    4. JavaScript
    5. [Vorlage] Denon HEOS Script
    • DJMarc75
      DJMarc75 @bouster last edited by
      @bouster Ausgabe von
      iob diag
      nochmal bitte
        @djmarc75 said in [Vorlage] Denon HEOS Script:
        iob diag
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         20:16:29 up 58 min,  3 users,  load average: 6.77, 2.36, 1.62
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=40.4'C
        volt=0.8900V
        *** Time and Time Zones ***
                       Local time: Sun 2023-05-21 20:16:29 CEST
                   Universal time: Sun 2023-05-21 18:16:29 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        1.2G        707M         40M        1.9G        2.5G
        Swap:            99M          0B         99M
        Total:          3.9G        1.2G        807M
                 3794 M total memory
                 1200 M used memory
                 1853 M active memory
                  646 M inactive memory
                  707 M free memory
                  245 M buffer memory
                 1640 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4       29G   22G  6.7G  76% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  2.7M  757M   1% /run
        /dev/loop0     squashfs   47M   47M     0 100% /snap/core18/2748
        /dev/loop1     squashfs   47M   47M     0 100% /snap/core18/2723
        /dev/loop2     squashfs  225M  225M     0 100% /snap/nextcloud/21522
        /dev/loop3     squashfs   44M   44M     0 100% /snap/snapd/18936
        /dev/loop4     squashfs   44M   44M     0 100% /snap/snapd/19124
        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
        /dev/mmcblk0p3 ext4       88G   24K   84G   1% /media/pi/b6462cb4-edb3-a74c-b924-794fd764376a
        Show mounted filesystems (real ones only):
        TARGET                                                SOURCE         FSTYPE   OPTIONS
        /                                                     /dev/mmcblk0p2 ext4     rw,noatime
        |-/snap/core18/2748                                   /dev/loop0     squashfs ro,nodev,relatime,errors=continue
        |-/snap/core18/2723                                   /dev/loop1     squashfs ro,nodev,relatime,errors=continue
        |-/snap/nextcloud/21522                               /dev/loop2     squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/18936                                   /dev/loop3     squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/19124                                   /dev/loop4     squashfs ro,nodev,relatime,errors=continue
        |-/boot                                               /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        `-/media/pi/b6462cb4-edb3-a74c-b924-794fd764376a /dev/mmcblk0p3 ext4     rw,nosuid,nodev,relatime,errors=remount-ro
        /var:
        11G     /var/
        6.9G    /var/lib
        4.8G    /var/lib/docker
        4.7G    /var/lib/docker/overlay2
        3.8G    /var/log
        Archived and active journals take up 1.7G in the file system.
        /opt/iobroker/backups:
        737M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        275M    /opt/iobroker/iobroker-data/
        128M    /opt/iobroker/iobroker-data/files
        119M    /opt/iobroker/iobroker-data/backup-objects
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        38M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
        9.1M    /opt/iobroker/iobroker-data/objects.jsonl
        8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        7.5M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.2afdfa2c.chunk.js.map
        7.1M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.21829349.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.5d4fbf6a.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.16.0
        /usr/bin/node           v18.16.0
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
        nodejs:
          Installed: 18.16.0-deb-1nodesource1
          Candidate: 18.16.0-deb-1nodesource1
          Version table:
         *** 18.16.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     6.1.4
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.heos.0                   : heos                  : raspberrypi                              - disabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 192.168.178.101
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.signal-cmb.0             : signal-cmb            : raspberrypi                              -  enabled
        + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 192.168.178.101 (SSL), run as: admin
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
          system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
          system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "backitup"     : 2.6.19   , installed 2.6.19
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "heos"         : 1.10.0   , installed 1.10.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
        Objects and States
        Objects:        5151
        States:         3385
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
        Hit:4 https://download.docker.com/linux/raspbian bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        xxx
        2023-05-21 20:09:38.649  - info: host.raspberrypi object deleted system.adapter.heos.1
        2023-05-21 20:09:38.653  - info: host.raspberrypi iobroker host.raspberrypi Deleting 22 state(s).
        2023-05-21 20:09:39.753  - info: host.raspberrypi iobroker exit 0
        2023-05-21 20:09:41.703  - info: admin.0 (22943) ==> Connected system.user.admin from ::ffff:192.168.178.84
        2023-05-21 20:10:16.793  - info: admin.0 (22943) <== Disconnect system.user.admin from ::ffff:192.168.178.84
        2023-05-21 20:10:33.806  - error: rpi2.0 (345) GPIO is not initialized!
