    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. BSB-LAN Adapter Funktioniert nach iobroker update nicht.
      FischerJedd @FischerJedd last edited by
      @fischerjedd
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       09:48:21 up 22:50,  1 user,  load average: 0.28, 0.28, 0.18
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=46.2'C
      volt=0.9060V
      *** Time and Time Zones ***
                     Local time: Mon 2023-05-29 09:48:21 CEST
                 Universal time: Mon 2023-05-29 07:48:21 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.6G        409M        6.5G        1.0M        738M        7.1G
      Swap:            99M          0B         99M
      Total:          7.7G        409M        6.6G
               7635 M total memory
                409 M used memory
                637 M active memory
                391 M inactive memory
               6487 M free memory
                 65 M buffer memory
                672 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      230G  2.9G  217G   2% /
      devtmpfs       devtmpfs  3.5G     0  3.5G   0% /dev
      tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
      tmpfs          tmpfs     1.5G  1.1M  1.5G   1% /run
      /dev/sda1      vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs     764M     0  764M   0% /run/user/1000
      [Sun May 28 10:57:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:C2:4C:1A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=84ea2d7e-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun May 28 10:57:29 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun May 28 10:57:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sun May 28 10:57:30 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      488M    /var/
      183M    /var/cache
      178M    /var/cache/apt
      155M    /var/lib
      130M    /var/lib/apt/lists
      Archived and active journals take up 48.0M in the file system.
      /opt/iobroker/backups:
      4.7M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      47M     /opt/iobroker/iobroker-data/
      17M     /opt/iobroker/iobroker-data/backup-objects
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      11M     /opt/iobroker/iobroker-data/objects.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      5.3M    /opt/iobroker/iobroker-data/states.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/local/bin/node             v18.16.0
      /usr/local/bin/npm              9.6.7
      /usr/local/bin/npx              9.6.7
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-2                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker-2                               -  enabled
      + system.adapter.bsblan.0                 : bsblan                : iobroker-2                               -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-2                               -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.19   , installed 2.6.19
      Adapter    "bsblan"       : 0.2.2    , installed 0.2.2
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Objects and States
      Objects:        156
      States:         118
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14523      507/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14530      507/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1524       535/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1526       535/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14108      590/io.admin.0
      udp        0      0 0.0.0.0:52747           0.0.0.0:*                           108        14452      396/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14563      789/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14450      396/avahi-daemon: r
      udp6       0      0 :::60850                :::*                                108        14453      396/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14574      789/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14451      396/avahi-daemon: r
          at Request.emit (node:events:513:28)
          at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
          at ClientRequest.emit (node:events:525:35)
          at Socket.socketOnData (node:_http_client:551:9)
          at Socket.emit (node:events:513:28)
          at addChunk (node:internal/streams/readable:324:12)
          at readableAddChunk (node:internal/streams/readable:297:9)
          at Readable.push (node:internal/streams/readable:234:10)
          at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
      2023-05-29 09:49:07.666  - info: bsblan.0 (1017) Setup new objects (700) ...
      2023-05-29 09:49:08.773  - error: bsblan.0 (1017) Error: Parse Error: Invalid header value char
      2023-05-29 09:49:08.773  - error: bsblan.0 (1017) RequestError: Error: Parse Error: Invalid header value char
          at new RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
          at plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
          at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
          at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      iob diag has finished.
      Press any key for a summary
                           v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.29-v8+
      Installation:           Native
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            7.6G        411M        6.5G        1.0M        738M        7.1G
      Swap:            99M          0B         99M
      Total:          7.7G        411M        6.6G
      Active iob-Instances:   5
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                156
      States:                 118
      Size of iob-Database:
      pi@iobroker-2:~ $
        Thomas Braun Most Active @FischerJedd last edited by
        @fischerjedd
        Installier es gescheit.
          FischerJedd @Thomas Braun last edited by
          Hallo, wie und wo kann man das Erkennen?
          Vielen Dank schon mal für die Info:
            Thomas Braun Most Active @FischerJedd last edited by Thomas Braun
            @fischerjedd
            An der entsprechenden Meldung von iob diag?
