Nach Update js-controller auf 1.4 startet socket io nicht
Hallo habe den Js-controller auf 1.4.0 upgadatet seitdem kommt bei socket i.o 1.8.6 folgende Fehlermeldungen
host.linaro-alip 2018-04-04 16:05:47.576 info Restart adapter system.adapter.socketio.0 because enabled host.linaro-alip 2018-04-04 16:05:47.576 error instance system.adapter.socketio.0 terminated with code 0 (OK) host.linaro-alip 2018-04-04 16:05:47.576 error Caught by controller[3]: at process._tickCallback (internal/process/next_tick.js:104:9) host.linaro-alip 2018-04-04 16:05:47.576 error Caught by controller[3]: at _combinedTickCallback (internal/process/next_tick.js:77:11) host.linaro-alip 2018-04-04 16:05:47.576 error Caught by controller[3]: at emitCloseNT (net.js:1574:8) host.linaro-alip 2018-04-04 16:05:47.576 error Caught by controller[3]: at Server.emit (events.js:185:7) host.linaro-alip 2018-04-04 16:05:47.576 error Caught by controller[3]: at emitNone (events.js:86:13) host.linaro-alip 2018-04-04 16:05:47.576 error Caught by controller[3]: at Server.g (events.js:292:16) host.linaro-alip 2018-04-04 16:05:47.575 error Caught by controller[3]: at Server. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:254:25) host.linaro-alip 2018-04-04 16:05:47.575 error Caught by controller[3]: at /opt/iobroker/node_modules/iobroker.socketio/main.js:87:32 host.linaro-alip 2018-04-04 16:05:47.575 error Caught by controller[3]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:58:26) host.linaro-alip 2018-04-04 16:05:47.575 error Caught by controller[3]: at Object.LE.create (/opt/iobroker/node_modules/greenlock/index.js:291:35) host.linaro-alip 2018-04-04 16:05:47.575 error Caught by controller[3]: at Object.module.exports.create (/opt/iobroker/node_modules/greenlock/lib/middleware.js:20:3) host.linaro-alip 2018-04-04 16:05:47.575 error Caught by controller[3]: at leLog (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:9:9) host.linaro-alip 2018-04-04 16:05:47.575 error Caught by controller[3]: 2018-04-04 16:05:47.525 - socketio.0 ReferenceError: log is not defined host.linaro-alip 2018-04-04 16:05:47.575 error Caught by controller[2]: 2018-04-04 16:05:47.524 - socketio.0 uncaught exception: log is not defined host.linaro-alip 2018-04-04 16:05:47.574 error Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:104:9) host.linaro-alip 2018-04-04 16:05:47.574 error Caught by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:77:11) host.linaro-alip 2018-04-04 16:05:47.574 error Caught by controller[1]: at emitCloseNT (net.js:1574:8) host.linaro-alip 2018-04-04 16:05:47.574 error Caught by controller[1]: at Server.emit (events.js:185:7) host.linaro-alip 2018-04-04 16:05:47.574 error Caught by controller[1]: at emitNone (events.js:86:13) host.linaro-alip 2018-04-04 16:05:47.574 error Caught by controller[1]: at Server.g (events.js:292:16) host.linaro-alip 2018-04-04 16:05:47.574 error Caught by controller[1]: at Server. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:254:25) host.linaro-alip 2018-04-04 16:05:47.574 error Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.socketio/main.js:87:32 host.linaro-alip 2018-04-04 16:05:47.573 error Caught by controller[1]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:58:26) host.linaro-alip 2018-04-04 16:05:47.573 error Caught by controller[1]: at Object.LE.create (/opt/iobroker/node_modules/greenlock/index.js:291:35) host.linaro-alip 2018-04-04 16:05:47.573 error Caught by controller[1]: at Object.module.exports.create (/opt/iobroker/node_modules/greenlock/lib/middleware.js:20:3) host.linaro-alip 2018-04-04 16:05:47.573 error Caught by controller[1]: at leLog (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:9:9) host.linaro-alip 2018-04-04 16:05:47.573 error Caught by controller[1]: ReferenceError: log is not defined host.linaro-alip 2018-04-04 16:05:47.573 error Caught by controller[0]: le.challenges[tls-sni-01].loopback should be defined as function (opts, domain, token, cb) { ... } and should prove (by external means) that the ACME server challenge 'tls-sni socketio.0 2018-04-04 16:05:47.535 info terminating https server on port 8084 socketio.0 2018-04-04 16:05:47.534 error ReferenceError: log is not defined at leLog (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:9:9) at Object.module.exports.create (/opt/iobroker/node_modules/greenlock/lib socketio.0 2018-04-04 16:05:47.533 error uncaught exception: log is not defined socketio.0 2018-04-04 16:05:45.970 info starting. Version 1.8.6 in /opt/iobroker/node_modules/iobroker.socketio, node: v6.13.1 host.linaro-alip 2018-04-04 16:05:44.345 info instance system.adapter.socketio.0 started with pid 20082gruß Stephan
Hast du einen reboot gemacht?
mich irritiert die hohe PID von 20082.