        2023-05-21 20:11:33.780  - error: rpi2.0 (345) GPIO is not initialized!
        2023-05-21 20:12:33.774  - error: rpi2.0 (345) GPIO is not initialized!
        2023-05-21 20:13:21.759  - info: admin.0 (22943) ==> Connected system.user.admin from ::ffff:192.168.178.84
        2023-05-21 20:13:29.605  - info: admin.0 (22943) <== Disconnect system.user.admin from ::ffff:192.168.178.84
        2023-05-21 20:13:33.772  - error: rpi2.0 (345) GPIO is not initialized!
        2023-05-21 20:14:15.071  - info: heos.0 (3089) searching for HEOS devices ...
        2023-05-21 20:14:23.164  - info: heos.0 (3089) searching for HEOS devices ...
        2023-05-21 20:14:31.254  - info: heos.0 (3089) searching for HEOS devices ...
        2023-05-21 20:14:31.272  - warn: heos.0 (3089) rebooting player 192.168.178.23
        2023-05-21 20:14:37.186  - info: heos.0 (3089) searching for HEOS devices ...
        2023-05-21 20:14:46.836  - info: host.raspberrypi "system.adapter.heos.0" disabled
        2023-05-21 20:14:46.839  - info: host.raspberrypi stopInstance system.adapter.heos.0 (force=false, process=true)
        2023-05-21 20:14:46.851  - info: heos.0 (3089) Got terminate signal TERMINATE_YOURSELF
        2023-05-21 20:14:46.852  - info: heos.0 (3089) disconnecting from HEOS ...
        2023-05-21 20:14:46.855  - info: heos.0 (3089) disconnected from HEOS
        2023-05-21 20:14:46.857  - info: heos.0 (3089) terminating
        2023-05-21 20:14:46.859  - info: heos.0 (3089) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-05-21 20:14:46.933  - info: host.raspberrypi stopInstance system.adapter.heos.0 send kill signal
        2023-05-21 20:14:47.456  - info: host.raspberrypi instance system.adapter.heos.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          withstu @bouster last edited by
          @bouster welches Script startest du denn? Der Adapter ist aus dem Script aus diesem Forumseintrag entstanden. Wenn du dieses Script und den Adapter startest, hast du es doppelt laufen. Stelle das Logging Level des Adapters auf Debug und packe die Ausgabe mal hier rein.
            Thomas Braun Most Active @bouster last edited by
            @bouster sagte in [Vorlage] Denon HEOS Script:
            Da ich etwas paranoid bin (evtl auch gerade weil ich mich nicht so gut auskenne) habe ich den Teil der IP adressen entfernt, wenn der auch nötig ist würde ich ihn lieber nicht ganz so öffentlich teilen.
            Das sind alles lokale IP-Adressen, damit kann niemand was von außen kommend anfangen.
            Im iob diag steht ggf. nur in den 25 Zeilen aus dem iobroker log was sensibles drin. Da sollte man nochmal drüber schauen. Aber IPs aus deinem lokalen Netzwerk sind vollkommen uninteressant für 'Hacker'.
              bouster @withstu last edited by
              @withstu Da kommt leider nichts nützliches bei raus... Das folgende spukt er beim Log-Level "silly" aus: und danach geht es immer mit "searching ..." weiter. Kein anderer output.
              heos.0
              	14832	2023-05-31 16:51:14.263	debug	searching for HEOS devices ...
              heos.0
              	14832	2023-05-31 16:50:44.248	info	searching for HEOS devices ...
              heos.0
              	14832	2023-05-31 16:50:44.044	info	starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.heos, node: v18.16.0, js-controller: 4.0.24
              host.raspberrypi
              		2023-05-31 16:50:40.075	info	instance system.adapter.heos.0 started with pid 14832
                @bouster Dann findet der Adapter die Player nicht mehr mit dem Protokoll SSDP. Prüfe mal, ob Netzwerkseitig alles passt: https://github.com/withstu/ioBroker.heos#network-requirements
                Alternativ könntest du die statische IP eines Players in die Adapter Konfiguration als bevorzugten IP hinzufügen.
