    4. Mal wieder "Send this info to developer"
      DeepCore last edited by
      Tja, hab mal wieder ein "Send this info to developer"… Hab einen HmIP-SPI Präsenzmelder an die neueste RaspberryMatic Version angelernt, und dann hm-rega und hm-rpc neu gestartet
      hm-rpc.2	2018-01-27 22:01:43.007	warn	Send this info to developer: {'type':'meta','meta':{'adapter':'hm-rpc','type':'paramsetDescription'},'common':{},'native':{'PRESENCE_DETECTION_STATE':{'MIN':false,'OPERATIONS':5,'MAX':true,'FLAGS':1,'ID':'PRESENCE_DETECTION_STATE','TYPE':'BOOL','DEFAULT':false,'CONTROL':'MOTIONDETECTOR_TRANSCEIVER.MOTION_DETECTION_STATE'},'ILLUMINATION':{'MIN':0,'OPERATIONS':5,'MAX':163830,'FLAGS':1,'ID':'ILLUMINATION','TYPE':'FLOAT','DEFAULT':0,'CONTROL':'MOTIONDETECTOR_TRANSCEIVER.ILLUMINATION'},'RESET_PRESENCE':{'MIN':false,'OPERATIONS':2,'MAX':true,'FLAGS':1,'ID':'RESET_PRESENCE','TYPE':'ACTION','DEFAULT':false,'CONTROL':'MOTIONDETECTOR_TRANSCEIVER.RESET_MOTION'},'CURRENT_ILLUMINATION':{'MIN':0,'OPERATIONS':5,'MAX':163830,'FLAGS':1,'ID':'CURRENT_ILLUMINATION','TYPE':'FLOAT','DEFAULT':0},'PRESENCE_DETECTION_ACTIVE':{'MIN':false,'OPERATIONS':7,'MAX':true,'FLAGS':1,'ID':'PRESENCE_DETECTION_ACTIVE','TYPE':'BOOL','DEFAULT':true,'CONTROL':'MOTIONDETECTOR_TRANSCEIVER.MOTION_DETECTION_ACTIVE'}}}
      hm-rpc.2	2018-01-27 22:01:43.003	warn	Send this info to developer: _id: 'hm-rpc.meta.VALUES.HmIP-SPI.PRESENCEDETECTOR_TRANSCEIVER.2'
      hm-rpc.2	2018-01-27 22:01:42.915	warn	Send this info to developer: {'type':'meta','meta':{'adapter':'hm-rpc','type':'paramsetDescription'},'common':{},'native':{'SABOTAGE':{'MIN':false,'OPERATIONS':5,'MAX':true,'FLAGS':9,'ID':'SABOTAGE','TYPE':'BOOL','DEFAULT':false},'CONFIG_PENDING':{'MIN':false,'OPERATIONS':5,'MAX':true,'FLAGS':9,'ID':'CONFIG_PENDING','TYPE':'BOOL','DEFAULT':false},'DUTY_CYCLE':{'MIN':false,'OPERATIONS':5,'MAX':true,'FLAGS':1,'ID':'DUTY_CYCLE','TYPE':'BOOL','DEFAULT':false},'LOW_BAT':{'MIN':false,'OPERATIONS':5,'MAX':true,'FLAGS':9,'ID':'LOW_BAT','TYPE':'BOOL','DEFAULT':false},'UNREACH':{'MIN':false,'OPERATIONS':5,'MAX':true,'FLAGS':25,'ID':'UNREACH','TYPE':'BOOL','DEFAULT':false},'RSSI_DEVICE':{'MIN':-128,'OPERATIONS':5,'MAX':127,'FLAGS':1,'ID':'RSSI_DEVICE','TYPE':'INTEGER','DEFAULT':0},'OPERATING_VOLTAGE':{'MIN':0,'OPERATIONS':5,'MAX':25.2,'FLAGS':1,'ID':'OPERATING_VOLTAGE','TYPE':'FLOAT','DEFAULT':0},'RSSI_PEER':{'MIN':-128,'OPERATIONS':5,'MAX':127,'FLAGS':1,'ID':'RSSI_PEER','TYPE':'INTEGER','DEFAULT':0},'ERROR_CODE':{'MIN':0,'OPERATIONS':5,'MAX':255,'FLAGS':9,'ID':'ERROR_CODE','TYPE':'INTEGER','DEFAULT':0},'UPDATE_PENDING':{'MIN':false,'OPERATIONS':5,'MAX':true,'FLAGS':9,'ID':'UPDATE_PENDING','TYPE':'BOOL','DEFAULT':false}}}
      hm-rpc.2	2018-01-27 22:01:42.912	warn	Send this info to developer: _id: 'hm-rpc.meta.VALUES.HmIP-SPI.MAINTENANCE.2'
      RaspberryMatic Firmwareversion	2.31.25.20180120
      HmIP-SPI Firmwareversion     1.2.4
      ioBroker Adapter-Versionen
      admin       - 1.7.6
      hm-rpc      - 1.5.0
      hm-rega     - 1.6.6
      web         - 2.1.9
      vis         - 1.1.1
      tankerkoenig - 1.0.4
      vis-jqui-mfd - 1.0.9
      icons-material-png - 0.1.0
      javascript  - 3.5.1
      vis-timeandweather - 1.1.7
      icons-mfd-svg - 1.0.2
      icons-mfd-png - 1.0.2
      sayit       - 1.6.6
      vis-google-fonts - 0.1.0
      socketio    - 1.8.6
      scenes      - 1.0.1
      influxdb    - 1.4.5
      telegram    - 1.0.9
      sonos       - 1.6.2
      text2command - 1.1.6
      cloud       - 2.4.4
      dwd         - 2.2.1
      weatherunderground - 1.1.1
      vis-history - 0.2.7
      history     - 1.6.3
      flot        - 1.7.0
      email       - 1.0.2
      hmm         - 1.0.1
      81.0k
