    4. [Gelöst] nach Admin upgrade 3.3.4 keine Webseite mehr
    • wendy2702
      wendy2702 last edited by
      Folge Thema aus diesem Thread : viewtopic.php?f=22&t=12776&p=135902#p135679
      Admin update nach Anleitung versucht:
      cd /opt/iobroker
      npm i https://github.com/ioBroker/ioBroker.admin
      cd node_modules/iobroker.admin
      npm i gulp
      node_modules/.bin/gulp
      Der "gulp" Befehl ist hier schon der korrigierte, in den ersten logs steht noch der alte Befehl
      Admin installiert:
      root@openmediavault /opt/iobroker > npm i https://github.com/ioBroker/ioBroker.admin
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis-mywidgets/package.json'
      + iobroker.admin@3.3.4
      removed 175 packages and updated 1 package in 20.192s
      root@openmediavault /opt/iobroker > cd node_modules/iobroker.admin/
      root@openmediavault /opt/iobroker/node_modules/iobroker.admin > npm i gulp
      npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm notice created a lockfile as package-lock.json. You should commit this file.
      + gulp@3.9.1
      added 272 packages from 163 contributors in 5.886s
      Und jetzt nur noch das im Browser:
      This adapter cannot be installed directly from github.
      You must install it from npm.
      Write for that "npm install iobroker.admin" in according directory.
      Der admin.0 läuft allerdings:
      root@openmediavault ~ > ps -ef |grep io.admin
      root      9036  9024  1 11:58 ?        00:00:01 io.admin.0
      • AlCalzone
        Was ist mit Schritt 5? Also "gulp" ausführen?
        • wendy2702
          root@openmediavault /opt/iobroker/node_modules/iobroker.admin > gulp
          -bash: gulp: Kommando nicht gefunden.
          Sorry… war bei markieren scheinbar nicht dabei beim ersten mal.
          • AlCalzone
            @wendy2702:
            Kommando nicht gefunden. `
            Dann hat er wohl den letzten Befehl nicht ausgeführt. Klappt es mit
            • wendy2702
              Sorry,
              habe gerade downgrade auf 3.3.3 gemacht.
              Muss ich gleich nochmal versuchen.
              • wendy2702
                Kurzer test:
                root@openmediavault /opt/iobroker/node_modules/iobroker.admin > node_modules/.bin/gulp
                [13:09:15] No gulpfile found
                Sollten wir das Thema besser auftrennen?
                Hat ja nichts mit "NPM Error" zu tun und ist auch nicht "Gelöst".
                Kannst du das machen?
                  Habs getrennt, danke für den Link! ich war eben zu faul zum suchen
                  • AlCalzone
                    @wendy2702:
                    Öhh, auf Github sehe ich definitiv ein gulpfile.js im Hauptordner. Ist die Datei bei dir in /opt/iobroker/node_modules/iobroker.admin vorhanden?
                    Alternativ könntest du folgenden Befehl probieren, der sollte das gleiche tun:
                    npm run prepublish
                    • wendy2702
                      @AlCalzone:
                      npm run prepublish
                      Wofür kann/soll ich diesen Befehl nehmen?
                      • wendy2702
                        Also ich weiß nicht was oder wohin er mit :
                        Installiert:
                        root@openmediavault /opt/iobroker > ls -la node_modules/iobroker.admin/
                        insgesamt 168
                        drwxrwxrwx   6 root root  4096 Mär 22 13:19 .
                        drwxrwxrwx 784 root root 36864 Mär 22 14:49 ..
                        drwxrwxrwx   2 root root  4096 Mär 22 13:19 admin
                        -rw-rw-rw-   1 root root 15039 Mär 22 13:19 CHANGELOG_OLD.md
                        -rw-rw-rw-   1 root root  9425 Mär 22 13:19 io-package.json
                        drwxrwxrwx   2 root root  4096 Mär 22 13:19 lib
                        -rw-rw-rw-   1 root root  1120 Mär 22 13:19 LICENSE
                        -rw-rw-rw-   1 root root 12397 Mär 22 13:19 main.js
                        drwxrwxrwx 160 root root  4096 Mär 22 13:19 node_modules
                        -rw-rw-rw-   1 root root  2971 Mär 22 13:19 package.json
                        -rw-rw-rw-   1 root root 44898 Mär 22 13:19 package-lock.json
                        -rw-rw-rw-   1 root root  8576 Mär 22 13:19 README.md
                        drwxrwxrwx   8 root root  4096 Mär 22 13:19 www
                        removed 175 packages and updated 1 package in 19.825s
                        insgesamt 116
                        drwxr-xr-x   4 root root  4096 Mär 22 17:56 .