                  @withstu Hallo nochmal. Ich habe den Adapter jetzt eine weitere Nacht laufen lassen und etwas mehr output bekommen:
                  heos.0
                  	14832	2023-06-01 06:58:30.112	info	searching for HEOS devices ...
                  heos.0
                  	14832	2023-06-01 06:58:25.111	debug	disconnected from HEOS
                  heos.0
                  	14832	2023-06-01 06:58:25.109	debug	data sent: heos://system/register_for_change_events?enable=off
                  heos.0
                  	14832	2023-06-01 06:58:25.109	debug	[HEARTBEAT] reset retries
                  heos.0
                  	14832	2023-06-01 06:58:25.109	debug	[HEARTBEAT] stop interval
                  heos.0
                  	14832	2023-06-01 06:58:25.109	debug	disconnecting from HEOS ...
                  heos.0
                  	14832	2023-06-01 06:58:25.109	debug	reconnecting to HEOS ...
                  heos.0
                  	14832	2023-06-01 06:58:25.108	debug	leader failure statistics: {"192.168.178.28":94,"192.168.178.23":94}
                  heos.0
                  	14832	2023-06-01 06:58:25.108	debug	[connect] Error: connect EHOSTUNREACH 192.168.178.28:1255
                  heos.0
                  	14832	2023-06-01 06:58:22.050	info	searching for HEOS devices ...
                  heos.0
                  	14832	2023-06-01 06:58:22.050	debug	connecting to HEOS (192.168.178.28) ...
                  heos.0
                  	14832	2023-06-01 06:58:22.050	debug	try to connect to 192.168.178.28 to reboot device
                  heos.0
                  	14832	2023-06-01 06:58:22.049	debug	following ips need to be rebooted: 192.168.178.28
                  heos.0
                  	14832	2023-06-01 06:58:17.048	debug	disconnected from HEOS
                  heos.0
                  	14832	2023-06-01 06:58:17.046	debug	data sent: heos://system/register_for_change_events?enable=off
                  heos.0
                  	14832	2023-06-01 06:58:17.045	debug	[HEARTBEAT] reset retries
                  heos.0
                  	14832	2023-06-01 06:58:17.045	debug	[HEARTBEAT] stop interval
                  heos.0
                  	14832	2023-06-01 06:58:17.045	debug	disconnecting from HEOS ...
                  heos.0
                  	14832	2023-06-01 06:58:17.045	debug	reconnecting to HEOS ...
                  heos.0
                  	14832	2023-06-01 06:58:17.045	debug	leader failure statistics: {"192.168.178.28":93,"192.168.178.23":94}
                  heos.0
                  	14832	2023-06-01 06:58:17.044	debug	[connect] Error: connect EHOSTUNREACH 192.168.178.23:1255
                  heos.0
                  	14832	2023-06-01 06:58:13.971	info	searching for HEOS devices ...
                  heos.0
                  	14832	2023-06-01 06:58:13.970	debug	connecting to HEOS (192.168.178.23) ...
                  heos.0
                  	14832	2023-06-01 06:58:13.970	debug	try to connect to 192.168.178.23 to reboot device
                  heos.0
                  	14832	2023-06-01 06:58:13.970	debug	following ips need to be rebooted: 192.168.178.23,192.168.178.28
                  heos.0
                  	14832	2023-06-01 06:58:08.968	debug	disconnected from HEOS
                  heos.0
                  	14832	2023-06-01 06:58:08.966	debug	[HEARTBEAT] reset retries
                  heos.0
                  	14832	2023-06-01 06:58:08.966	debug	[HEARTBEAT] stop interval
                  heos.0
                  	14832	2023-06-01 06:58:08.966	debug	disconnecting from HEOS ...
                  heos.0
                  	14832	2023-06-01 06:58:08.965	debug	reconnecting to HEOS ...
                  heos.0
                  	14832	2023-06-01 06:58:07.964	debug	add reboot ip 192.168.178.28
                  heos.0
                  	14832	2023-06-01 06:58:07.964	debug	add reboot ip 192.168.178.23
                  heos.0
                  	14832	2023-06-01 06:58:07.964	debug	rebooting all players
                  heos.0
                  	14832	2023-06-01 06:58:07.963	debug	can't find any HEOS devices. Try to connect known device IPs and reboot them to exclude device failure...
                  heos.0
                  	14832	2023-06-01 06:57:37.961	debug	searching for HEOS devices ...
                    @bouster Der Adapter kann keine Verbindung zu Port 1255 des Players aufbauen (EHOSTUNREACH 192.168.178.28:1255). Hast du mal versucht die Player kurz vom Strom zu nehmen?
                      @withstu Beide player 192.168.178.28:1255 und 192.168.178.23:1255 werden regelmäßig vom Netz genommen und nur bei bedarf gestartet.