            Lösch den Kram einfach aus den falschen Verzeichnissen und installier nodejs nie anders als via Paketmanager 'apt'.
            iob stop
            sudo rm /usr/local/bin/n*
            sudo reboot
              Vielen Dank, aber warum ist das immer nach einer Neuinstallation, habe es x-mal versucht.
              Ich bin wohl zu alt dafür.
              Schönes rest WoEnd noch.
                @fischerjedd sagte in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
                Du machst irgendwas anders als vorgesehen.
                Schau in meiner Signatur nach wie man nodejs (und auch andere Softwarepakete) richtig via Paketmanager installiert. Leider sind halt auch viele dämliche/falsche/behämmerte Anleitungen Machwerke draußen unterwegs.
                  OK werde ich so machen.
                  Vielen Dank nochmal für die schnelle Hilfe.
                    @fischerjedd
                    ![0_1685352408168_056ce302-a4bc-45bf-9214-43891f25997b-image.png](Uploading 100%)
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=debian
                     11:20:51 up 18 min,  3 users,  load average: 0.22, 0.23, 0.21
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=47.2'C
                    volt=0.9060V
                                   Local time: Mon 2023-05-29 11:20:52 CEST
                               Universal time: Mon 2023-05-29 09:20:52 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            7.6G        365M        6.7G        1.0M        540M        7.2G
                    Swap:            99M          0B         99M
                    Total:          7.7G        365M        6.8G
                             7635 M total memory
                              365 M used memory
                              503 M active memory
                              299 M inactive memory
                             6729 M free memory
                               28 M buffer memory
                              512 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4      230G  2.8G  217G   2% /
                    tmpfs          tmpfs     1.5G  1.2M  1.5G   1% /run
                    [Mon May 29 11:01:58 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:C2:4C:1A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=84ea2d7e-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Mon May 29 11:02:00 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Mon May 29 11:02:00 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                    [Mon May 29 11:02:01 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                    /var:
                    513M    /var/
                    183M    /var/cache
                    178M    /var/cache/apt
                    155M    /var/lib
                    Archived and active journals take up 72.0M in the file system.
                    36M     /opt/iobroker/iobroker-data/
                    4.2M    /opt/iobroker/iobroker-data/objects.jsonl
                    1.1M    /opt/iobroker/iobroker-data/backup-objects/2023-05-29_08-57_objects.jsonl.gz
                    /usr/bin/node           v18.16.0
                    /usr/bin/npm            9.5.1
                    /usr/bin/npx            9.5.1
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        156
                    States:         118
                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12288      507/iobroker.js-con
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15367      507/iobroker.js-con
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12755      541/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15479      591/io.admin.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          12766      541/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12623      398/avahi-daemon: r
                    udp        0      0 0.0.0.0:34353           0.0.0.0:*                           108        12625      398/avahi-daemon: r
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1707       790/dhcpcd
                    udp6       0      0 :::45951                :::*                                108        12626      398/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        12624      398/avahi-daemon: r
                    udp6       0      0 :::546                  :::*                                0          15415      790/dhcpcd
                    2023-05-29 11:21:37.557  - info: bsblan.0 (4314) Setup new objects (700) ...
                    2023-05-29 11:21:38.587  - error: bsblan.0 (4314) Error: Parse Error: Invalid header value char
                    2023-05-29 11:21:38.587  - error: bsblan.0 (4314) RequestError: Error: Parse Error: Invalid header value char
                                         v.2023-04-16
                    Kernel:                 6.1.29-v8+
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            9.5.1
                                            /usr/bin/npx            9.5.1
                    MEMORY:
                    Mem:            7.6G        362M        6.7G        1.0M        541M        7.2G
                    Swap:            99M          0B         99M
                    Total:          7.7G        362M        6.8G
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                156
                    States:                 118
                    476K    /opt/iobroker/iobroker-data/states.jsonl
                    pi@iobroker-2:~ $
                      @fischerjedd
                      Ich mag es ja gar nicht sagen...
                      OK der Fehler mit nodejs ist weg, aber bsb-lan, da ist dieselbe Reaktion, auch nach
                      dem Deinstall und neu Install mit Neustart.
