    4. Fehler beim Installieren der metro widgets
    • N
      navino last edited by
      bekomme folgende Fehlermeldung, vis und andere widgets gehen…
      exit 25
      iobroker 2015-08-29 14:33:29 info npm
      iobroker 2015-08-29 14:33:29 info ELIFECYCLE
      iobroker 2015-08-29 14:33:29 info code
      iobroker 2015-08-29 14:33:29 info npm ERR!
      iobroker 2015-08-29 14:33:29 info npm ERR! npm -v 1.4.28
      iobroker 2015-08-29 14:33:29 info npm ERR! node -v v0.10.35
      iobroker 2015-08-29 14:33:29 info command "C:\Program Files\nodejs\\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/ioBroker/node_modules/iobroker.v
      iobroker 2015-08-29 14:33:29 info ERR!
      iobroker 2015-08-29 14:33:29 info Windows_NT 6.1.7601npm
      iobroker 2015-08-29 14:33:29 info System
      iobroker 2015-08-29 14:33:29 info npm ERR! There is likely additional logging output above.
      iobroker 2015-08-29 14:33:29 info ERR! You can get their info via:npm ERR! npm owner ls iobroker.vis-metro
      iobroker 2015-08-29 14:33:29 info npm ERR! Tell the author that this fails on your system:npm ERR! node node_modules/grunt/lib/grunt prepublish
      iobroker 2015-08-29 14:33:29 info npm ERR! not with npm itself.
      iobroker 2015-08-29 14:33:29 info npm ERR! This is most likely a problem with the iobroker.vis-metro package,
      iobroker 2015-08-29 14:33:29 info npm ERR! Failed at the iobroker.vis-metro@0.1.7 prepublish script.
      iobroker 2015-08-29 14:33:29 info ERR! Exit status 8npm
      iobroker 2015-08-29 14:33:29 info iobroker.vis-metro@0.1.7 prepublish: node node_modules/grunt/lib/grunt prepublish
      iobroker 2015-08-29 14:33:29 info at node.js:929:3
      iobroker 2015-08-29 14:33:29 info at startup (node.js:119:16)
      iobroker 2015-08-29 14:33:29 info at Function.Module.runMain (module.js:497:10)
      iobroker 2015-08-29 14:33:29 info at Function.Module._load (module.js:280:25)
      iobroker 2015-08-29 14:33:29 info at Function.Module._resolveFilename (module.js:338:15)
      iobroker 2015-08-29 14:33:29 info Error: Cannot find module 'C:\Program Files\ioBroker\node_modules\iobroker.vis-metro\node_modules\grunt\lib\grunt'
      iobroker 2015-08-29 14:33:29 info ^
      iobroker 2015-08-29 14:33:29 info throw err;
      iobroker 2015-08-29 14:33:29 info module.js:340
      iobroker 2015-08-29 14:33:29 info npm install --production --prefix "C:/Program Files/ioBroker/node_modules/iobroker.vis-metro" (System call)
      iobroker 2015-08-29 14:33:29 info host.fujitsuH720 install adapter vis-metro
      iobroker 2015-08-29 14:33:26 info npm install iobroker.vis-metro --production --prefix "C:/Program Files/ioBroker" (System call)
      iobroker 2015-08-29 14:33:26 info add vis-metro
      navino
        Fitti last edited by
        Schreibe bitte mal die Version des js-contoller unter dem Reiter Host in iobroker.
        Hast du einen roten LOG-Reiter? Kannst du darin auch noch Fehler sehen?
        Welche node.js Version nutzt Du? Laut Doku benötigt IoBroker eine Version >0.8 und <0.12.
        Keine Ahnung, ob es absoluter Unsinn ist, was ich hier schreibe, aber vielleicht hilft es Bluefox zur Analyse?
        Grüße,
        Fitti
          Die nodejs version kleiner 0.12 galt wegen node red. Inzwischen ist diese Beschränkung aufgehoben. Trotzdem habe ich den Eindruck, dass iobroker mit neueren Versionen nicht vernünftig läuft.
          Mit den nodejs versionen gibt es auch unterschiedliche npm Versionen. Auch hier scheint es zu Problemen zu kommen, wobei ich glaube, dass npm (Server) selbst besonders am Wochenende Probleme hat.
          Gesendet von meinem LIFETAB_S785X mit Tapatalk
          • N
            @Fitti:
            Grüße,
            Fitti `
            Habe die Version 0.7.11 , Log-reiter ist nicht rot, außer dem Fehler mit dem metro sehe ich sonst keine fehler
            nodjs habe ich in der version 0.10.35
            Kommisch ist, das ich das Problem erst nach der Deinsatllation habe. habe alles komplett deinstalliert, reste in den Verzeichnissen gelöscht…
            navino
              Mach mal
              cd /opt/iobroker
              npm cache clean
              iobroker upload vis-metro
              • N
                @Homoran:
                Mach mal
                cd /opt/iobroker `
                Ich habe kein opt Dir …
                gruß
                navino
                  Dann mach die restlichen Befehle in deinem Installationsverzeichnis von windows.
