    4. [gelöst] wie project json bearbeiten (wg der nicht löschbaren widgets) / zudem: views nicht exportierbar
      tempestas last edited by
      Hi, zwei Themen habe ich.
      Zum einen habe ich mehrfach gelesen, dass man die "unlöschbaren Widgets" nur mittels Bearbeiten der jeweiligen Projekt JSON wegbekommt (?). Nur: wie geht das?
      Thema zwei: ich kann in meinem Projekt einige Views nicht exportieren, weiß aber nicht warum. Der Inspektor sagt das hier:
      moment-with-locales.min.js:28 Deprecation warning: moment.lang is deprecated. Use moment.locale instead.
      Arguments: de
      Error
      at Function.lang (http://192.168.2.220:8082/vis/lib/js/moment-with-locales.min.js:28:3346)
      at http://192.168.2.220:8082/vis/js/vis.js:3010:32
      at Socket. <anonymous>(http://192.168.2.220:8082/vis/js/conn.js:1223:17)
      at Socket.onack (http://192.168.2.220:8082/lib/js/socket.io.js:5225:9)
      at Socket.onpacket (http://192.168.2.220:8082/lib/js/socket.io.js:5149:12)
      at Manager. <anonymous>(http://192.168.2.220:8082/lib/js/socket.io.js:5522:15)
      at Manager.Emitter.emit (http://192.168.2.220:8082/lib/js/socket.io.js:5657:20)
      at Manager.ondecoded (http://192.168.2.220:8082/lib/js/socket.io.js:4668:8)
      at Decoder. <anonymous>(http://192.168.2.220:8082/lib/js/socket.io.js:5522:15)
      at Decoder.Emitter.emit (http://192.168.2.220:8082/lib/js/socket.io.js:2556:20)
      k @ moment-with-locales.min.js:28
      translate.js:20 "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"},
      7translate.js:20 "ctrl - Bool": {"en": "ctrl - Bool", "de": "ctrl - Bool", "ru": "ctrl - Bool"},
      2translate.js:20 "helper": {"en": "helper", "de": "helper", "ru": "helper"},
      hqwidgets.js:899 Version vis-hqwidgets: 1.1.1
      dimmer.png Failed to load resource: the server responded with a status of 404 (Not Found)
      2:8082/vis/edit.html?home#03_KLIMA:1 Uncaught SyntaxError: Invalid or unexpected token
      at eval (<anonymous>)
      at http://192.168.2.220:8082/lib/js/jquery-1.11.2.min.js:2:2622
      at Function.globalEval (http://192.168.2.220:8082/lib/js/jquery-1.11.2.min.js:2:2633)
      at m.fn.init.domManip (http://192.168.2.220:8082/lib/js/jquery-1.11.2.min.js:3:23107)
      at m.fn.init.t.fn.domManip (http://192.168.2.220:8082/vis/lib/js/can.custom.min.js:28:2469)
      at m.fn.init.append (http://192.168.2.220:8082/lib/js/jquery-1.11.2.min.js:3:20620)
      at m.fn.init. <anonymous>(http://192.168.2.220:8082/lib/js/jquery-1.11.2.min.js:3:22151)
      at m.access (http://192.168.2.220:8082/lib/js/jquery-1.11.2.min.js:3:3399)
      at m.fn.init.html (http://192.168.2.220:8082/lib/js/jquery-1.11.2.min.js:3:21736)
      at m.fn.init.window.jQuery.fn.(anonymous function) [as html] (http://192.168.2.220:8082/vis/widgets/hqwidgets/js/odometer.min.js:2:1916)</anonymous></anonymous></anonymous></anonymous></anonymous>
      • wendy2702
        wendy2702 last edited by
        Welche VIS Version hast du?
        Ich hatte das unter Linux mit VIS 1.1.1, nach downgrade auf 1.0.4 ging es wieder.
          1.1.1
          wie gesagt, der Widget Bug ist mir ja bekannt, die Lösung in der Theorie auch.. nur die Praxis… :oops:
          • wendy2702
            OK.
            Irgendwo hatte irgendwer beschrieben wo was gelöscht werden muss im File…
            Aber wo nur... :shock:
              ich krieg es noch zusammen so gerade eben :lol:
              widget zum löschen merken (am besten die ID oder den Namen)
              iobroker stopen
              Sicherung anlegen ( der Datei zumindest)
              unter \opt\iobroker\iobroker-data\files\vis.0\
              stehen die Projekte
              im einzelnen Projektt ist eine vis-views.json diese editieren
              den gesamten Knoten des Widget löschen
              speichern
              iobroker starten
              • htrecksler
                @arteck:
                speichern
                iobroker starten `
                … und ggf. ist ganz am Ende der Datei das betroffene Widget als "aktives Widget" eingetragen.
                in dem Fall muss dort ebenfalls ein anderes Widget eingetragen werden.
                Edit: Ach ja, ich habe noch den Browserverlauf gelöscht. Ich weiß nicht ob es erforderlich ist, aber kann ja nicht schaden.
                  ` > im einzelnen Projektt ist eine vis-views.json diese editieren
                  den gesamten Knoten des Widget löschen `
                  Dummy hier: und das geht wie? Kann man das per Notepad++ öffnen oder so?
                    @tempestas:
                    Dummy hier: und das geht wie? Kann man das per Notepad++ öffnen oder so? `
                    jaha
                      Top, danke!
                      81.0k
