    4. Update Mi Home Vacuum auf 1.1.0 schlägt fehl/Fehlermeldungen
      Kueppert last edited by
      Hallo in die Gemeinde,
      habe eben vom 0.6.0 auf 1.1.0 ein Update gefahren und folgende Fehlermeldung erhalten:
      ! Fertig mit Fehler: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431 target[attr] = additional[attr]; ^ TypeError: Cannot create property 'en' on string 'This adapter allows control Xiaomi vacuum cleaner' at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431:34) at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:434:21) at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:487:64) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8) at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:134:20)
      und hier was im grauen Kasten im Admin steht, nicht darüber:
      ! $ ./iobroker upgrade mihome-vacuum
      ! Update mihome-vacuum from @0.6.0 to @1.1.0
      ! NPM version: 5.7.1
      ! npm install iobroker.mihome-vacuum@1.1.0 –production --save --prefix "/opt/iobroker" (System call)
      ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.mihome-vacuum"
      ! npm
      ! notice created a lockfile as package-lock.json. You should commit this file.
      ! got /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin
      ! upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
      ! ERROR: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431 target[attr] = additional[attr];
      ! TypeError: Cannot create property 'en' on string 'This adapter allows control Xiaomi vacuum cleaner'
      ! at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431:34)
      ! at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:434:21)
      ! at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:487:64)
      ! at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      ! at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      ! at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
      ! at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      ! at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
      ! at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:134:20)
      ! ERROR: process exited with code 1</anonymous></anonymous></anonymous>
      Ist das jetzt schlimm oder in Ordnung/gewollt so?? 🙂
      JS-Controller: v.1.4.0
      Danke und Grüße, Thorsten
        Node.JS 4 oder 6?
          Node.js 6.13.1
          • Espace0401
            Espace0401 last edited by
            Bei mir das gleiche!!!! Habe es aber erstmal nur auf meinem Reserve System ausprobiert. Nach dem aktualisieren wird dann aber die Version 1.1.0 angezeigt.
            • dslraser
              dslraser Forum Testing Most Active last edited by
              normales Update schlägt bei mir auch fehl.
              Über URL (GitHub) lief das Update sauber durch.
              das stand im Log
              ! iobroker 2018-04-11 21:00:04.193 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:134:20)
              ! iobroker 2018-04-11 21:00:04.193 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
              ! iobroker 2018-04-11 21:00:04.193 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
              ! iobroker 2018-04-11 21:00:04.193 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              ! iobroker 2018-04-11 21:00:04.193 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
              ! iobroker 2018-04-11 21:00:04.193 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
              ! iobroker 2018-04-11 21:00:04.193 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
              ! iobroker 2018-04-11 21:00:04.193 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:487:64)
              ! iobroker 2018-04-11 21:00:04.193 error at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:434:21)
              ! iobroker 2018-04-11 21:00:04.193 error at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431:34)
              ! iobroker 2018-04-11 21:00:04.193 error TypeError: Cannot create property 'en' on string 'This adapter allows control Xiaomi vacuum cleaner'
              ! iobroker 2018-04-11 21:00:04.193 error ^
              ! iobroker 2018-04-11 21:00:04.193 error /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431 target[attr] = additional[attr];
              • apollon77
                apollon77 last edited by
                Legt bitte mal ein GitHub Issue beim Adapter dafür an, Danke
                  @apollon77:
                  Legt bitte mal ein GitHub Issue beim Adapter dafür an, Danke ` Erledigt
                  Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
                  • Espace0401
                    Mit js-controller Version 1.4.2 gab es beim Update keine Fehlermeldung mehr.
                    Gruss Joachim
                    1.1k
                    81.0k
