    4. Test Adapter Hoover hON
      e-i-k-e @jkalver last edited by
      @jkalver sagte in Test Adapter Hoover hON:
      Hallo @tombox ,
      Ich habe den Adapter (v0.0.6) installiert.
      Beim Starten bekomme ich folgende Fehler:
      Missing step1 url
      "*/{"event":{"descriptor":"markup://aura:systemError","attributes":{"values":{"message":"[AuraClientInputException from server] Unexpected request input. Expected input format: \"Data in a request must be a valid JSON Object and must be in the expected format.\".","showOverride":false}},"eventDef":{"descriptor":"markup://aura:systemError","t":"APPLICATION","xs":"G","a":{"message":["message","aura://String","G",false],"error":["error","aura://String","G",false],"auraError":["auraError","aura://Object","I",false,null],"timestamp":["timestamp","aura://Integer","I",false],"showOverride":["showOverride","aura://Boolean","I",false,false]}}},"exceptionMessage":"[AuraClientInputException from server] Unexpected request input. Expected input format: \"Data in a request must be a valid JSON Object and must be in the expected format.\".","exceptionEvent":true}/ERROR/"
      Meine Konfig:
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v18.15.0
      v18.15.0
      9.5.0
      4.0.23
      Was mache ich falsch?
      Gruss
      Jens
      Ich habe das gleiche Problem.
      Was läuft hier falsch?
      Den Weinkühlschrank habe ich in der h0n entfernt und zwei Klimaanlagen hinzugefügt.
      hoover.0
      2023-05-05 22:21:18.153	error	"*/{\"event\":{\"descriptor\":\"markup://aura:systemError\",\"attributes\":{\"values\":{\"message\":\"[AuraClientInputException from server] Unexpected request input. Expected input format: \\\"Data in a request must be a valid JSON Object and must be in the expected format.\\\".\",\"showOverride\":false}},\"eventDef\":{\"descriptor\":\"markup://aura:systemError\",\"t\":\"APPLICATION\",\"xs\":\"G\",\"a\":{\"message\":[\"message\",\"aura://String\",\"G\",false],\"error\":[\"error\",\"aura://String\",\"G\",false],\"auraError\":[\"auraError\",\"aura://Object\",\"I\",false,null],\"timestamp\":[\"timestamp\",\"aura://Integer\",\"I\",false],\"showOverride\":[\"showOverride\",\"aura://Boolean\",\"I\",false,false]}}},\"exceptionMessage\":\"[AuraClientInputException from server] Unexpected request input. Expected input format: \\\"Data in a request must be a valid JSON Object and must be in the expected format.\\\".\",\"exceptionEvent\":true}/*ERROR*/"
      hoover.0
      2023-05-05 22:21:18.152	error	Missing step1 url
      hoover.0
      2023-05-05 22:21:16.200	info	starting login
      hoover.0
      2023-05-05 22:21:16.134	info	starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.hoover, node: v18.16.0, js-controller: 5.0.1-alpha.0-20230418-efa3e809
      T E 2 Replies Last reply Reply Quote 0
        tombox @e-i-k-e last edited by
        @e-i-k-e kannst du mir den account bitte mal zusenden zum anschauen
          e-i-k-e @tombox last edited by
          @tombox Ja. Schick dir gleich eine PN.
            astrakid @e-i-k-e last edited by
            ich habe nun einne bakcofen, der ebenfalls über hOn gesteuert wird. der aufbau der objekte ist analog zu dem einer waschmaschine. da ich gerne einzelne parameter über iobroker starten würde (die app zickt bei mir rum, so muss ich mich jeden tag neu anmelden, was mit komplexen passwörtern etwas nervig ist), wäre eine idee, verschiedene aufrufe zu sammeln ("remote -> send"), um darüber steuerungen für einzelne teile zusammenzubauen.