                        drwxrwxrwx 784 root root 36864 Mär 22 17:56 ..
                        drwxr-xr-x   2 root root  4096 Mär 22 17:56 admin
                        -rw-r--r--   1 root root 14519 Mär 22 17:56 CHANGELOG_OLD.md
                        -rw-r--r--   1 root root  9740 Mär 22 17:56 io-package.json
                        drwxr-xr-x   2 root root  4096 Mär 22 17:56 lib
                        -rw-r--r--   1 root root  1099 Mär 22 17:56 LICENSE
                        -rw-r--r--   1 root root 12397 Mär 22 17:56 main.js
                        -rw-r--r--   1 root root  2976 Mär 22 17:56 package.json
                        -rw-r--r--   1 root root  8421 Mär 22 17:56 README.md
                        Aber die Files aus dem Github Package die man erhält wenn man das ZIP lädt sind nicht zu sehen.
                        • AlCalzone
                          @wendy2702:
                          Wofür kann/soll ich diesen Befehl nehmen? `
                          Der wäre anstatt "gulp" oder "node_modules/.bin/gulp".
                          • wendy2702
                            OK.
                            Aber ohne die Files muss ich das garnicht weiter testen.
                            • AlCalzone
                              @wendy2702:
                              OK.
                              Aber ohne die Files muss ich das garnicht weiter testen. `
                              Probier mal als Installationsbefehl
                              npm i https://github.com/ioBroker/ioBroker.admin/tarball/master
                              also explizit auf den Tarball verweisen.
                              • wendy2702
                                Kann ich erst morgen.
                                Bin heute nicht mehr lokal am Rechner und remote über Ipad will ich das nicht probieren.
                                • wendy2702
                                  Bin ja gerne Versuchskaninchen 🙂
                                  root@openmediavault /opt/iobroker > npm i https://github.com/ioBroker/ioBroker.admin/tarball/master
                                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis-mywidgets/package                       .json'
                                  removed 175 packages and updated 1 package in 15.442s
                                  insgesamt 168
                                  drwxr-xr-x   7 root root  4096 Mär 23 09:51 .
                                  drwxrwxrwx 784 root root 36864 Mär 23 09:51 ..
                                  drwxr-xr-x   3 root root  4096 Mär 23 09:51 admin
                                  -rw-r--r--   1 root root   713 Mär 21 18:41 appveyor.yml
                                  -rw-r--r--   1 root root 14519 Mär 21 18:41 CHANGELOG_OLD.md
                                  -rw-r--r--   1 root root  1844 Mär 21 18:41 DEVELOPER.md
                                  drwxr-xr-x   6 root root  4096 Mär 23 09:51 docs
                                  -rw-r--r--   1 root root 23081 Mär 21 18:41 gulpfile.js
                                  -rw-r--r--   1 root root  9740 Mär 21 18:41 io-package.json
                                  drwxr-xr-x   2 root root  4096 Mär 23 09:51 lib
                                  -rw-r--r--   1 root root  1099 Mär 21 18:41 LICENSE
                                  -rw-r--r--   1 root root 12397 Mär 21 18:41 main.js
                                  -rw-r--r--   1 root root   128 Mär 21 18:41 .npmignore
                                  -rw-r--r--   1 root root  3083 Mär 23 09:51 package.json
                                  -rw-r--r--   1 root root  8421 Mär 21 18:41 README.md
                                  drwxr-xr-x  11 root root  4096 Mär 23 09:51 src
                                  drwxr-xr-x   3 root root  4096 Mär 23 09:51 test
                                  -rw-r--r--   1 root root   447 Mär 21 18:41 .travis.yml
                                  npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://med                       ium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                                  npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future v                       ersions of Node.js
                                  + gulp@3.9.1
                                  added 272 packages from 163 contributors in 5.581s
                                  module.js:478
                                      throw err;
                                  Error: Cannot find module 'gulp-less'
                                      at Function.Module._resolveFilename (module.js:476:15)
                                      at Function.Module._load (module.js:424:25)
                                      at Module.require (module.js:504:17)
                                      at require (internal/module.js:20:19)
                                      at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/gulpfile.js:3:21)
                                      at Module._compile (module.js:577:32)
                                      at Object.Module._extensions..js (module.js:586:10)
                                      at Module.load (module.js:494:32)
                                      at tryModuleLoad (module.js:453:12)
                                      at Function.Module._load (module.js:445:3)
                                  root@openmediavault /opt/iobroker/node_modules/iobroker.admin ></anonymous>
                                  Wenigstens sind die Dateien jetzt vorhanden.
