    4. Modbus adapter
    Modbus adapter
      arteck Developer Most Active @NWH last edited by
      @nwh sagte in Modbus adapter:
      Poll error count
      zeigmal die einstellungen der allgemeinen Seite von modbus
      NWH 1 Reply Last reply Reply Quote 0
      • NWH
        NWH @arteck last edited by
        @arteck
        Aber ich habe nie was gendert bei diesen Einstellungen.
          arteck Developer Most Active @NWH last edited by arteck
          @nwh irgendwo bekommst du ein timeout..
          stell mal bitte Abfrageintervall von 6000 auf 10000 (also von 6 sekunden abfrage auf 10)
          • NWH
            @arteck Habe ich.
            Man kann sagen alle 15 sec. kommt so ein Pool Error
            modbus.0
            2023-05-31 07:48:10.636	debug	[DevID_3] Poll start ---------------------
            modbus.0
            2023-05-31 07:48:01.938	debug	[DevID_3/inputRegs] Poll address 30953 DONE
            modbus.0
            2023-05-31 07:48:00.585	warn	Poll error count: 3 code: "App Timeout"
            modbus.0
            2023-05-31 07:48:00.436	debug	[DevID_3/inputRegs] Poll address 30953 - 2 registers
            modbus.0
            2023-05-31 07:48:00.436	debug	[DevID_3/inputRegs/30775] Calculation result = 295, type = number
            modbus.0
            2023-05-31 07:48:00.435	debug	[DevID_3/inputRegs/30775] Formula = x = (x<0) ? 0:x
            modbus.0
            2023-05-31 07:48:00.435	debug	[DevID_3/inputRegs/30775] Input Value = 295
            modbus.0
            2023-05-31 07:48:00.435	debug	[DevID_3/inputRegs] Poll address 30775 DONE
            modbus.0
            2023-05-31 07:47:59.391	debug	[DevID_3/inputRegs] Poll address 30775 - 8 registers
            modbus.0
            2023-05-31 07:47:59.390	debug	[DevID_3/inputRegs] Poll address 30513 DONE
            modbus.0
            2023-05-31 07:47:57.734	debug	[DevID_3/inputRegs] Poll address 30513 - 26 registers
            modbus.0
            2023-05-31 07:47:57.733	debug	[DevID_3/inputRegs] Poll address 30201 DONE
            modbus.0
            2023-05-31 07:47:55.385	debug	[DevID_3/inputRegs] Poll address 30201 - 4 registers
            modbus.0
            2023-05-31 07:47:55.384	debug	[DevID_3] Poll start ---------------------
            modbus.0
            2023-05-31 07:47:49.600	debug	[DevID_3/inputRegs] Poll address 30953 DONE
            modbus.0
            2023-05-31 07:47:46.441	debug	[DevID_3/inputRegs] Poll address 30953 - 2 registers
            modbus.0
            2023-05-31 07:47:46.440	debug	[DevID_3/inputRegs/30775] Calculation result = 295, type = number
            modbus.0
            2023-05-31 07:47:46.440	debug	[DevID_3/inputRegs/30775] Formula = x = (x<0) ? 0:x
            modbus.0
            2023-05-31 07:47:46.440	debug	[DevID_3/inputRegs/30775] Input Value = 295
            modbus.0
            2023-05-31 07:47:46.440	debug	[DevID_3/inputRegs] Poll address 30775 DONE
            modbus.0
            2023-05-31 07:47:45.334	warn	Poll error count: 2 code: "App Timeout"
            modbus.0
            2023-05-31 07:47:44.639	debug	[DevID_3/inputRegs] Poll address 30775 - 8 registers
            modbus.0
            2023-05-31 07:47:44.638	debug	[DevID_3/inputRegs] Poll address 30513 DONE
            modbus.0
            2023-05-31 07:47:40.243	debug	[DevID_3/inputRegs] Poll address 30513 - 26 registers
            modbus.0
            2023-05-31 07:47:40.242	debug	[DevID_3/inputRegs] Poll address 30201 DONE
            modbus.0
            2023-05-31 07:47:40.133	debug	[DevID_3/inputRegs] Poll address 30201 - 4 registers
            modbus.0
            2023-05-31 07:47:40.132	debug	[DevID_3] Poll start ---------------------
            modbus.0
            2023-05-31 07:47:32.273	debug	[DevID_3/inputRegs] Poll address 30953 DONE
            modbus.0
            2023-05-31 07:47:30.081	warn	Poll error count: 1 code: "App Timeout"
              @nwh und der WR ist normal erreichbar ? sowohl in der app als auch in browser ?
              mach den noch rein
              • NWH
                @arteck Wenn ich das anklicke dann kommt das.
