    4. Kein Start mehr nach reboot vom PI
    • sissiwup
      sissiwup last edited by
      mein iobroker wollte nach einem Neustart des PI nicht mehr hochfahren:
      2015-09-29 18:28:36.992  - info: host.raspberrypi ioBroker.js-controller version 0.7.11 js-controller starting
      2015-09-29 18:28:37.008  - info: host.raspberrypi Copyright (c) 2014-2015 bluefox, hobbyquaker
      2015-09-29 18:28:37.010  - info: host.raspberrypi hostname: raspberrypi
      2015-09-29 18:28:37.011  - info: host.raspberrypi ip addresses: 192.168.1.12 192.168.1.185
      2015-09-29 18:28:45.019  - info: inMem-states listening on port 9000
      2015-09-29 18:28:45.615  - info: inMem-objects listening on port 9001
      2015-09-29 18:28:45.630  - info: host.raspberrypi InMemoryDB connected
      2015-09-29 18:28:45.671  - info: host.raspberrypi 26 instances found
      2015-09-29 18:28:45.675  - warn: host.raspberrypi does not start any instances on this host
      2015-09-29 18:30:27.520  - info: host.raspberrypi received SIGTERM
      2015-09-29 18:30:27.619  - info: host.raspberrypi terminated
      2015-09-29 18:30:28.523  - info: host.raspberrypi received SIGTERM
      2015-09-29 18:30:28.610  - info: host.raspberrypi terminated
      2015-09-29 18:30:36.981  - info: host.raspberrypi ioBroker.js-controller version 0.7.11 js-controller starting
      2015-09-29 18:30:36.993  - info: host.raspberrypi Copyright (c) 2014-2015 bluefox, hobbyquaker
      2015-09-29 18:30:36.994  - info: host.raspberrypi hostname: raspberrypi
      2015-09-29 18:30:36.994  - info: host.raspberrypi ip addresses: 192.168.1.12 192.168.1.185
      2015-09-29 18:30:45.044  - info: inMem-states listening on port 9000
      2015-09-29 18:30:45.654  - info: inMem-objects listening on port 9001
      2015-09-29 18:30:45.668  - info: host.raspberrypi InMemoryDB connected
      2015-09-29 18:30:45.709  - info: host.raspberrypi 26 instances found
      2015-09-29 18:30:45.713  - warn: host.raspberrypi does not start any instances on this host
      2015-09-29 18:32:41.736  - info: host.raspberrypi received SIGTERM
      2015-09-29 18:32:41.742  - info: host.raspberrypi stopInstance system.adapter.admin.0
      2015-09-29 18:32:41.743  - warn: host.raspberrypi stopInstance system.adapter.admin.0 not running
      2015-09-29 18:32:41.743  - info: host.raspberrypi stopInstance system.adapter.web.0
      2015-09-29 18:32:41.744  - warn: host.raspberrypi stopInstance system.adapter.web.0 not running
      2015-09-29 18:32:41.744  - info: host.raspberrypi stopInstance system.adapter.vis.0
      2015-09-29 18:32:41.744  - info: host.raspberrypi stopInstance system.adapter.vis-metro.0
      2015-09-29 18:32:41.744  - info: host.raspberrypi stopInstance system.adapter.vis-lcars.0
      2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0
      2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.vis-bars.0
      2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.vis-plumb.0
      2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.0
      2015-09-29 18:32:41.745  - warn: host.raspberrypi stopInstance system.adapter.hm-rpc.0 not running
      2015-09-29 18:32:41.745  - info: host.raspberrypi stopInstance system.adapter.hm-rega.0
      2015-09-29 18:32:41.746  - warn: host.raspberrypi stopInstance system.adapter.hm-rega.0 not running
      2015-09-29 18:32:41.746  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1
      2015-09-29 18:32:41.746  - warn: host.raspberrypi stopInstance system.adapter.hm-rpc.1 not running
      2015-09-29 18:32:41.746  - info: host.raspberrypi stopInstance system.adapter.vis-colorpicker.0
      2015-09-29 18:32:41.746  - info: host.raspberrypi stopInstance system.adapter.fritzbox.0
      2015-09-29 18:32:41.747  - warn: host.raspberrypi stopInstance system.adapter.fritzbox.0 not running
      2015-09-29 18:32:41.747  - info: host.raspberrypi stopInstance system.adapter.javascript.0
      2015-09-29 18:32:41.747  - warn: host.raspberrypi stopInstance system.adapter.javascript.0 not running
      2015-09-29 18:32:41.747  - info: host.raspberrypi stopInstance system.adapter.yr.0
      2015-09-29 18:32:41.747  - warn: host.raspberrypi stopInstance system.adapter.yr.0 not scheduled
      2015-09-29 18:32:41.747  - info: host.raspberrypi stopInstance system.adapter.node-red.0
      2015-09-29 18:32:41.749  - warn: host.raspberrypi stopInstance system.adapter.node-red.0 not running
      2015-09-29 18:32:41.750  - info: host.raspberrypi stopInstance system.adapter.history.0
      2015-09-29 18:32:41.750  - warn: host.raspberrypi stopInstance system.adapter.history.0 not running
      2015-09-29 18:32:41.750  - info: host.raspberrypi stopInstance system.adapter.ping.0
      2015-09-29 18:32:41.750  - warn: host.raspberrypi stopInstance system.adapter.ping.0 not running
      2015-09-29 18:32:41.842  - info: host.raspberrypi terminated
      2015-09-29 18:32:42.740  - info: host.raspberrypi received SIGTERM
      2015-09-29 18:32:56.633  - info: host.raspberrypi ioBroker.js-controller version 0.7.11 js-controller starting
      2015-09-29 18:32:56.644  - info: host.raspberrypi Copyright (c) 2014-2015 bluefox, hobbyquaker
      2015-09-29 18:32:56.646  - info: host.raspberrypi hostname: raspberrypi
      2015-09-29 18:32:56.646  - info: host.raspberrypi ip addresses: 192.168.1.12
      2015-09-29 18:33:18.610  - info: inMem-states listening on port 9000
      2015-09-29 18:33:19.317  - info: inMem-objects listening on port 9001
      2015-09-29 18:33:19.330  - info: host.raspberrypi InMemoryDB connected
      2015-09-29 18:33:19.372  - info: host.raspberrypi 26 instances found
      2015-09-29 18:33:19.376  - warn: host.raspberrypi does not start any instances on this host
      2015-09-29 18:37:46.599  - info: host.raspberrypi received SIGTERM
      Kann man am Log sehen, wo es hakt?
      Ich habe das Backup des Data-Ordners von heute Nacht eingespielt, danach lief alles wieder.
        @sissiwup:
        Ich habe das Backup des Data-Ordners von heute Nacht eingespielt, danach lief alles wieder. `
        Name von raspberry host wurde geändert.
        • sissiwup
          nachdem ich das Backup (von iobroker) von der Nacht wieder eingespielt hatte, lief alles wieder.
          Wo kann ich denn den Hostnamen ändern?
            über die Konsole mit raspi-config
            • sissiwup
              Danke. Da habe ich aber nichts gemacht. Hostname ist geblieben wie vorher.
                ` > 2015-09-29 18:28:45.671 - info: host.raspberrypi 26 instances found
                2015-09-29 18:28:45.675 - warn: host.raspberrypi does not start any instances on this host `
                Sagt, dass Adapter Instanzen existieren, aber nicht für diesen Host.
                Nächstes Mal
                iobroker o get "system.adapter.admin.0" --pretty
                Aufrufen und schauen "common.host" Wert.
