    4. Was bedeuten diese Fehler im Log=
      audioconcept last edited by
      Hallo
      was bedeuten diese Fehler im Log?
      ioBroker.adminAdapterInstanzenObjekteZuständeEreignisseGruppenBenutzerAufzählungenHostsLognode-red.0Skripte
      System
      Admin
      Log	Log-Größe: 0.01 MB
      Refresh
      Copy
      Clear
      Clear on disk
      	Zeit		Nachricht
      x
      raspberrypi	2015-09-23 19:36:46	info	host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      raspberrypi	2015-09-23 19:36:46	error	host.raspberrypi instance system.adapter.admin.0 terminated with code 1 ()
      raspberrypi	2015-09-23 19:36:40	info	host.raspberrypi instance system.adapter.admin.0 started with pid 3125
      host-raspberrypi	2015-09-23 19:36:10	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:36:10	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:36:10	error	port 8081 already in use
      admin-0	2015-09-23 19:36:10	info	requesting all objects
      admin-0	2015-09-23 19:36:10	info	requesting all states
      admin-0	2015-09-23 19:36:10	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:36:05	info	instance system.adapter.admin.0 started with pid 3119
      host-raspberrypi	2015-09-23 19:35:35	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:35:35	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:35:35	error	port 8081 already in use
      admin-0	2015-09-23 19:35:35	info	requesting all objects
      admin-0	2015-09-23 19:35:35	info	requesting all states
      admin-0	2015-09-23 19:35:34	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:35:30	info	instance system.adapter.admin.0 started with pid 3109
      host-raspberrypi	2015-09-23 19:35:00	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:35:00	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:34:59	error	port 8081 already in use
      admin-0	2015-09-23 19:34:59	info	requesting all objects
      admin-0	2015-09-23 19:34:59	info	requesting all states
      admin-0	2015-09-23 19:34:59	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:34:54	info	instance system.adapter.admin.0 started with pid 3103
      host-raspberrypi	2015-09-23 19:34:24	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:34:24	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:34:24	error	port 8081 already in use
      admin-0	2015-09-23 19:34:24	info	requesting all objects
      admin-0	2015-09-23 19:34:24	info	requesting all states
      admin-0	2015-09-23 19:34:24	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:34:18	info	instance system.adapter.admin.0 started with pid 3093
      host-raspberrypi	2015-09-23 19:33:48	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:33:48	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:33:48	error	port 8081 already in use
      admin-0	2015-09-23 19:33:48	info	requesting all objects
      admin-0	2015-09-23 19:33:48	info	requesting all states
      admin-0	2015-09-23 19:33:48	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:33:43	info	instance system.adapter.admin.0 started with pid 3082
      host-raspberrypi	2015-09-23 19:33:13	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:33:13	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:33:13	error	port 8081 already in use
      admin-0	2015-09-23 19:33:12	info	requesting all objects
      admin-0	2015-09-23 19:33:12	info	requesting all states
      admin-0	2015-09-23 19:33:12	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:33:08	info	instance system.adapter.admin.0 started with pid 3076
      host-raspberrypi	2015-09-23 19:32:38	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:32:38	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:32:37	error	port 8081 already in use
      admin-0	2015-09-23 19:32:37	info	requesting all objects
      admin-0	2015-09-23 19:32:37	info	requesting all states
      admin-0	2015-09-23 19:32:37	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:32:32	info	instance system.adapter.admin.0 started with pid 3065
      host-raspberrypi	2015-09-23 19:32:02	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:32:02	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:32:02	error	port 8081 already in use
      admin-0	2015-09-23 19:32:02	info	requesting all objects
      admin-0	2015-09-23 19:32:02	info	requesting all states
      admin-0	2015-09-23 19:32:02	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:31:57	info	instance system.adapter.admin.0 started with pid 3059
      host-raspberrypi	2015-09-23 19:31:27	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:31:27	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:31:27	error	port 8081 already in use
      admin-0	2015-09-23 19:31:27	info	requesting all objects
      admin-0	2015-09-23 19:31:27	info	requesting all states
      admin-0	2015-09-23 19:31:26	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:31:21	info	instance system.adapter.admin.0 started with pid 3049
      host-raspberrypi	2015-09-23 19:30:51	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:30:51	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:30:51	error	port 8081 already in use
      admin-0	2015-09-23 19:30:50	info	requesting all objects
      admin-0	2015-09-23 19:30:50	info	requesting all states
      admin-0	2015-09-23 19:30:50	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:30:45	info	instance system.adapter.admin.0 started with pid 3039
      host-raspberrypi	2015-09-23 19:30:15	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:30:15	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:30:15	error	port 8081 already in use
