    4. SMA Energy Meter in Echtzeit auslesen
      Marcolotti last edited by
      Trigger: Falls WERT von Objekt Netzbezug.
      mach mal aktualisiere "WERT" von Objekt Gesamtverbrauch.
      Den Gesamtverbrauch (Hausverbrauch) ermittelst du aber anders. Anbei mal mein Blockly-Script.
       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="A_|oG95s;SJyu.E{x%7V" x="-637" y="-587"><mutation items="1"></mutation>
          <value name="OID0"><shadow type="field_oid" id=",XHVS?h[R1:AZAj~(]{I"><field name="oid">modbus.0.inputRegisters.30775_PVLeistung</field></shadow></value>
          <statement name="STATEMENT"><block type="controls_if" id="qHHO|g6/TAQ.).Yo{lH?"><value name="IF0"><block type="logic_compare" id="ReyL(zZ-IFCB!(,SQ7e."><field name="OP">GT</field>
                  <value name="A"><block type="get_value" id="8d,ucU}B{Mu_/WoqL*wW"><field name="ATTR">val</field>
                      <field name="OID">modbus.0.inputRegisters.30865_Bezug</field></block></value>
                  <value name="B"><block type="math_number" id="7gE)SC`pgjZ,OaJMKO@X"><field name="NUM">1</field></block></value></block></value>
              <statement name="DO0"><block type="update" id="gKGH45oZ.F#AW?GZDqUx"><mutation delay_input="false"></mutation>
                  <field name="OID">javascript.0.PV_Anlage.AktHausverbrauch</field>
                  <value name="VALUE"><block type="math_arithmetic" id="%%je1MKU.._nRf^9FUk7"><field name="OP">ADD</field>
                      <value name="A"><shadow type="math_number" id="_y%]3cOycFhKAJnHhJi("><field name="NUM">1</field></shadow>
                        <block type="get_value" id="bdETUtBo:uyyeb]WQBO-"><field name="ATTR">val</field>
                      <value name="B"><shadow type="math_number" id="-Z[8!/-igUXos;(vJUVw"><field name="NUM">1</field></shadow>
                        <block type="get_value" id="/.AZOS,oX]g-1|ppFf-q"><field name="ATTR">val</field>
                          <field name="OID">javascript.0.PV_Anlage.Werte.PVLeistung</field></block></value></block></value></block></statement></block></statement>
          <next><block type="on_ext" id="+hCBHdKPoJ07auWNVqF]"><mutation items="1"></mutation>
              <value name="OID0"><shadow type="field_oid" id="*+mSamkO0_PDL=-{%cK7"><field name="oid">modbus.0.inputRegisters.30865_Bezug</field></shadow></value>
              <statement name="STATEMENT"><block type="controls_if" id="0K4{*}3bY@,{E.kwU2iQ"><value name="IF0"><block type="logic_compare" id="ed)^9`y`u5M({wRJ0QK-"><field name="OP">LT</field>
                      <value name="A"><block type="get_value" id="q60LaHAnF9zFFy*t)8kv"><field name="ATTR">val</field>
                          <field name="OID">modbus.0.inputRegisters.30775_PVLeistung</field></block></value>
                      <value name="B"><block type="math_number" id="g`gA;;Igq%#{~XX:lVXG"><field name="NUM">1</field></block></value></block></value>
                  <statement name="DO0"><block type="update" id="Zwm;%=MetHz@Z[rTU^k*"><mutation delay_input="false"></mutation>
                      <value name="VALUE"><block type="get_value" id="1K{jq}Q;uUh|#T1Fnml;"><field name="ATTR">val</field>
                          <field name="OID">modbus.0.inputRegisters.30865_Bezug</field></block></value></block></statement></block></statement>
              <next><block type="on_ext" id=").9fLJ-=]~P)cBvbL@N8"><mutation items="1"></mutation>
                  <value name="OID0"><shadow type="field_oid" id="K(p8q^h+TEg6`+Tz|zHd"><field name="oid">modbus.0.inputRegisters.30867_Einspeisung</field></shadow></value>
                  <statement name="STATEMENT"><block type="controls_if" id="aOwi+@J%Af2z`M]iUntU"><value name="IF0"><block type="logic_compare" id="HUpU+1WgogWAt~g::j1]"><field name="OP">GT</field>
                          <value name="A"><block type="get_value" id="s!Ryj}gQ_Rbb2hT9FOqr"><field name="ATTR">val</field>
                              <field name="OID">modbus.0.inputRegisters.30867_Einspeisung</field></block></value>
                          <value name="B"><block type="math_number" id="`c{;cIl!vvFwx3#M85m."><field name="NUM">1</field></block></value></block></value>
