    4. Performance Probleme im iobroker Admin auf pi4
      Thomas Braun Most Active @maxpd last edited by
      @maxpd
      iobroker update adaptername@versionsnummer --debug
        maxpd @Thomas Braun last edited by
        @thomas-braun fehlt da evtl noch etwas?
        pi@iobroker:~ $ iobroker update chromecast@3.0.3 --debug
        Used repository: chromecast@3.0.3
        Error: unknown repository is active - "chromecast@3.0.3". Known: stable, beta
        pi@iobroker:~ $ iobroker update doorbird@0.1.5 --debug
        Used repository: doorbird@0.1.5
        Error: unknown repository is active - "doorbird@0.1.5". Known: stable, beta
          @maxpd
          Sorry
          iobroker upgrade adaptername@versionsnummer --debug
            muss wohl so bleiben, die einen gibts nicht, die anderen schmeißen viele errors
            pi@iobroker:~ $ iobroker upgrade doorbird@0.1.5 --debug
            Adapter "doorbird" is not in the repository and cannot be updated.
            Cannot upgrade: Cannot read properties of undefined (reading 'controller')
            pi@iobroker:~ $ iobroker upgrade chromecast@3.0.3 --debug
            Would you like to reinstall version 3.0.3 of chromecast now? [(y)es, (n)o]: y
            Update chromecast from @3.0.3 to @3.0.3
            NPM version: 9.5.1
            Installing iobroker.chromecast@3.0.3... (System call)
            npm WARN skipping integrity check for git dependency ssh://git@github.com/iobrok        er-community-adapters/ioBroker.sma-em.git
            npm WARN skipping integrity check for git dependency ssh://git@github.com/nbueng        er/ioBroker.govee.git
            npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfon        so/ioBroker.google-sharedlocations.git
            npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1        337/ioBroker.doorbird.git
            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason        s. As it's a core Node module, we will not transfer it over to other users. You        may safely remove the package from your dependencies.
            npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now        a built-in Node module. If you've depended on crypto, you should switch to the o        ne that's built-in.
            npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide        s its own type definitions, so you do not need this installed.
            npm WARN deprecated topo@3.0.3: This module has moved and is now available at @h        api/topo. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
            npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee        n deprecated because it extends the now deprecated request package, see https://        github.com/request/request/issues/3142
            npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated        in favor of babel-cli. Check https://opencollective.com/babel to support the Bab        el maintainers
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b        ecause it extends the now deprecated request package, see https://github.com/req        uest/request/issues/3142
            npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @h        api/hoek. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS        ON 3
            npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, fl        atted is its successor.
            npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and        does not need to be installed separately. It is now unmaintained.
            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav        e a low-severity ReDos regression when used in a Node.js environment. It is reco        mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss        ues/797)
            npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy.        new code should use the URLSearchParams API instead.
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
            npm WARN deprecated joi@14.3.1: This module has moved and is now available at @h        api/joi. Please update your dependencies as this version is no longer maintained        an may contain bugs and security issues.
            npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in        0.5.0
            npm ERR! code 1
            npm ERR! git dep preparation failed
            npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install        --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false        --offline=false --no-progress --no-save --no-audit --include=dev --include=peer        --include=optional --no-package-lock-only --no-dry-run
            npm ERR! > iobroker.esphome@0.2.4 install
            npm ERR! > npip install
            npm ERR!
            npm ERR! No python_modules directory; installing pip locally if needed.
            npm ERR! Successfully completed pip check.
            npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/s        imple
            npm ERR! Collecting esphome>=2021.8
            npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2023.5.5        -py2.py3-none-any.whl (2.7 MB)
            npm ERR! Collecting tornado>=3.2
            npm ERR!   Using cached tornado-6.3.2.tar.gz (508 kB)
            npm ERR!   Installing build dependencies: started
            npm ERR!   Installing build dependencies: finished with status 'done'
            npm ERR!   Getting requirements to build wheel: started
            npm ERR!   Getting requirements to build wheel: finished with status 'done'
            npm ERR!   Preparing metadata (pyproject.toml): started
            npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
            npm ERR! Collecting voluptuous==0.13.1 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.        13.1-py3-none-any.whl (35 kB)
            npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp39-c        p39-linux_armv7l.whl (45 kB)
            npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.        1-py3-none-any.whl (75 kB)
            npm ERR! Collecting colorama==0.4.6 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.6-        py2.py3-none-any.whl (25 kB)
            npm ERR!   Using cached tornado-6.3.1-cp38-abi3-linux_armv7l.whl
            npm ERR! Collecting tzlocal==5.0.1 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-5.0.1-py        3-none-any.whl (20 kB)
            npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2        .py3-none-any.whl (341 kB)
            npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py        2.py3-none-any.whl (90 kB)
            npm ERR! Collecting platformio==6.1.6 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-6.        1.6-py3-none-any.whl (416 kB)
            npm ERR! Collecting esptool==4.5.1 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-4.5.1-py        3-none-any.whl (320 kB)
            npm ERR! Collecting click==8.1.3 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.1.3-py3-no        ne-any.whl (96 kB)
            npm ERR! Collecting esphome-dashboard==20230516.0 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphom        e_dashboard-20230516.0-py3-none-any.whl (1.7 MB)
