    4. Metro Tile Value List Parameter
      Arminhh last edited by
      moin moin,
      ist es möglich beim diesem Widget anstelle der Parameter wie in Dynamische Linke beschrieben in den Feldern Beschriftung [0]…. [7] den Inhalt einer Variable zu schreiben? Anbei ein Versuch von mir?
      Die Variable heißt node-red.0.OwntracksMHstandort mit dem Inhalt z.B zuhause, Büro oder sonstwas.
      In das Feld Beschriftung [0] habe ich {node-red.0.OwntracksMHstandort.zuhause} geschrieben.
      ObjektID ist node-red.0.OwntracksMHstandort
      mfg
      Arminhh
        Das sollte gehen.
          leider nicht! Im Viewmodus nur eine weiße Fläche!
          mfg
          Arminhh
            Habe extra gecheckt. Das geht. Was für ein Wert hat Object ID und Value von Object ID?
              die Objekt ID hat node-red.0.OwntracksMHstandort
              Beschriftung 0 {node-red.0.OwntracksMHstandort.zuhause}
              Beschriftung 1 {node-red.0.OwntracksMHstandort.Buero}
              hier der exportierte View
              [{"tpl":"tplMetroTileList8","data":{"oid":"node-red.0.OwntracksMHstandort","visibility-cond":"==","visibility-val":1,"label0":"{node-red.0.OwntracksMHstandort.zuhause}","label1":"{node-red.0.OwntracksMHstandort.Buero}","label2":"","label3":"","label4":"","label5":"","label6":"","label7":"","bg_class0":"bg-red","bg_class1":"bg-emerald","bg_class2":"bg-orange","bg_class3":"bg-cyan","bg_class4":"","bg_class5":"","bg_class6":"","bg_class7":"","icon_class0":"","icon_class1":"","icon_class2":"","icon_class3":"","icon_class4":"","icon_class5":"","icon_class6":"","icon_class7":"","icon_badge0":"","icon_badge1":"","icon_badge2":"","icon_badge3":"","icon_badge4":"","icon_badge5":"","icon_badge6":"","icon_badge7":"","badge_bg_class0":"","badge_bg_class1":"","badge_bg_class2":"","badge_bg_class3":"","badge_bg_class4":"","badge_bg_class5":"","badge_bg_class6":"","badge_bg_class7":"","brand_bg_class0":"","brand_bg_class1":"","brand_bg_class2":"","brand_bg_class3":"","brand_bg_class4":"","brand_bg_class5":"","brand_bg_class6":"","brand_bg_class7":"","icon0":"/icons-mfd-svg/status_away_1.svg","icon1":"/icons-mfd-svg/status_available.svg","icon2":"/icons-mfd-svg/status_away_1.svg","icon3":"/icons-mfd-svg/scene_office.svg","icon_width":"85","icon_height":"85","transform":true,"icon_top":"27","icon_left":"35","hover":"true"},"style":{"left":"697px","top":"207px","background-color":"","width":"100","height":"100","text-align":"center"},"widgetSet":"metro"}]
              Danke für die Hilfe!!!
                Und was für einen Wert hat node-red.0.OwntracksMHstandort?
                "0", "1", 0, 1, true,"true", false,"false"
                  @Bluefox:
                  Genau das war meine Frage! Die Werte sind zuhause, Buero etc.
                    :roll: Jetzt verstehe ich.
                    Nein, es ist nicht möglich. du muss Umweg über Skript machen:
                    createState('node-red.0.OwntracksMHstandortNumber',0, function () {
                         setNumber(getState('node-red.0.OwntracksMHstandort').val);
                    function setNumber(val) {
                        switch(val) {
                            case 'zuhause':
                                 setState('node-red.0.OwntracksMHstandortNumber', 0);
                                 break;
                            case 'Büro':
                                 setState('node-red.0.OwntracksMHstandortNumber', 1);
                                 break;
                    on('node-red.0.OwntracksMHstandort', function (obj) {
                        setNumber(obj.newState.val);