                      <statement name="DO0"><block type="update" id="8#B{9[vq+}.yjz4yt({;"><mutation delay_input="false"></mutation>
                          <value name="VALUE"><block type="math_arithmetic" id="6_p4XZ+.80LPnLU26+Qy"><field name="OP">MINUS</field>
                                <block type="get_value" id="/V5kC~bpl~iB)okjV~Y-"><field name="ATTR">val</field>
                                <block type="get_value" id="R(!t|d+6)8LLtF,vqJrs"><field name="ATTR">val</field>
                                  <field name="OID">modbus.0.inputRegisters.30867_Einspeisung</field></block></value></block></value></block></statement></block></statement>
                  <next><block type="on_ext" id="?36x-AQU8nD[OmAgz[_]"><mutation items="1"></mutation>
                      <value name="OID0"><shadow type="field_oid" id="tUm]PB6uk2%jJAb}2te:"><field name="oid">javascript.0.PV_Anlage.AktHausverbrauch</field></shadow></value>
                      <statement name="STATEMENT"><block type="controls_if" id="PxZ/oA[33q#/d~xL=!M{"><value name="IF0"><block type="logic_compare" id="oUy-3/+PJeC:uIB9JTkl"><field name="OP">GT</field>
                              <value name="A"><block type="get_value" id="-EfAF.m7|8F2NN7sTPm6"><field name="ATTR">val</field>
                                  <field name="OID">javascript.0.PV_Anlage.AktHausverbrauch</field></block></value>
                              <value name="B"><block type="get_value" id="6tvlPvH7#`/c6*0)z}_g"><field name="ATTR">val</field>
                                  <field name="OID">javascript.0.PV_Anlage.MaxVerbrauchHeute</field></block></value></block></value>
                          <statement name="DO0"><block type="update" id="7~kniq!7nBj?^0]Ibhk!"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="get_value" id="KqDq?2tl*2wVnB!lu;8Z"><field name="ATTR">val</field>
                                  <field name="OID">javascript.0.PV_Anlage.AktHausverbrauch</field></block></value></block></statement></block></statement>
                      <next><block type="schedule" id="5BUMKb@ibWS7o?x2HzV+"><field name="SCHEDULE">59 59 23 * * *</field>
                          <statement name="STATEMENT"><block type="update" id="}%Q^Ta92/;nMH7!^ct|e"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="math_number" id="HnO;1qG,Ylaj*A@P=c(-"><field name="NUM">0</field></block></value>
                              <next><block type="update" id="|qy!pM2Uu~x:1Kreg)Oa"><mutation delay_input="false"></mutation>
                                  <field name="OID">javascript.0.PV_Anlage.MaxPVHeute</field>
                                  <value name="VALUE"><block type="math_number" id="fxF.%(]-Eo/Q|RkyMhKA"><field name="NUM">0</field></block></value></block></next></block></statement>
                          <next><block type="on_ext" id="n9_GDzS1NxQt2!RfN@Be"><mutation items="1"></mutation>
                              <value name="OID0"><shadow type="field_oid" id="4;_,hSYl5TxrGbMP,[l}"><field name="oid">modbus.0.inputRegisters.30775_PVLeistung</field></shadow></value>
                              <statement name="STATEMENT"><block type="controls_if" id="^Q.6FAXh!F7|qs6Nz/+#"><value name="IF0"><block type="logic_compare" id="y?-W.IqVC)OMg~rZ]t:8"><field name="OP">GT</field>
                                      <value name="A"><block type="get_value" id="NJFvsM[F-qi;W=o`m.ly"><field name="ATTR">val</field>
                                      <value name="B"><block type="get_value" id="Jd`/x7z!1L_[%FltwK[S"><field name="ATTR">val</field>
                                          <field name="OID">javascript.0.PV_Anlage.MaxPVHeute</field></block></value></block></value>
                                  <statement name="DO0"><block type="update" id="*HHkx8OmN=E)HkaCdqLz"><mutation delay_input="false"></mutation>
                                      <value name="VALUE"><block type="get_value" id="l]/F%O}Yfn_nRj*I?@RD"><field name="ATTR">val</field>
                                          <field name="OID">javascript.0.PV_Anlage.Werte.PVLeistung</field></block></value></block></statement>
