    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. BSB-LAN Adapter Funktioniert nach iobroker update nicht.
      Thomas Braun Most Active @FischerJedd last edited by
      @fischerjedd
      Irgendwas musst du ja beim Adapter an Einstellungen getätigt haben.
      Das Log schaut man sich am besten so an
      iob logs --watch | uniq
      und startet den Adapter/die Instanz dann neu. Ausgaben im Logfile dann hier, in CodeTags eingebettet, reinkopieren.
        FischerJedd @Thomas Braun last edited by
        2023-05-29 11:42:04.780 - error: bsblan.0 (10434) Error: Parse Error: Invalid header value char
        2023-05-29 11:42:04.781 - error: bsblan.0 (10434) RequestError: Error: Parse Error: Invalid header value char
        at new RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
        at plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
        at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
        at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
        at Request.emit (node:events:513:28)
        at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
        at ClientRequest.emit (node:events:525:35)
        at Socket.socketOnData (node:_http_client:551:9)
        at Socket.emit (node:events:513:28)
        at addChunk (node:internal/streams/readable:324:12)
        at readableAddChunk (node:internal/streams/readable:297:9)
        at Readable.push (node:internal/streams/readable:234:10)
        at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
        2023-05-29 11:42:14.802 - info: bsblan.0 (10434) Setup new objects (700) ...
        2023-05-29 11:42:16.913 - error: bsblan.0 (10434) Error: Parse Error: Invalid header value char
        2023-05-29 11:42:16.914 - error: bsblan.0 (10434) RequestError: Error: Parse Error: Invalid header value char
          @fischerjedd
          In CodeTags, damit man das auch lesen kann.
            noch nie gemacht
            so
            29.05.2023 00:00:09.078 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
            29.05.2023 00:00:10.326 – Fehler : bsblan.0 (1017) Fehler: Analysefehler: Ungültiger Header-Wert char
            29.05.2023 00:00:10.326 – Fehler : bsblan.0 (1017) RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char
            bei neuem RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
            unter plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
            bei Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
            unter self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
            bei Request.emit (node:events:513:28)
            unter Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
            bei ClientRequest.emit (node:events:525:35)
            bei Socket.socketOnData (node:_http_client:551:9)
            bei Socket.emit (node:events:513:28)
            bei addChunk (node:internal/streams/readable:324:12)
            bei readableAddChunk (node:internal/streams/readable:297:9)
            bei Readable.push (node:internal/streams/readable:234:10)
            bei TCP.onStreamRead (node:internal/stream_base_commons:190:23)
            29.05.2023 00:00:21.344 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
            29.05.2023 00:00:22.374 – Fehler : bsblan.0 (1017) Fehler: Analysefehler: Ungültiger Header-Wert char
            29.05.2023 00:00:22.375 – Fehler : bsblan.0 (1017) RequestError: Fehler: Parse-Fehler: Ungültiger Header-Wert char
            29.05.2023 00:00:33.392 - Info : bsblan.0 (1017) Neue Objekte einrichten (700) ...
              @fischerjedd
              Nein.
              Schau hier rein:
              https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
              • Glasfaser
                Glasfaser @FischerJedd last edited by Glasfaser
                @fischerjedd sagte in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
                @fischerjedd
                In dem Protokoll steht
                Dazu habe ich ganz am Anfang etwas geschrieben !
                @glasfaser sagte in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
                Stelle in der Instanz die Logstufe auf DEBUG .
                Starte den Adapter und zeige hier die Log Ausgabe davon !
                EDIT :
                Expertenmodus ..... dann auf den Bleistift ... von Info auf Debug ändern .
                  FischerJedd @Glasfaser last edited by FischerJedd
                  @glasfaser
                  Super erklärt, jetzt habe ich dussel es auch kapiert.
                  Thomas Braun F 2 Replies Last reply Reply Quote 0
                    @fischerjedd
                    Warum ändert sich die Sprache im logfile von Englisch auf Deutsch?
                    Übersetzungsautomatiken im Browser aktiv? Aber das dürfte das LogFile nicht tangieren.
                    Vielleicht führt das auch zu den 'invalid header value char' Meldungen...
                      FischerJedd @FischerJedd last edited by
                      @fischerjedd
                      Nächstes Problem
                      Ich mache hier gerade eine Fortbildung
                        @fischerjedd
                        Nächstes Problem
                        Schau hier rein:
                          Ich habe es mal in Firefox gestartet
                          alles das selbe
                          • Glasfaser
                            alles das selbe
                            Was das selbe ... stehn gerade auf dem Schlauch was du meinst !?
                              @glasfaser
                              ich meinte, das Verhalten ist dasselbe, selber Fehler
                                @fischerjedd
                                wegen automatische Übersetzung englisch - deutsch
                                  FischerJedd @FischerJedd last edited by FischerJedd
                                  @fischerjedd
                                  ist bei Firefox nicht eingestellt
                                  Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                                  • Glasfaser
                                    @fischerjedd
                                    dort ausgeschaltet !?
