    4. Node.js: Cannot find module
      Communicate last edited by
      seit gestern ist mein iobroker (inkl. vis) nur sporadisch erreichbar.
      Im Log wiederholt sich folgender Fehler ständig:
      host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
      Hat jemand ne Idee, warum das so spontan kommen kann und wie ich das beheben könnte?
      Dominic
        Kam das wirklich spontan, oder nach einem update?
        UND:
        @Communicate:
        host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module) `
        da müsste auch noch stehen welches modul
          es kam spontan und danach habe ich dann per iobroker upgrade alles aktualisiert.
          So sieht das Log aus:
          raspberrypi 2015-09-28 20:47:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:47:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:47:04 info host.raspberrypi instance system.adapter.admin.1 started with pid 9292
          raspberrypi 2015-09-28 20:46:34 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:46:34 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:46:29 info host.raspberrypi instance system.adapter.admin.1 started with pid 9291
          raspberrypi 2015-09-28 20:45:59 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:45:59 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:45:55 info host.raspberrypi instance system.adapter.admin.1 started with pid 9290
          raspberrypi 2015-09-28 20:45:25 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:45:25 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:45:19 info host.raspberrypi instance system.adapter.admin.1 started with pid 9289
          raspberrypi 2015-09-28 20:44:49 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:44:49 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:44:39 info host.raspberrypi instance system.adapter.admin.1 started with pid 9288
          raspberrypi 2015-09-28 20:44:09 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:44:09 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:44:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:44:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:44:01 info host.raspberrypi instance system.adapter.admin.1 started with pid 9287
          raspberrypi 2015-09-28 20:43:31 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:43:31 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:43:26 info host.raspberrypi instance system.adapter.admin.1 started with pid 9286
          raspberrypi 2015-09-28 20:42:56 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:42:56 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:42:46 info host.raspberrypi instance system.adapter.admin.1 started with pid 9285
          raspberrypi 2015-09-28 20:42:16 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:42:16 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:42:06 info host.raspberrypi instance system.adapter.admin.1 started with pid 9284
          raspberrypi 2015-09-28 20:41:36 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:41:36 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:41:28 info host.raspberrypi instance system.adapter.admin.1 started with pid 9283
          raspberrypi 2015-09-28 20:40:58 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:40:58 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:40:52 info host.raspberrypi instance system.adapter.admin.1 started with pid 9282
          raspberrypi 2015-09-28 20:40:22 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:40:22 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:40:15 info host.raspberrypi instance system.adapter.admin.1 started with pid 9281
          raspberrypi 2015-09-28 20:40:14 info host.raspberrypi instance system.adapter.admin.1 started with pid 9281
          raspberrypi 2015-09-28 20:39:45 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:39:45 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:39:44 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:39:44 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:39:36 info host.raspberrypi instance system.adapter.admin.1 started with pid 9280
          raspberrypi 2015-09-28 20:39:06 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:39:06 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:38:58 info host.raspberrypi instance system.adapter.admin.1 started with pid 9279
          raspberrypi 2015-09-28 20:38:28 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:38:28 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:38:21 info host.raspberrypi instance system.adapter.admin.1 started with pid 9278
          raspberrypi 2015-09-28 20:38:20 info host.raspberrypi instance system.adapter.admin.1 started with pid 9278
          raspberrypi 2015-09-28 20:37:50 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:37:50 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:37:38 info host.raspberrypi instance system.adapter.admin.1 started with pid 9277
          raspberrypi 2015-09-28 20:37:08 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:37:08 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:37:02 info host.raspberrypi instance system.adapter.admin.1 started with pid 9276
          raspberrypi 2015-09-28 20:36:32 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:36:32 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:36:27 info host.raspberrypi instance system.adapter.admin.1 started with pid 9275
          raspberrypi 2015-09-28 20:35:58 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:35:58 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:35:57 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:35:57 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:35:50 info host.raspberrypi instance system.adapter.admin.1 started with pid 9274
          raspberrypi 2015-09-28 20:35:20 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:35:20 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:35:09 info host.raspberrypi instance system.adapter.admin.1 started with pid 9273
          raspberrypi 2015-09-28 20:34:39 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:34:39 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:34:33 info host.raspberrypi instance system.adapter.admin.1 started with pid 9272
          raspberrypi 2015-09-28 20:34:03 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:34:03 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:33:57 info host.raspberrypi instance system.adapter.admin.1 started with pid 9271
          raspberrypi 2015-09-28 20:33:27 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:33:27 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:33:15 info host.raspberrypi instance system.adapter.admin.1 started with pid 9270
          raspberrypi 2015-09-28 20:32:45 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:32:45 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:32:32 info host.raspberrypi instance system.adapter.admin.1 started with pid 9269
          raspberrypi 2015-09-28 20:32:02 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:32:02 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:31:55 info host.raspberrypi instance system.adapter.admin.1 started with pid 9268
          raspberrypi 2015-09-28 20:31:25 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:31:25 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:31:16 info host.raspberrypi instance system.adapter.admin.1 started with pid 9267