            npm ERR! Collecting aioesphomeapi==13.7.5 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphome        api-13.7.5-py2.py3-none-any.whl (55 kB)
            npm ERR! Collecting zeroconf==0.60.0 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.60.0        -cp39-cp39-manylinux_2_31_armv7l.whl (2.1 MB)
            npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13        .7.1-py2.py3-none-any.whl (145 kB)
            npm ERR! Collecting pyparsing>=3.0 (from esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/pyparsing/pyparsing-3.0.        9-py3-none-any.whl (98 kB)
            npm ERR! Collecting protobuf>=3.19.0 (from aioesphomeapi==13.7.5->esphome>=2021.        8)
            npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-4.23.2        -cp39-cp39-linux_armv7l.whl (946 kB)
            npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==13.7.5->espho        me>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseproto        col-0.3.1-py3-none-any.whl (20 kB)
            npm ERR! Collecting async-timeout>=4.0 (from aioesphomeapi==13.7.5->esphome>=202        1.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/async-timeout/async_time        out-4.0.2-py3-none-any.whl (5.8 kB)
            npm ERR! Collecting bitstring>=3.1.6 (from esptool==4.5.1->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.0.        2-py3-none-any.whl (46 kB)
            npm ERR! Collecting cryptography>=2.1.4 (from esptool==4.5.1->esphome>=2021.8)
            npm ERR!   Using cached cryptography-40.0.2.tar.gz (625 kB)
            npm ERR! Collecting ecdsa>=0.16.0 (from esptool==4.5.1->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.p        y3-none-any.whl (142 kB)
            npm ERR! Collecting reedsolo<=1.6.0,>=1.5.3 (from esptool==4.5.1->esphome>=2021.        8)
            npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.6.0-        cp39-cp39-linux_armv7l.whl (897 kB)
            npm ERR! Collecting bottle==0.12.* (from platformio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py        3-none-any.whl (90 kB)
            npm ERR! Collecting marshmallow==3.* (from platformio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
            npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==6.1.6->esphome>=2021.8        )
            npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.        29-py2.py3-none-any.whl (174 kB)
            npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-p        ackages (from platformio==6.1.6->esphome>=2021.8) (2.25.1)
            npm ERR! Collecting semantic-version==2.10.* (from platformio==6.1.6->esphome>=2        021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semanti        c_version-2.10.0-py2.py3-none-any.whl (19 kB)
            npm ERR! Collecting tabulate==0.9.* (from platformio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.9.0-        py3-none-any.whl (35 kB)
            npm ERR! Collecting aiofiles==22.1.* (from platformio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-22.1.0        -py3-none-any.whl (14 kB)
            npm ERR! Collecting ajsonrpc==1.* (from platformio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-        py3-none-any.whl (22 kB)
            npm ERR! Collecting starlette==0.23.* (from platformio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.23        .1-py3-none-any.whl (64 kB)
            npm ERR! Collecting uvicorn==0.20.* (from platformio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.20.0-p        y3-none-any.whl (56 kB)
            npm ERR! Collecting wsproto==1.2.* (from platformio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.2.0-py        3-none-any.whl (24 kB)
            npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.60.0->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-        none-any.whl (12 kB)
            npm ERR! Collecting packaging>=17.0 (from marshmallow==3.*->platformio==6.1.6->e        sphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1        -py3-none-any.whl (48 kB)
            npm ERR! Collecting anyio<5,>=3.4.0 (from starlette==0.23.*->platformio==6.1.6->        esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.0-py3-no        ne-any.whl (80 kB)
            npm ERR! Collecting typing-extensions>=3.10.0 (from starlette==0.23.*->platformi        o==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing        _extensions-4.6.2-py3-none-any.whl (31 kB)
            npm ERR! Collecting h11>=0.8 (from uvicorn==0.20.*->platformio==6.1.6->esphome>=        2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-        any.whl (58 kB)
            npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==4.5.1->esphom        e>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp        39-linux_armv7l.whl (364 kB)
            npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-pack        ages (from ecdsa>=0.16.0->esptool==4.5.1->esphome>=2021.8) (1.16.0)
            npm ERR! Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packa        ges (from anyio<5,>=3.4.0->starlette==0.23.*->platformio==6.1.6->esphome>=2021.8        ) (2.10)
            npm ERR! Collecting sniffio>=1.1 (from anyio<5,>=3.4.0->starlette==0.23.*->platf        ormio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py        3-none-any.whl (10 kB)
            npm ERR! Collecting exceptiongroup (from anyio<5,>=3.4.0->starlette==0.23.*->pla        tformio==6.1.6->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exception        group-1.1.1-py3-none-any.whl (14 kB)
            npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==4.        5.1->esphome>=2021.8)
            npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21        -py2.py3-none-any.whl (119 kB)
            npm ERR! Building wheels for collected packages: cryptography
            npm ERR!   Building wheel for cryptography (pyproject.toml): started
            npm ERR!   Building wheel for cryptography (pyproject.toml): finished with statu        s 'error'
            npm ERR! Failed to build cryptography
            npm ERR! npm WARN using --force Recommended protections disabled.
            npm ERR! npm WARN old lockfile
            npm ERR! npm WARN old lockfile The package-lock.json file was created with an ol        d version of npm,
            npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the        registry.
            npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
            npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell        /source-map-url#deprecated
            npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/ur        ix#deprecated
            npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolv        e-url#deprecated
            npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/ly        dell/source-map-resolve#deprecated
            npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive securit        y updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
            npm ERR! Cache entry deserialization failed, entry ignored
            npm ERR!   error: subprocess-exited-with-error
            npm ERR!
            npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run succes        sfully.
