    4. [gelöss] admin 3.3.1 adapter starten ständig neu
      stephan61 last edited by
      Habe heute admin 3.3.1 mit host 1.3.0 npm 5.7.1 und node v 6.13.1 upgedatet jetzt starten die adpter nacheinander immer wieder neu
      woran liegt das?
      host.linaro-alip
      2018-03-12 18:15:16.153
      error
      instance system.adapter.telegram.0 terminated with code 7 (Adapter already running)
      host.linaro-alip
      2018-03-12 18:15:16.152
      error
      Caught by controller[1]: 2018-03-12 18:15:16.108 - telegram.0 already running
      host.linaro-alip
      error
      Caught by controller[0]: See https://github.com/yagop/node-telegram-bot-api/issues/319\. at module.js:577:32
      host.linaro-alip
      error
      Caught by controller[0]: In the future, you will have to enable it yourself.
      host.linaro-alip
      error
      Caught by controller[0]: Mon, 12 Mar 2018 17:15:15 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
      host.linaro-alip
      2018-03-12 18:15:14.988
      info
      Restart adapter system.adapter.upnp.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.upnp.0 terminated with code 7 (Adapter already running)
      host.linaro-alip
      2018-03-12 18:15:14.987
      error
      Caught by controller[0]: 2018-03-12 18:15:14.925 - upnp.0 already running
      host.linaro-alip
      2018-03-12 18:15:14.646
      info
      instance system.adapter.unifi.0 started with pid 5219
      host.linaro-alip
      2018-03-12 18:15:12.842
      info
      Restart adapter system.adapter.systeminfo.0 because enabled
      host.linaro-alip
      2018-03-12 18:15:12.839
      error
      instance system.adapter.systeminfo.0 terminated with code 7 (Adapter already running)
      host.linaro-alip
      2018-03-12 18:15:12.834
      error
      Caught by controller[0]: 2018-03-12 18:15:12.738 - systeminfo.0 already running
      host.linaro-alip
      2018-03-12 18:15:11.125
      info
      Restart adapter system.adapter.hm-rega.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
      Caught
      2018-03-12 18:15:11.124
      error
      by controller[0]: 2018-03-12 18:15:11.040 - hm-rega.0 already running
      host.linaro-alip
      2018-03-12 18:15:10.684
      info
      Restart adapter system.adapter.sonoff.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.sonoff.0 terminated with code 7 (Adapter already running)
      Caught
      2018-03-12 18:15:10.683
      error
      by controller[0]: 2018-03-12 18:15:10.646 - sonoff.0 already running
      web.1
      2018-03-12 18:15:10.657
      info
      2018-03-12T17:15:10.657Z Connected system.user.admin
      host.linaro-alip
      2018-03-12 18:15:10.184
      info
      Restart adapter system.adapter.web.1 because enabled
      host.linaro-alip
      2018-03-12 18:15:10.183
      error
      instance system.adapter.web.1 terminated with code 7 (Adapter already running)
      Caught
      error
      by controller[0]: 2018-03-12 18:15:10.115 - web.1 already running
      host.linaro-alip
      2018-03-12 18:15:09.784
      info
      Restart adapter system.adapter.socketio.0 because enabled
      host.linaro-alip
      2018-03-12 18:15:09.779
      error
      instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
      host.linaro-alip
      2018-03-12 18:15:09.755
      info
      Restart adapter system.adapter.simple-api.0 because enabled
      host.linaro-alip
      2018-03-12 18:15:09.754
      error
      instance system.adapter.simple-api.0 terminated with code 7 (Adapter already running)
      Caught
      error
      by controller[0]: 2018-03-12 18:15:09.550 - simple-api.0 already running
      host.linaro-alip
      2018-03-12 18:15:09.718
      info
      Restart adapter system.adapter.hue.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.hue.0 terminated with code 7 (Adapter already running)
      Caught
      2018-03-12 18:15:09.717