          raspberrypi 2015-09-28 20:30:46 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:30:46 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:30:32 info host.raspberrypi instance system.adapter.admin.1 started with pid 9266
          raspberrypi 2015-09-28 20:30:02 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:30:02 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:29:58 info host.raspberrypi instance system.adapter.admin.1 started with pid 9265
          raspberrypi 2015-09-28 20:29:28 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:29:28 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:29:14 info host.raspberrypi instance system.adapter.admin.1 started with pid 9264
          raspberrypi 2015-09-28 20:29:13 info host.raspberrypi instance system.adapter.admin.1 started with pid 9264
          raspberrypi 2015-09-28 20:28:43 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:28:43 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:28:36 info host.raspberrypi instance system.adapter.admin.1 started with pid 9263
          raspberrypi 2015-09-28 20:28:06 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:28:06 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:28:01 info host.raspberrypi instance system.adapter.admin.1 started with pid 9262
          raspberrypi 2015-09-28 20:27:31 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:27:31 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:27:27 info host.raspberrypi instance system.adapter.admin.1 started with pid 9261
          raspberrypi 2015-09-28 20:26:57 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:26:57 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:26:52 info host.raspberrypi instance system.adapter.admin.1 started with pid 9260
          raspberrypi 2015-09-28 20:26:22 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:26:22 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:26:09 info host.raspberrypi instance system.adapter.admin.1 started with pid 9259
          raspberrypi 2015-09-28 20:25:39 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:25:39 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          raspberrypi 2015-09-28 20:25:38 info host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
          raspberrypi 2015-09-28 20:25:38 error host.raspberrypi instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:25:26 info instance system.adapter.admin.1 started with pid 9258
          host-raspberrypi 2015-09-28 20:24:56 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:24:56 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:24:49 info instance system.adapter.admin.1 started with pid 9257
          host-raspberrypi 2015-09-28 20:24:19 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:24:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:24:07 info instance system.adapter.admin.1 started with pid 9256
          host-raspberrypi 2015-09-28 20:23:37 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:23:37 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:23:33 info instance system.adapter.admin.1 started with pid 9255
          host-raspberrypi 2015-09-28 20:23:03 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:23:03 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:22:59 info instance system.adapter.admin.1 started with pid 9254
          host-raspberrypi 2015-09-28 20:22:29 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:22:29 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:22:25 info instance system.adapter.admin.1 started with pid 9253
          host-raspberrypi 2015-09-28 20:21:55 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:21:55 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:21:49 info instance system.adapter.admin.1 started with pid 9252
          host-raspberrypi 2015-09-28 20:21:19 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:21:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:21:14 info instance system.adapter.admin.1 started with pid 9251
          host-raspberrypi 2015-09-28 20:20:44 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:20:44 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:20:38 info instance system.adapter.admin.1 started with pid 9250
          host-raspberrypi 2015-09-28 20:20:08 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:20:08 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:20:01 info instance system.adapter.admin.1 started with pid 9249
          host-raspberrypi 2015-09-28 20:19:31 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:19:31 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:19:27 info instance system.adapter.admin.1 started with pid 9248
          host-raspberrypi 2015-09-28 20:18:57 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:18:57 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:18:53 info instance system.adapter.admin.1 started with pid 9247
          host-raspberrypi 2015-09-28 20:18:23 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:18:23 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:18:19 info instance system.adapter.admin.1 started with pid 9246
          host-raspberrypi 2015-09-28 20:17:49 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:17:49 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:17:40 info instance system.adapter.admin.1 started with pid 9245
          host-raspberrypi 2015-09-28 20:17:10 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:17:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:17:06 info instance system.adapter.admin.1 started with pid 9244
          host-raspberrypi 2015-09-28 20:16:36 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:16:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:16:32 info instance system.adapter.admin.1 started with pid 9233
          host-raspberrypi 2015-09-28 20:16:02 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:16:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:15:57 info instance system.adapter.admin.1 started with pid 9232
          host-raspberrypi 2015-09-28 20:15:27 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:15:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:15:22 info instance system.adapter.admin.1 started with pid 9231
          host-raspberrypi 2015-09-28 20:14:52 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:14:52 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:14:48 info instance system.adapter.admin.1 started with pid 9230
          host-raspberrypi 2015-09-28 20:14:18 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:14:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:14:08 info instance system.adapter.admin.1 started with pid 9229
          host-raspberrypi 2015-09-28 20:13:38 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:13:38 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:13:33 info instance system.adapter.admin.1 started with pid 9228
          host-raspberrypi 2015-09-28 20:13:03 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:13:03 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:12:59 info instance system.adapter.admin.1 started with pid 9227
          host-raspberrypi 2015-09-28 20:12:28 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:12:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:12:25 info instance system.adapter.admin.1 started with pid 9226