            npm ERR!   │ exit code: 1
            npm ERR!   ╰─> [247 lines of output]
            npm ERR!       running bdist_wheel
            npm ERR!       running build
            npm ERR!       running build_py
            npm ERR!       creating build
            npm ERR!       creating build/lib.linux-armv7l-cpython-39
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography
            npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpyt        hon-39/cryptography
            npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-c        python-39/cryptography
            npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-        cpython-39/cryptography
            npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpyth        on-39/cryptography
            npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cp        ython-39/cryptography
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/x509
            npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-ar        mv7l-cpython-39/cryptography/x509
            npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> buil        d/lib.linux-armv7l-cpython-39/cryptography/x509
            npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cp        ython-39/cryptography/x509
            npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-c        python-39/cryptography/x509
            npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-c        python-39/cryptography/x509
            npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-c        python-39/cryptography/x509
            npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-        armv7l-cpython-39/cryptography/x509
            npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv        7l-cpython-39/cryptography/x509
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat
            npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l        -cpython-39/cryptography/hazmat
            npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-ar        mv7l-cpython-39/cryptography/hazmat
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bi        ndings
            npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib        .linux-armv7l-cpython-39/cryptography/hazmat/bindings
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/ba        ckends
            npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib        .linux-armv7l-cpython-39/cryptography/hazmat/backends
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/pr        imitives
            npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> buil        d/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> b        uild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/l        ib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.l        inux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.l        inux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/li        b.linux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib        .linux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py ->        build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/li        b.linux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/l        ib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bi        ndings/openssl
            npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
            npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py        -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
            npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> b        uild/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/ba        ckends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/        lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/ed448.py -> buil        d/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/poly1305.py -> b        uild/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/dh.py -> build/l        ib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build        /lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -        > build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/hmac.py -> build        /lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/l        ib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build        /lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> buil        d/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/ed25519.py -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/hashes.py -> bui        ld/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/x448.py -> build        /lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/        lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> b        uild/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/pr        imitives/ciphers
            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> bui        ld/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> bui        ld/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py ->        build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py        -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/pr        imitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> b        uild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py ->        build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -        > build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py ->        build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py        -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py ->        build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> b        uild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py        -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py ->        build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py        -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/pr        imitives/kdf
            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build        /lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build        /lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/l        ib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> buil        d/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/        lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> bui        ld/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/pr        imitives/serialization
            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py        -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serializati        on
            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py        -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serializatio        n
            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.p        y -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serializat        ion
            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -        > build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__        .py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serializ        ation
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/pr        imitives/twofactor
            npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> b        uild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
            npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> b        uild/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
            npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py        -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
            npm ERR!       running egg_info
            npm ERR!       writing src/cryptography.egg-info/PKG-INFO
            npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_        links.txt
            npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
            npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.tx        t
            npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
            npm ERR!       reading manifest template 'MANIFEST.in'
            npm ERR!       no previously-included directories found matching 'docs/_build'
            npm ERR!       warning: no previously-included files found matching 'vectors'
            npm ERR!       warning: no previously-included files matching '*' found under di        rectory 'vectors'
            npm ERR!       warning: no previously-included files matching '*' found under di        rectory '.github'
            npm ERR!       warning: no previously-included files found matching 'release.py'
            npm ERR!       warning: no previously-included files found matching '.readthedoc        s.yml'
            npm ERR!       warning: no previously-included files found matching 'ci-constrai        nts-requirements.txt'
            npm ERR!       warning: no previously-included files found matching 'mypy.ini'
            npm ERR!       adding license file 'LICENSE'
            npm ERR!       adding license file 'LICENSE.APACHE'
            npm ERR!       adding license file 'LICENSE.BSD'
            npm ERR!       adding license file 'LICENSE.PSF'
            npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
            npm ERR!       /tmp/pip-build-env-qxvrjdnf/overlay/lib/python3.9/site-packages/s        etuptools/command/build_py.py:201: _Warning: Package 'cryptography.hazmat.bindin        gs._rust' is absent from the `packages` configuration.
            npm ERR!       !!
            npm ERR!
            npm ERR!               *********************************************************        ***********************
            npm ERR!               ############################
            npm ERR!               # Package would be ignored #
            npm ERR!               Python recognizes 'cryptography.hazmat.bindings._rust' as        an importable package[^1],
            npm ERR!               but it is absent from setuptools' `packages` configuratio        n.
            npm ERR!
            npm ERR!               This leads to an ambiguous overall configuration. If you        want to distribute this
            npm ERR!               package, please make sure that 'cryptography.hazmat.bindi        ngs._rust' is explicitly added
            npm ERR!               to the `packages` configuration field.
            npm ERR!
            npm ERR!               Alternatively, you can also rely on setuptools' discovery        methods
            npm ERR!               (for example by using `find_namespace_packages(...)`/`fin        d_namespace:`
            npm ERR!               instead of `find_packages(...)`/`find:`).
            npm ERR!
            npm ERR!               You can read more about "package discovery" on setuptools        documentation page:
            npm ERR!
            npm ERR!               - https://setuptools.pypa.io/en/latest/userguide/package_        discovery.html
            npm ERR!
            npm ERR!               If you don't want 'cryptography.hazmat.bindings._rust' to        be distributed and are
            npm ERR!               already explicitly excluding 'cryptography.hazmat.binding        s._rust' via
            npm ERR!               `find_namespace_packages(...)/find_namespace` or `find_pa        ckages(...)/find`,
            npm ERR!               you can try to use `exclude_package_data`, or `include-pa        ckage-data=False` in
            npm ERR!               combination with a more fine grained `package-data` confi        guration.
            npm ERR!
            npm ERR!               You can read more about "package data files" on setuptool        s documentation page:
            npm ERR!
            npm ERR!               - https://setuptools.pypa.io/en/latest/userguide/datafile        s.html
            npm ERR!
            npm ERR!
            npm ERR!               [^1]: For Python, any directory (with suitable naming) ca        n be imported,
            npm ERR!                     even if it does not contain any `.py` files.
            npm ERR!                     On the other hand, currently there is no concept of        package data
            npm ERR!                     directory, all directories are treated like package        s.
            npm ERR!
            npm ERR!       !!
            npm ERR!         check.warn(importable)
            npm ERR!       /tmp/pip-build-env-qxvrjdnf/overlay/lib/python3.9/site-packages/s        etuptools/command/build_py.py:201: _Warning: Package 'cryptography.hazmat.bindin        gs._rust.openssl' is absent from the `packages` configuration.
            npm ERR!       !!
            npm ERR!
            npm ERR!               Python recognizes 'cryptography.hazmat.bindings._rust.ope        nssl' as an importable package[^1],
            npm ERR!
            npm ERR!               package, please make sure that 'cryptography.hazmat.bindi        ngs._rust.openssl' is explicitly added
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!               If you don't want 'cryptography.hazmat.bindings._rust.ope        nssl' to be distributed and are
            npm ERR!               already explicitly excluding 'cryptography.hazmat.binding        s._rust.openssl' via
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!       !!
            npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpyth        on-39/cryptography
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bi        ndings/_rust
            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> bu        ild/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/        lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/        lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build        /lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/        lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
            npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bi        ndings/_rust/openssl
            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.p        yi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/opens        sl
            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi        -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
            npm ERR!       running build_ext
            npm ERR!       running build_rust
            npm ERR!
            npm ERR!           =============================DEBUG ASSISTANCE================        =============
            npm ERR!           If you are seeing a compilation error please try the followin        g steps to
            npm ERR!           successfully install cryptography:
            npm ERR!           1) Upgrade to the latest pip and try again. This will fix err        ors for most
            npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgr        ading-pip
            npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for s        pecific
            npm ERR!              instructions for your platform.
            npm ERR!           3) Check our frequently asked questions for more information:
            npm ERR!              https://cryptography.io/en/latest/faq/
            npm ERR!           4) Ensure you have a recent Rust toolchain installed:
            npm ERR!              https://cryptography.io/en/latest/installation/#rust
            npm ERR!
            npm ERR!           Python: 3.9.2
            npm ERR!           platform: Linux-6.1.21-v7l+-armv7l-with-glibc2.31
            npm ERR!           pip: n/a
            npm ERR!           setuptools: 67.8.0
            npm ERR!           setuptools_rust: 1.6.0
            npm ERR!           rustc: n/a
            npm ERR!
            npm ERR!       error: can't find Rust compiler
            npm ERR!
            npm ERR!       If you are using an outdated pip version, it is possible a prebui        lt wheel is available for this package but pip is not able to install from it. I        nstalling from the wheel would avoid the need for a Rust compiler.
            npm ERR!
            npm ERR!       To update pip, run:
            npm ERR!
            npm ERR!           pip install --upgrade pip
            npm ERR!
            npm ERR!       and then retry package installation.
            npm ERR!
            npm ERR!       If you did intend to build this package from source, try installi        ng a Rust compiler from your system package manager and ensure it is on the PATH        during installation. Alternatively, rustup (available at https://rustup.rs) is        the recommended way to download and update the Rust compiler toolchain.
            npm ERR!
            npm ERR!       This package requires Rust >=1.48.0.
            npm ERR!       [end of output]
            npm ERR!
            npm ERR!   note: This error originates from a subprocess, and is likely not a pr        oblem with pip.
            npm ERR!   ERROR: Failed building wheel for cryptography
            npm ERR! ERROR: Could not build wheels for cryptography, which is required to in        stall pyproject.toml-based projects
            npm ERR! npm ERR! code 1
            npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clone3HOfw1
            npm ERR! npm ERR! command failed
            npm ERR! npm ERR! command sh -c npip install
            npm ERR!
            npm ERR! npm ERR! A complete log of this run can be found in:
            npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-05-29T10_55_28_101Z-debug-0        .log
            npm ERR!     /home/iobroker/.npm/_logs/2023-05-29T10_52_14_402Z-debug-0.log
            Update "system.adapter.chromecast.0"
            INFO: Directory "/opt/iobroker/node_modules/iobroker.chromecast/admin" was not f        ound! Nothing was uploaded or deleted.
              Thomas Braun Most Active @maxpd last edited by Thomas Braun
              @maxpd
              Da klemmt es bei esphome.
              Verschieb mal das lock-file
              sudo mv /lib/python3.11/EXTERNALLY-MANAGED ~
              Pfad an die von dir verwendete Version von python3 anpassen.
              Könnte bei dir
              sudo mv /lib/python3.9.2/EXTERNALLY-MANAGED ~
              sein.
                @maxpd sagte in Performance Probleme im iobroker Admin auf pi4:
                Nein, kann nicht so bleiben, weil es dir alles bezüglich npm und Adapter-Installationen/Updates usw. blockiert.
                  pi@iobroker:/opt/iobroker $ python3 --version
                  Python 3.9.2
                  pi@iobroker:/opt/iobroker $ cd
                  pi@iobroker:~ $ sudo mv /lib/python3.9.2/EXTERNALLY-MANAGED ~
                  mv: der Aufruf von stat für '/lib/python3.9.2/EXTERNALLY-MANAGED' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                    @maxpd
                    Dann schau wie der Pfad ggf. genau heißt. Und ob es die Datei 'EXTERNALLY-MANAGED' überhaupt gibt.
                      @thomas-braun die files/ordner mit python im name finde ich auf dem system. Ich weiß nicht wie du auf EXTERNALLY-MANAGED kommst.