            ich fange einfach mal an:
              "macAddress": "id of the device set by adapter",
              "timestamp": "2022-05-10T08:16:35.010Z",
              "commandName": "startProgram",
              "programName": "PROGRAMS.TD.CARE_45",
              "transactionId": "2022-05-10T08:16:35.011Z",
              "applianceOptions": {
                "opt1": "anticrease",
                "opt2": "dryingManager",
                "opt3": "bestIroning",
                "opt4": "hybrid"
              "device": {
                "mobileOs": "ios",
                "mobileId": "2xxxxxx3-9xxE-4xx3-Axx8-1xxxxxxxxxx8",
                "osVersion": "15.5",
                "appVersion": "1.40.2",
                "deviceModel": "iPhone10,5"
              "attributes": {
                "prStr": "Care 45",
                "energyLabel": "0",
                "channel": "mobileApp",
                "origin": "lastProgram"
              "ancillaryParameters": {
                "dryTimeMM": "45",
                "energyLabel": "0",
                "functionalId": "8",
                "programFamily": "[dashboard]",
                "programRules": {
                  "opt3": {
                    "dryLevel": {
                      "2|3|4": {
                        "fixedValue": "0",
                        "typology": "fixed"
                  "dryTime": {
                    "dryTimeMM": {
                      "30": {
                        "fixedValue": "1",
                        "typology": "fixed"
                      "45": {
                        "fixedValue": "2",
                        "typology": "fixed"
                      "59": {
                        "fixedValue": "3",
                        "typology": "fixed"
                      "70": {
                        "fixedValue": "4",
                        "typology": "fixed"
                      "80": {
                        "fixedValue": "5",
                        "typology": "fixed"
                      "90": {
                        "fixedValue": "6",
                        "typology": "fixed"
                      "100": {
                        "fixedValue": "7",
                        "typology": "fixed"
                      "110": {
                        "fixedValue": "8",
                        "typology": "fixed"
                      "120": {
                        "fixedValue": "9",
                        "typology": "fixed"
                      "130": {
                        "fixedValue": "10",
                        "typology": "fixed"
                      "140": {
                        "fixedValue": "11",
                        "typology": "fixed"
                      "150": {
                        "fixedValue": "12",
                        "typology": "fixed"
                      "160": {
                        "fixedValue": "13",
                        "typology": "fixed"
                      "170": {
                        "fixedValue": "14",
                        "typology": "fixed"
                      "180": {
                        "fixedValue": "15",
                        "typology": "fixed"
                      "190": {
                        "fixedValue": "16",
                        "typology": "fixed"
                      "200": {
                        "fixedValue": "17",
                        "typology": "fixed"
                      "210": {
                        "fixedValue": "18",
                        "typology": "fixed"
                      "220": {
                        "fixedValue": "19",
                        "typology": "fixed"
                  "dryLevel": {
                    "opt3": {
                      "1": {
                        "fixedValue": "1",
                        "typology": "fixed"
                "remoteActionable": "1",
                "remoteVisible": "1",
                "suggestedLoadD": "2"
              "parameters": {
                "dryTime": "2",
                "dryingManager": "0",
                "hybrid": "1",
                "checkUpStatus": "0",
                "anticrease": "0",
                "delayTime": "0",
                "prCode": "54",
                "prPosition": "13",
                "dryLevel": "0",
                "bestIroning": "0",
                "onOffStatus": "1"
              "applianceType": "TD"
              astrakid @Guest last edited by
              @dp20eic sagte in Test Adapter Hoover hON:
              @astrakid sagte in Test Adapter Hoover hON:
              Wie kann ich einen Waschvorgang pausieren und wieder fortsetzen? In der App gibt es die Funktion, im Adapter habe ich den Datenpunkt noch nicht gefunden auf die Schnelle...
              schon mal in ioBroker unter Objekte in die Suche pause eingegeben?
              ich habe keine entsprechenden datenpunkte... nur einen aus der history...?!
                astrakid @astrakid last edited by
                hi,
                ich bekomme neuerdings folgende fehlermeldung:
                AxiosError: Request failed with status code 301
                die app scheint nicht mehr zu funktionieren bei mir. neue URLs?
                ? 1 Reply Last reply Reply Quote 1
                  A Former User @astrakid last edited by
                  Moin,
                  bei mir auch, in zwei Installationen, habe ein issues aufgemacht.
                  https://github.com/TA2k/ioBroker.hoover/issues/9
                  VG
                  Bernd
                  dp20eic created this issue in TA2k/ioBroker.hoover
                  open the adapter is not able to connect to hoover/hOn Server anymore #9
                    @astrakid bitte 0.1.0 testen
                    ? A 3 Replies Last reply Reply Quote 0
                      A Former User @tombox last edited by
                      @tombox sagte in Test Adapter Hoover hON:
                      Moin,
                      nop, siehe neue Logs bei Github.
