    4. Fehler history
    Fehler history
    • sissiwup
      sissiwup last edited by
      Merkwürdiger Fehler im history Adapter:
      2015-09-29 04:14:27.545  - error: uncaught exception: Cannot read property 'ts' of null
      2015-09-29 04:14:27.563  - error: TypeError: Cannot read property 'ts' of null
          at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.history/history.js:105:33)
          at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
          at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
          at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
          at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
          at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
          at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
          at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
      2015-09-29 04:14:27.893  - error: host.raspberrypi instance system.adapter.history.0 terminated with code 6 (uncaught exception)
      2015-09-29 04:14:27.894  - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
      2015-09-29 04:14:57.941  - info: host.raspberrypi instance system.adapter.history.0 started with pid 16949
      2015-09-29 04:15:00.196  - info: history.0 starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.history</anonymous></anonymous></anonymous>
        @sissiwup:
        Vielleicht wurde irgendeinen Datenpunkt gelöscht. Werde Prüfung einbauen.
        1.1k