                      /home/iobroker/.platformio/packages/tool-scons/scons-local-4.3.0/SCons/Node/Python.py
                      /home/iobroker/.platformio/packages/tool-scons/scons-local-4.3.0/SCons/Node/__pycache__/Python.cpython-39.pyc
                      /home/iobroker/.platformio/packages/tool-scons/scons-local-4.3.0/SCons/Scanner/Python.py
                      /home/iobroker/.platformio/packages/tool-scons/scons-local-4.3.0/SCons/Tool/python.py
                      /opt/iobroker/iobroker-data/files/iobroker.javascript.admin/vs/basic-languages/python/python.js
                      /opt/iobroker/node_modules/authenticate-pam/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/bufferutil/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/canvas/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/cpu-features/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/diskusage/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/epoll/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/google/protobuf/internal/__pycache__/python_message.cpython-39.pyc
                      /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/google/protobuf/internal/python_message.py
                      /opt/iobroker/node_modules/mdns/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/node-dht-sensor/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/nodejieba/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/sharp/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/ssh2/lib/protocol/crypto/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/unix-dgram/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/ursa-optional/build/node_gyp_bins/python3
                      /opt/iobroker/node_modules/utf-8-validate/build/node_gyp_bins/python3
                      /usr/bin/python3
                      /usr/bin/python3-config
                      /usr/bin/python3.9
                      /usr/bin/python3.9-config
                      /usr/include/python3.9/Python-ast.h
                      /usr/include/python3.9/Python.h
                      /usr/include/python3.9/pythonrun.h
                      /usr/lib/arm-linux-gnueabihf/pkgconfig/python-3.9-embed.pc
                      /usr/lib/arm-linux-gnueabihf/pkgconfig/python-3.9.pc
                      /usr/lib/arm-linux-gnueabihf/pkgconfig/python3-embed.pc
                      /usr/lib/arm-linux-gnueabihf/pkgconfig/python3.pc
                      /usr/lib/node_modules/npm/node_modules/node-gyp/gyp/.github/workflows/Python_tests.yml
                      /usr/lib/python3.9/config-3.9-arm-linux-gnueabihf/python-config.py
                      /usr/lib/python3.9/config-3.9-arm-linux-gnueabihf/python.o
                      /usr/lib/valgrind/python3.supp
                      /usr/share/applications/python3.9.desktop
                      /usr/share/bash-completion/completions/python
                      /usr/share/bash-completion/completions/python2
                      /usr/share/bash-completion/completions/python2.7
                      /usr/share/bash-completion/completions/python3
                      /usr/share/bash-completion/completions/python3.3
                      /usr/share/bash-completion/completions/python3.4
                      /usr/share/bash-completion/completions/python3.5
                      /usr/share/bash-completion/completions/python3.6
                      /usr/share/bash-completion/completions/python3.7
                      /usr/share/bash-completion/completions/python3.8
                      /usr/share/bash-completion/helpers/python
                      /usr/share/binfmts/python3.9
                      /usr/share/doc/python3/python-policy.html
                      /usr/share/doc/python3/python-policy.txt.gz
                      /usr/share/doc/python3-debconf
                      /usr/share/doc/python3-dev
                      /usr/share/doc/python3-setuptools/python 2 sunset.rst
                      /usr/share/doc/python3.9/python-policy.txt.gz
                      /usr/share/doc/python3.9-dev
                      /usr/share/lintian/overrides/python3
                      /usr/share/lintian/overrides/python3-apt
                      /usr/share/lintian/overrides/python3-certifi
                      /usr/share/lintian/overrides/python3-distutils
                      /usr/share/lintian/overrides/python3-lib2to3
                      /usr/share/lintian/overrides/python3-pip
                      /usr/share/lintian/overrides/python3.9
                      /usr/share/lintian/overrides/python3.9-minimal
                      /usr/share/locale/ar/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/be/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/bg/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/bn/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/ca/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/cs/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/csb/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/da/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/de/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/el/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/en_AU/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/en_CA/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/eo/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/es/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/fi/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/fr/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/gl/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/he/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/hr/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/hu/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/id/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/it/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/ja/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/ka/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/ko/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/ku/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/lt/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/lv/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/mk/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/nb/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/ne/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/nl/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/oc/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/pl/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/pt/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/pt_BR/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/ro/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/ru/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/sk/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/sl/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/sq/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/sr/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/sv/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/th/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/tl/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/tr/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/uk/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/vi/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/zh_CN/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/zh_HK/LC_MESSAGES/python-apt.mo
                      /usr/share/locale/zh_TW/LC_MESSAGES/python-apt.mo
                      /usr/share/man/man1/python3-config.1.gz
                      /usr/share/man/man1/python3.1.gz
                      /usr/share/man/man1/python3.9-config.1.gz
                      /usr/share/man/man1/python3.9.1.gz
                      /usr/share/nano/python.nanorc
                      /usr/share/pixmaps/python3.9.xpm
                      /usr/share/pixmaps/python3.xpm
                      /usr/share/python3/dist/python3-six
                      /usr/share/python3/python.mk
                      /usr/share/source-highlight/python.lang
                      /var/lib/dpkg/info/python-apt-common.list
                      /var/lib/dpkg/info/python-apt-common.md5sums
