    4. Fehler bei Installation vis-jqui-mfd
      tesso last edited by
      Beim Versuch den Adapter vis-jqui-mfd zu installieren erscheint folgender Fehler:
      root@pi01:/opt/iobroker# iobroker add vis-jqui-mfd
      npm install iobroker.vis-jqui-mfd --production --prefix "/opt/iobroker" (System call)
      npm http GET https://registry.npmjs.org/iobroker.vis-jqui-mfd
      npm http 404 https://registry.npmjs.org/iobroker.vis-jqui-mfd
      npm ERR! TypeError: Cannot read property 'latest' of undefined
      npm ERR!     at next (/usr/local/lib/node_modules/npm/lib/cache.js:687:35)
      npm ERR!     at /usr/local/lib/node_modules/npm/lib/cache.js:675:5
      npm ERR!     at saved (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/get.js:142:7)
      npm ERR!     at /usr/local/lib/node_modules/npm/node_modules/graceful-fs/polyfills.js:133:7
      npm ERR!     at Object.oncomplete (fs.js:107:15)
      npm ERR! If you need help, you may report this log at:
      npm ERR!     <http: github.com/isaacs/npm/issues="">npm ERR! or email it to:
      npm ERR!     <npm-@googlegroups.com>npm ERR! System Linux 3.18.11-v7+
      npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.vis-jqui-mfd" "--production" "--prefix" "/opt/iobroker"
      npm ERR! cwd /opt/iobroker
      npm ERR! node -v v0.10.22
      npm ERR! npm -v 1.3.14
      npm ERR! type non_object_property_load
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /opt/iobroker/npm-debug.log
      npm ERR! not ok code 0
      host.pi01 Cannot install iobroker.vis-jqui-mfd: 1</npm-@googlegroups.com></http:>
        @tesso:
        npm http 404 https://registry.npmjs.org/iobroker.vis-jqui-mfd `
        oder:
        npm ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/iobroker.vis-jqui-mfd
        npm ERR! 404
        npm ERR! 404 'iobroker.vis-jqui-mfd' is not in the npm registry.
        npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
        npm ERR! 404
        npm ERR! 404 Note that you can also install from a
        npm ERR! 404 tarball, folder, http url, or git url.
        also:
        @tesso:
        OK, danke also einfach ignorieren. `
          Also auch in Arbeit. dann werde ich auch das ignorieren.
          Ich dachte nur, weil eine Versionsnummer dabei steht müsste sich das installieren lassen.