                                  Aber "gulp" lässt sich nicht ausführen.
                                  Und wenn ich den Admin startet steht im Browser wieder das:
                                  • wendy2702
                                    Habe mal das "gulp-less" nach installiert.
                                    Dann vermisst er das nächste:
                                    module.js:478
                                        throw err;
                                    Error: Cannot find module 'gulp-sass'
                                        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/gulpfile.js:4:21)
                                    • wendy2702
                                      Mal alle fehlenden und nicht automatisch installierten Pakete Manuel hinzugefügt und dann "gulp" gestartet:
                                      [10:14:23] Using gulpfile /opt/iobroker/node_modules/iobroker.admin/gulpfile.js
                                      [10:14:23] Starting 'wwwLanguages2words'...
                                      [10:14:23] Finished 'wwwLanguages2words' after 55 ms
                                      [10:14:23] Starting 'adminLanguages2words'...
                                      [10:14:23] Finished 'adminLanguages2words' after 2.93 ms
                                      [10:14:23] Starting '1_words'...
                                      [10:14:23] Finished '1_words' after 18 μs
                                      [10:14:23] Starting 'iobCSS'...
                                      [10:14:23] Starting 'adminCSS'...
                                      [10:14:23] Starting 'appCSS'...
                                      [10:14:23] Finished 'appCSS' after 2.99 ms
                                      [10:14:23] Starting 'treeTableCSS'...
                                      [10:14:23] Starting 'configCSS'...
                                      [10:14:23] Finished 'configCSS' after 1.69 ms
                                      [10:14:23] Starting 'materializeCSS'...
                                      [10:14:23] Finished 'materializeCSS' after 1.65 ms
                                      [10:14:23] Starting 'vendorJS'...
                                      [10:14:23] Starting 'materializeJS'...
                                      [10:14:23] Starting 'appJS'...
                                      [10:14:23] Starting 'fancyTreeJS'...
                                      [10:14:23] Starting 'appHTML'...
                                      [10:14:23] Starting 'aceCopy'...
                                      [10:14:23] Starting 'colorpickerCopy'...
                                      [10:14:23] Starting 'colorpick.min'...
                                      [10:14:27] Finished 'colorpick.min' after 3.67 s
                                      [10:14:27] Starting 'appCopy'...
                                      [10:14:27] Finished 'aceCopy' after 3.68 s
                                      [10:14:27] Finished 'treeTableCSS' after 3.7 s
                                      [10:14:27] Finished 'fancyTreeJS' after 3.69 s
                                      [10:14:27] Finished 'iobCSS' after 3.83 s
                                      [10:14:27] Finished 'adminCSS' after 3.82 s
                                      [10:14:27] Starting '2_css'...
                                      [10:14:27] Finished '2_css' after 2.3 μs
                                      [10:14:27] Finished 'colorpickerCopy' after 4 s
                                      events.js:160
                                            throw er; // Unhandled 'error' event
                                      ReferenceError: Unknown plugin "transform-es2015-arrow-functions" specified in "base" at 0, attempted to resolve relative to "/opt/iobroker/node_modules/iobroker.admin/src/materialize-css/js"
                                          at /opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/options/option-manager.js:180:17
                                          at Array.map (native)
                                          at Function.normalisePlugins (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/options/option-manager.js:158:20)
                                          at OptionManager.mergeOptions (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/options/option-manager.js:234:36)
                                          at OptionManager.init (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/options/option-manager.js:368:12)
                                          at File.initOptions (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/index.js:212:65)
                                          at new File (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/index.js:135:24)
                                          at Pipeline.transform (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/pipeline.js:46:16)
                                          at DestroyableTransform._transform (/opt/iobroker/node_modules/iobroker.admin/node_modules/gulp-babel/index.js:36:22)
                                          at DestroyableTransform.Transform._read (/opt/iobroker/node_modules/iobroker.admin/node_modules/through2/node_modules/readable-stream/lib/_stream_transform.js:184:10)
                                          at DestroyableTransform.Transform._write (/opt/iobroker/node_modules/iobroker.admin/node_modules/through2/node_modules/readable-stream/lib/_stream_transform.js:172:83)
                                          at doWrite (/opt/iobroker/node_modules/iobroker.admin/node_modules/through2/node_modules/readable-stream/lib/_stream_writable.js:418:64)
                                      • AlCalzone
                                        @wendy2702:
                                        Mal alle fehlenden und nicht automatisch installierten Pakete Manuel hinzugefügt `
                                        Ahhh, das macht Sinn. "npm install paketname" installiert nur die dependencies, nicht die devDependencies, ganz vergessen.