                      /var/lib/dpkg/info/python-pip-whl.conffiles
                      /var/lib/dpkg/info/python-pip-whl.list
                      /var/lib/dpkg/info/python-pip-whl.md5sums
                      /var/lib/dpkg/info/python.list
                      /var/lib/dpkg/info/python.postrm
                      /var/lib/dpkg/info/python2.7-minimal.list
                      /var/lib/dpkg/info/python2.7-minimal.postrm
                      /var/lib/dpkg/info/python3-apt.list
                      /var/lib/dpkg/info/python3-apt.md5sums
                      /var/lib/dpkg/info/python3-apt.postinst
                      /var/lib/dpkg/info/python3-apt.prerm
                      /var/lib/dpkg/info/python3-certifi.list
                      /var/lib/dpkg/info/python3-certifi.md5sums
                      /var/lib/dpkg/info/python3-certifi.postinst
                      /var/lib/dpkg/info/python3-certifi.prerm
                      /var/lib/dpkg/info/python3-chardet.list
                      /var/lib/dpkg/info/python3-chardet.md5sums
                      /var/lib/dpkg/info/python3-chardet.postinst
                      /var/lib/dpkg/info/python3-chardet.prerm
                      /var/lib/dpkg/info/python3-debconf.list
                      /var/lib/dpkg/info/python3-debconf.md5sums
                      /var/lib/dpkg/info/python3-debconf.postinst
                      /var/lib/dpkg/info/python3-debconf.prerm
                      /var/lib/dpkg/info/python3-dev.list
                      /var/lib/dpkg/info/python3-dev.md5sums
                      /var/lib/dpkg/info/python3-distro.list
                      /var/lib/dpkg/info/python3-distro.md5sums
                      /var/lib/dpkg/info/python3-distro.postinst
                      /var/lib/dpkg/info/python3-distro.prerm
                      /var/lib/dpkg/info/python3-distutils.list
                      /var/lib/dpkg/info/python3-distutils.md5sums
                      /var/lib/dpkg/info/python3-distutils.postinst
                      /var/lib/dpkg/info/python3-distutils.prerm
                      /var/lib/dpkg/info/python3-idna.list
                      /var/lib/dpkg/info/python3-idna.md5sums
                      /var/lib/dpkg/info/python3-idna.postinst
                      /var/lib/dpkg/info/python3-idna.prerm
                      /var/lib/dpkg/info/python3-lib2to3.list
                      /var/lib/dpkg/info/python3-lib2to3.md5sums
                      /var/lib/dpkg/info/python3-lib2to3.postinst
                      /var/lib/dpkg/info/python3-lib2to3.prerm
                      /var/lib/dpkg/info/python3-minimal.list
                      /var/lib/dpkg/info/python3-minimal.md5sums
                      /var/lib/dpkg/info/python3-minimal.postinst
                      /var/lib/dpkg/info/python3-minimal.prerm
                      /var/lib/dpkg/info/python3-pip.list
                      /var/lib/dpkg/info/python3-pip.md5sums
                      /var/lib/dpkg/info/python3-pip.postinst
                      /var/lib/dpkg/info/python3-pip.prerm
                      /var/lib/dpkg/info/python3-pkg-resources.list
                      /var/lib/dpkg/info/python3-pkg-resources.md5sums
                      /var/lib/dpkg/info/python3-pkg-resources.postinst
                      /var/lib/dpkg/info/python3-pkg-resources.prerm
                      /var/lib/dpkg/info/python3-requests.list
                      /var/lib/dpkg/info/python3-requests.md5sums
                      /var/lib/dpkg/info/python3-requests.postinst
                      /var/lib/dpkg/info/python3-requests.prerm
                      /var/lib/dpkg/info/python3-setuptools.list
                      /var/lib/dpkg/info/python3-setuptools.md5sums
                      /var/lib/dpkg/info/python3-setuptools.postinst
                      /var/lib/dpkg/info/python3-setuptools.prerm
                      /var/lib/dpkg/info/python3-six.list
                      /var/lib/dpkg/info/python3-six.md5sums
                      /var/lib/dpkg/info/python3-six.postinst
                      /var/lib/dpkg/info/python3-six.prerm
                      /var/lib/dpkg/info/python3-toml.list
                      /var/lib/dpkg/info/python3-toml.md5sums
                      /var/lib/dpkg/info/python3-toml.postinst
                      /var/lib/dpkg/info/python3-toml.prerm
                      /var/lib/dpkg/info/python3-urllib3.list
                      /var/lib/dpkg/info/python3-urllib3.md5sums
                      /var/lib/dpkg/info/python3-urllib3.postinst
                      /var/lib/dpkg/info/python3-urllib3.prerm
                      /var/lib/dpkg/info/python3-wheel.list
                      /var/lib/dpkg/info/python3-wheel.md5sums
                      /var/lib/dpkg/info/python3-wheel.postinst
                      /var/lib/dpkg/info/python3-wheel.prerm
                      /var/lib/dpkg/info/python3.7-minimal.list
                      /var/lib/dpkg/info/python3.7-minimal.postrm
                      /var/lib/dpkg/info/python3.9-dev.list
                      /var/lib/dpkg/info/python3.9-dev.md5sums
                      /var/lib/dpkg/info/python3.9-minimal.list
                      /var/lib/dpkg/info/python3.9-minimal.md5sums
                      /var/lib/dpkg/info/python3.9-minimal.postinst
                      /var/lib/dpkg/info/python3.9-minimal.postrm
                      /var/lib/dpkg/info/python3.9-minimal.preinst
                      /var/lib/dpkg/info/python3.9-minimal.prerm
                      /var/lib/dpkg/info/python3.9.list
                      /var/lib/dpkg/info/python3.9.md5sums
                      /var/lib/dpkg/info/python3.9.postinst
                      /var/lib/dpkg/info/python3.9.prerm
                      /var/lib/dpkg/info/python3.list
                      /var/lib/dpkg/info/python3.md5sums
                      /var/lib/dpkg/info/python3.postinst
                      /var/lib/dpkg/info/python3.postrm
                      /var/lib/dpkg/info/python3.preinst
                      /var/lib/dpkg/info/python3.prerm
                      /var/lib/python/python3.9_installed
                        Thomas Braun Most Active last edited by
                        @maxpd
                        Wie gesagt, die Datei dürfte in /lib/python....
                        liegen. Tut Sie jedenfalls auf meinem System:
                        echad@chet:~ $ ls -lAh /lib/python3.11/EXTERNALLY-MANAGED
                        -rw-r--r-- 1 root root 645 Apr 15 16:51 /lib/python3.11/EXTERNALLY-MANAGED
                        echad@chet:~ $
                        Die Datei, wenn sie existiert, verhindert den früheren Weg Python-Programme von extern zu installieren. Das sollte jetzt nicht mehr so gemacht werden. Der esphome-Adapter verwendet den allerdings noch und springt deswegen aus dem Gleis. Jedenfalls auf meinem System. Ob das auf deinem alten System auch so ist weiß ich nicht, vermute es aber.
                          @maxpd
                          Gerade nochmal genauer geschaut.
                          Das dürfte bei dir nicht daran liegen. Es muss noch npip nachinstalliert werden.
                          ERR! > npip install
                          Zur Installation des esphome-Adapters gibt es einen eigenen Thread.
                          Frage am Rande: Brauchst du den Adapter überhaupt?
                            Jaein, ich hatte ihn letztes Jahr installiert und ein Projekt damit getestet.
                            Die Installation war ein Drama für sich, wegen cryptography Problemen und Python-Versions-Problemen.
                            Ich war froh, dass es jetzt lief.
                            Im Laufe des Jahres werde ich das Projekt weiterführen.
                            Können ihn auch löschen und von neu installieren.
                            Was mit
                            ERR! > npip install
                            zu tun ist, konnte mir google und chatgpt nicht sagen.
                            Es gibt verschieden Themen zur ESP Installation, das stimmt. Aber irgendwie ist es bei dem Adapter immer sehr speziell.
                            • David G.