      admin-0	2015-09-23 19:30:15	info	requesting all objects
      admin-0	2015-09-23 19:30:15	info	requesting all states
      admin-0	2015-09-23 19:30:15	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:30:11	info	instance system.adapter.ical.1 terminated with code 0 (OK)
      host-raspberrypi	2015-09-23 19:30:10	info	instance system.adapter.ical.0 terminated with code 0 (OK)
      host-raspberrypi	2015-09-23 19:30:10	info	instance system.adapter.admin.0 started with pid 3033
      ical-1	2015-09-23 19:30:05	info	processing URL: Dorotka http://www.dorotka.net/kalenderdatei/defaultcalendar.ics
      ical-0	2015-09-23 19:30:05	info	processing URL: Mülltermine http://www.dorotka.net/kalenderdatei/mülltermine.ics
      ical-0	2015-09-23 19:30:04	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
      ical-1	2015-09-23 19:30:04	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
      host-raspberrypi	2015-09-23 19:30:00	info	instance system.adapter.ical.0 started with pid 3018
      host-raspberrypi	2015-09-23 19:30:00	info	instance system.adapter.ical.1 started with pid 3017
      host-raspberrypi	2015-09-23 19:29:40	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:29:40	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:29:40	error	port 8081 already in use
      admin-0	2015-09-23 19:29:40	info	requesting all objects
      admin-0	2015-09-23 19:29:40	info	requesting all states
      admin-0	2015-09-23 19:29:40	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:29:35	info	instance system.adapter.admin.0 started with pid 3007
      host-raspberrypi	2015-09-23 19:29:05	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:29:05	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:29:04	error	port 8081 already in use
      admin-0	2015-09-23 19:29:04	info	requesting all objects
      admin-0	2015-09-23 19:29:04	info	requesting all states
      admin-0	2015-09-23 19:29:04	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:28:59	info	instance system.adapter.admin.0 started with pid 3001
      host-raspberrypi	2015-09-23 19:28:29	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:28:29	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:28:29	error	port 8081 already in use
      admin-0	2015-09-23 19:28:29	info	requesting all objects
      admin-0	2015-09-23 19:28:29	info	requesting all states
      admin-0	2015-09-23 19:28:29	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:28:24	info	instance system.adapter.admin.0 started with pid 2992
      host-raspberrypi	2015-09-23 19:27:54	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:27:54	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:27:54	error	port 8081 already in use
      admin-0	2015-09-23 19:27:53	info	requesting all objects
      admin-0	2015-09-23 19:27:53	info	requesting all states
      admin-0	2015-09-23 19:27:53	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:27:48	info	instance system.adapter.admin.0 started with pid 2981
      host-raspberrypi	2015-09-23 19:27:18	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:27:18	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:27:18	error	port 8081 already in use
      admin-0	2015-09-23 19:27:18	info	requesting all objects
      admin-0	2015-09-23 19:27:18	info	requesting all states
      admin-0	2015-09-23 19:27:17	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:27:13	info	instance system.adapter.admin.0 started with pid 2972
      host-raspberrypi	2015-09-23 19:26:43	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:26:43	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:26:43	error	port 8081 already in use
      admin-0	2015-09-23 19:26:42	info	requesting all objects
      admin-0	2015-09-23 19:26:42	info	requesting all states
      admin-0	2015-09-23 19:26:42	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:26:37	info	instance system.adapter.admin.0 started with pid 2962
      host-raspberrypi	2015-09-23 19:26:07	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:26:07	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:26:07	error	port 8081 already in use
      admin-0	2015-09-23 19:26:07	info	requesting all objects
      admin-0	2015-09-23 19:26:07	info	requesting all states
      admin-0	2015-09-23 19:26:07	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:26:02	info	instance system.adapter.admin.0 started with pid 2956
      host-raspberrypi	2015-09-23 19:25:32	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:25:32	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:25:32	error	port 8081 already in use
      admin-0	2015-09-23 19:25:31	info	requesting all objects
      admin-0	2015-09-23 19:25:31	info	requesting all states
      admin-0	2015-09-23 19:25:31	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-09-23 19:25:26	info	instance system.adapter.admin.0 started with pid 2947
      host-raspberrypi	2015-09-23 19:24:56	info	Restart adapter system.adapter.admin.0 because enabled
      host-raspberrypi	2015-09-23 19:24:56	error	instance system.adapter.admin.0 terminated with code 1 ()
      admin-0	2015-09-23 19:24:56	error	port 8081 already in use
      admin-0	2015-09-23 19:24:56	info	requesting all objects
      admin-0	2015-09-23 19:24:56	info	requesting all states
      admin-0	2015-09-23 19:24:56	info	starting. Version 0.5.11 in /opt/iobroker/node_modules/iobroker.admin
        tesso last edited by
        Da läuft noch ein Prozess der Port 8081 schon belegt.