                                        npm install
                                        im Ordner des Admin-Adapters sollte eigentlich alle devDependencies installieren. Das Transform-Plugin scheint er nämlich nicht installiert zu haben.
                                        • wendy2702
                                          @AlCalzone:
                                          npm install
                                          :oops: Hätte ich auch drauf kommen können aber wenn man davor sitzt …. wie war das mit dem Wald und den Bäumen
                                          root@openmediavault /opt/iobroker/node_modules/iobroker.admin > npm install
                                          npm WARN prepublish-on-install As of npm@5, `prepublish` scripts are deprecated.
                                          npm WARN prepublish-on-install Use `prepare` for build steps and `prepublishOnly` for upload-only.
                                          npm WARN prepublish-on-install See the deprecation note in `npm help scripts` for more information.
                                          npm WARN lifecycle iobroker.admin@3.3.4~prepublish: cannot run in wd %s %s (wd=%s) iobroker.admin@3.3.4 node node_modules/gulp/bin/gulp default /opt/iobroker/node_modules/iobroker.admin
                                          added 161 packages from 395 contributors in 7.49s
                                          [10:34:22] Using gulpfile /opt/iobroker/node_modules/iobroker.admin/gulpfile.js
                                          [10:34:22] Starting 'wwwLanguages2words'...
                                          [10:34:22] Finished 'wwwLanguages2words' after 70 ms
                                          [10:34:22] Starting 'adminLanguages2words'...
                                          [10:34:22] Finished 'adminLanguages2words' after 2.69 ms
                                          [10:34:22] Starting '1_words'...
                                          [10:34:22] Finished '1_words' after 21 μs
                                          [10:34:22] Starting 'iobCSS'...
                                          [10:34:22] Starting 'adminCSS'...
                                          [10:34:22] Starting 'appCSS'...
                                          [10:34:22] Finished 'appCSS' after 3.22 ms
                                          [10:34:22] Starting 'treeTableCSS'...
                                          [10:34:22] Starting 'configCSS'...
                                          [10:34:22] Finished 'configCSS' after 1.89 ms
                                          [10:34:22] Starting 'materializeCSS'...
                                          [10:34:22] Finished 'materializeCSS' after 1.75 ms
                                          [10:34:22] Starting 'vendorJS'...
                                          [10:34:22] Starting 'materializeJS'...
                                          [10:34:22] Starting 'appJS'...
                                          [10:34:22] Starting 'fancyTreeJS'...
                                          [10:34:22] Starting 'appHTML'...
                                          [10:34:22] Starting 'aceCopy'...
                                          [10:34:22] Starting 'colorpickerCopy'...
                                          [10:34:22] Starting 'colorpick.min'...
                                          [10:34:26] Finished 'colorpick.min' after 3.91 s
                                          [10:34:26] Starting 'appCopy'...
                                          [10:34:26] Finished 'fancyTreeJS' after 3.91 s
                                          [10:34:26] Finished 'aceCopy' after 3.92 s
                                          [10:34:26] Finished 'treeTableCSS' after 4.02 s
                                          [10:34:26] Finished 'iobCSS' after 4.08 s
                                          [10:34:26] Finished 'adminCSS' after 4.07 s
                                          [10:34:26] Starting '2_css'...
                                          [10:34:26] Finished '2_css' after 2.56 μs
                                          [10:34:26] Finished 'colorpickerCopy' after 4.25 s
                                          [10:34:50] Finished 'vendorJS' after 27 s
                                          [10:34:50] Finished 'materializeJS' after 28 s
                                          [10:34:50] Finished 'appHTML' after 27 s
                                          [10:34:56] Finished 'appJS' after 33 s
                                          [10:34:56] Starting '3_js'...
                                          [10:34:56] Finished '3_js' after 13 μs
                                          [10:34:56] Finished 'appCopy' after 30 s
                                          [10:34:56] Starting '4_static'...
                                          [10:34:56] Finished '4_static' after 10 μs
                                          [10:34:56] Starting 'default'...
                                          [10:34:56] Finished 'default' after 1.45 μs
                                          Admin Webseite erreichbar.
                                          • AlCalzone
                                            Super!
                                            Zur Vollständigkeit: folgendes hat bei mir funktioniert
                                            /opt/iobroker $ npm i https://github.com/ioBroker/ioBroker.admin/tarball/master
                                            /opt/iobroker $ cd node_modules/iobroker.admin
                                            /opt/iobroker/node_modules/iobroker.admin $ npm install
                                            /opt/iobroker/node_modules/iobroker.admin $ npm run prepublish
                                            81.1k
                                            5404