                Ja ist erreichbar.
                modbus.0
                2023-05-31 08:20:42.564	warn	Poll error count: 1 code: "App Timeout"
                modbus.0
                2023-05-31 08:20:30.838	warn	get state error: DB closed
                modbus.0
                2023-05-31 08:20:27.782	warn	Poll error count: 5 code: "App Timeout"
                modbus.0
                2023-05-31 08:20:12.532	warn	Poll error count: 4 code: "App Timeout"
                modbus.0
                2023-05-31 08:19:57.280	warn	Poll error count: 3 code: "App Timeout"
                modbus.0
                2023-05-31 08:19:42.027	warn	Poll error count: 2 code: "App Timeout"
                arteck J 2 Replies Last reply Reply Quote 0
                  @nwh langsam gehen mir die Ideen aus
                    JoergH @NWH last edited by
                    @nwh @arteck
                    Hat der WR wirklich die ID 3??
                    Wenn mehrere Geräte ID an ist, dann sollte er nur auf seine ID reagieren und ohne das auf jede Anfrage, oder nicht?
                    Da würde ich mal versuchen was er bei anderen IDs auswirkt.
                    Dann kannst Du auch mal "nur multiple write" anklicken....
                    Ich habe mit einem WR von Sunsynk ein ähnliches Problem. Der wirft mir in unregelmäßigen Abständen auch mal ein timeoit raus, läuft aber prinzipiell. Bisher konnte ich das nicht lösen, aber außer "Schönheit der Arbeit" bisher auch nicht schlimm.
                      @joergh sagte in Modbus adapter:
                      3 ist die SMA voreingestellte...
                        JoergH @arteck last edited by
                        @arteck Nur warum reagiert er dann nicht auf diese wenn man "mehrere IDs" auswählt?
                        Überträgt der Adapter sie denn korrekt statt nur Broadcast (0) zu senden?
                        • NWH
                          NWH @JoergH last edited by NWH
                          @joergh @arteck @Glasfaser
                          Ich habe jetzt "nur multiple write" angeklickt, leider keine Änderung.
                          Funktionieren tut es ja aber ca. alle 10 bis 15 min. kommt der Fehler
                          modbus.0
                          2023-05-31 10:39:06.841	warn	On error: {"code":"ERR_STREAM_WRITE_AFTER_END"}
                          modbus.0
                          2023-05-31 10:39:06.841	error	Client in error state.
                          modbus.0
                          2023-05-31 10:39:06.840	error	Socket Error
                          Solange es funktioniert geht es ja, aber gut sind die Fehler und Warnungen auf Dauer sicher nicht.
                          Hat das eigentlich auf die Ressourcen (CPU, Speicher usw.) eine Auswirkungen?
                            wie kommst du da drauf.. dass es auf dauer nicht gut ist.. was erwartest du was passiert ????
                            • NWH
                              @arteck Fehler sind auf Dauer nie gut, würde ich mal behaupten.
                              Ich erwarte gar nix, war nur eine Frage!
                                dann muss ich dein Weltbild zerstören.. Software ist nie fehlerfrei.. also auch wenn du nix siehst ..
                                lass laufen..
                                komisch ist ea aber schon
                                  @nwh
                                  Die Fehlermeldung ist jetzt eine andere...
                                  Tja, da hakelt er vielleicht alle 15 min. aus anderen Gründen. Wenn es so regelmäßig kommt, könnte es auch mit ganz anderen Dingen zu tun haben die alle 15 Minuten auf dem pi laufen und den Adapter im Timing stören...ist aber alles Spekulation. Spielt aber auch keine Rolle, wenn es nur so selten auftritt dass mal ein Datensatz nicht korrekt gelesen wird.
                                    Sneak-L8 @arteck last edited by
                                    @arteck Hallo zusammen,
                                    seit zwei Tagen erhalte ich die bisher nur an manchen Tagen und dan nur alle ca. 6 Stunden auftretende Meldung dauerhaft:
                                    modbus.1
                                    	2023-06-19 11:25:11.429	info	(COMPACT) setState not processed because States database not connected
                                    modbus.1
                                    	2023-06-19 11:25:11.428	info	(COMPACT) Connected to slave 192.168.97.46
                                    modbus.1
                                    	2023-06-19 11:24:11.419	info	(COMPACT) setState not processed because States database not connected
                                    modbus.1
                                    	2023-06-19 11:24:11.418	info	(COMPACT) Disconnected from slave 192.168.97.46
                                    modbus.1
                                    	2023-06-19 11:24:10.421	error	(COMPACT) Reconnect did not help, restart adapter
                                    modbus.1
                                    	2023-06-19 11:24:10.420	info	(COMPACT) setState not processed because States database not connected
                                    modbus.1
                                    	2023-06-19 11:24:10.420	warn	(COMPACT) Poll error count: 1132 code: {"err":"timeout","timeout":5000}
                                    modbus.1
                                    	2023-06-19 11:24:10.419	error	(COMPACT) Client in error state.