      error
      by controller[0]: 2018-03-12 18:15:09.647 - hue.0 already running
      host.linaro-alip
      2018-03-12 18:15:09.664
      info
      instance system.adapter.systeminfo.0 started with pid 5177
      host.linaro-alip
      2018-03-12 18:15:09.571
      info
      instance system.adapter.hm-rpc.0 started with pid 5162
      host.linaro-alip
      2018-03-12 18:15:09.029
      info
      instance system.adapter.hm-rega.0 started with pid 5156
      host.linaro-alip
      2018-03-12 18:15:08.415
      info
      instance system.adapter.sonoff.0 started with pid 5150
      host.linaro-alip
      2018-03-12 18:15:08.163
      info
      Restart adapter system.adapter.history.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host.linaro-alip
      2018-03-12 18:15:08.099
      info
      Restart adapter system.adapter.node-red.0 because enabled
      host.linaro-alip
      2018-03-12 18:15:08.098
      error
      instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
      Caught
      error
      by controller[0]: 2018-03-12 18:15:08.018 - node-red.0 already running
      host.linaro-alip
      2018-03-12 18:15:08.058
      info
      instance system.adapter.daswetter.0 terminated with code 0 (OK)
      host.linaro-alip
      2018-03-12 18:15:08.027
      info
      Restart adapter system.adapter.text2command.0 because enabled
      host.linaro-alip
      2018-03-12 18:15:08.026
      error
      instance system.adapter.text2command.0 terminated with code 7 (Adapter already running)
      Caught
      error
      by controller[0]: 2018-03-12 18:15:07.890 - text2command.0 already running
      host.linaro-alip
      2018-03-12 18:15:07.930
      info
      Restart adapter system.adapter.sayit.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
      Caught
      2018-03-12 18:15:07.919
      error
      by controller[0]: 2018-03-12 18:15:07.849 - sayit.0 already running
      host.linaro-alip
      2018-03-12 18:15:07.270
      info
      Restart adapter system.adapter.paw.0 because enabled
      host.linaro-alip
      2018-03-12 18:15:07.259
      error
      instance system.adapter.paw.0 terminated with code 7 (Adapter already running)
      Caught
      2018-03-12 18:15:07.258
      error
      by controller[0]: 2018-03-12 18:15:07.178 - paw.0 already running
      host.linaro-alip
      2018-03-12 18:15:07.078
      info
      instance system.adapter.web.1 started with pid 5124
      host.linaro-alip
      2018-03-12 18:15:06.980
      info
      Restart adapter system.adapter.parser.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.parser.0 terminated with code 7 (Adapter already running)
      Caught
      2018-03-12 18:15:06.954
      error
      by controller[0]: 2018-03-12 18:15:06.869 - parser.0 already running
      host.linaro-alip
      2018-03-12 18:15:05.569
      info
      instance system.adapter.simple-api.0 started with pid 5114
      host.linaro-alip
      2018-03-12 18:15:05.529
      info
      instance system.adapter.socketio.0 started with pid 5108
      host.linaro-alip
      2018-03-12 18:15:05.409
      info
      instance system.adapter.hue.0 started with pid 5102
      host.linaro-alip
      2018-03-12 18:15:04.898
      info
      instance system.adapter.history.0 started with pid 5096
      javascript.0
      2018-03-12 18:15:04.772
      info
      script.js.common.Strom.umrechnung: 128419.212
      host.linaro-alip
      2018-03-12 18:15:04.740
      info
      instance system.adapter.text2command.0 started with pid 5085
      host.linaro-alip
      2018-03-12 18:15:04.700
      info
      instance system.adapter.node-red.0 started with pid 5084
      host.linaro-alip
      2018-03-12 18:15:04.478
      info
      Restart adapter system.adapter.broadlink2.0 because enabled
      host.linaro-alip
      2018-03-12 18:15:04.477
      error
      instance system.adapter.broadlink2.0 terminated with code 7 (Adapter already running)