        Versuche````
        cd /opt/iobroker
        ./iobroker stop
        ps -A | grep io
        Dann sollte ein oder mehrere Prozesse mit io auftauchen. Diese dann mit kill Prozess-ID löschen oder den raspy neu starten.
          Hi
          hab ich ausgeführt und dann neu gestartet.
          Jetzt steht im Log:
          Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
          raspberrypi	2015-09-24 08:23:59	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi	2015-09-24 08:23:59	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
          raspberrypi	2015-09-24 08:23:52	info	host.raspberrypi instance system.adapter.admin.1 started with pid 2971
          raspberrypi	2015-09-24 08:23:22	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi	2015-09-24 08:23:22	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
          raspberrypi	2015-09-24 08:23:15	info	host.raspberrypi instance system.adapter.admin.1 started with pid 2962
          raspberrypi	2015-09-24 08:22:45	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi	2015-09-24 08:22:45	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
          raspberrypi	2015-09-24 08:22:38	info	host.raspberrypi instance system.adapter.admin.1 started with pid 2956
          raspberrypi	2015-09-24 08:22:08	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi	2015-09-24 08:22:08	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
          raspberrypi	2015-09-24 08:21:57	info	host.raspberrypi instance system.adapter.admin.1 started with pid 2947
          raspberrypi	2015-09-24 08:21:27	info	host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi	2015-09-24 08:21:27	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
          example.1	2015-09-24 08:21:22	info	example.1 stateChange example.1.testVariable {'val':null,'ack':true,'ts':1443075683,'from':'system.adapter.example.1','lc':1443075683}
          Dieses steht nach der Ausführung noch drin:
            Hi
            wenn ich jetzt mal einen Restart mache kommt dieses hier (aber Iobroker läuft trotzdem):
              Bitte als root starten!
                Ich hab es noch mal als admin gemacht und dann habe ich jetzt nur noch:
                ps -A | grep io
                2753 ? 00:00:13 io.hm-rega.0
                Im Log steht jetzt noch als Fehler:
                host-raspberrypi	2015-09-24 12:45:11	error	 instance system.adapter.admin.1 terminated with code 1 ()
                admin-1	2015-09-24 12:45:09	error	 port 8081 already in use
                admin-1	2015-09-24 12:45:02	error	 no connection to objects DB
                raspberrypi	2015-09-24 12:45:11	error	host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
                  @audioconcept:
                  Ich hab es noch mal als admin gemacht `
                  ich denke doch als root - oder?
                  Was ist sonst noch auf deinem Raspi drauf?
                  Wenn nur ioBroker, dann mach mal einen reboot des Raspi
                  Oder
                  Hast du bei der Konfiguration bei einem Adapter den Port auf 8081 umgestellt?
                  Wieso hast du 2x admin laufen?
                    Hi Homoran
                    sorry meinte als root.
                    Neustart des Pi hab ich immer gemacht.
                    Ich hab wirklich zwei Admin drauf. Hatte mich auch schon gefragt warum, dachte aber es muss so sein.
                    Admin 0 und Admin 1
                    Kann ich den Admin 1 einfach mal auf inaktiv setzen?
                    Hab es auf inaktiv gesetzt und neustart gemacht und mal sehen ob es dann besser ist.
                      Jepp
                      keine Fehlermeldungen mehr seit dem admin :1 auf inaktiv.
                      Kann ich den einfach löschen?
                      Vielen Dank.
                        Natürlich, sonst hätte ich nicht gefragt!
                        @audioconcept:
                        Hatte mich auch schon gefragt warum, `
                        Das ist mein Text!
                        @Homoran:
                        Wieso hast du 2x admin laufen? `
                        Wenn da keine Absicht hintersteckt - z.B. weil du dich aus den Systemgeschossen hast, weil der erste admin falsch konfiguriert war, kannst du den zweiten löschen.
                        Überprüfe aber bitte vorher die Konfig.
