    4. Upgrade io.broker admin von 2.0.7 auf 2.0.9 schlug fehl
      MarcKo1th last edited by
      Hallo Zusammen !
      Bei meinem heutigen Upgrade des ioboker.admin von Version 2.0.7 auf 2.0.9 blieb die Software hängen.
      Habe dann über putty folgendes eingegeben:
      sudo pgrep -f '^io.*' |xargs kill -9
      cd /opt/iobroker
      sudo npm cache clean
      sudo npm install iobroker.js-controller
      sudo npm install iobroker.admin
      sudo chmod 777 * -R
      iobroker l i
      iobroker start
      hier das Ergebnis:
      npm ERR! Linux 4.4.38-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller"
      npm ERR! node v4.8.0
      npm ERR! npm v2.15.11
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller/node_modules/jszip/node_modules/core-js/client
      npm ERR! code ENOTEMPTY
      npm ERR! errno -39
      npm ERR! syscall rmdir
      npm ERR! ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jszip/node_modules/core-js/client'
      npm ERR!
      npm ERR! If you need help, you may report this error at:
      npm ERR! <https://github.com/npm/npm/issues>
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jszip/node_modules/core-js/client'
      npm ERR! error rolling back at Error (native)
      npm ERR! error rolling back { [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jszip/node_modules/core-js/client']
      npm ERR! error rolling back errno: -39,
      npm ERR! error rolling back code: 'ENOTEMPTY',
      npm ERR! error rolling back syscall: 'rmdir',
      npm ERR! error rolling back path: '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jszip/node_modules/core-js/client' }
      npm ERR! Please include the following file with any support request:
      npm ERR! /opt/iobroker/npm-debug.log
      pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.admin
      npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.ical/node_modules/request/node_modules/http-signature/node_modules/jsprim requires assert-plus@'1.0.0' but will load
      npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.ical/node_modules/request/node_modules/http-signature/node_modules/assert-plus,
      npm WARN unmet dependency which is version 0.2.0
      iobroker.admin@2.0.9 node_modules/iobroker.admin
      ├── connect-flash@0.1.1
      ├── xtend@4.0.1
      ├── passport.socketio@3.7.0
      ├── cookie-parser@1.4.3 (cookie-signature@1.0.6, cookie@0.3.1)
      ├── passport-local@1.0.0 (passport-strategy@1.0.0)
      ├── passport@0.3.2 (passport-strategy@1.0.0, pause@0.0.1)
      ├── express-session@1.15.6 (utils-merge@1.0.1, on-headers@1.0.1, cookie-signature@1.0.6, cookie@0.3.1, parseurl@1.3.2, depd@1.1.2, crc@3.4.4, uid-safe@2.1.5, debug@2.6.9)
      ├── body-parser@1.18.2 (content-type@1.0.4, bytes@3.0.0, depd@1.1.2, qs@6.5.1, on-finished@2.3.0, raw-body@2.3.2, http-errors@1.6.2, debug@2.6.9, iconv-lite@0.4.19, type-is@1.6.15)
      ├── express@4.16.2 (cookie-signature@1.0.6, utils-merge@1.0.1, content-type@1.0.4, cookie@0.3.1, parseurl@1.3.2, escape-html@1.0.3, array-flatten@1.1.1, setprototypeof@1.1.0, encodeurl@1.0.2, merge-descriptors@1.0.1, methods@1.1.2, fresh@0.5.2, content-disposition@0.5.2, etag@1.8.1, range-parser@1.2.0, path-to-regexp@0.1.7, vary@1.1.2, serve-static@1.13.1, statuses@1.3.1, safe-buffer@5.1.1, depd@1.1.2, on-finished@2.3.0, qs@6.5.1, finalhandler@1.1.0, debug@2.6.9, proxy-addr@2.0.2, type-is@1.6.15, accepts@1.3.4, send@0.16.1)
      ├── socket.io@1.7.4 (object-assign@4.1.0, socket.io-adapter@0.5.0, has-binary@0.1.7, debug@2.3.3, socket.io-parser@2.3.1, engine.io@1.8.5, socket.io-client@1.7.4)
      ├── express-fileupload@0.1.4 (streamifier@0.1.1, busboy@0.2.14, fs-extra@0.22.1)
      └── request@2.83.0 (aws-sign2@0.7.0, oauth-sign@0.8.2, tunnel-agent@0.6.0, forever-agent@0.6.1, is-typedarray@1.0.0, caseless@0.12.0, safe-buffer@5.1.1, stringstream@0.0.5, aws4@1.6.0, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.1, performance-now@2.1.0, qs@6.5.1, uuid@3.2.1, combined-stream@1.0.5, mime-types@2.1.17, tough-cookie@2.3.3, form-data@2.3.1, hawk@6.0.2, http-signature@1.2.0, har-validator@5.0.3)
      pi@raspberrypi:/opt/iobroker $ sudo chmod 777 * -R
      pi@raspberrypi:/opt/iobroker $ iobroker l i
      module.js:327
      throw err;
      at Function.Module._resolveFilename (module.js:325:15)
      at Function.Module._load (module.js:276:25)
      at Function.Module.runMain (module.js:441:10)
      at startup (node.js:140:18)
      at node.js:1043:3
      pi@raspberrypi:/opt/iobroker $ iobroker start
      module.js:327
      throw err;
      at node.js:1043:3
      wenn ich jetzt folgendes eingebe:
      cd /opt/iobroker
      sudo chmod 777 * -R
      sudo npm install iobroker.js-controller –production
      erscheint:
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller" "–production"
      npm ERR! errno -39
      npm ERR!
      hat jemand für mich eine Idee ?
      (hoffentlich muss ich nicht iobroker komplett neu aufsetzen. weiss nämlich nicht mehr wie es geht…)
      Danke und Gruß
      Marcus
      • wendy2702
        wendy2702 last edited by
        Was bedeutet denn das: > blieb die Software hängen ?
        Und wieso killst du alle iobroker Prozesse bloß weil sich ein Adapter deiner Meinung nach nicht updated?
        Welche HW benutzt du? Je nach HW kann so ein Update schonmal ein wenig dauern. Wie hast du denn fest gestellt das die „Software hängen geblieben“ ist?
        Wenn du noch nicht viel konfiguriert hattest und auf deinem System nur iobroker läuft/lief… würde ich es schnell neu installieren.
        PS: Bitte beim nächsten mal logfile in Spoiler und Code tags setzen
        81.0k