                                  <next><block type="controls_if" id="Of|KASl2L#md3Ja5=BtB"><value name="IF0"><block type="logic_compare" id="4CLR;Ws?UfX])eQ8^mw*"><field name="OP">GT</field>
                                          <value name="A"><block type="get_value" id="LG!0Q+G[j(NJ~z:T]cO1"><field name="ATTR">val</field>
                                          <value name="B"><block type="get_value" id="(7I?/+syvHG:S@XcH},C"><field name="ATTR">val</field>
                                              <field name="OID">javascript.0.PV_Anlage.MAXPVever</field></block></value></block></value>
                                      <statement name="DO0"><block type="update" id="CL,.4(Wj5Sm].!4y@?pm"><mutation delay_input="false"></mutation>
                                          <value name="VALUE"><block type="get_value" id="._6z#.CayIYZT.7#c*VG"><field name="ATTR">val</field>
                                              <field name="OID">javascript.0.PV_Anlage.Werte.PVLeistung</field></block></value></block></statement></block></next></block></statement>
                              <next><block type="on_ext" id="m2w.v~KBYw4MNQAZ%4e6"><mutation items="1"></mutation>
                                  <value name="OID0"><shadow type="field_oid" id="2^/i*jy?5F[n9W?N|j}j"><field name="oid">javascript.0.PV_Anlage.AktHausverbrauch</field></shadow></value>
                                  <statement name="STATEMENT"><block type="controls_if" id="PSIuUZVF2K(,lk{P5b!N"><value name="IF0"><block type="logic_compare" id="Kl(Kt;=?F(Imszqzzi1u"><field name="OP">GT</field>
                                          <value name="A"><block type="get_value" id="aRM%{M?GRx0bPQAmdysW"><field name="ATTR">val</field>
                                          <value name="B"><block type="get_value" id="f!B5KEC)Kek]YHFH8RnY"><field name="ATTR">val</field>
                                              <field name="OID">javascript.0.PV_Anlage.MAXVerbrauchever</field></block></value></block></value>
                                      <statement name="DO0"><block type="update" id="(uh]J)8E9BWJ8HjyC=Hp"><mutation delay_input="false"></mutation>
                                          <value name="VALUE"><block type="get_value" id=":AS43UBCU|d/)vy[`0F_"><field name="ATTR">val</field>
                                      <next><block type="controls_if" id="%b8RpM92~YV2,QS5D?4~"><value name="IF0"><block type="logic_compare" id="NSjOvY#BB,KrdffsFBbU"><field name="OP">LT</field>
                                              <value name="A"><block type="math_arithmetic" id=",J.XLc7i2y1|mMQbNy/f"><field name="OP">ADD</field>
                                                  <value name="A"><shadow type="math_number" id="NH32l;.J+J)|Wm@Au~0e"><field name="NUM">1</field></shadow>
                                                    <block type="get_value" id="Eis/z}IaDz4qR/w?{GWl"><field name="ATTR">val</field>
                                                  <value name="B"><shadow type="math_number" id="~URDq5C3v{k[VYcx7-I!"><field name="NUM">10</field></shadow></value></block></value>
                                              <value name="B"><block type="get_value" id="lW]UZDSjI7pOgV^?;GDA"><field name="ATTR">val</field>
                                                  <field name="OID">javascript.0.PV_Anlage.MinVerbrauchever</field></block></value></block></value>
                                          <statement name="DO0"><block type="update" id="nNr6_]Wghq-]NAkpi:^Q"><mutation delay_input="false"></mutation>
                                              <value name="VALUE"><block type="get_value" id="rGwq^6qZiHx:!0T)5Jx("><field name="ATTR">val</field>
                                                  <field name="OID">javascript.0.PV_Anlage.AktHausverbrauch</field></block></value></block></statement></block></next></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block></xml>
      Gruß Marco
      • Q
        Qlink last edited by
        Meinst du so:
        Funktioniert leider trotzdem nicht 😞
        Wie kann ich dein Blockly in Textform importieren und wieder in Blocklys umwandeln ?
