Weckfunktion in VIS
Code Export:
schedule("* * * * *", function () { if (getState("hm-rega.0.5209").val == 0) { setState("sayit.0.tts.text", "de;" + 'verschlafen'); } }); //JTNDeG1sJTIweG1sbnMlM0QlMjJodHRwJTNBJTJGJTJGd3d3LnczLm9yZyUyRjE5OTklMkZ4aHRtbCUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnNjaGVkdWxlJTIyJTIwaWQlM0QlMjIlN0JVMGJOJTIzVSU1QiU1QnY1Q1FIUSolNUUqJTVCMSUyMiUyMHglM0QlMjIzODglMjIlMjB5JTNEJTIyMTYzJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyU0NIRURVTEUlMjIlM0UqJTIwKiUyMColMjAqJTIwKiUzQyUyRmZpZWxkJTNFJTNDc3RhdGVtZW50JTIwbmFtZSUzRCUyMlNUQVRFTUVOVCUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmNvbnRyb2xzX2lmJTIyJTIwaWQlM0QlMjI2JTJGQmQlMkNPbiU1RSUzQkJzZUtfZGp2UHpPJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIySUYwJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIybG9naWNfY29tcGFyZSUyMiUyMGlkJTNEJTIyJTNBJTVEYSU3RCU1QmRTMUlzcmZYcmNxMkVhJTNCJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyT1AlMjIlM0VFUSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyQSUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmdldF92YWx1ZSUyMiUyMGlkJTNEJTIyJTVFVW1hWCU0MENhJTdCJTdCY1UhNXUlNjAyLS5IJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyQVRUUiUyMiUzRXZhbCUzQyUyRmZpZWxkJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyT0lEJTIyJTNFaG0tcmVnYS4wLjUyMDklM0MlMkZmaWVsZCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJCJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIybWF0aF9udW1iZXIlMjIlMjBpZCUzRCUyMkNxcjIoKC0lM0QlM0JRa0VrbFAlM0RxR1IqJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyTlVNJTIyJTNFMCUzQyUyRmZpZWxkJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0NzdGF0ZW1lbnQlMjBuYW1lJTNEJTIyRE8wJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyc2F5aXQlMjIlMjBpZCUzRCUyMmYlM0FYMmluRS05flFINCUzQWdVJTJGYyUzRiUyNSUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMklOU1RBTkNFJTIyJTNFLjAlM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMkxBTkdVQUdFJTIyJTNFZGUlM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMkxPRyUyMiUzRSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyTUVTU0FHRSUyMiUzRSUzQ3NoYWRvdyUyMHR5cGUlM0QlMjJ0ZXh0JTIyJTIwaWQlM0QlMjIlNDAlMkMlNUV0JTYwJTdCbSg0Qno5U3VUQUtYekwlMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJURVhUJTIyJTNFdmVyc2NobGFmZW4lM0MlMkZmaWVsZCUzRSUzQyUyRnNoYWRvdyUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZzdGF0ZW1lbnQlM0UlM0MlMkZibG9jayUzRSUzQyUyRnN0YXRlbWVudCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGeG1sJTNF
Code Export:
schedule("* * * * *", function () { if (getState("hm-rega.0.5209").val == 0) { setState("sayit.0.tts.text", "de;" + 'verschlafen'); } }); 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 ```` `
Nicht den generierten Code sondern Block bitte [emoji6]
Links neben Zeige Code die Pfeiltasten
Send from mobile device
Man lernt doch nie aus
<xml xmlns="http://www.w3.org/1999/xhtml"><block type="schedule" id="{U0bN#U[[v5CQHQ*^*[1" x="388" y="163"><field name="SCHEDULE">* * * * *</field> <statement name="STATEMENT"><block type="controls_if" id="6/Bd,On^;BseK_djvPzO"><value name="IF0"><block type="logic_compare" id=":]a}[dS1IsrfXrcq2Ea;"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="^UmaX@Ca{{cU!5u`2-.H"><field name="ATTR">val</field> <field name="OID">hm-rega.0.5209</field></block></value> <value name="B"><block type="math_number" id="Cqr2((-=;QkEklP=qGR*"><field name="NUM">0</field></block></value></block></value> <statement name="DO0"><block type="sayit" id="f:X2inE-9~QH4:gU/c?%"><field name="INSTANCE">.0</field> <field name="LANGUAGE">de</field> <value name="MESSAGE"><shadow type="text" id="@,^t`{m(4Bz9SuTAKXzL"><field name="TEXT">verschlafen</field></shadow></value></block></statement></block></statement></block></xml>
waere ja auch langweilig !
ich bekommen 0 fehler wen ich diesen block 1:1 uebernehme, sayit hast du aber installiert ?