Bei mir läuft nach dem Update alles ohne Probleme.
Mach mal, wie Rainer schon schrieb, einen kompletten Reboot des Hosts.
Gruß,
Eric
Von unterwegs getippert
Hallo Habe ein Reboot durchgeführt
Fehler bleibt gleich
PID ist jetzt 3588
wenn ich letsencript abschalte starte der Adapter ohne Fehler
Gruß Stephan
wenn ich letsencript abschalte starte der Adapter ohne Fehler `
ok, den nutze ich nicht.Gruß,
Eric
Schalte debug level aus. In der nächsten Version von js-controller wird gefixt.
Halo,
Ich hab ein ähnliches Problem nach dem Update auf JS Controller 1.4
Bei mir startet die Webserver Instanz, die Letsencrypt nutzt, nicht.
Die ohne (HTTP) läuft ohne Probleme.
Ich habe die Version 2.1.9 des Web Adapters installiert.
Der Log Level für die Webserver instance stand auf "Warn"
Hab den Log Level jetzt auf "error" gesetzt, aber der Adapter stürzt immer noch ab.
Grüße, FW
hier der Log
host.wg6-wetter 2018-04-04 18:56:27.841 info object change system.adapter.web.1 host.wg6-wetter 2018-04-04 18:56:22.398 info Restart adapter system.adapter.web.1 because enabled host.wg6-wetter 2018-04-04 18:56:22.397 error instance system.adapter.web.1 terminated with code 0 (OK) Caught 2018-04-04 18:56:22.396 error by controller[1]: at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16) Caught 2018-04-04 18:56:22.396 error by controller[1]: at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:246:12) Caught 2018-04-04 18:56:22.396 error by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:134:20) Caught 2018-04-04 18:56:22.396 error by controller[1]: at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15) Caught 2018-04-04 18:56:22.396 error by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8) Caught 2018-04-04 18:56:22.395 error by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) Caught 2018-04-04 18:56:22.395 error by controller[1]: at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15) Caught 2018-04-04 18:56:22.395 error by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) Caught 2018-04-04 18:56:22.395 error by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9) Caught 2018-04-04 18:56:22.395 error by controller[1]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:705:21) Caught 2018-04-04 18:56:22.394 error by controller[1]: at /opt/iobroker/node_modules/iobroker.web/main.js:168:29 Caught 2018-04-04 18:56:22.394 error by controller[1]: at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:700:28) Caught 2018-04-04 18:56:22.394 error by controller[1]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:58:26) Caught 2018-04-04 18:56:22.394 error by controller[1]: at Object.LE.create (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/index.js:291:35) Caught 2018-04-04 18:56:22.394 error by controller[1]: at Object.module.exports.create (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/lib/middleware.js:20:3) Caught 2018-04-04 18:56:22.393 error by controller[1]: at leLog (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:9:9) Caught 2018-04-04 18:56:22.392 error by controller[1]: ReferenceError: log is not defined Caught 2018-04-04 18:56:22.391 error by controller[0]: le.challenges[tls-sni-01].loopback should be defined as function (opts, domain, token, cb) { ... } and should prove (by external means) that the ACME server challenge 'tls-sni-01' w web.1 2018-04-04 18:56:22.320 error uncaught exception: log is not definedgeändert: code in code-Tags; Homoran(Mod)
gleiches Problem hab ich auch.
Lösung ist ein Downgrade auf Version 1.3:
cd /opt/iobroker sudo iobroker stop npm cache clean npm install iobroker.js-controller@1.3.0 sudo iobroker start sudo reboot -
Danke für die Anleitung.
Hat bei mir auch funktioniert.
HTTPS Webserver läuft wieder.
Grüße, FW
Mit 1.4.2 sollte es gefixt sein.
Jap mit 1.4.2 geht https wieder grad getestet.
Super Arbeit