                                    modbus.1
                                    	2023-06-19 11:24:10.418	error	(COMPACT) Request timed out.
                                    modbus.1
                                    	2023-06-19 11:24:10.417	warn	(COMPACT) Error: undefined
                                    modbus.1
                                    	2023-06-19 11:24:05.415	info	(COMPACT) setState not processed because States database not connected
                                    modbus.1
                                    	2023-06-19 11:24:05.414	info	(COMPACT) Connected to slave 192.168.97.46
                                    modbus.1
                                    	2023-06-19 11:23:05.408	info	(COMPACT) setState not processed because States database not connected
                                    modbus.1
                                    	2023-06-19 11:23:05.407	info	(COMPACT) Disconnected from slave 192.168.97.46
                                    modbus.1
                                    	2023-06-19 11:23:04.410	error	(COMPACT) Reconnect did not help, restart adapter
                                    modbus.1
                                    	2023-06-19 11:23:04.409	info	(COMPACT) setState not processed because States database not connected
                                    modbus.1
                                    	2023-06-19 11:23:04.409	warn	(COMPACT) Poll error count: 1131 code: {"err":"timeout","timeout":5000}
                                    modbus.1
                                    	2023-06-19 11:23:04.408	error	(COMPACT) Client in error state.
                                    modbus.1
                                    	2023-06-19 11:23:04.407	error	(COMPACT) Request timed out.
                                    modbus.1
                                    	2023-06-19 11:23:04.406	warn	(COMPACT) Error: undefined
                                    Ich habe in der letzten Zeit weder den Raspi, NodeJs, noch Adapter upgedatet. Auch der WR (SMA TriPower TL1000-3) ist unverändert.
                                    Plattform
                                        linux
                                    Betriebssystem
                                        linux
                                    Architektur
                                        arm
                                    CPUs
                                    Geschwindigkeit
                                        1400 MHz
                                    Modell
                                        ARMv7 Processor rev 4 (v7l)
                                    RAM
                                        923.14 MB
                                    System-Betriebszeit
                                        21:37:39
                                    Node.js
                                        v16.16.0 (Es gibt eine neuere Version: v16.20.0 - Empfohlene Version v18.16.0)
                                    time
                                        1687169029347
                                    timeOffset
                                        -120
                                    Anzahl der Adapter
                                        473
                                    NPM
                                        8.11.0
                                    Datenträgergröße
                                        28.98 GB
                                    freier Festplattenspeicher
                                        24.5 GB
                                    Betriebszeit
                                        21:54:23
                                    Aktive Instanzen
                                        24
                                    Weg
                                        /opt/iobroker/
                                    Hostname
                                        raspberrypi
                                    Neustart des Raspi hat leider auchnichts gebracht.
                                    Wie bei den anderen liefert der WR trotzdem brav alle Daten.
                                    Ich kann die Meldungen in meiner Log-Überwachung auch auf ignore setzen, daber komishc ist das schon ...
                                    Gibt es sonst noch Tipps?
                                      arteck Developer Most Active @Sneak-L8 last edited by
                                      @sneak-l8 sagte in Modbus adapter:
                                      gesehen
                                        @arteck Ja, muss ich noch machen. Das sollte aber nicht für die Meldungen verantwortlich sein, wenn sich am System nichts geändert hat.
                                        Hattte testweise mal ein register, da ich e nicht brauche rausgenommen. Danach war kurz Ruhe. aber jetzt kommen die Meldungen wieder zuverlässig alle paar Minuten. Heute haben die Meldungen um 11:06 Uhr plötzich aufgehört. Mal sehen wie lange ...
                                        Homoran S 2 Replies Last reply Reply Quote 0
                                          Homoran Global Moderator Administrators @Sneak-L8 last edited by
                                          Dann ist ggf. zuviel los auf deinem Bus, oder das hier gesagte könnte zutreffen.
                                            Sneak-L8 @Sneak-L8 last edited by
                                            @arteck Gerade habe ich noch im Log folgende Zeile gefunden:
                                            11:06:40.511	modbus.1	(COMPACT) Poll error count: 2425 code: "ReadInputRegisters: Invalid FC 0"
                                            Ist die Kommunikationsaienheit des WR vielleicht bei "end-of-lifetime"?
                                            modbus modbus adapter
                                            140
                                            978
                                            369376