                      VG
                      Bernd
                      • Palm_Maniac
                        Palm_Maniac last edited by
                        Der Fehler 301 tritt bei mir seit dem Update auf V0.1.0 auch auf. Nutze die Hoover Schnittstelle.
                          astrakid @tombox last edited by
                          @tombox wie bei meinen vorschreibern: klappt nicht.
                            Moin,
                            auf Anraten von @tombox habe ich die Version nochmals über github installiert
                            Anschließend wurde der Adapter gelb und die Fehlermeldung tauchte wieder im Log auf, siehe Github
                            Ich habe anschließend noch ein Upload aus ioBroker heraus angestoßen, danach ein Restart des Adapters und er wurde wieder Grün 🙂
                            Upload, z.B.: so:
                            VG
                            Bernd
                            Palm_Maniac 1 Reply Last reply Reply Quote 0
                            • Palm_Maniac
                              Palm_Maniac @Guest last edited by Palm_Maniac
                              @dp20eic Ich habs mal nach deiner Anleitung versucht, brachte aber nichts. Der Adapter bleibt gelb und im Log steht weiterhin Fehlercode 301.
                              PS: Jetzt läuft auch die Vorgängerversion V0.0.7 nicht mehr, die vor dem Update perfekt funktionierte. Das hier steht im Log:
                              hoover.0 2023-06-06 16:01:03.789	error	""
                              hoover.0 2023-06-06 16:01:03.788	error	AxiosError: Request failed with status code 301
                                A Former User @Palm_Maniac last edited by
                                @palm_maniac sagte in Test Adapter Hoover hON:
                                Moin,
                                das ist seltsam, in beiden ioBroker Installationen, die ich betreibe, hat es genau so funktioniert 🤔
                                Hast Du mal mit einer zweiten Instanz versucht, ist das Passwort auch wirklich korrekt?
                                VG
                                Bernd
                                Installation debian:
                                Installation arch linux
                                • Palm_Maniac
                                  @dp20eic Die Zugangsdaten funktionieren in der App. Hab gerade mal ne neue Instanz versucht mit dem gleichen Ergebnis und Fehlercode. Alles erst seit dem Update von V0.0.7 auf V0.1.0.
                                    Moin,
                                    ah, da könnte der Hund auch noch begraben liegen.
                                    Bei mir ist es die hOn-APP bei Dir auch?
                                    VG
                                    Bernd
                                    P.S.: Sollte es bei Dir der Hoover-Wiz sein, dann musst Du mal bei Github bei meinem Issues Deine Daten mit anhängen, sodass @tombox sich das anschauen kann, vielleicht haben sich die Logins der beiden APPs verändert und sind nicht mehr kompatibel.
                                    • Palm_Maniac
                                      @dp20eic ja, ich nutze den Hover-Wizard Zugang, nicht hON. Hab mich mal an den Issue in Github rangehängt.
                                        tombox @Palm_Maniac last edited by
                                        @palm_maniac für hover wizard brauch ich nochmal Zugangsdaten um das zu fixen
                                        Palm_Maniac sigi234 2 Replies Last reply Reply Quote 0
                                        • Palm_Maniac
                                          Palm_Maniac @tombox last edited by
                                          @tombox Hab dir ne PN geschickt.
                                            sigi234 Forum Testing Most Active @tombox last edited by sigi234
                                            Hallo, geht bei mir auch nicht? [hover wizard]
                                            hoover.0
                                            2023-06-14 20:55:22.986	info	starting login
                                            hoover.0
                                            2023-06-14 20:55:22.975	info	starting. Version 0.1.1 (non-npm: TA2k/ioBroker.hoover#7deb12caf1e561fde36b85d4a8afd7016896095e) in C:/ioBroker/_iob_Test/node_modules/iobroker.hoover, node: v18.16.0, js-controller: 4.0.24
                                            hoover.0
                                            2023-06-14 20:55:23.746	error	AxiosError: Unsupported protocol javascript:
                                            hoover.0
                                            2023-06-14 20:55:23.746	error	Login step #3 failed
                                            Version: 0.1.1
                                            31.7k
                                            79.8k
                                            184
                                            18911
