects.jsonl gespeichert? Wenn die Datei weiter so wächst, habe ich da früher oder später Probleme. Würde das gerne verhinden
                                        Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                                          Ein aktueller js-controller, der auf jsonl/jsonl läuft macht das von alleine.
                                          Alternativ regelmäßig den iob fix laufen lassen, der macht das u. a. auch.
                                            apollon77 @bot1000 last edited by
                                            @bot1000 wie Thomas sagt. Js-Controller 4.0.24 is your friend.
                                            429
                                            81548