          host-raspberrypi 2015-09-28 20:11:54 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:11:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:11:50 info instance system.adapter.admin.1 started with pid 9225
          host-raspberrypi 2015-09-28 20:11:20 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:11:20 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:11:10 info instance system.adapter.admin.1 started with pid 9224
          host-raspberrypi 2015-09-28 20:10:40 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:10:40 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:10:36 info instance system.adapter.admin.1 started with pid 9223
          host-raspberrypi 2015-09-28 20:10:06 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:10:06 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:10:01 info instance system.adapter.admin.1 started with pid 9222
          host-raspberrypi 2015-09-28 20:09:31 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:09:31 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:09:26 info instance system.adapter.admin.1 started with pid 9221
          host-raspberrypi 2015-09-28 20:08:56 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:08:56 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:08:51 info instance system.adapter.admin.1 started with pid 9220
          host-raspberrypi 2015-09-28 20:08:21 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:08:21 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:08:09 info instance system.adapter.admin.1 started with pid 9219
          host-raspberrypi 2015-09-28 20:07:39 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:07:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:07:34 info instance system.adapter.admin.1 started with pid 9218
          host-raspberrypi 2015-09-28 20:07:04 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:07:04 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:07:00 info instance system.adapter.admin.1 started with pid 9217
          host-raspberrypi 2015-09-28 20:06:30 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:06:30 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:06:25 info instance system.adapter.admin.1 started with pid 9216
          host-raspberrypi 2015-09-28 20:05:55 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:05:55 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:05:51 info instance system.adapter.admin.1 started with pid 9215
          host-raspberrypi 2015-09-28 20:05:20 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:05:20 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:05:11 info instance system.adapter.admin.1 started with pid 9214
          host-raspberrypi 2015-09-28 20:04:41 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:04:41 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:04:36 info instance system.adapter.admin.1 started with pid 9213
          host-raspberrypi 2015-09-28 20:04:06 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:04:06 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:04:02 info instance system.adapter.admin.1 started with pid 9212
          host-raspberrypi 2015-09-28 20:03:32 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:03:32 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:03:28 info instance system.adapter.admin.1 started with pid 9211
          host-raspberrypi 2015-09-28 20:02:58 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:02:58 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:02:51 info instance system.adapter.admin.1 started with pid 9209
          host-raspberrypi 2015-09-28 20:02:21 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:02:21 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:02:17 info instance system.adapter.admin.1 started with pid 9208
          host-raspberrypi 2015-09-28 20:01:46 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:01:46 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:01:38 info instance system.adapter.admin.1 started with pid 9207
          host-raspberrypi 2015-09-28 20:01:08 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:01:08 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:01:03 info instance system.adapter.admin.1 started with pid 9206
          host-raspberrypi 2015-09-28 20:00:33 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 20:00:33 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 20:00:29 info instance system.adapter.admin.1 started with pid 9205
          host-raspberrypi 2015-09-28 19:59:59 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:59:59 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:59:54 info instance system.adapter.admin.1 started with pid 9204
          host-raspberrypi 2015-09-28 19:59:23 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:59:23 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:59:18 info instance system.adapter.admin.1 started with pid 9203
          host-raspberrypi 2015-09-28 19:58:48 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:58:48 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:58:40 info instance system.adapter.admin.1 started with pid 9202
          host-raspberrypi 2015-09-28 19:58:10 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:58:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:58:05 info instance system.adapter.admin.1 started with pid 9201
          host-raspberrypi 2015-09-28 19:57:35 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:57:35 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:57:31 info instance system.adapter.admin.1 started with pid 9200
          host-raspberrypi 2015-09-28 19:57:01 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:57:01 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:56:57 info instance system.adapter.admin.1 started with pid 9199
          host-raspberrypi 2015-09-28 19:56:27 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:56:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:56:23 info instance system.adapter.admin.1 started with pid 9198
          host-raspberrypi 2015-09-28 19:55:53 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:55:53 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:55:48 info instance system.adapter.admin.1 started with pid 9197
          host-raspberrypi 2015-09-28 19:55:18 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:55:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:55:06 info instance system.adapter.admin.1 started with pid 9196
          host-raspberrypi 2015-09-28 19:54:36 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:54:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:54:32 info instance system.adapter.admin.1 started with pid 9195
          host-raspberrypi 2015-09-28 19:54:02 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:54:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:53:58 info instance system.adapter.admin.1 started with pid 9194
          host-raspberrypi 2015-09-28 19:53:28 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:53:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:53:24 info instance system.adapter.admin.1 started with pid 9193
          host-raspberrypi 2015-09-28 19:52:54 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:52:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:52:48 info instance system.adapter.admin.1 started with pid 9192