          Siehe Bild. 😉
            C1500 last edited by
            vielen Dank für die Anleitung, es funktioniert bei mir.
            Laut ioBroker werden bei mir jetzt die Werte in Systemvariablen der CCU geschrieben.
            Leider kann ich das auf der CCU nicht nachvollziehen da die CCU seit der Einstellung in ioBroker nicht mehr erreichbar ist.
            Es kommt nur die Meldung "Zuviele gleichzeitige Verbindungen!!"
            Baut ioBroker denn für jede Variable eine eigene Verbindung auf?
            Ist das füllen von 2 Variablen in der CCU schon zu viel für die Verbindung?
            Muss ich die Übertragungsrate irgendwie reduzieren?
            Oder fehlen noch eine Einstellung oder Software in der CCU?
            Sorry für die vielen Fragen aber ich bin absoluter Anfänger mit ioBroker.
            Eines hätte ich dann auch noch:
            Kann ich die Werte in ioBroker irgendwie loggen um mir den Verbrauchsverlauf grafisch anzeigen zu lassen?
            Als Maximum würde ich gerne eine Woche zurück anschauen können
            Könnte mir hier bitte jemand helfen?
            Gruß Peer
            Nachtrag:
            Ich verwende einen RPi3 mit ioBroker und eine CCU2
            Screenshots der ioBroker Einstellung kann ich heute Abend nachreichen.
            Das Steuern z.B. der Lampen an der CCU über die VIS von ioBroker funktioniert.
            Nachtrag 2:
            Ich kam gerade doch wieder auf die CCU Weboberfläche
            Die Systemvariablen werden nicht aktualisiert.
            So sind sie in der CCU eingestellt:
            Und das steht auf der Startseite:
            Nachtrag 3:
            Ich hab nochmal den Namen geändert und alles aktualisiert.
            Leider ohne Erfolg.
            Die Einstellung des Objektes schaut so aus:
            Und so schauts in node.red aus:
            Hoffe ihr könnt mir helfen
            Gruß Peer
              Hallo Peer,
              eigentlich sollte das mit der CCU anstandslos klappen. Kontrolliere bitte nochmal, ob du bei NodeRed das richtige eingetragen hast. Unter Verbrauch dieses Value.
              721_verbrauch.jpg <–--
              Alternativ schick mir doch mal deinen Node-Red Flow (exportieren). Da kann ich mir das mal anschauen.
              Laut deiner Bilder hast du ja den History-Adapter bereits in Verwendung. Wenn nicht, installiere ihn mal und tätige mal folgende Einstellungen.
              Unter Objekte, rechts auf das Zahnrad drücken (Objekt deiner Wahl). In der nächsten Maske:
              Gruß Marco
                Servus Marco
                Der Flow ist der aus dem ersten Post.
                Ich hab nur nach dem anlegen die entsprechenden Systemvariablen zugewiesen.
                Unter Objekte tauchen bei hm-rega.0 auch die richtigen Werte auf.
                Die Einstellung in NodeRed schauen so aus:
                Sollten also auch passen.
                RPi und CCU2 sind auch schon mal neu gestartet werden
                Ich schick dir den Flow mal per PN (EDIT: Darf ich leider noch nicht)
                Hast du noch ne Idee?
                Die History schau ich mir nochmal genauer an
                Danke für den Tip
                Gruß Peer
                  Servus Zusammen
                  hat noch jemand eine Idee warum die Daten nicht an die CCU weiter gegeben werden?
                  Oder soll ich lieber einen neuen Threat aufmachen wo es nur um das Thema geht?
                  Gruß Peer
                    Was sagt denn deine HM-Rega Konfiguration?
                    Gruß Marco
                      Hallo Marco
                      Ja, Variablen sind Aktiv
                      Hast du noch eine Idee?
                      Gruß Peer
                        Hallo Peer,
                        wenn du unter Objekte -> HM-Rega eine deiner Variablen von Hand änderst, wird das synchronisiert?
                        Gruß Marco
                          Servus Marco
                          Zunächst hab ich heute alle hr.rega und hm.rpc neu installiert und node.Red neu gestartet.
                          Leider keine Werte in der CUU2.