                                      @fischerjedd
                                      Hol das log direkt aus dem Dateisystem und nicht irgendwie über den Browser.
                                      Im Terminal mit
                                        @thomas-braun said in BSB-LAN Adapter Funktioniert nach iobroker update nicht.:
                                        login as: pi
                                        pi@192.168.33.23's password:
                                        Linux iobroker-2 6.1.29-v8+ #1652 SMP PREEMPT Wed May 24 14:46:55 BST 2023 aarch        64
                                        The programs included with the Debian GNU/Linux system are free software;
                                        the exact distribution terms for each program are described in the
                                        individual files in /usr/share/doc/*/copyright.
                                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                        permitted by applicable law.
                                        Last login: Mon May 29 11:20:27 2023 from 192.168.33.17
                                        SSH is enabled and the default password for the 'pi' user has not been changed.
                                        This is a security risk - please login as the 'pi' user and type 'passwd' to set        a new password.
                                        pi@iobroker-2:~ $ iob logs --watch | uniq
                                        2023-05-29 12:33:58.226  - error: bsblan.0 (13225) Error: Parse Error: Invalid header value char
                                        2023-05-29 12:33:58.227  - error: bsblan.0 (13225) RequestError: Error: Parse Error: Invalid header value char
                                        2023-05-29 12:33:58.227  - debug: bsblan.0 (13225) Reset Timer
                                        2023-05-29 12:34:00.009  - info: bsblan.0 (13225) Scheduled restart.
                                        2023-05-29 12:34:00.010  - info: bsblan.0 (13225) cleaned everything up...
                                        2023-05-29 12:34:00.056  - info: bsblan.0 (13225) terminating
                                        2023-05-29 12:34:00.058  - info: bsblan.0 (13225) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2023-05-29 12:34:00.597  - info: host.iobroker-2 instance system.adapter.bsblan.0 scheduled normal terminated and will be restarted on schedule.
                                        2023-05-29 12:34:00.597  - info: host.iobroker-2 Restart adapter system.adapter.bsblan.0 because enabled
                                        2023-05-29 12:34:01.628  - info: host.iobroker-2 instance system.adapter.bsblan.0 started with pid 13240
                                        2023-05-29 12:34:03.492  - debug: bsblan.0 (13240) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2023-05-29 12:34:03.532  - debug: bsblan.0 (13240) Objects client ready ... initialize now
                                        2023-05-29 12:34:03.536  - debug: bsblan.0 (13240) Objects create System PubSub Client
                                        2023-05-29 12:34:03.537  - debug: bsblan.0 (13240) Objects create User PubSub Client
                                        2023-05-29 12:34:03.566  - debug: bsblan.0 (13240) Objects client initialize lua scripts
                                        2023-05-29 12:34:03.576  - debug: bsblan.0 (13240) Objects connected to redis: 127.0.0.1:9001
                                        2023-05-29 12:34:03.599  - debug: bsblan.0 (13240) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2023-05-29 12:34:03.610  - debug: bsblan.0 (13240) States create System PubSub Client
                                        2023-05-29 12:34:03.611  - debug: bsblan.0 (13240) States create User PubSub Client
                                        2023-05-29 12:34:03.628  - debug: bsblan.0 (13240) States connected to redis: 127.0.0.1:9000
                                        2023-05-29 12:34:03.752  - info: bsblan.0 (13240) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.bsblan, node: v18.16.0, js-controller: 4.0.24
                                        2023-05-29 12:34:03.825  - debug: bsblan.0 (13240) Schedule restart: */30 * * * * *
                                        2023-05-29 12:34:03.894  - info: bsblan.0 (13240) Values found: 700
                                        2023-05-29 12:34:03.897  - debug: bsblan.0 (13240) Fetch values ...
                                        2023-05-29 12:34:03.984  - info: bsblan.0 (13240) Setup new objects (700) ...
                                        2023-05-29 12:34:05.398  - error: bsblan.0 (13240) Error: Parse Error: Invalid header value char
                                        2023-05-29 12:34:05.399  - error: bsblan.0 (13240) RequestError: Error: Parse Error: Invalid header value char
                                            a
                                        • Glasfaser
                                          vor allen hatte ich noch einen alten Raspberry mit iobroker wo es lief, bis zu dem Moment
                                          als ich Dussel Updates für den iobroker installiert habe.
                                          Mit welcher Version lief es denn vorher ?
                                          Aktuelle in Stable ist die 0.0.2 ..
                                          Hast du eventuell die Beta genutzt , dort sind einige Änderung enthalten , vielleicht lief es mit der !?
                                            @glasfaser
                                            Deshalb ja ich dussel, ich kann es nicht mehr nachvollziehen,
                                            es kann sein.
                                            979
