    4. System.adapter.admin.0 terminated due to SIGKILL
    • sissiwup
      sissiwup last edited by
      ist es normal dass, der admin Adapter alle paar Minuten neu gestartet wird?
      2015-10-04 20:55:28.413  - info: history.0 moving 480 entries to couchdb
      2015-10-04 20:55:29.730  - info: history.0 moved 480 history datapoints from Redis history.system.adapter.node-red.0.uptime to CouchDB history.system.adapter.node-red.0.uptime.20151004
      2015-10-04 21:00:00.151  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 6788
      2015-10-04 21:00:04.097  - info: yr.0 starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.yr
      2015-10-04 21:00:05.667  - info: yr.0 got weather data from yr.no
      2015-10-04 21:00:11.907  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 0 (OK)
      2015-10-04 22:00:00.160  - info: host.raspberrypi instance system.adapter.yr.0 started with pid 8413
      2015-10-04 22:00:03.296  - info: yr.0 starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.yr
      2015-10-04 22:00:05.196  - info: yr.0 got weather data from yr.no
      2015-10-04 22:00:11.860  - info: host.raspberrypi instance system.adapter.yr.0 terminated with code 0 (OK)
      2015-10-04 22:18:19.533  - info: history.0 moving 480 entries to couchdb
      2015-10-04 22:18:20.920  - info: history.0 moved 480 history datapoints from Redis history.system.adapter.hm-rega.0.memHeapUsed to CouchDB history.system.adapter.hm-rega.0.memHeapUsed.20151004
      2015-10-04 22:20:20.990  - info: history.0 moving 480 entries to couchdb
      2015-10-04 22:20:22.754  - info: history.0 moved 480 history datapoints from Redis history.system.adapter.ping.0.memHeapUsed to CouchDB history.system.adapter.ping.0.memHeapUsed.20151004
      2015-10-04 22:27:11.278  - info: history.0 moving 480 entries to couchdb
      2015-10-04 22:27:14.705  - info: history.0 moved 480 history datapoints from Redis history.system.adapter.ping.0.uptime to CouchDB history.system.adapter.ping.0.uptime.20151004
      2015-10-04 22:29:23.238  - warn: host.raspberrypi instance system.adapter.admin.0 terminated due to SIGKILL
      2015-10-04 22:29:23.247  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2015-10-04 22:29:53.309  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 9267
      2015-10-04 22:30:00.297  - info: admin.0 starting. Version 0.5.13 in /opt/iobroker/node_modules/iobroker.admin
      2015-10-04 22:30:00.416  - info: admin.0 requesting all states
      2015-10-04 22:30:00.421  - info: admin.0 requesting all objects
      2015-10-04 22:30:00.428  - info: admin.0 http server listening on port 8081
      2015-10-04 22:30:00.429  - info: admin.0 Use link "http://localhost:8081" to configure.
      2015-10-04 22:30:05.536  - info: history.0 moving 480 entries to couchdb
      2015-10-04 22:30:05.608  - info: admin.0 received all states
      2015-10-04 22:30:07.522  - info: admin.0 received all objects
      2015-10-04 22:30:07.572  - info: history.0 moved 480 history datapoints from Redis history.system.adapter.hm-rega.0.uptime to CouchDB history.system.adapter.hm-rega.0.uptime.20151004
      2015-10-04 22:31:01.434  - info: history.0 moving 480 entries to couchdb
      2015-10-04 22:31:05.442  - info: history.0 moved 480 history datapoints from Redis history.hm-rpc.1.CUX9104003.1.IMAGE to CouchDB history.hm-rpc.1.CUX9104003.1.IMAGE.20151004
      2015-10-04 22:40:16.297  - warn: host.raspberrypi instance system.adapter.admin.0 terminated due to SIGKILL
      2015-10-04 22:40:16.308  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
      2015-10-04 22:40:46.366  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 9572
      2015-10-04 22:40:53.023  - info: admin.0 starting. Version 0.5.13 in /opt/iobroker/node_modules/iobroker.admin
      2015-10-04 22:40:53.224  - info: admin.0 requesting all states
      2015-10-04 22:40:53.230  - info: admin.0 requesting all objects
      2015-10-04 22:40:53.235  - info: admin.0 http server listening on port 8081
      2015-10-04 22:40:53.236  - info: admin.0 Use link "http://localhost:8081" to configure.
      2015-10-04 22:40:58.010  - info: admin.0 received all states
      2015-10-04 22:40:59.699  - info: admin.0 received all objects
      Anschließend vrabschiedt sich scheinbar der io.js-controller und nichts geht mehr.
      Um 22:40 ist der letzte Eintrag. Danach ist erst nach dem Neustart etwas zu sehen.
      Wo kann ich noch schauen, als im log, was passiert ist?