                              David G. @maxpd last edited by
                              Soll ich Kühlkörper nutzen oder einen aktiven Lüfter?
                              Ich habe beides im Einsatz (war beides beim Case bei).
                                @maxpd
                                Da muss noch nopy installiert und gerade gedengelt werden.
                                cd /opt/iobroker
                                npm i nopy
                                sudo -u iobroker chmod ug+x /opt/iobroker/node_modules/nopy/src/n*
                                aus:
                                https://forum.iobroker.net/topic/54265/esphome-error-process-exited-with-code-25/140
                                  @thomas-braun sorry, ist Zeit vergangen. Viel um die Ohren.
                                  Ich habe an der Stelle nochmal weiter angeknüpft, aber leider kann ich auch nopy nicht installieren.
                                  npm i nopy
                                  npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.sma-em.git
                                  npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.chromecast.git
                                  npm WARN skipping integrity check for git dependency ssh://git@github.com/nbuenger/ioBroker.govee.git
                                  npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git
                                  npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1337/ioBroker.doorbird.git
                                  npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                  npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                                  npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                  npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                  npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers
                                  npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                  npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
                                  npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                  npm ERR! code 1
                                  npm ERR!
                                  npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                                  npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2023.8.2-py2.py3-none-any.whl (2.8 MB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.3.3-cp38-abi3-linux_armv7l.whl (426 kB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
                                  npm ERR! Collecting PyYAML==6.0.1 (from esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0.1-cp39-cp39-linux_armv7l.whl (45 kB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.6-py2.py3-none-any.whl (25 kB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.3.2-cp38-abi3-linux_armv7l.whl (425 kB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-5.0.1-py3-none-any.whl (20 kB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                                  npm ERR! Collecting platformio==6.1.9 (from esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-6.1.9-py3-none-any.whl (418 kB)
                                  npm ERR! Collecting esptool==4.6.2 (from esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-4.6.2-py3-none-any.whl (338 kB)
                                  npm ERR! Collecting click==8.1.6 (from esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.1.6-py3-none-any.whl (97 kB)
                                  npm ERR! Collecting esphome-dashboard==20230711.0 (from esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20230711.0-py3-none-any.whl (5.6 MB)
                                  npm ERR! Collecting aioesphomeapi==15.0.0 (from esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-15.0.0-py2.py3-none-any.whl (58 kB)
                                  npm ERR! Collecting zeroconf==0.80.0 (from esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.80.0-cp39-cp39-manylinux_2_31_armv7l.whl (2.5 MB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/pyparsing/pyparsing-3.1.1-py3-none-any.whl (103 kB)
                                  npm ERR! Collecting protobuf>=3.19.0 (from aioesphomeapi==15.0.0->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-4.24.1-cp39-cp39-linux_armv7l.whl (906 kB)
                                  npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==15.0.0->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                                  npm ERR! Collecting async-timeout>=4.0 (from aioesphomeapi==15.0.0->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
                                  npm ERR! Collecting bitstring>=3.1.6 (from esptool==4.6.2->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.1-py3-none-any.whl (56 kB)
                                  npm ERR! Collecting cryptography>=2.1.4 (from esptool==4.6.2->esphome>=2021.8)
                                  npm ERR!   Using cached cryptography-41.0.3.tar.gz (630 kB)
                                  npm ERR! Collecting ecdsa>=0.16.0 (from esptool==4.6.2->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                                  npm ERR! Collecting reedsolo<1.8,>=1.5.3 (from esptool==4.6.2->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.7.0-py3-none-any.whl (32 kB)
                                  npm ERR! Collecting bottle==0.12.* (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                                  npm ERR! Collecting pyelftools==0.29 (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                                  npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==6.1.9->esphome>=2021.8) (2.25.1)
                                  npm ERR! Collecting semantic-version==2.10.* (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.10.0-py2.py3-none-any.whl (19 kB)
                                  npm ERR! Collecting tabulate==0.* (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.9.0-py3-none-any.whl (35 kB)
                                  npm ERR! Collecting aiofiles>=0.8.0 (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-23.2.1-py3-none-any.whl (15 kB)
                                  npm ERR! Collecting ajsonrpc==1.2.* (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                                  npm ERR! Collecting marshmallow==3.19.* (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR! Collecting starlette==0.28.* (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.28.0-py3-none-any.whl (68 kB)
                                  npm ERR! Collecting uvicorn==0.22.* (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.22.0-py3-none-any.whl (58 kB)
                                  npm ERR! Collecting wsproto==1.2.* (from platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.2.0-py3-none-any.whl (24 kB)
                                  npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.80.0->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                                  npm ERR! Collecting packaging>=17.0 (from marshmallow==3.19.*->platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                                  npm ERR! Collecting anyio<5,>=3.4.0 (from starlette==0.28.*->platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)
                                  npm ERR! Collecting typing-extensions>=3.10.0 (from starlette==0.28.*->platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
                                  npm ERR! Collecting h11>=0.8 (from uvicorn==0.22.*->platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                                  npm ERR! Collecting bitarray<3.0.0,>=2.8.0 (from bitstring>=3.1.6->esptool==4.6.2->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.1-cp39-cp39-linux_armv7l.whl (227 kB)
                                  npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==4.6.2->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp39-linux_armv7l.whl (364 kB)
                                  npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==4.6.2->esphome>=2021.8) (1.16.0)
                                  npm ERR! Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5,>=3.4.0->starlette==0.28.*->platformio==6.1.9->esphome>=2021.8) (2.10)
                                  npm ERR! Collecting sniffio>=1.1 (from anyio<5,>=3.4.0->starlette==0.28.*->platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                                  npm ERR! Collecting exceptiongroup (from anyio<5,>=3.4.0->starlette==0.28.*->platformio==6.1.9->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (14 kB)
                                  npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==4.6.2->esphome>=2021.8)
                                  npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                                  npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
                                  npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                  npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                                  npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                  npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                  npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                                  npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
                                  npm ERR!
