    2. English
    4. Ring doorbell adapter custom settings error
      Mikee123 last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Lenovo Windows 11 Pro
      Arbeitsspeicher: 16GB
      Festplattenart: SSD
      Betriebssystem: Windows
      Node-Version: 3.2.2
      Nodejs-Version: 18.16.0
      NPM-Version: 9.5.1
      Installationsart: Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      I have used the same setup on this PC before, after upgrading to Windows 11 (from 10) I reinstalled Iobroker and the Ring adapter. When I open the objects then open the Ring directory, on the right hand side is the cog to open and change the object settings. That is where I used to add setting for MQTT. But when I try to open custom settings now, I get a error 'cannot load jsonConfig of ring: not existsRing 2.png ring.png
      • MartinP
        MartinP @Mikee123 last edited by MartinP
        @mikee123 reinstalled from Backup? Recently there was a thread, with a recommendation, that one has to wait for ca 1 hour before manually interacting with ioBroker after restore of a backup
        https://forum.iobroker.net/topic/65831/java-scripte-nach-backup-wiederherstellung-nicht-vorhanden/7?_=1685451821207
        "Anschließend beginnt die Arbeit des controllers/admin alle Adapter neu zu installieren, passend zu einer ggf. anderen Hardware, nodejs und OS.
        Das kann je nach Hardware auch schon mal 1h+ dauern.
        In dieser Zeit darf nichts manuell an ioBroker geändert werden, sonst wird möglicherweise dieser Rebuild gestört und endet in einem undefinierten Zustand."
          Mikee123 @MartinP last edited by
          @martinp I reinstalled it from the website, not from a backup, so a fresh install
          • werner2000x
            werner2000x last edited by werner2000x
            Ich habe mit dem Ring Adapter auch Errors:
            Device with Type cocoa_doorbell_v2 not yet supported, please inform dev Team via Github.
            und Infos:
            Unsupported Device Info: RingCamera { subscriptions: [ [SafeSubscriber] ], initialData: { id: 12345678, kind: 'cocoa_doorbell_v2', description: 'Haus'
            starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.ring, node: v16.20.1, js-controller: 4.0.24
            Gibt es dazu Löungen?
            • mcm1957
              mcm1957 @werner2000x last edited by
              @werner2000x said in Ring doorbell adapter custom settings error:
              und Infos:
              This is the english section.
              So please use english language
