    4. [gelöst] Mehrere Fehler in der Log *javascript/cloud/admin*
    • E
      el-lutschi last edited by
      meine ioBroker Log wirft immer und immer wieder folgende Fehlermeldungen aus.
      cloud.0 2018-01-22 10:42:47.370 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      javascript.0 2018-01-22 10:42:47.367 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0 2018-01-22 10:42:47.365 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0 2018-01-22 10:42:46.851 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      cloud.0 2018-01-22 10:42:46.813 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      javascript.0 2018-01-22 10:42:46.810 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      javascript.0 2018-01-22 10:42:46.773 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      Und ich weiß einfach nicht woran es liegt.
      Außerdem erhalte ich beim Ausführen eines Blockly Skripts immer folgenden Fehler:
      javascript.0	2018-01-22 10:42:46.756	warn	at Object. (script.js.Custom_Scripts.Automationen.Heizung_An/Aus_Hin:9:5)
      javascript.0	2018-01-22 10:42:46.746	warn	Wrong type of hm-rpc.0.OEQ0243547.4.SET_TEMPERATURE: "string". Please fix, while deprecated and will not work in next versions.
      Skript:
      Kann mir jemand weiterhelfen?
      Danke und Gruß
      Chris
        cernst1980 last edited by
        Du weist der Temperature einen String ("20") zu, es wird aber eine Zahl (20) erwartet.
        Unter Mathematik findest du die Zahlen.
        • E
          @cernst1980:
          Unter Mathematik findest du die Zahlen. `
          Vielen Dank! Das hat Problem Nummer 2 gelöst!
          Gerade ist mir auch aufgefallen, dass Problem 1 auftritt, wenn das Heizung An/Aus Skript ausgeführt wird.
          • E
            Problem 1 konnte ich nun auch lösen!
            Wie, findet ihr hier:
            http://ww.iobroker.com/forum/viewtopic.php?f=22&t=9701
            81.0k