                  Da kenne ich mich nicht aus.
                  • N
                    habe ich, leider ohne Erfolg.
                    Dann habe ich alles nocheinmal mit einem anderen Account probiert….wegen Cache oder so... auch nicht.
                    Dann habe ich einen anderen Rechner probiert, der noch nie was mit mit ioBroker und nodejs zu tun hatte, selbes Problem.
                    Also mach erstma weiter ohne metro... 😞
                    navino
                      Was für ein Windows nutzt Du? Vielleicht schaffe ich es noch mal kurz das bei mir auszuprobieren…
                      • N
                        Ich habe Windows 7 64 Bit, habe es auch auf Window 7 32 Bit probiert.
                          Jupp, dass Gleiche bei mir, jedoch andere Fehleranzeigen.
                          Der Colorpicker, hqwidgets und bar widgets ließen sich installieren.
                          Ich habe sowohl den 0.5.0 Installer verwendet, als auch
                          node 0.10.22 manuell installiert und dann per Hand npm install iobroker.
                          Das Fehlerbild ist identisch, wenn man die Metros installieren möchte:
                          $ ./iobroker add vis-metro
                          host.computer1 install adapter vis-metro
                          module.js:340
                              throw err;
                              at node.js:929:3
                          npm
                           ERR!
                           iobroker.vis-metro@0.1.7 prepublish: `node node_modules/grunt/lib/grunt prepublish`npm ERR!
                           Exit status 8npm
                           ERR!
                          npm
                           ERR!
                           Failed at the iobroker.vis-metro@0.1.7 prepublish script.npm
                           ERR!
                           This is most likely a problem with the iobroker.vis-metro package,npm
                           ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
                          npm
                           ERR!     node node_modules/grunt/lib/grunt prepublishnpm
                           ERR!
                          npm
                          ERR!
                          npm
                          ERR!
                          System Windows_NT 6.1.7601
                          npm
                          ERR!
                          command
                           "C:\\Program Files\\nodejs\\\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/ioBroker/node_modules/iobroker.vis-metro"
                          npm
                          ERR!
                          cwd C:\Windows\system32npm
                          ERR! node -v v0.10.35npm ERR! npm -v 1.4.28
                          npm ERR! code ELIFECYCLE
                          Cannot install iobroker.vis-metro: 1
                          ERROR: process exited with code 25
                            Habe keine ahnung und deswegen gegoogelt.
                            Mit nodejs kommt auch npm
                            Wie sieht es denn aus, wenn du anschließend ein älteres nodejs installierst:
                            @Fitti:
                            als auch node 0.10.22 manuell installiert `
                            Wird dann auch npm downgegraded?
                            auf meinem RasPi 2:
                             node -v v0.10.22
                            npm -v 1.3.14
                              Genau. Auf meiner Banane ist auch 0.10.22
                              Mit Bluefoxs 0.5.0 Installer kommt 0.10.35 rauf.
                              Deshalb hatte ich alles (iobroker und node.js) gelöscht und manuell 0.10.22 installiert. Und dann über den node packet installer npm iobroker installiert.
                              Fehler bleibt (leider) exakt identisch.
                              Fitti
                                AndyUM61 last edited by
                                Hat denn das Problem inzwischen jemand gelöst?
                                Ich habe das gleiche Problem mit dem metro-widgets:(.
                                Die plump-widgets sind bei mir auch nicht sichtbar.
                                Andy
                                  Ich schätze, das kann nur Bluefox. Und der ist gerade noch im Urlaub.
                                    @AndyUM61:
                                    Andy `
                                    Obwohl ich noch nicht ganz da bin 8-) . Sollte es jetzt gehen.
                                      Hast du dich wenigstens gut erholt?
                                      Gesendet von meinem Cynus T7 mit Tapatalk
                                        @Homoran:
                                        Gesendet von meinem Cynus T7 mit Tapatalk `
                                        Ja 8-) :lol: :geek:
                                          jetzt kommen zwar nicht mehr die Fehlermeldungen, und er scheint korrekt zu installieren,
                                          jedoch habe ich noch immer weder metro- noch plump-Widgets zur Auswahl im vis:(.
                                          Oder sind die irgendwo versteckt?
                                          Gruß Andy
                                          (ioBroker unter Windows 8.1)
                                            hast du das vis selbst nach der Installation der widgets neu gestartet?
                                            3057