                          Hi
                          grins ja war dein Spruch 🙂
                          Ich bin mir nicht sicher was ich genau nachsehen soll in der Konfig. aber ich kann es auch nicht aktiviert so lassen.
                          Hab aber jetzt noch diese Meldungen bekommen:
                          cal-1	2015-09-24 15:31:54	info	 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
                          ical-0	2015-09-24 15:31:54	info	 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
                          ical-0	2015-09-24 15:31:44	error	 no connection to objects DB
                          ical-1	2015-09-24 15:31:44	error	 no connection to objects DB
                          host-raspberrypi	2015-09-24 15:30:00	info	 instance system.adapter.ical.0 started with pid 3500
                          host-raspberrypi	2015-09-24 15:30:00	info	 instance system.adapter.ical.1 started with pid 3499
                          hm-rega-0	2015-09-24 15:28:26	warn	 Pending request for more than 125000 ms
                          hm-rega-0	2015-09-24 15:28:18	warn	 Pending request for more than 100000 ms
                          hm-rega-0	2015-09-24 15:28:10	warn	 Pending request for more than 75000 ms
                          hm-rega-0	2015-09-24 15:28:01	warn	 Pending request for more than 50000 ms
                          hm-rega-0	2015-09-24 15:27:50	warn	 Pending request for more than 25000 ms
                          hm-rega-0	2015-09-24 15:26:56	warn	 Pending request for more than 125000 ms
                          hm-rega-0	2015-09-24 15:26:48	warn	 Pending request for more than 100000 ms
                          hm-rega-0	2015-09-24 15:26:40	warn	 Pending request for more than 75000 ms
                          hm-rega-0	2015-09-24 15:26:31	warn	 Pending request for more than 50000 ms
                          hm-rega-0	2015-09-24 15:26:20	warn	 Pending request for more than 25000 ms
                          fritzbox-0	2015-09-24 15:23:48	info	 data from 192.168.0.1: 24.09.15 15:23:48;DISCONNECT;0;0;
                          fritzbox-0	2015-09-24 15:23:25	info	 data from 192.168.0.1: 24.09.15 15:23:25;RING;0;xxxxxxxxx;7223772;ISDN;
                          fritzbox-0	2015-09-24 13:21:35	info	 adapter connected to fritzbox: 192.168.0.1
                          host-raspberrypi	2015-09-24 15:00:21	info	 instance system.adapter.ical.1 terminated with code 0 (OK)
                          host-raspberrypi	2015-09-24 15:00:21	info	 instance system.adapter.ical.0 terminated with code 0 (OK)
                            Ich hab mal die Telefonnummer aus deinem log ausge-ixt
                            @audioconcept:
                            Ich bin mir nicht sicher was ich genau nachsehen soll in der Konfig. `
                            Vergleiche admin-0 und admin-1
                            wenn die gleich sind kannst du admin-1 löschen.
                            @audioconcept:
                            aber ich kann es auch nicht aktiviert so lassen. `
                            Nein, kannst du nicht!
                            Da hat ioBroker probllem (gehabt) die rega auf der CCU zu erreichen.
                            Nicht dass die abgestürzt ist.
                              Hi ich bekomme es nicht gelöscht.Bleibt ewig dort hängen.
                              $ ./iobroker del admin.1
                              host.raspberrypi Counted 1 instances of admin.1
                              host.raspberrypi Counted 7 states "system.adapter.admin.1*" from states
                              Im Admin 0 steht die IP auf 0.0.0.0 da muss doch die vom Server rein? Oder?
                              Ich hab im Admin 0 dann die Serveradresse eingetragen. War das ein Fehler? Jetzt hab ich beim Aufruf immer dieses Zahnrad am laufen.
                              Was kann ich da machen?
                              VIS geht aber einwandfrei. Komme nur nicht ins Admin
                                Ja das war ein Fehler! Da MUSS 0.0.0.0 stehen.
                                Such mal im Forum, das muss stehen, wie man jetzt es halbwegs gerettet bekommt
                                Irgenwie mit iobroker add admin und einer portangabe.
                                Sonsthast du wieder das andere problem.
                                Bin nicht mehr am PC
                                Gesendet von meinem LIFETAB_S785X mit Tapatalk
                                  iobroker set admin.0 –ip 0.0.0.0
                                  war die Rettung. Jetzt geht es wieder.
                                  Jetzt muss ich nur noch Admin .1 gelöscht bekommen.
                                  1605