Edit: probier mal das hier bitte was komt dan im log ?
code fuer import (variable mit deiner ersetzen):
<xml xmlns="http://www.w3.org/1999/xhtml"><block type="schedule" id="{U0bN#U[[v5CQHQ*^*[1" x="263" y="88"><field name="SCHEDULE">* * * * *</field> <statement name="STATEMENT"><block type="controls_if" id="6/Bd,On^;BseK_djvPzO"><value name="IF0"><block type="logic_compare" id=":]a}[dS1IsrfXrcq2Ea;"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="^UmaX@Ca{{cU!5u`2-.H"><field name="ATTR">val</field> <field name="OID">hm-rega.0.4910</field></block></value> <value name="B"><block type="math_number" id="Cqr2((-=;QkEklP=qGR*"><field name="NUM">0</field></block></value></block></value> <statement name="DO0"><block type="debug" id="/1prg8I8p~#f0P1y64R}"><field name="Severity">log</field> <value name="TEXT"><shadow type="text" id="qu4PB7LfZhzQ#{a{@pA~"><field name="TEXT">Ich bin ein test ==> Verschlafen</field></shadow></value></block></statement></block></statement></block></xml>
Ja, SayIt läuft gut bei mir.
Hab Es getestet alles gut
Systemlog zeigt keine weiteren Infos, falls das eine Intension war.
1935_b4.png -
Dann bin ich jetzt ratlos warum er den sayit Block nicht schluckt bei dir
Kein Ding,
Danke nochmal für die Hilfe.
Ich teste das mal morgen "ohne Wein" mit dem Code den ich bei den SayIt Skripten direkt eingegeben habe.
Wird schon
*/offtopic
Ich teste das mal morgen "ohne Wein" …. `
Wo bleibt denn da der Spaß [emoji3]
Auf gutes Gelingen lass von dir hören was raus kommt
Hallo Zusammen
Vergleicht doch mal die Adapter Versionen.
Bei mir geben die Imports auch keine Fehler.
"Text to Speech" v1.6.3
"Javascript" v3.4.5
"js-controller" v1.2.0
Geht zu Bett, ist doch schon spät
Ich muß noch meine Musik für die Weihnachtsbeleuchtung 2017 schneiden :lol:
HoHoHo, Weihnachten kommt schneller als man glaubt - daswegen auch der Wcker - HoHoho
keiner mehr wach :lol:
Ich tippe mal drauf, daß der ein oder andere sowas bereits realisiert hat bzw. eine gut Idee hierfür hat.
Ich suche eine Weckfunktion, die nach Wochentag und Zeitpunkt (ev. auch via Script vordefiniert) einen Alarm auslöst bzw. einen Datenpunkt schaltet.
Kann mir da wer unbürokratisch weiterhelfen?
Danke & Grüße
Thomas
Background: Soll ein Last Minute Voicecall via SayIt oder Alarm mit HM Schaltsteckdose werden, um einen Familien Kollektivverschlafen zu verhindern
Heute passiert - :lol: `
Hallo galferiz,
ich glaube eine unbürokratische Version wäre mit google kalender und iCal adapter.
gKalender mit iCal verbinden und neue Ereignis namens "Wecker" einfügen.
Danach hast du im Objekte -> iCal.0 -> events eine neue Datenpunkt namens Wecker. Dieser Datenpunkt bekommt den wert true sobald in dein Kalender einen Termin mit Bezeichnung "Wecker" eingetragen wird und Uhrzeit und Datum vom Termin eintreffen. Dann kannst du z.Bs. im Kalender ein Serientermin eintragen vom Montag bis Freitag morgens um 6:30 Uhr mit dauer 1 minute. Damit wird dein Datenpunkt zur dieser Zeitpunkt für eine minute den wert true bekommen.
Mit eine kleine Blockly Script zum beispiel so:
Kannst du deine Meldung ausgeben.
Vorteil ist das du, ohne am Script was zu ändern, deine triggerzeiten ändern kannst wie du sie brauchst. Du kannst auch andere Ereignisse damit realisieren. Ich habe z.B. eine Anwesenheit simulation wenn Ereignis Urlaub eintrifft.
Ein sehr interessanter Ansatz der sicherlich auch gut geht.
Der einzige Hinternisgrund ist dabei nur, daß man ja täglich eingeben müßte unter Google wann man aufstehn will. Ne Menge arbeit auf Jahr gesehen
` Hi galferiz,
Im Google Kalender gibt es die Möglichkeit serientermine einzugeben, also du kannst für ein Termin sagen ob es einmalig ist oder z.Bs. Täglich, Wöchentlich, monatlich oder jährlich also von Mo. Bis Fr. Sind 5 Termine die du anlegen müsstest. So habe ich es gemacht.
Gesendet von meinem SM-G950F mit Tapatalk
Stimmt, jetzt wo du es sagst.
Danke für den Hinweis, somit ist das sicher die eleganteste Lösung
Schon mal den neuen Kalender Adapter probiert? Der sollte ideal sein denke ich.
Gesendet von meinem SM-G930F mit Tapatalk
Du kannst auch die Timer Funktion von Buzzy etwas umbauen und zu einem Wecker umfunktionieren. Dann kannst du direkt in Vis deine Weckzeit eingeben.
http://forum.iobroker.net/viewtopic.php … 160#p84609
Würde ja reichen wenn du dir die Rolladenöffungzeit umbaust. Musst nur noch definieren was als Aktion ausgegeben werden soll.
Mfg