      Caught
      error
      by controller[0]: 2018-03-12 18:15:04.318 - broadlink2.0 already running
      host.linaro-alip
      2018-03-12 18:15:04.240
      info
      instance system.adapter.sayit.0 started with pid 5074
      host.linaro-alip
      2018-03-12 18:15:04.124
      info
      Restart adapter system.adapter.ping.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.ping.0 terminated with code 7 (Adapter already running)
      Caught
      2018-03-12 18:15:04.123
      error
      by controller[0]: 2018-03-12 18:15:04.079 - ping.0 already running
      host.linaro-alip
      2018-03-12 18:15:03.758
      info
      instance system.adapter.parser.0 started with pid 5064
      host.linaro-alip
      2018-03-12 18:15:03.380
      info
      instance system.adapter.paw.0 started with pid 5056
      host.linaro-alip
      2018-03-12 18:15:02.568
      info
      instance system.adapter.broadlink2.0 started with pid 5018
      host.linaro-alip
      2018-03-12 18:15:02.407
      info
      instance system.adapter.ping.0 started with pid 5012
      daswetter.0
      2018-03-12 18:15:01.873
      info
      starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
      daswetter.0
      2018-03-12 18:15:01.794
      info
      States connected to redis: 0.0.0.0:6379
      javascript.0
      2018-03-12 18:15:00.577
      info
      script.js.common.Heizung.Waermebedarf: Ventil Küche 14 Ventil Bad 44 Ventil Wohnzimmer 13 Ventil Esszimmer 13 Ventilges 84
      host.linaro-alip
      2018-03-12 18:15:00.045
      info
      instance system.adapter.daswetter.0 started with pid 4979
      host.linaro-alip
      2018-03-12 18:14:58.647
      info
      Restart adapter system.adapter.javascript.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
      Caught
      2018-03-12 18:14:58.646
      error
      by controller[0]: 2018-03-12 18:14:58.608 - javascript.0 already running
      host.linaro-alip
      2018-03-12 18:14:55.635
      info
      instance system.adapter.javascript.0 started with pid 4962
      host.linaro-alip
      2018-03-12 18:14:49.946
      info
      Restart adapter system.adapter.scenes.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.scenes.0 terminated with code 7 (Adapter already running)
      Caught
      error
      by controller[0]: 2018-03-12 18:14:49.925 - scenes.0 already running
      host.linaro-alip
      2018-03-12 18:14:48.947
      info
      Restart adapter system.adapter.pushbullet.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.pushbullet.0 terminated with code 7 (Adapter already running)
      Caught
      error
      by controller[0]: 2018-03-12 18:14:48.918 - pushbullet.0 already running
      host.linaro-alip
      2018-03-12 18:14:48.888
      info
      Restart adapter system.adapter.owntracks.0 because enabled
      host.linaro-alip
      error
      instance system.adapter.owntracks.0 terminated with code 7 (Adapter already running)
      Caught
      2018-03-12 18:14:48.887
      error
      by controller[0]: 2018-03-12 18:14:48.858 - owntracks.0 already running
      host.linaro-alip
      2018-03-12 18:14:48.716
      info
      instance system.adapter.scenes.0 started with pid 4942
      web.1
      2018-03-12 18:14:48.710
      info
      2018-03-12T17:14:48.710Z Connected system.user.admin
      host.linaro-alip
      2018-03-12 18:14:47.981
      info
      Restart adapter system.adapter.web.0 because enabled
      gruss Stephan
      geändert: Code in Code-Tags; Homoran (Mod)
      mania25 created this issue in yagop/node-telegram-bot-api
      closed Error: cannot enable cancellation after promises are in use #319
      • AlCalzone
        Anscheinend wurden beim Update die Adapter nicht richtig beendet. Am einfachsten ist es wohl, wenn du die Kiste mal komplett neu startest.
          Hätte ich auch dran denken können
          Gruß Stephan