                                  npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
                                  npm ERR!   ╰─> [170 lines of output]
                                  npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                  npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                  npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                  npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                  npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography
                                  npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                  npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                  npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                  npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                  npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                  npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                  npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                  npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
                                  npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
                                  npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
                                  npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
                                  npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
                                  npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
                                  npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
                                  npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
                                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
                                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
                                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
                                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
                                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
                                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
                                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
                                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
                                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
                                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
                                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
                                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
                                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
                                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
                                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
                                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
                                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
                                  npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
                                  npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
                                  npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
                                  npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
                                  npm ERR!       warning: no files found matching '*.c' under directory 'src/_cffi_src'
                                  npm ERR!       warning: no files found matching '*.h' under directory 'src/_cffi_src'
                                  npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
                                  npm ERR!       warning: no previously-included files found matching 'src/rust/target'
                                  npm ERR!       warning: no previously-included files matching '*' found under directory 'src/rust/target'
                                  npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
                                  npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
                                  npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
                                  npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-39/cryptography
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
                                  npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
                                  npm ERR!
                                  npm ERR!           =============================DEBUG ASSISTANCE=============================
                                  npm ERR!           If you are seeing a compilation error please try the following steps to
                                  npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
                                  npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
                                  npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
                                  npm ERR!
                                  npm ERR!           pip: n/a
                                  npm ERR!           setuptools: 68.1.2
                                  npm ERR!           setuptools_rust: 1.7.0
                                  npm ERR!           rustc: n/a
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
                                  npm ERR!
                                  npm ERR!       This package requires Rust >=1.56.0.
                                  npm ERR!
                                  npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
                                  npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
                                  npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clone7oQ0I7
                                  npm ERR!
                                  npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-24T18_39_23_609Z-debug-0.log
                                  npm ERR!     /home/iobroker/.npm/_logs/2023-08-24T18_35_44_775Z-debug-0.log
                                  Es lassen sich auch keine Adapter Updates mehr über das iobroker interface installieren.
                                  $ iobroker upgrade backitup@2.6.23 --debug
                                  Update backitup from @2.6.19 to @2.6.23
                                  host.iobroker Adapter "system.adapter.backitup.0" is stopped.
                                  NPM version: 9.5.1Installing iobroker.backitup@2.6.23... (System call)
                                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                  npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                  npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                  npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                  npm ERR! code 1
                                  npm ERR! /home/iobroker/.npm/_logs/2023-08-24T18_29_21_549Z-debug-0.log
                                  upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                  upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                  upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                  upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                  upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                  upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                  upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                  upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                  upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                  upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                  upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                  host.iobroker Adapter "system.adapter.backitup.0" is started
                                  Process exited with code 0
                                  Ich deinstalliere nun das vermeintliche Problemkind ESP Home Adapter. Dauer 9 Minuten. Gefühlt noch immer Performance Probleme, trotz neuem Netzteil mit mehr Power und externer HDD an separatem Hub.
                                  Nach der Deinstallation erneut versucht den Backup Adapter zu aktualisieren.
                                  Wirft leider weiterhin gleiche Fehlermeldungen.
                                  mikeal created this issue in request/request
                                  open Request’s Past, Present and Future #3142
                                  Qix- created this issue in visionmedia/debug
                                  closed ReDos Vulnerability Regression Visibility Notice #797
                                  crunchip Thomas Braun 4 Replies Last reply Reply Quote 0
                                    crunchip Forum Testing Most Active @maxpd last edited by
                                    @maxpd ist sozusagen das selbe wie hier
                                    https://forum.iobroker.net/post/1033272
                                      maxpd @crunchip last edited by
                                      @crunchip wenn ich das richtig verstehe sind wir die Python Punkte aber ein paar Posts obendrüber schonmal durchgegangen, ohne Erfolg; respektive mit dem Effekt, dass momentan alles klemmt 😉
                                        sind das 2 Adapter direkt von git?
                                          @maxpd
                                          Ich weiß, das hilft dir nicht, aber hier läuft das 1A durch:
                                          echad@chet:/opt/iobroker $ iob add esphome
                                          NPM version: 9.6.7
                                          Installing iobroker.esphome@0.2.4... (System call)
                                          added 96 packages in 3m
                                          106 packages are looking for funding
                                            run `npm fund` for details
                                          host.chet install adapter esphome
                                          upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
                                          upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
                                          upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
                                          upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
                                          upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
                                          upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
                                          host.chet object system.adapter.esphome created/updated
                                          host.chet create instance esphome
                                          host.chet object system.adapter.esphome.0.alive created
                                          host.chet object system.adapter.esphome.0.connected created
                                          host.chet object system.adapter.esphome.0.compactMode created
                                          host.chet object system.adapter.esphome.0.cpu created
                                          host.chet object system.adapter.esphome.0.cputime created
                                          host.chet object system.adapter.esphome.0.memHeapUsed created
                                          host.chet object system.adapter.esphome.0.memHeapTotal created
                                          host.chet object system.adapter.esphome.0.memRss created
                                          host.chet object system.adapter.esphome.0.uptime created
                                          host.chet object system.adapter.esphome.0.inputCount created
                                          host.chet object system.adapter.esphome.0.outputCount created
                                          host.chet object system.adapter.esphome.0.eventLoopLag created
                                          host.chet object system.adapter.esphome.0.sigKill created
                                          host.chet object system.adapter.esphome.0.logLevel created
                                          host.chet object esphome.0.info created
                                          host.chet object esphome.0.info.connection created
                                          host.chet Set default value of esphome.0.info.connection: false
                                          host.chet object system.adapter.esphome.0 created
                                            ticaki Developer @Thomas Braun last edited by
                                            @thomas-braun sagte in Performance Probleme im iobroker Admin auf pi4:
                                            Gibts da eine Auto Update Funktion?
                                            Nein, wozu auch?
                                            Es gibt unattended-upgrades für Container ganz nützlich, würde ich aber nicht auf dem iobroker hauptsystem verwenden.
                                            9229
