    4. Probleme bei Installation Logitech Harmony Hub
      Don71 last edited by
      Hallo Leute,
      ich bin neu hier und hoffe das mir jemand helfen kann.
      Bei der Installation des Harmony Hub bekomme ich jede menge Fehler angezeigt.
      Andere Adapter konnte ich alle installieren.
      Siehe unten.
      Danke vorab 😄
      $ ./iobroker add harmony
      npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
      npm
      WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.8.7","npm":"2.15.11"})
      npm WARN
      addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
      ! npm WARN
      addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN
      addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
      npm
      WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      npm WARN
      addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm
      WARN addRemoteGit
      at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN
      addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)npm
      WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }
      npm
      WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">
      npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefined
      ! npm
      ERR! Linux 4.4.0-116-generic
      npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.7
      ! npm ERR! npm v2.15.11npm ERR! code ENOGIT
      ! npm ERR! not found: gitnpm ERR!
      npm
      ERR! Failed using git.npm ERR! This is most likely not a problem with npm itself.
      npm ERR! Please check if you have git installed and in your PATH.
      ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
      ! host.SmartHomePC install adapter harmony
      npm
      npm WARN
      npm WARN
      ! npm WARN addRemoteGit
      at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
      npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
      npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      npm WARN
      addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: not found: git] code: 'ENOGIT' }
      ! npm
      ERR!
      npm
      undefined
      npm
      npm
      ERR! argv
      npm
      ERR! code ENOGIT
      npm ERR!
      ! npm ERR! Failed using git.npm ERR! This is most likely not a problem with npm itself.
      npm
      ERR!
      npm
      npm
      npm
      WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit
      npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
      npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
      ! npm
      npm
      npm
      npm ERR! node v4.8.7npm ERR! npm v2.15.11
      npm ERR!
      npm ERR!
      ERROR: host.SmartHomePC Cannot install harmony
      ERROR: process exited with code 13</https:></https:></https:>
      ****geändert: Code in Code-Tags und Spoiler; Homoran (Mod)****
      • wendy2702
        wendy2702 last edited by
        Hi und Willkommen im Forum,
        kannst du das Log bitte beim nächsten mal in Spoiler und Code Tags verpacken!
        Jetzt zum Problem:
        Deine NPM Version ist zu alt. Bitte updaten.
          @wendy2702:
          Deine NPM Version ist zu alt. Bitte updaten. `
          nicht nur 😉
          @Don71:
          Please check if you have git installed and in your PATH. `
          cd /opt/iobroker
          sudo apt-get install git
          • wendy2702
            Handy Display ohne Tapatalk ist definitiv zu klein um hier was zu machen 😄
            Rainer hat natürlich recht und ich das überlesen.