                          ich hab jetzt mal die Instanz node.Red pausiert und hab dann im Objekt den Wert geändert und mit dem Haken gespeichert.
                          Dieser Wert wird dann auch in die CCU2 übertragen.
                          Irgendwie versteh ich das jetzt nicht.
                          Die Werte werden in das Objekt geschrieben aber nicht übertragen.
                          Wenn ich die gleichen Werte manuell schreibe, werden sie übertragen.
                          Kann es daran liegen, das die Übertragung länger dauert als die Aktualisierung die vom SMA-EM kommt?
                          Mein ioBroker läuft auf einem RPI3, das sollte doch von der Geschwindigkeit reichen, oder?
                          Sollte ja reichen.
                          Kann man die Aktualisierung des SMA-EM reduzieren? Alle 5-10 Sekunden würde ja voll und ganz reichen.
                          Gruß Peer
                            Hast du mal bei Node-Red an den zugehörigen Anschluss ein Debug-Modul angehängt? Ob überhaupt da Daten rauskommen?
                            Stell mal bitte das nochmal um, ich glaube es hängt daran:
                            Statt Value -> Command
                              Servus Marco,
                              FU**
                              Warum auch immer es vorher nicht ging (Hatte definitiv auch schon mal "command" drin)
                              Jetzt geht es
                              Herzlichen Dank für deine Bemühungen
                              Gruß Peer
                                Steffi81 last edited by
                                Hallo zusammen
                                Bräuchte Eure Hilfe in Sachen SMA Energy Meter.
                                Habe bei mir 2 verbaut, am Hauptzähler den 20 und im Schuppen den 10 am WR.
                                Hab versucht nach Marcolotti's Anleitung die Energy Meter aus zulesen, aber es klappt nicht.
                                Bekomme keine Werte. In dem neu angelegtem Flow steht zwar connect bei den 4 Ausgabe Werten, wenn ich dann aber unter Objekte schaue, steht bei dem Node Adatper nur nen leerer Flow, keine Werte nichts.
                                Muss ich noch irgendwo was einstellen oder so?
                                Im Netzwerk sind sie verfügbar, Router hat auch IP Adresse vergeben. Der 20 hat sogar eine Web Oberfläche, auf die komm ich auch drauf, der 10 hat sowas nicht.
                                Beim 20 werden die Werte allerdings mit Minis angezeigt, keine Ahnung warum, SMA weiß aber schon Bescheid und versucht das raus zu finden. Und nein, er ist nicht falsch rum angeschlossen, mehrmals geprüft 🙂
                                Über eine IOS App kann ich beide Geräte ohne Problem einsehen.
                                Hoffe Ihr habt eine Idee.
                                Mfg
                                Stephan
                                  probiere doch mal den SMA EnergyMeter Adapter.
                                  Gruß Marco
                                    Gibt es den denn schon bzw. ist der denn schon ausgereift? Hatte letztens nur gelesen, dass noch Testpersonen dafür gesucht werden 🙂
                                    Habe nicht wirklich Lust, was auszuprobieren und hinterher läuft bei mir nix mehr 🙂
                                    • Dutchman
                                      @Steffi81:
                                      Habe nicht wirklich Lust, was auszuprobieren und hinterher läuft bei mir nix mehr 🙂 `
                                      Alles in der latest repository kann man ohne große Gefahr testen/Benutzen
                                      Send from mobile device
                                        Ist der SMA Adapter denn "latest repository"? Was auch immer das heißt :lol:
                                        Bin halt nicht so der intensive IoBroker Freak, hab zwar schon einiges gemacht und auch hin bekommen, aber bei komplizierten Sachen hört es dann auch schon auf 🙂
                                        Unter den Adaptern habe ich den SMA noch nicht gefunden, wüsste jetzt auch garnicht, wie ich den hinzufügen soll :oops:
                                        Mfg
                                          also bei mir ist der SMA-Adapter mit v0.5.1 im repo latest enthalten.
                                          hast du admin und controller auf dem neuesten stand?
                                          Rainer
                                            Also hatte am We IoBroker über Putty upgedatet.
                                            Admin hatte ich auch schon upgedatet. Muss ich nachher noch mal schauen, ob ich den finde unter den ganzen aufgeführten Adaptern, oder muss ich noch wo anders schauen bzw. manuell hinzufügen?
                                            Mfg
                                            85
                                            26259