                      Was (soweit mein Verständnis reicht) merkwürdig ist, ist dass er die Player neustarten kann. Dann muss er den Player doch auch finden.
                        @bouster nicht ganz. Der Adapter versucht die Player zu rebooten, kann sich aber nicht verbinden. Wenn der Adapter keinen Player über SSDP finden kann, versucht er sich nacheinander mit allen bereits bekannten IPs aus den Player States direkt zu verbinden und die Player neu zu starten. So wird versucht mögliche SSDP Fehler durch Reboot der Player zu beheben.
                          @withstu Da das leider alles nicht geholfen hat. Frage ich mich auf welche Weise kommen sich denn das Skript und der Adapter in die Quere? Könnte da das Problem liegen, dass ich beides mal ausgeführt habe?
                            ich habe es final endlich hinbekommen und der Adapter läuft jetzt. Ich weiß nicht was anders ist als vorher. Es hat nun ohne andere Änderungen funktioniert den Adapter zu verbinden, jedoch nur mit direkter IP Eingabe der Player.
                            • hg6806
                              hg6806 Most Active last edited by
                              Hi, ich bin gerade hier auf den Thread gestoßen und möchte auch die Browser Funktion umsetzen.
                              Das hat soweit geklappt, jedoch habe ich nicht die beiden Zeile "Overview" und "Back". Wie bekommt man die?
                                withstu @hg6806 last edited by
                                @hg6806 Hast du dir bereits das Script in der Readme angeschaut? https://github.com/withstu/ioBroker.heos?tab=readme-ov-file#browse-sources
                                • hg6806
                                  @withstu
                                  Ja sicher, daher habe ich es ja und implementiert. Ich kann ja auch durch die Favoriten browsen.
                                  Jedoch fehlen mir eben diese zwei Zeilen. Und somit komme ich nicht zurück
                                  • hg6806
                                    Auf einmal klappt es.
                                    Hatte vorher schon mal den Adapter neu gestartet. Die beiden Zeichen oben rechts waren immer ausgegraut.
                                    Nun werde ich mal weiter experimentieren.
                                    Danke für den Adapter und das Script!
                                    • hg6806
                                      hg6806 Most Active last edited by hg6806
                                      Sorry, habe noch eine Frage zu dem Script, bzw. Adapter.
                                      Und zwar tauchen im Browser immer Dienste wie "Deezer", "Soundcloud" usw auf.
                                      Diese Dienste habe ich aber gar nicht abonniert!
                                      Wenn ich in der HEOS App unter "Musikdienste" -> "bearbeiten" schaue, ist lediglich TuneIn drin. Die ändern könnte ich hinzufügen, müsste dafür aber auch ein Konto erstellen.
                                      Ich habe auch schon in Objekten die Ordner der Dienste ganz rausgelöscht.
                                      Sobald man den Adapter neu startet, werden diese wieder angelegt.
                                      Die stehen zwar unter "Available" auf false, werden aber trotzdem im Browser angezeigt
                                      Also, wie bekomme ich die Dienste ganz raus?
                                      Wenn man danach googelt soll man die über den Reiter "Musik" die entfernen. Den Reiter habe ich aber gar nicht in der App.
                                      • Meister Mopper
                                        Meister Mopper @hg6806 last edited by
                                        @hg6806 sagte in [Vorlage] Denon HEOS Script:
                                        Joa, tauchen bei mir im Browser auch auf. Aber was solls, ist doch eher egal als wichtig. 🤷‍♂️
                                          withstu @Meister Mopper last edited by
                                          @meister-mopper Ihr müsst nur euer JSON -> HTML Script anpassen und available = false rausfiltern. z.B.:
                                                for (let i = 0; i < data.payload.length; i++) {
                                                    let payload = data.payload[i];
                                                    if(!payload.available){
                                                        continue;
                                          • hg6806
                                            hg6806 Most Active @withstu last edited by
                                            @withstu
                                            Ich danke dir!
                                            Obwohl ich von Scripten so gar keine Ahnung habe, habe ich es wohl hinbekommen. Zumindest wird es rausgefiltert.
                                            Der Teil sieht dann hoffentlich wie folgt aus:
                                            html += "</th><th>" + (data.name == "sources" ? "Overview" : data.name) + "</th><th></th></tr>";
                                                          continue;
                                                        html += "<tr class=\"";
                                                        if (payload.type == "control") {
                                                            html += "heos-browse-row-control";
                                                        } else {
                                                            html += "heos-browse-row-media"
                                            javascript template
                                            47
                                            349
                                            64395