          host-raspberrypi 2015-09-28 19:52:18 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:52:18 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:52:09 info instance system.adapter.admin.1 started with pid 9191
          host-raspberrypi 2015-09-28 19:51:39 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:51:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:51:34 info instance system.adapter.admin.1 started with pid 9190
          host-raspberrypi 2015-09-28 19:51:04 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:51:04 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:50:58 info instance system.adapter.admin.1 started with pid 9189
          host-raspberrypi 2015-09-28 19:50:28 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:50:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:50:24 info instance system.adapter.admin.1 started with pid 9188
          host-raspberrypi 2015-09-28 19:49:54 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:49:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:49:49 info instance system.adapter.admin.1 started with pid 9187
          host-raspberrypi 2015-09-28 19:49:19 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:49:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:49:13 info instance system.adapter.admin.1 started with pid 9186
          host-raspberrypi 2015-09-28 19:48:43 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:48:43 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:48:37 info instance system.adapter.admin.1 started with pid 9185
          host-raspberrypi 2015-09-28 19:48:07 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:48:07 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:48:02 info instance system.adapter.admin.1 started with pid 9184
          host-raspberrypi 2015-09-28 19:47:32 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:47:32 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:47:27 info instance system.adapter.admin.1 started with pid 9183
          host-raspberrypi 2015-09-28 19:46:57 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:46:57 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:46:52 info instance system.adapter.admin.1 started with pid 9182
          host-raspberrypi 2015-09-28 19:46:22 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:46:22 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:46:17 info instance system.adapter.admin.1 started with pid 9181
          host-raspberrypi 2015-09-28 19:45:47 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:45:47 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:45:40 info instance system.adapter.admin.1 started with pid 9180
          host-raspberrypi 2015-09-28 19:45:10 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:45:10 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:45:05 info instance system.adapter.admin.1 started with pid 9179
          host-raspberrypi 2015-09-28 19:44:35 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:44:35 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:44:31 info instance system.adapter.admin.1 started with pid 9178
          host-raspberrypi 2015-09-28 19:44:01 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:44:01 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:43:57 info instance system.adapter.admin.1 started with pid 9177
          host-raspberrypi 2015-09-28 19:43:27 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:43:27 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:43:22 info instance system.adapter.admin.1 started with pid 9176
          host-raspberrypi 2015-09-28 19:42:52 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:42:52 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:42:47 info instance system.adapter.admin.1 started with pid 9175
          host-raspberrypi 2015-09-28 19:42:17 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:42:17 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:42:09 info instance system.adapter.admin.1 started with pid 9174
          host-raspberrypi 2015-09-28 19:41:39 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:41:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:41:32 info instance system.adapter.admin.1 started with pid 9173
          host-raspberrypi 2015-09-28 19:41:02 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:41:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:40:58 info instance system.adapter.admin.1 started with pid 9172
          host-raspberrypi 2015-09-28 19:40:28 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:40:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:40:24 info instance system.adapter.admin.1 started with pid 9171
          host-raspberrypi 2015-09-28 19:39:54 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:39:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:39:49 info instance system.adapter.admin.1 started with pid 9170
          host-raspberrypi 2015-09-28 19:39:19 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:39:19 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:39:09 info instance system.adapter.admin.1 started with pid 9169
          host-raspberrypi 2015-09-28 19:38:39 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:38:39 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:38:35 info instance system.adapter.admin.1 started with pid 9168
          host-raspberrypi 2015-09-28 19:38:05 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:38:05 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:38:00 info instance system.adapter.admin.1 started with pid 9167
          host-raspberrypi 2015-09-28 19:37:30 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:37:30 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:37:24 info instance system.adapter.admin.1 started with pid 9166
          host-raspberrypi 2015-09-28 19:36:54 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:36:54 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:36:43 info instance system.adapter.admin.1 started with pid 9165
          host-raspberrypi 2015-09-28 19:36:12 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:36:12 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:36:06 info instance system.adapter.admin.1 started with pid 9164
          host-raspberrypi 2015-09-28 19:35:36 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:35:36 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:35:32 info instance system.adapter.admin.1 started with pid 9163
          host-raspberrypi 2015-09-28 19:35:02 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:35:02 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:34:58 info instance system.adapter.admin.1 started with pid 9162
          host-raspberrypi 2015-09-28 19:34:28 info Restart adapter system.adapter.admin.1 because enabled
          host-raspberrypi 2015-09-28 19:34:28 error instance system.adapter.admin.1 terminated with code 8 (node.js: Cannot find module)
          host-raspberrypi 2015-09-28 19:34:23 info instance system.adapter.admin.1 started with pid 9161
          host-raspberrypi 2015-09-28 19:33:53 info Restart adapter system.adapter.admin.1 because enabled
            mach mal ein reboot
              so, log einträge sind weg. Ich hatte auf einmal eine zweite admin instanz.
