    4. Sonoff 4Ch Pro eigenleben
      Alveran last edited by
      ich weiß nicht ob ich hier richtig bin. Aber mein Sonoff 4Ch Pro mit Tasmota Firmware und Anbindung an IObroker hat ein Eigenleben auf Kanal 1.
      Ständig schaltet es von selbst ein und aus.
      Hier ein Auszug aus dem LOG:
      09:04:29 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"OFF"}
      09:04:29 MQT: stat/Sonoff4chpro2/POWER1 = OFF
      09:05:29 MQT: tele/Sonoff4chpro2/STATE = {"Time":"2018-04-23T09:05:29","Uptime":"2T23:55:44","Vcc":3.427,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Zyxel","RSSI":100,"APMac":"08:96:D7:90:D1:8D"}}
      09:10:29 MQT: tele/Sonoff4chpro2/STATE = {"Time":"2018-04-23T09:10:29","Uptime":"3T00:00:44","Vcc":3.427,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Zyxel","RSSI":100,"APMac":"08:96:D7:90:D1:8D"}}
      09:12:27 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"ON"}
      09:12:27 MQT: stat/Sonoff4chpro2/POWER1 = ON
      09:15:29 MQT: tele/Sonoff4chpro2/STATE = {"Time":"2018-04-23T09:15:29","Uptime":"3T00:05:44","Vcc":3.427,"POWER1":"ON","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Zyxel","RSSI":100,"APMac":"08:96:D7:90:D1:8D"}}
      09:20:29 MQT: tele/Sonoff4chpro2/STATE = {"Time":"2018-04-23T09:20:29","Uptime":"3T00:10:44","Vcc":3.427,"POWER1":"ON","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Zyxel","RSSI":100,"APMac":"08:96:D7:90:D1:8D"}}
      09:21:16 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"OFF"}
      09:21:16 MQT: stat/Sonoff4chpro2/POWER1 = OFF
      09:24:48 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"ON"}
      09:24:48 MQT: stat/Sonoff4chpro2/POWER1 = ON
      09:25:29 MQT: tele/Sonoff4chpro2/STATE = {"Time":"2018-04-23T09:25:29","Uptime":"3T00:15:44","Vcc":3.427,"POWER1":"ON","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Zyxel","RSSI":100,"APMac":"08:96:D7:90:D1:8D"}}
      09:30:29 MQT: tele/Sonoff4chpro2/STATE = {"Time":"2018-04-23T09:30:29","Uptime":"3T00:20:44","Vcc":3.427,"POWER1":"ON","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Zyxel","RSSI":100,"APMac":"08:96:D7:90:D1:8D"}}
      09:30:59 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"OFF"}
      09:30:59 MQT: stat/Sonoff4chpro2/POWER1 = OFF
      09:35:24 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"ON"}
      09:35:24 MQT: stat/Sonoff4chpro2/POWER1 = ON
      09:35:29 MQT: tele/Sonoff4chpro2/STATE = {"Time":"2018-04-23T09:35:29","Uptime":"3T00:25:44","Vcc":3.427,"POWER1":"ON","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Zyxel","RSSI":100,"APMac":"08:96:D7:90:D1:8D"}}
      09:40:29 MQT: tele/Sonoff4chpro2/STATE = {"Time":"2018-04-23T09:40:29","Uptime":"3T00:30:44","Vcc":3.427,"POWER1":"ON","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Zyxel","RSSI":100,"APMac":"08:96:D7:90:D1:8D"}}
      09:41:35 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"OFF"}
      09:41:35 MQT: stat/Sonoff4chpro2/POWER1 = OFF
      09:44:14 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"ON"}
      09:44:14 MQT: stat/Sonoff4chpro2/POWER1 = ON
      09:45:29 MQT: tele/Sonoff4chpro2/STATE = {"Time":"2018-04-23T09:45:29","Uptime":"3T00:35:44","Vcc":3.427,"POWER1":"ON","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","Wifi":{"AP":1,"SSId":"Zyxel","RSSI":100,"APMac":"08:96:D7:90:D1:8D"}}
      09:46:00 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"OFF"}
      09:46:00 MQT: stat/Sonoff4chpro2/POWER1 = OFF