                        @fischerjedd
                        In dem Protokoll steht
                        RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char bei neuem RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15) bei plumbing.callback (/opt/iobroker/node_modules/ request-promise-core/lib/plumbing.js:87:29) bei Request.RP$callback [als _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31) bei self.callback (/opt/iobroker/node_modules/request/request.js:185:22) bei Request.emit (node:events:513:28) bei Request.onRequestError (/opt/iobroker/node_modules/request/request .js:877:8) bei ClientRequest.emit (node:events:525:35) bei Socket.socketOnData (node:_http_client:551:9) bei Socket.emit (node:events:513:28) bei addChunk (node :internal/streams/readable:324:12) bei readableAddChunk (Knoten:internal/streams/readable:297:9) bei Readable.push (Knoten:internal/streams/readable:234:10) bei TCP.onStreamRead (node:internal/stream_base_commons:190:23)
                        F Glasfaser 2 Replies Last reply Reply Quote 0
                          @fischerjedd
                          Natürlich alles in rot
                          in Schwarz
                          Neue Objekte einrichten (700) ..
                            @fischerjedd
                            Dann ist jetzt zumindest die Basis sauber und du kannst dich auf den Adapter konzentrieren.
                            Wie sehen die Einstellungen da aus und wie sieht ein Start des Adapters im Logfile aus?
                              ÄÄÄÄÄh wo, wie, was...
                              Ich oute mich als dau
                                @fischerjedd
                                Irgendwas musst du ja beim Adapter an Einstellungen getätigt haben.
                                Das Log schaut man sich am besten so an
                                iob logs --watch | uniq
                                und startet den Adapter/die Instanz dann neu. Ausgaben im Logfile dann hier, in CodeTags eingebettet, reinkopieren.
                                  2023-05-29 11:42:04.780 - error: bsblan.0 (10434) Error: Parse Error: Invalid header value char
                                  2023-05-29 11:42:04.781 - error: bsblan.0 (10434) RequestError: Error: Parse Error: Invalid header value char
                                  2023-05-29 11:42:14.802 - info: bsblan.0 (10434) Setup new objects (700) ...
                                  2023-05-29 11:42:16.913 - error: bsblan.0 (10434) Error: Parse Error: Invalid header value char
                                  2023-05-29 11:42:16.914 - error: bsblan.0 (10434) RequestError: Error: Parse Error: Invalid header value char
                                    @fischerjedd
                                    In CodeTags, damit man das auch lesen kann.
                                      noch nie gemacht
                                      so
                                      29.05.2023 00:00:09.078 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
                                      29.05.2023 00:00:10.326 – Fehler : bsblan.0 (1017) Fehler: Analysefehler: Ungültiger Header-Wert char
                                      29.05.2023 00:00:10.326 – Fehler : bsblan.0 (1017) RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char
                                      unter plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
                                      bei Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
                                      unter self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                      unter Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
                                      bei addChunk (node:internal/streams/readable:324:12)
                                      bei readableAddChunk (node:internal/streams/readable:297:9)
                                      bei Readable.push (node:internal/streams/readable:234:10)
                                      29.05.2023 00:00:21.344 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
                                      29.05.2023 00:00:22.374 – Fehler : bsblan.0 (1017) Fehler: Analysefehler: Ungültiger Header-Wert char
                                      29.05.2023 00:00:22.375 – Fehler : bsblan.0 (1017) RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char
                                      29.05.2023 00:00:33.392 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
                                        @fischerjedd
                                        Nein.
                                        Schau hier rein:
                                        https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                                        • Glasfaser
                                          Glasfaser @FischerJedd last edited by Glasfaser
                                          @fischerjedd
                                          Dazu habe ich ganz am Anfang etwas geschrieben !
                                          @glasfaser sagte in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
                                          Stelle in der Instanz die Logstufe auf DEBUG .
                                          Starte den Adapter und zeige hier die Log Ausgabe davon !
                                          EDIT :
                                          Expertenmodus ..... dann auf den Bleistift ... von Info auf Debug ändern .
                                            FischerJedd @Glasfaser last edited by FischerJedd
                                            @glasfaser
                                            Super erklärt, jetzt habe ich dussel es auch kapiert.
                                            Thomas Braun F 2 Replies Last reply Reply Quote 0
                                            979