              Was auch immer ich gemacht habe, dass die auf einmal da war…
                kommando zurück. jetzt kann ich gar nicht mehr auf iobroker zugreifen:
                Diese Webseite ist nicht verfügbar.
                ERR_CONNECTION_REFUSED
                auch ein reboot hat nichts gebracht 😞
                  jetzt siehts so aus, als hätte ich gar keine admin instanz mehr.
                  Und owohl die VIS instanz ja da ist, kann ich vis auch nicht mehr aufrufen 😞
                  ps -A | grep io
                  17 ? 00:00:00 bioset
                  20 ? 00:00:00 rpciod
                  23 ? 00:00:00 nfsiod
                  35 ? 00:00:00 DWC Notificatio
                  2043 ? 00:00:11 io.js-controlle
                  2325 ? 00:00:09 io.web.0
                  2375 ? 00:00:08 io.hm-rega.0
                  2376 ? 00:00:07 io.hm-rpc.0
                  2378 ? 00:00:06 io.vis.0
                    reboot!
                    und wenn danach immer noch kein admin da ist:
                    cd /opt/iobroker
                    iobroker stop
                    npm install iobroker.admin
                    iobroker start
                      reboot hatte ich schon durch.
                      admin neu isntallieren probiere ich gerade
                        das klappt leider auch nicht mehr:
                        dules/utf-8-validate
                        node-gyp rebuild
                        ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate/build'
                        CXX(target) Release/obj.target/validation/src/validation.o
                        SOLINK_MODULE(target) Release/obj.target/validation.node
                        SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
                        COPY Release/validation.node
                        make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate/build'
                        ! > bufferutil@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
                        node-gyp rebuild
                        ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil/build'
                        CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                        SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                        SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
                        COPY Release/bufferutil.node
                        make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil/build'
                        ! > utf-8-validate@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
                        node-gyp rebuild
                        ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate/build'
                        make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate/build'
                        ! > bufferutil@1.2.1 install /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
                        node-gyp rebuild
                        ! make: Entering directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil/build'
                        make: Leaving directory '/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil/build'
                        npm ERR!
                        npm ERR! Additional logging details can be found in:
                        npm ERR! /opt/iobroker/npm-debug.log
                        npm ERR! not ok code 0
                        und hier die npm-debug.log:
                        root@raspberrypi:/opt/iobroker# tail /opt/iobroker/npm-debug.log
                        6592 error npm-@googlegroups.com6593 error System Linux 3.18.11+
                        6594 error command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin"
                        6595 error cwd /opt/iobroker
                        6596 error node -v v0.10.22
                        6597 error npm -v 1.3.14
                        6598 error path /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie/lib/permuteDomain.js
                        6599 error code ENOENT
                        6600 error errno 34
                        6601 verbose exit [ 34, true ]/npm-@googlegroups.com
                          Da fehlt ihm eine Datei.
                          Versuch es mal mit:
                          cd /opt/iobroker
                          npm cache clean
                          npm install iobroker.admin --production
                          Wenn das nicht klappt, hat mir bei einem solchen Problem mit einem anderen Adapter der Tip von versteckt geholfen, alles im Verzeichnis /tmp zu installieren und dann rüberzukopieren
                          …oder plattmachen
                            scheint erstmal geklappt zu haben. aber merkwürdig ists trotzdem…
                            2497
