    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер ioBroker Admin
    • E
      electric69 last edited by
      Обновление драйвера admin "зависает".
      Просто останавливается на моменте как на скриншоте и все…
      Содержание лог-файла:
      ! 2015-01-20 23:10:11.163 - ^[[32minfo^[[39m: host.bananapi Update repository "default" under "conf/sources-dist.json"
      ! 2015-01-20 23:10:26.907 - ^[[32minfo^[[39m: iobroker upgrade admin
      ! 2015-01-20 23:10:31.143 - ^[[32minfo^[[39m: iobroker npm install iobroker.admin –production [/opt/iobroker/lib]
      ! 2015-01-20 23:10:35.875 - ^[[32minfo^[[39m: iobroker npm
      ! 2015-01-20 23:10:35.886 - ^[[32minfo^[[39m: iobroker
      ! 2015-01-20 23:10:35.893 - ^[[32minfo^[[39m: iobroker WARN
      ! 2015-01-20 23:10:35.918 - ^[[32minfo^[[39m: iobroker package.json daemonize2@0.4.2 No repository field.
      ! 2015-01-20 23:11:50.537 - ^[[32minfo^[[39m: iobroker npm
      ! 2015-01-20 23:11:50.547 - ^[[32minfo^[[39m: iobroker
      ! 2015-01-20 23:11:50.562 - ^[[32minfo^[[39m: iobroker WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
      ! 2015-01-20 23:14:51.002 - ^[[32minfo^[[39m: iobroker npm install "/opt/iobroker/node_modules/iobroker.admin" –production --prefix "/opt/iobroker/node_modules/iobroker.admin"
      ! 2015-01-20 23:15:28.140 - ^[[32minfo^[[39m: iobroker got /opt/iobroker/node_modules/iobroker.admin/admin
      ! 2015-01-20 23:15:28.164 - ^[[32minfo^[[39m: iobroker upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      ! 2015-01-20 23:15:28.203 - ^[[32minfo^[[39m: host.bananapi object change system.adapter.admin.0
      ! 2015-01-20 23:15:28.222 - ^[[32minfo^[[39m: admin.0 terminating http server on port 8081
      ! 2015-01-20 23:15:28.208 - ^[[32minfo^[[39m: host.bananapi stopInstance system.adapter.admin.0
      ! 2015-01-20 23:15:28.299 - ^[[32minfo^[[39m: admin.0 terminating
      ! 2015-01-20 23:15:28.209 - ^[[32minfo^[[39m: host.bananapi stopInstance system.adapter.admin.0 killing pid 2256
      ! 2015-01-20 23:15:28.346 - ^[[32minfo^[[39m: iobroker upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      ! 2015-01-20 23:15:28.440 - ^[[32minfo^[[39m: host.bananapi instance system.adapter.admin.0 terminated with code 0 (OK)
      ! 2015-01-20 23:15:28.463 - ^[[32minfo^[[39m: iobroker Adapter "admin" updated
      ! 2015-01-20 23:15:28.693 - ^[[32minfo^[[39m: iobroker exit 0
      ! 2015-01-20 23:15:30.761 - ^[[32minfo^[[39m: host.bananapi instance system.adapter.admin.0 started with pid 5209[/spoiler]
        Необходимо обновится до 0.4.5. Я нашёл коварную ошибку….. Которую сам же встроил. 😞
        • I
          instalator last edited by
          Сменил в настройках порт, админка не загружается по новому порту, где хранятся настройки чтобы вернуть порт обратно?
          Нашел, поменял, не помогло. Выставил в Bind 0.0.0.0 - в итоге завелось
            @instalator:
            Нашел, поменял, не помогло. Выставил в Bind 0.0.0.0 - в итоге завелось Ну ты хоть EDIT или UPDATE пиши: > Сменил в настройках порт, админка не загружается по новому порту, где хранятся настройки чтобы вернуть порт обратно?
            UPD: Нашел, поменял, не помогло. Выставил в Bind 0.0.0.0 - в итоге завелось `
            А то получается как будто "тихо сам с собою я веду беседу 🙂
            • I
              Вроде как промелькивала версия 5.0. хотя сейчас показвает актуальную 4.8?
              • I
                Не первый раз наблюдаю подобную картину. Стоит обновить страничку и обновлений оказывается нету.
                • I
                  Как переменные добавить раскидать по комнатам?
                    На данный момент это возможно, но очень и очень неудобно.
                    По моему кто-то пишет улучшение. http://forum.iobroker.net/viewtopic.php?f=24&t=894
                    • I
                      обновил до 0.5.1 страница не открывается, бесконечно крутится шестеренка. vis открывается
                      • I
                        Поставил npm install ioBroker.admin поставилась версия 0.4.8…Обновил снова до 0.5.1 опять не грузится админка.
                        • I
                          Как всегда сам с собой пообщался. Вообщем нужно сначала обновить сервер а потом админ.)
                          • E
                            Может было уже, повторюсь, в адаптерах есть какой то "flot", иконки нет, в логе ошибки…
                            • I
                              @electric69:
                              Может было уже, повторюсь, в адаптерах есть какой то "flot", иконки нет, в логе ошибки… `
                              У меня нету. Хотя пробовал руками как то поставить. Это я так понял будет новый драйвер дня рисования графиков
                                Спасибо. Ошибка в /opt/iobroker/iobroker-data/node_modules/ioBroker.js-controller/conf/sources-dist.json
                                Вместо (строка 27)
                                  "flot": {
                                    "meta": "https://raw.githubusercontent.com/ruhr70/ioBroker.flot/master/io-package.json",
                                    "icon": "https://raw.githubusercontent.com/ruhr70/ioBroker.flot/master/admin/flot.png"
                                должно быть
                                  "flot": {
                                    "meta": "https://raw.githubusercontent.com/ioBroker/ioBroker.flot/master/io-package.json",
                                    "icon": "https://raw.githubusercontent.com/ioBroker/ioBroker.flot/master/admin/flot.png"
                                Можно поменять ручками или дождатся следующей версии (не скоро)
                                • I
                                  @Bluefox:
                                  Вместо (строка 27)
                                    "flot": {
                                  должно быть
                                    "flot": {
                                  Можно поменять ручками или дождатся следующей версии (не скоро) `
                                  Дак flot все таки работает уже? у меня его в списке вообще нету.
                                  • aurodionov
                                    aurodionov last edited by
                                    @instalator:
                                    Дак flot все таки работает уже? у меня его в списке вообще нету. `
                                    Ставится и даже можно открыть по ip:8082/flot/edit.html
                                    • I
                                      @aurodionov:
                                      @instalator:
                                      Дак flot все таки работает уже? у меня его в списке вообще нету. Ставится и даже можно открыть по ip:8082/flot/edit.html
                                      Поставил…. Выбрал период 14 дней комп завис наглухо... пришлось ребутить жестко по кнопке.
                                      • aurodionov
                                        l
                                        Это по божески, я два месяца выбрал ,вот прикурил так прикурил. неттоп на атоме час почти в дауне был.
                                        Думаю со временем починят .
                                        • I
                                          @aurodionov:
                                          l `
                                          Причем вешается не сервак а клиентская машина
                                          • aurodionov
                                            Не комп, браузер(пробовал ток под хромом), i7 не повесил, просто затупил
                                            89
                                            26326