      09:47:35 LOG: SerialLog 2, WebLog 3, SysLog 0, LogHost domus1, LogPort 514, TelePeriod 300
      09:47:35 HTP: Configuration
      09:47:35 CFG: Saved to flash at F6, Count 793, Bytes 1712
      09:47:37 HTP: Main Menu
      09:47:39 HTP: Console
      09:47:46 APP: Button1 level 1-0
      09:47:46 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"ON"}
      09:47:46 MQT: stat/Sonoff4chpro2/POWER1 = ON
      09:47:46 APP: Button1 level 0-1
      09:47:47 CFG: Saved to flash at F5, Count 794, Bytes 1712
      09:48:34 HTP: Main Menu
      09:48:37 HTP: Information
      09:48:39 APP: Button1 level 1-0
      09:48:39 MQT: stat/Sonoff4chpro2/RESULT = {"POWER1":"OFF"}
      09:48:39 MQT: stat/Sonoff4chpro2/POWER1 = OFF
      09:48:39 APP: Button1 level 0-1
      09:48:40 CFG: Saved to flash at F4, Count 795, Bytes 1712
      09:48:41 HTP: Main Menu
      09:49:02 HTP: Information
      09:49:05 HTP: Main Menu
      09:49:06 HTP: Console
        Lajungcl last edited by
        Hi zusammen,
        Ich habe genau das gleiche Thema… sporadisch geht der Schalter an und wieder aus...
        Hab schon alles durch und bin ratlos...ich tippe fast darauf, das der iobroker mit dem mqtt Server irgendwie den Status anfragt und dann den Schalter togglen lässt.
        Ich sehe das es über mqt angesprochen wird..es ist nicht selbst der sonof Touch...
        Wie hast du das Thema gelöst? danke & grüße Lars
          Ich habe herausgefunden, das er der Sonoff selber ist.
          Hab die Software nochmal geflashed und nun ist das ding tot…
          Daher ist das Thema hier für mich nun erledigt 😉
          Danke & schönen Abend
            ple last edited by
            Kurz gefragt, ist das Dingen überhaupt zu gebrauchen?
            Wollte ein Torantrieb damit realisieren für 2 Tore. Antriebe sind 24V.
            das schöne an dem Dingen, die Ausgänge sind per Jumper direkt verriegelt. Wüsste sonst nicht wie ich auf die schnelle das realisieren könnte, außer mit Homematic Jalousieaktoren. Aber die gehen wieder ins Geld.
              paul.honka last edited by
              Habe das gleiche Problem, bei mir ist es der Kanal Power2 vom CH4 Pro.
              Er wird laufend durch MQTT geschaltet. Änder ich den Port von MQTT ist
              Ruhe. Liegt meiner Meinung an MQTT oder oder an Tasmota. Habe 6.21 drauf.
              Versuch mal morgen ne 5er Version zu flashen.
              Beste Grüsse paul
                Habe mal auf Tasmota 6.30 upgedatet. Der Fehler, bei mir das selbstständige Toggle,
                ist immer noch. Bei MGT auf unterschiedliche IPs, der CH4 toggelt es weiter.
                Anbei die Logs vom CH4 Pro
                07:08:57 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.59:1883, rc -2\. Wiederversuch in 10 s
                07:09:00 RSL: stat/Sonoff_1Ch4Pro/RESULT = {"POWER2":"ON"}
                07:09:00 RSL: stat/Sonoff_1Ch4Pro/POWER2 = ON
                Ein Tasmotafehler oder Firmware?
                Beste Grüsse paul
                  schalte mal probeweise MQTT ab am Gerät.. ich wette das es dann nicht mehr vorkommt..
                    Ich habe zwar MQTT nicht ausgeschaltet, aber im Sonoff CH4 eine
                    falsche IP für MQTT eingetragen. Iobroker läuft unter der .58.
                    Dürften nicht kommunizieren. Was heißt RSL als Quelle?
                    Beste Grüsse paul
                    81.1k
